K230 DPU API Reference#
The DPU is mainly responsible for the depth calculation of 3D structured light, providing depth information for 3D facial recognition.
Function Description#
Binding Mode Call Process#
Diagram
Non-Binding Mode Call Process#
Diagram
API Reference#
DPU Usage#
This module provides the following APIs:
kd_mpi_dpu_init#
Description:
Initialize the DPU device.
Syntax:
Parameters:
Parameter Name
Input/Output
init
Pointer to the structure for initializing the DPU device.
Input
Return Value:
Success
Non-zero
Failure, see error code
Chip Differences:
None.
Requirements:
  • Header file: mpi_dpu_api.h
  • Library file: libdpu.a
Notes:
Related Topics:
k_dpu_init_t
kd_mpi_dpu_delete#
Description:
Delete the initialized DPU device.
Syntax:
k_s32 kd_mpi_dpu_delete();
Parameters:
Parameter Name
Input/Output
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
This function should be called after the DPU device has been initialized.
Related Topics:
kd_mpi_dpu_parse_file#
Description:
Parse DPU configuration parameters from the DPU configuration file.
Syntax:
Parameters:
Parameter Name
Input/Output
param_path
Path to the configuration file
Input
param
Pointer to the structure for DPU device parameters, the parsed device parameters are stored here
Output
lcn_param
Pointer to the structure for LCN channel parameters, the parsed channel parameters are stored here
Output
ir_param
Pointer to the structure for IR channel parameters, the parsed channel parameters are stored here
Output
g_temp_space
Pointer to the template image structure, the parsed template image’s starting address is stored here
Output
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • DPU device parameters include long-cycle and short-cycle parameters.
  • lcn_param and ir_param are subsets of DPU device parameters. If the DPU device parameters are already configured, these two channel parameters can be ignored. If you need to change the parameters in these two channel parameter structures, you can either change the channel parameters and then call kd_mpi_dpu_set_chn_attr to make the changes effective, or change the device parameters and then call kd_mpi_dpu_set_dev_attr to make the changes effective. If only the channel parameters are changed, calling kd_mpi_dpu_set_chn_attr is more efficient.
  • The template image structure contains the virtual and physical addresses of the parsed template image, as well as the size of the template image.
Related Topics:
k_dpu_dev_param_t
kd_mpi_dpu_set_dev_attr#
Description:
Configure DPU device attributes.
Syntax:
Parameters:
Parameter Name
Input/Output
attr
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • This function should be called after the DPU device has been initialized to configure DPU device attributes.
  • When configuring DPU device attributes for the first time, attr’s tytz_temp_recfg and align_depth_recfg should be set to K_TRUE to load the corresponding parameters into the DPU. For subsequent changes to DPU device attributes, if the long-cycle parameters have not changed, setting these two members to K_FALSE can save the time for the DPU to reload the long-cycle parameters.
Related Topics:
k_dpu_dev_attr_t
kd_mpi_dpu_get_dev_attr#
Description:
Get DPU device attributes.
Syntax:
k_s32 kd_mpi_dpu_get_dev_attr(k_dpu_dev_attr_t *attr);
Parameters:
Parameter Name
Input/Output
attr
Output
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
k_dpu_dev_attr_t
kd_mpi_dpu_set_ref_image#
Description:
Configure DPU reference image.
Syntax:
Parameters:
Parameter Name
Input/Output
ref_path
Reference image path
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • This function should be called after configuring DPU device attributes to configure the reference image.
Related Topics:
kd_mpi_dpu_set_processed_ref_image#
Description:
Configure the offline processed DPU reference image.
Syntax:
Parameters:
Parameter Name
Input/Output
ref_path
Processed reference image path
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • This function should be called after configuring DPU device attributes to configure the reference image. The configured reference image should be pre-processed offline, and calling this function can save about 70ms compared to kd_mpi_dpu_set_ref_image.
Related Topics:
kd_mpi_dpu_set_template_image#
Description:
Configure DPU template image.
Syntax:
Parameters:
Parameter Name
Input/Output
temp_space
Template image structure.
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • This function should be called after configuring DPU device attributes to configure the template image.
  • temp_space should be passed as a parameter during kd_mpi_dpu_parse_file to obtain template image information from the configuration file.
Related Topics:
kd_mpi_dpu_start_dev#
Description:
Start the DPU device.
Syntax:
k_s32 kd_mpi_dpu_start_dev();
Parameters:
Parameter Name
Input/Output
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dpu_set_chn_attr#
Description:
Configure DPU channel attributes.
Syntax:
Parameters:
Parameter Name
Input/Output
lcn_attr
Speckle image channel attributes.
Input
ir_attr
Infrared image channel attributes.
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • The current DPU device has two channels: 0 and 1. Configure lcn_attr->chn_num and ir_attr->chn_num (if the infrared image channel is enabled) to specify the input and output channels for the speckle and infrared images, respectively.
  • After initially starting the DPU device kd_mpi_dpu_start_dev, this function should be called to configure channel attributes. The speckle image channel must be configured, while the infrared image channel can be left unconfigured (set to NULL) if it is not enabled.
  • During operation, if only one channel’s attributes need to be changed, only the structure for that channel needs to be passed in, and the other channel’s parameter can be NULL. Both channels’ parameters can also be passed in simultaneously. If both channels’ parameters are NULL, the configuration will not take effect.
Related Topics:
kd_mpi_dpu_get_chn_attr#
Description:
Get DPU channel attributes.
Syntax:
Parameters:
Parameter Name
Input/Output
lcn_attr
Output
ir_attr
Output
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dpu_start_chn#
Description:
Start the DPU channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • The channel number should be 0 or 1.
Related Topics:
kd_mpi_dpu_stop_chn#
Description:
Stop the DPU channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dpu_send_frame#
Description:
In non-binding mode, send a frame of data to the DPU.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
addr
Physical address of the data to be sent
Input
s32_millisec
Wait time. When this parameter is set to -1, it is blocking mode, and it will return only after the sending is successful; when this parameter is set to 0, it is non-blocking mode, and it will return immediately if the sending is successful, and return other values immediately if the sending fails. For detailed failure information, refer to DPU error codes.
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • If both speckle and infrared image channels are enabled, the infrared and speckle images must be strictly interleaved when inputting.
Related Topics:
kd_mpi_dpu_get_frame#
Description:
Get a frame of data from the DPU.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
result
DPU output result union, its member variables are k_dpu_chn_lcn_result_t and k_dpu_chn_ir_result_t. The user should decide which member to use as the output result for this channel based on the configuration in kd_mpi_dpu_set_chn_attr.
Output
s32_millisec
Wait time. When this parameter is set to -1, it is blocking mode, and it will return only after the fetching is successful; when this parameter is set to 0, it is non-blocking mode, and it will return immediately if the fetching is successful, and return other values immediately if the fetching fails. For detailed failure information, refer to DPU error codes.
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • If both infrared and speckle image channels are enabled, make sure to retrieve the output results from both channels in a timely manner, otherwise the results in the buffer will overflow, causing an inability to continue inputting.
Related Topics:
kd_mpi_dpu_release_frame#
Description:
In non-binding mode, release the obtained result.
Syntax:
Parameters:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • This function will release the data in the buffer sequentially, with the earliest generated result being released first. The DPU buffer is currently set to 3, so please release the result obtained from kd_mpi_dpu_get_frame as soon as possible after use.
Related Topics:
Data Types#
public data types#
k_dpu_init_t#
Description:
Initialize the data structure of DPU device
Definition:
    k_u32 start_num;
    k_u32 buffer_num;
} k_dpu_init_t;
Members:
Member Name
start_num
Start frame number of DPU
buffer_num
Count of DPU caching buffer, at least 1
Notes:
kd_mpi_dpu_init
k_dpu_dev_param_t#
Description:
DPU device parameter structure.
Definition:
    k_dpu_long_parameter_t lpp;
    k_dpu_short_parameter_t spp;
} k_dpu_dev_param_t;
Members:
Member Name
lpp
DPU Long Period Parameter Structure
spp
DPU Short Period Parameter Structure
Notes:
  • When the user needs to change the values in the long period parameters, they should use the virtual address member variable.
k_dpu_lcn_param_t#
Description:
structure parameters of speckle image channel.
Definition:
    k_u8 matching_length_left_p0;
    float depth_p1;
    float depth_p2;
    float depth_precision;
} k_dpu_lcn_param_t;
Members:
Member Name
Coarse search: range of disparity calculation to the left, value: 0~256, integer
matching_length_right_p0
Coarse search: range of disparity calculation to the right, value: 0~256, integer
image_check_match_threshold
Speckle image quality evaluation: template matching threshold, range: 0.0~1.0, float: 0.01 precision
depth_p1
Disparity to depth: depth value calculation coefficient p1, range: 0.0~50000.0, float: 0.01 precision
depth_p2
Disparity to depth: depth value calculation coefficient p2, range: -5.0~100.0, float: 0.01 precision
depth_precision
Disparity to depth: depth value precision (multiplier), range: 0.0~100.0, float: 0.1 precision
Notes:
  • This channel structure parameter is a subset of the device structure parameters. If the device parameters have already been configured and the channel parameters are the same as the device parameters, the channel parameters do not need to be configured.
k_dpu_ir_param_t#
Description:
Infrared image channel parameter structure.
Definition:
    float depth_k1;
    float depth_k2;
    float tz;
} k_dpu_ir_param_t;
Members:
Member Name
depth_k1
Directly corresponds to a register. Tri-image alignment: depth value calculation coefficient k1, range: 2e-4~1e-2, float: 1e-5 precision
depth_k2
Directly corresponds to a register. Tri-image alignment: depth value calculation coefficient k2, range: 0.5~1.5, float: 0.001 precision
tz
Directly corresponds to a register. Tri-image alignment: projector z-direction offset (millimeters), range: -5.0~5.0, float: 0.001 precision
Notes:
k_dpu_user_space_t#
Description:
User template image structure parameters.
Definition:
    k_bool used;
    k_u32 size;
    k_u64 phys_addr;
    void *virt_addr;
} k_dpu_user_space_t;
Members:
Member Name
used
Not relevant to the user
size
Size of the user template image
phys_addr
Physical address of the template image
virt_addr
Virtual address of the template image
Notes:
k_dpu_dev_attr_t#
Description:
Configuration structure for DPU device attributes.
Definition:
    k_dpu_mode_e mode;
    k_bool tytz_temp_recfg;
    k_bool align_depth_recfg;
    k_bool ir_never_open;
    k_u32 param_valid;
    k_dpu_dev_param_t dev_param;
} k_dpu_dev_attr_t;
Members:
Member Name
DPU operating mode, including binding mode and non-binding mode.
tytz_temp_recfg
Whether to update and load SAD temperature compensation parameters and TyTz row compensation calculations. When this flag is K_FALSE, it indicates no update; when K_TRUE, it indicates an update.
align_depth_recfg
Whether to update and load tri-image alignment/depth calculation parameters. When this flag is K_FALSE, it indicates no update; when K_TRUE, it indicates an update.
ir_never_open
The vb pool is configured when the DPU device is started and released when the DPU device is paused. Its size is initialized when the device is started, so space is reserved for depth/disparity images, infrared output, quality check, coarse and fine column disparity, and initial row-column disparity. Users can choose whether to enable tri-image alignment during the usage cycle via dev_param.spp.flag_align. If there will be no infrared image output during the entire usage cycle, there is no need to reserve space for infrared images. Configuring as K_TRUE indicates no need to reserve space for infrared image output, configuring as K_FALSE indicates the need to reserve space.
param_valid
When configuring DPU device attributes, set this member to any non-zero value. When the device attributes take effect, the output result of the corresponding frame will return this arbitrary value.
dev_param
Notes:
  • When configuring the DPU device attributes for the first time, tytz_temp_recfg and align_depth_recfg should be set to K_TRUE to load the corresponding parameters into the DPU.
k_dpu_chn_lcn_attr_t#
Description:
Configuration structure for speckle image channel attributes.
Definition:
    k_u8 param_valid;
    k_s32 chn_num;
    k_dpu_lcn_param_t lcn_param;
} k_dpu_chn_lcn_attr_t;
Members:
Member Name
param_valid
When configuring speckle image channel attributes, set this member to any non-zero value. When the device attributes take effect, the output result of the corresponding frame will return this arbitrary value.
chn_num
Channel number. The current DPU device has two channels. Users can set this channel number to 0 or 1. The speckle image channel will input and output on the corresponding channel. If the infrared image channel is enabled, this channel number should be different from the infrared image channel number.
lcn_param
Speckle image channel parameters.
Notes:
k_dpu_chn_ir_attr_t#
Description:
Configuration structure for infrared image channel attributes.
Definition:
    k_u8 param_valid;
    k_s32 chn_num;
    k_dpu_ir_param_t ir_param;
} k_dpu_chn_ir_attr_t;
Members:
Member Name
param_valid
When configuring infrared image channel attributes, set this member to any non-zero value. When the device attributes take effect, the output result of the corresponding frame will return this arbitrary value.
chn_num
Channel number. The current DPU device has two channels. Users can set this channel number to 0 or 1. The infrared image channel will input and output on the corresponding channel. This channel number should be different from the speckle image channel number.
ir_param
Infrared image channel parameters.
Notes:
k_dpu_chn_result_u#
Description:
Union for obtaining DPU output results.
Definition:
typedef union {
} k_dpu_chn_result_u;
Members:
Member Name
lcn_result
Speckle image channel output result structure. k_dpu_chn_lcn_result_t
ir_result
Infrared image channel output result structure. k_dpu_chn_ir_result_t
Notes:
  • Users should choose which member to use as the output result based on their own configuration. In kd_mpi_dpu_set_chn_attr, users configure the mapping between channel numbers and channel types.
k_dpu_chn_lcn_result_t#
Description:
Structure for DPU speckle image channel output results.
Definition:
    k_u32 time_ref;
    k_u64 pts;
    k_dpu_disp_out_t disp_out;
    k_dpu_depth_out_t depth_out;
    k_dpu_qlt_out_t qlt_out;
    k_dpu_param_flag_t flag;
} k_dpu_chn_lcn_result_t;
Members:
Member Name
pts
Timestamp, valid in binding mode.
disp_out
Disparity image output result structure.
depth_out
Depth image output result structure.
qlt_out
Quality check output result structure. Includes quality check results, coarse and fine column disparity (initial resolution) results, and initial row-column disparity results.
flag
This structure is used to mark which frame the user-configured parameters take effect. The structure includes the param_valid variables from k_dpu_dev_attr_t, k_dpu_chn_lcn_attr_t, and k_dpu_chn_ir_attr_t.
Notes:
k_dpu_chn_ir_result_t#
Description:
Structure for DPU infrared image channel output results.
Definition:
    k_u32 time_ref;
    k_u64 pts;
    k_dpu_ir_out_t ir_out;
} k_dpu_chn_ir_result_t;
Members:
Member Name
pts
ir_out
Infrared image output result structure.
flag
Notes:
k_dpu_disp_out_t#
Description:
Structure for disparity image output results.
Definition:
    k_bool valid;
    k_u32 length;
    k_u64 disp_phys_addr;
    k_u64 disp_virt_addr;
} k_dpu_disp_out_t;
Members:
Member Name
valid
K_TRUE: indicates the output result is valid; K_FALSE: indicates the output result is invalid.
length
Length of the output result.
disp_phys_addr
Physical address of the disparity image output result.
disp_virt_addr
Virtual address of the disparity image output result.
Notes:
k_dpu_depth_out_t#
Description:
Structure for depth image output results.
Definition:
    k_bool valid;
    k_u32 length;
    k_u64 depth_phys_addr;
    k_u64 depth_virt_addr;
} k_dpu_depth_out_t;
Members:
Member Name
valid
length
depth_phys_addr
Physical address of the depth image output result.
depth_virt_addr
Virtual address of the depth image output result.
Translation#
Notes:
k_dpu_ir_out_t#
Description:
Structure for infrared image output results.
Definition:
    k_bool valid;
    k_u32 length;
    k_u64 ir_phys_addr;
    k_u64 ir_virt_addr;
} k_dpu_ir_out_t;
Members:
Member Name
valid
length
ir_phys_addr
Physical address of the infrared image output result.
ir_virt_addr
Virtual address of the infrared image output result.
Notes:
k_dpu_qlt_out_t#
Description:
Structure for quality check output results.
Definition:
    k_bool valid;
    k_u32 qlt_length;
    k_u32 sad_disp_length;
    k_u32 init_sad_disp_length;
    k_u64 qlt_phys_addr;
    k_u64 qlt_virt_addr;
    k_u64 sad_disp_phys_addr;
    k_u64 sad_disp_virt_addr;
} k_dpu_qlt_out_t;
Members:
Member Name
valid
qlt_length
Length of the quality check output result.
sad_disp_length
Length of the coarse and fine column disparity (initial resolution) output result.
Length of the initial row-column disparity output result.
qlt_phys_addr
Physical address of the quality check output result.
qlt_virt_addr
Virtual address of the quality check output result.
sad_disp_phys_addr
Physical address of the coarse and fine column disparity (initial resolution) output result.
sad_disp_virt_addr
Virtual address of the coarse and fine column disparity (initial resolution) output result.
init_sad_disp_phys_addr
Physical address of the initial row-column disparity output result.
init_sad_disp_virt_addr
Virtual address of the initial row-column disparity output result.
Notes:
Long and Short Cycle Parameter Types#
This module includes the following data types:
k_dpu_long_parameter_t#
Description:
DPU long cycle parameter structure.
Definition:
The long cycle parameter has too many members to display here. Refer to the structure k_dpu_long_parameter_t in k_dpu_comm.h in the K230_SDK.
Notes:
  • When users need to change the values in the long cycle parameters, they should use the virtual address member variable.
k_dpu_short_parameter_t#
Description:
DPU short cycle parameter structure.
Definition:
The short cycle parameter has too many members to display here. Refer to the structure k_dpu_short_parameter_t in k_dpu_comm.h in the K230_SDK.
Notes:
Error Codes#
DPU Error Codes#
Table 41
Error Code
Macro Definition
0xa00118001
K_ERR_DPU_INVALID_DEVID
Invalid device ID
0xa00118002
K_ERR_DPU_INVALID_CHNID
Invalid channel ID
0xa00118003
K_ERR_DPU_ILLEGAL_PARAM
Invalid parameter
0xa00118004
K_ERR_DPU_EXIST
DPU device already exists
0xa00118005
K_ERR_DPU_UNEXIST
DPU device does not exist
0xa00118006
K_ERR_DPU_NULL_PTR
Null pointer error
0xa00118007
K_ERR_DPU_NOT_CONFIG
DPU not configured
0xa00118008
K_ERR_DPU_NOT_SUPPORT
Unsupported function
0xa00118009
K_ERR_DPU_NOT_PERM
Operation not permitted
0xa0011800c
K_ERR_DPU_NOMEM
Memory allocation failed, e.g., insufficient system memory
0xa0011800d
K_ERR_DPU_NOBUF
Insufficient buffer
0xa0011800e
K_ERR_DPU_BUF_EMPTY
Buffer empty
0xa0011800f
K_ERR_DPU_BUF_FULL
Buffer full
0xa00118010
K_ERR_DPU_NOTREADY
Device not ready
0xa00118011
K_ERR_DPU_BADADDR
Invalid address
0xa00118012
K_ERR_DPU_BUSY
DPU is busy
Debug Information#
Debug information uses the proc file system to reflect the current running state of the system in real-time. The recorded information can be used for problem localization and analysis.
File Directory#
/proc/
File List#
File Name
umap/dpu
Records some information about the current DPU module
Debug Information#
downScale: false align: false
check: false
quanlity_check: 0 ir: 0
disp/depth: 0
Pathway Selection Information#
Parameter
downScale
Whether to downscale for coarse search
align
Whether to align three images
align_ir
Whether to align infrared images
align_rgbCoord
Whether to align disparity values to the color image coordinate system
depthout
Whether to output depth maps
denoise
Whether to denoise disparity maps
median_p0
Whether to apply median filtering in coarse search
median_denoise
Whether to apply internal median filtering for disparity denoising
median_post
Whether to apply post-processing median filtering for disparity/three-image alignment
median_ir
Whether to apply median filtering for three-image aligned infrared images
check
Whether to perform quality check and initial search for object speckle images
Image Size Information#
Parameter
width_speckle
Width in pixels of the original speckle/infrared image
height_speckle
Height in pixels of the original speckle/infrared image
width_color
Width in pixels of the original color image
height_color
Height in pixels of the original color image
width_output
Width in pixels of the output disparity/depth/infrared image
height_output
Height in pixels of the output disparity/depth/infrared image
Result Length Information#
Parameter
sad_disp_x
Length of the coarse and fine column disparity (initial resolution) result
init_sad_disp_xy
quanlity_check
Length of the quality check result
ir
Length of the infrared image result
disp/depth
Length of the disparity/depth image result
Debug information needs to be viewed during DPU operation. After DPU stops running, all current information will be reset to zero.
Demo Description#
DPU Demo Introduction#
The DPU demo implements both binding and non-binding modes. In the msh, input /bin/sample_dpu.elf to execute the non-binding mode, which ends after running ten frames. Input /bin/sample_dpu.elf BOUND to execute the binding mode, where VVI simulates the upper layer continuously inputting data to the DPU, and the DPU displays information after computation.
Feature Description#
The demo includes functions such as initializing and deleting the DPU, parsing parameters from the configuration file, configuring device attributes, configuring channel attributes, starting and pausing the device, starting and pausing the channel, input and output data, and pipeline binding.
Non-binding Mode#
By calling the API, the DPU device is initialized, parameters are parsed from the configuration file, device attributes are configured based on the parsed parameters, the API is called to set the reference image and template image, the DPU device is started, speckle and infrared image channel attributes are configured, the channel is started, ten frames are looped through and the results are compared, then the channel is stopped, the device is stopped, and the device is deleted.
Binding Mode#
By calling the API, the DPU device is initialized, parameters are parsed from the configuration file, VVI and DPU channels are bound, device attributes are configured based on the parsed parameters, the API is called to set the reference image and template image, the DPU device is started, speckle and infrared image channel attributes are configured, the DPU channel is started, the VVI channel is started, and VVI continuously inputs data to the DPU as the simulated upper layer. The user inputs ‘e’ to stop the channel and device.
Compilation and Execution#
Refer to the document “K230 SDK Demo Usage Guide” for compilation and execution.
