K230 SDK CanMV Board Demo User Guide
Contents
K230 SDK CanMV Board Demo User Guide#
This document introduces the demo functions provided by the K230 SDK and their usage. The executable programs on rt-smart are all compiled by default into the small core/sharefs directory. When testing the large core programs, you need to wait for the small core to fully start, and then enter the /sharefs/app directory in the large core’s msh to test. The audio and video resource files used in each test demo can be obtained from the following link: https://kendryte-download.canaan-creative.com/k230/downloads/test_resource/
Demo Introduction#
Display_demo#
Display_demo Introduction#
The VO (Video Output) module actively reads video and graphic data from the corresponding memory location and outputs video and graphics through the corresponding display device. It supports display/write-back devices, video layers, and graphic layers.
Feature Description#
Video output includes a test case, which is the insertion of frames into the vo osd layer.
Dependency Resources#
A monitor with an HDMI interface and an HDMI cable. The monitor must support 1080P30, otherwise, it will not display.
Usage Instructions#
Compilation#
Execution#
Insert a frame into the vo osd layer:
./sample_vo.elf 15
After executing the command, pressing Enter once will insert a pure green image, pressing Enter again will exit the program.
Image Description
Venc_demo#
Venc_demo Introduction#
The Venc demo encodes the graphics received by vi and can add a frame and OSD overlay to the input image. It supports encoding protocols H.264/H.265/JPEG. The encoded result can be stored as a file and exported locally for playback using video software.
Camera
Usage Instructions#
mpp_demo Execution#
After executing ./sample_venc.elf -h, the usage instructions for the demo are output as follows:
index:
    0) H.265e.
    1) JPEG encode.
    2) OSD + H.264e.
    3) OSD + Border + H.265e.
sensor_index: see vicap doc
Refer to the k230_docs/zh/01_software/board/mpp/K230_Camera_Sensor适配指南.md document for the sensor_index values regarding k_vicap_sensor_type, the default value is 7.
./sample_venc.elf 0 -sensor 24 -o out.265 // Canmv-K230-V1.0/1.1 board
./sample_venc.elf 0 -sensor 39 -o out.265 // Canmv-K230-V2.0 board
MAPI Encoding Demo#
The default sensor type used by sample_venc is IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_LINEAR. Currently, this demo supports 3 channels of encoding. The sensor type and other parameters can be modified through command line arguments as described below:
  2. Start the inter-core communication process on the large core side by executing ./sample_sys_init.elf.
  3. On the small core side, in the /mnt directory, execute ./sample_venc. By default, it performs one channel of h264 video encoding with a resolution of 1280x720, and the generated stream file is stored in the /tmp directory. To pass parameters, refer to the following parameter description:
Usage: ./sample_venc -s 24 -n 2 -o /tmp -t 0            // Canmv-K230-V1.0/1.1 board
                            see vicap doc
                     -t or --type [type_index]
                            0: h264 type
                            1: h265 type
                            2: jpeg type
Usage: ./sample_venc -s 39 -n 2 -o /tmp -t 0            // Canmv-K230-V2.0 board
You can stop the execution by pressing ctrl+c. Depending on the encoding type, different stream files will be generated in the specified output directory on the small core. For h264 type, files like stream_chn0.264 will be generated, where 0 represents channel 0; for h265 type, files like stream_chn0.265 will be generated, similarly, 0 represents channel 0; for jpeg type, files like chn0_0.jpg will be generated, representing the 0th image of channel 0, and by default, 10 jpg images will be generated.
Viewing Results#
The output file can be exported locally and viewed using video playback software.
Nonai_2d_demo#
Nonai_2d_demo Introduction#
The Nonai_2d demo implements image overlay functions on the input file.
Nonai_2d performs image overlay operations by reading yuv (I420 format) files.
None.
Usage Instructions#
The input parameters are as follows:
Parameter Name
Default Value
-i
Input file name
-w
Image width
-h
Image height
-o
Output file name
Execution#
Viewing Results#
The output file can be exported locally and viewed using yuv playback software.
Vdec_demo#
Vdec_demo Introduction#
The Vdec demo implements video decoding functions. It supports decoding H.264/H.265/JPEG formats. The supported input data formats are .264/.265/.jpeg.
The Vdec demo decodes by reading stream files. The decoding output results are displayed on the screen.
None.
Usage Instructions#
Execution#
Execute ./sample_vdec.elf -help to see the configurable parameters and descriptions. The default values are as follows:
Parameter Name
Default Value
i
Input file name, with suffixes .264/.265/.jpg
vo connector type, refer to the vo documentation
The type values refer to the description of k_connector_type in k230_docs/zh/01_software/board/mpp/K230_视频输出_API参考.md, set to 0.
Viewing Results#
Audio_demo#
Audio_demo Introduction#
The audio demo implements audio input and output functions by calling API interfaces. Both audio input and output use the i2s module. The demo includes test cases for audio input or output individually, as well as simultaneous testing of audio input and output.
Audio Input#
Audio input captures the sound from the environment and saves it as a file to analyze whether it is normal.
The demo captures 15 seconds of audio data, and the captured file format is wav, which can be directly played using VLC.
Audio Output#
Audio output plays wav files, and by plugging in earphones, you can judge whether the sound is normal.
The demo tests the audio output function by playing wav files. Different audio format wav files can be uploaded to test the audio output function.
Audio Input and Output#
  1. Test the i2s module function, i.e., real-time capture of environmental sounds through i2s audio input and real-time output through i2s audio output. By plugging in earphones, you can hear the environmental sounds in real-time.
Audio Encoding and Decoding#
Usage Instructions#
Compilation#
Execution#
After starting the rt-smart system, navigate to the /sharefs/app directory, where sample_audio.elf is the test demo.
  • You can enter ./sample_audio.elf -help to view the demo usage instructions.
Parameter
Default
Test different module functions [0,12]
samplerate
Configure different sampling rates for audio input and output (8k-192k)
44100
enablecodec
Whether to enable the built-in codec [0,1]. 1: Use built-in codec
bitwidth
Set audio sampling precision [16,24,32].
16
filename
Name of the wav/g711 file to load or save.
channels
Set the number of audio channels, mono or stereo [1,2].
monochannel
How to set mono, set mono type [0,1]. 0: Onboard mic, 1: Headphone input
audio3a
Whether to enable audio3a: enable_ans:0x01, enable_agc:0x02, enable_aec:0x04, multiple options can be combined
msh /sharefs/app>./sample_audio.elf
Please input:
-type: test audio function[0-12]
    type 0:sample ai i2s module
    type 1:sample ai pdm module
    type 2:sample ao i2s module
    type 3:sample ai(i2s) to ao (api) module
    type 4:sample ai(i2s) to ao (sysbind) module
    type 5:sample ai(pdm) to ao (api) module
    type 6:sample ai(pdm) bind ao (sysbind) module
    type 7:sample aenc(ai->aenc->file) (sysbind) module
    type 8:sample adec(file->adec->ao) (sysbind) module
    type 9:sample aenc(ai->aenc->file) (api) module
    type 10:sample adec(file->adec->ao) (api) module
    type 11:sample overall test (ai->aenc->file file->adec->ao) module
    type 12:sample overall test (ai->aenc  adec->ao loopback ) module
-samplerate: set audio sample(8000 ~ 192000)
-enablecodec: enable audio codec(0,1)
-loglevel: show kernel log level[0,7]
-bitwidth: set audio bit width(16,24,32)
-channels: channel count
-monochannel:0:mic input 1:headphone input
-filename: load or save file name
-audio3a: enable audio3a:enable_ans:0x01,enable_agc:0x02,enable_aec:0x04
I2S Audio Input Test#
Enter ./sample_audio.elf -type 0 -enablecodec 1 -bitwidth 16 -filename test.wav -audio3a 1 to collect PCM audio data for 15 seconds and save it as a wav format file.
audio type:0,sample rate:44100,bit width:16,channels:2,enablecodec:1,monochannel:0
mmz blk total size:7.46 MB
vb_set_config ok
ans_enable
========ans_enable:1,agc_enable:0,aec_enable:0
audio_save_init get vb block size:2646044
=======kd_mpi_sys_mmap total size:2646044
[0s] timestamp 0 us,curpts:1505976917
[1s] timestamp 1000000 us,curpts:1506976917
[2s] timestamp 2000000 us,curpts:1507976917
[3s] timestamp 3000000 us,curpts:1508976917
[4s] timestamp 4000000 us,curpts:1509976917
[5s] timestamp 5000000 us,curpts:1510976917
[6s] timestamp 6000000 us,curpts:1511976917
[7s] timestamp 7000000 us,curpts:1512976917
[8s] timestamp 8000000 us,curpts:1513976917
[9s] timestamp 9000000 us,curpts:1514976917
[10s] timestamp 10000000 us,curpts:1515976917
[11s] timestamp 11000000 us,curpts:1516976917
[12s] timestamp 12000000 us,curpts:1517976917
[13s] timestamp 13000000 us,curpts:1518976917
dump binary memory test1.wav 0x10225000 0x104ab01c
[14s] timestamp 14000000 us,curpts:1519976917
destroy vb block
sample done
I2S Audio Output Test#
Supports playing wav files. You need to copy the wav file to the sharefs path. This demo will loop playing the wav file (any other wav files can also be used). Users can press any key to exit the function test.
Enter ./sample_audio.elf -type 2 -filename test.wav -enablecodec 1 to play wav audio.
audio type:2,sample rate:44100,bit width:16,channels:2,enablecodec:1,monochannel:0
vb_set_config ok
enter q key to exit
========read_wav_header:headerlen:44,channel:2,samplerate:44100,bitpersample:16
open file:test.wav ok,file size:2646044,data size:2646000,wav header size:44
=========_get_audio_frame virt_addr:0x1002aa000
q
disable ao audio
destroy vb block
sample done
Enter ./sample_audio.elf -type 3 -bitwidth 16 -enablecodec 1 -samplerate 8000 -audio3a 1 to test audio input and output functions in real-time via the API interface.
audio type:3,sample rate:8000,bit width:16,channels:2,enablecodec:1,monochannel:0
mmz blk total size:1.35 MB
vb_set_config ok
enter q key to exit
sample ai(i2s) to ao module
ans_enable
[0s] timestamp 0 us,curpts:2017301433
[1s] timestamp 1000000 us,curpts:2018301433
[2s] timestamp 2000000 us,curpts:2019301433
[3s] timestamp 3000000 us,curpts:2020301433
[4s] timestamp 4000000 us,curpts:2021301433
[5s] timestamp 5000000 us,curpts:2022301433
[6s] timestamp 6000000 us,curpts:2023301433
[7s] timestamp 7000000 us,curpts:2024301433
[8s] timestamp 8000000 us,curpts:2025301433
[9s] timestamp 9000000 us,curpts:2026301433
[10s] timestamp 10000000 us,curpts:2027301433
[11s] timestamp 11000000 us,curpts:2028301433
[12s] timestamp 12000000 us,curpts:2029301433
[13s] timestamp 13000000 us,curpts:2030301433
[14s] timestamp 14000000 us,curpts:2031301433
[15s] timestamp 15000000 us,curpts:2032301433
q
[16s] timestamp 16000000 us,curpts:2033301433
disable ao module
disable ai module
release vb block
destroy vb block
sample done
System Bind Test for I2S Audio Input and Output Modules#
Enter ./sample_audio.elf -type 4 -bitwidth 16 -enablecodec 1 -samplerate 8000 -audio3a 1 to test audio input and output functions in real-time by binding the ai and ao modules.
By calling the system binding API interface: kd_mpi_sys_bind to bind the ai and ao modules, test the overall audio input and output functionality. Users can press any key to exit the function test.
audio type:4,sample rate:8000,bit width:16,channels:2,enablecodec:1,monochannel:0
vb_set_config ok
enter q key to exit
sample ai(i2s) bind ao module
ans_enable
q
disable ao module
disable ai module
release vb block
destroy vb block
sample done
Encoding Test#
Acquire ai data, encode and save to a file. Encoding and decoding only support g711a/u/lpcm, 16bit.
System binding method: ./sample_audio.elf -type 7 -bitwidth 16 -enablecodec 1 -filename /sharefs/i2s_codec.g711a -audio3a 1
audio type:7,sample rate:44100,bit width:16,channels:2,enablecodec:1,monochannel:0
vb_set_config ok
enter q key to exit
sample aenc module (sysbind)
ans_enable
q
destroy vb block
sample done
API interface method: ./sample_audio.elf -type 9 -bitwidth 16 -enablecodec 1 -filename /sharefs/i2s_codec.g711a -audio3a 1
audio type:9,sample rate:44100,bit width:16,channels:2,enablecodec:1,monochannel:0
vb_set_config ok
enter q key to exit
sample aenc module (api)
ans_enable
q
destroy vb block
sample done
Decoding Test#
Read file data and decode for playback. Encoding and decoding only support g711a/u/lpcm, 16bit.
System binding method: ./sample_audio.elf -type 8 -filename /sharefs/i2s_codec.g711a -enablecodec 1 -bitwidth 16
audio type:8,sample rate:44100,bit width:16,channels:2,enablecodec:1,monochannel:0
vb_set_config ok
enter q key to exit
sample adec module (sysbind)
read file again
q
destroy vb block
sample done
API interface method: ./sample_audio.elf -type 10 -filename /sharefs/i2s_codec.g711a -enablecodec 1 -bitwidth 16
audio type:10,sample rate:44100,bit width:16,channels:2,enablecodec:1,monochannel:0
vb_set_config ok
enter q key to exit
sample adec module (api)
read file again
q
destroy vb block
sample done
Audio Full Process Test#
1)The recording module ai->aenc->file and playback module file->adec->ao run simultaneously to simulate a voice intercom scenario. Using built-in codec, 16bit precision for simulation. Use -filename to select the file to play, in g711a format, and -samplerate to select the sampling rate. The recording file name is the playback file name appended with _rec: for example, if -filename is /sharefs/test.g711a, then the recording file name is /sharefs/test.g711a_rec.
./sample_audio.elf -type 11 -filename /sharefs/i2s_codec.g711a -audio3a 1
audio type:11,sample rate:44100,bit width:16,channels:2,enablecodec:0,monochannel:0
vb_set_config ok
enter q key to exit
sample ai->aenc->file file->adec->ao module
Force the sampling accuracy to be set to 16,use inner codec
========start play thread
ans_enable
========start record thread,record file:/sharefs/i2s_codec.g711a_rec
read file again
q
destroy vb block
sample done
2)ai->aenc and adec->ao link loopback test by binding. Using built-in codec, 16bit precision for simulation.
Also test the timestamp of the stream after g711 encoding.
./sample_audio.elf -type 12 -samplerate 48000 -enablecodec 1 -audio3a 1 &
audio type:12,sample rate:48000,bit width:16,channels:2,enablecodec:1,monochannel:0
mmz blk total size:8.12 MB
vb_set_config ok
enter q key to exit
[0s] g711 stream timestamp 0 us,curpts:341326051
[1s] g711 stream timestamp 1000000 us,curpts:342326051
[2s] g711 stream timestamp 2000000 us,curpts:343326051
[3s] g711 stream timestamp 3000000 us,curpts:344326051
[4s] g711 stream timestamp 4000000 us,curpts:345326051
[5s] g711 stream timestamp 5000000 us,curpts:346326051
q
destroy vb block
sample done
Enter cat /proc/umap/sysbind to view the system bindings between modules.
    FirMod  FirDev  FirChn  SecMod  SecDev  SecChn  TirMod  TirDev  TirChn    SendCnt     rstCnt
    ai       0       0    aenc       0       0    null       0       0        310          0
    adec     0       0      ao       0       0    null       0       0        310          0
mapi Audio Test#
After the system starts, enter the command on the big core: /sharefs/app/sample_sys_init.elf &
  • On the small core, you can enter /mnt/sample_audio -help to view the demo usage instructions.
Parameter
Default
Test different module functions [0,4]
samplerate
Different sampling rates for audio input and output (8k-192k)
44100
enablecodec
filename
channels
Set the number of audio channels, mono or stereo [1,2]. When using mono, the onboard mic sound is fixed.
./sample_audio
Please input:
-type: test mapi audio function[0-2]
    type 0:sample ai->aenc module
    type 1:sample adec->ao module
    type 2:sample ai->aenc adec->ao loopback module
    type 3:play wav
    type 4:sample ai->aenc module(lpcm)
-channels: audio channels(1,2)
Note: Software audio noise reduction (ans) is enabled by default.
  • ai->aenc Test
On the small core, execute the command: /mnt/sample_audio -type 0 -filename test.g711a, press q to exit the test. The demo can collect audio data in real-time, encode it into g711a format, and save it to a file.
audio type:0,sample rate:44100,channels:2,enablecodec:1,filename:test.g711a
mmz blk total size:2.07 MB
@@@@enable vqe ans
[AENC_S] [Func]:_init_datafifo [Line]:174 [Info]:_aenc_datafifo_init_slave ok,datafifo_phyaddr:0x1021b000,data_hdl:0x1021b000
enter 'q' key to exit
_aenc_dataproc chn_num:0,stream data:0x10015000,data len:3528,seq:0,timestamp:79247530
_aenc_dataproc chn_num:0,stream data:0x1001f800,data len:3528,seq:1,timestamp:79287530
_aenc_dataproc chn_num:0,stream data:0x1002a000,data len:3528,seq:2,timestamp:79327530
_aenc_dataproc chn_num:0,stream data:0x10034800,data len:3528,seq:3,timestamp:79367530
_aenc_dataproc chn_num:0,stream data:0x1003f000,data len:3528,seq:4,timestamp:79407530
_aenc_dataproc chn_num:0,stream data:0x10049800,data len:3528,seq:5,timestamp:79447530
_aenc_dataproc chn_num:0,stream data:0x10054000,data len:3528,seq:6,timestamp:79487530
_aenc_dataproc chn_num:0,stream data:0x1005e800,data len:3528,seq:7,timestamp:79527530
_aenc_dataproc chn_num:0,stream data:0x10069000,data len:3528,seq:8,timestamp:79567530
_aenc_dataproc chn_num:0,stream data:0x10073800,data len:3528,seq:9,timestamp:79607530
_aenc_dataproc chn_num:0,stream data:0x1007e000,data len:3528,seq:10,timestamp:79647530
_aenc_dataproc chn_num:0,stream data:0x10088800,data len:3528,seq:11,timestamp:79687530
_aenc_dataproc chn_num:0,stream data:0x10093000,data len:3528,seq:12,timestamp:79727530
_aenc_dataproc chn_num:0,stream data:0x1009d800,data len:3528,seq:13,timestamp:79767530
_aenc_dataproc chn_num:0,stream data:0x100a8000,data len:3528,seq:14,timestamp:79807530
_aenc_dataproc chn_num:0,stream data:0x100b2800,data len:3528,seq:15,timestamp:79847530
_aenc_dataproc chn_num:0,stream data:0x100bd000,data len:3528,seq:16,timestamp:79887530
_aenc_dataproc chn_num:0,stream data:0x100c7800,data len:3528,seq:17,timestamp:79927530
_aenc_dataproc chn_num:0,stream data:0x100d2000,data len:3528,seq:18,timestamp:79967530
_aenc_dataproc chn_num:0,stream data:0x100dc800,data len:3528,seq:19,timestamp:80007530
_aenc_dataproc chn_num:0,stream data:0x100e7000,data len:3528,seq:20,timestamp:80047530
_aenc_dataproc chn_num:0,stream data:0x100f1800,data len:3528,seq:21,timestamp:80087530
_aenc_dataproc chn_num:0,stream data:0x100fc000,data len:3528,seq:22,timestamp:80127530
_aenc_dataproc chn_num:0,stream data:0x10106800,data len:3528,seq:23,timestamp:80167530
_aenc_dataproc chn_num:0,stream data:0x10111000,data len:3528,seq:24,timestamp:80207530
_aenc_dataproc chn_num:0,stream data:0x10118000,data len:3528,seq:25,timestamp:80247530
  • adec->ao Test
On the small core, execute the command: /mnt/sample_audio -type 1 -filename test.g711a, press q to exit the test. The demo can loop decode and play the locally stored g711a format file.
audio type:1,sample rate:44100,channels:2,enablecodec:1,filename:test.g711a
[ADEC_S] [Func]:_init_datafifo [Line]:189 [Info]:_adec_datafifo_init_slave ok,datafifo_phyaddr:0x1021b000,data_hdl:0x1021b000
read file again
  • ai->aenc adec->ao Loopback Test
On the small core, execute the command: /mnt/sample_audio -type 2, press q to exit the test. The demo can collect audio data in real-time, encode it into g711a format, then decode the g711a formatted data and play it back.
audio type:2,sample rate:44100,channels:2,enablecodec:1,filename:
[ADEC_S] [Func]:_init_datafifo [Line]:189 [Info]:_adec_datafifo_init_slave ok,datafifo_phyaddr:0x1021c000,data_hdl:0x1021c000
@@@@enable vqe ans
read file again
q
sample done
Vicap_demo#
Vicap_demo Introduction#
The vicap demo implements camera data collection and preview functions by calling MPI interfaces.
Camera module
Usage Instructions#
Compilation#
  1. Execute make mpp-clean && rt-smart && make build-image in the k230_sdk directory to compile the modifications for the large core into the SD card image. The image file sysimage-sdcard.img will be generated in the k230_sdk/output/k230_evb_defconfig/images/ directory.
Execution#
  2. Mount this directory to /sharefs on the small core Linux via NFS.
  3. On the large core, use the cd /sharefs command to enter the /sharefs directory.
When you input the sample_vicap command, the following prompt information will be printed:
usage: ./sample_vicap -mode 0 -dev 0 -sensor 23 -chn 0 -chn 1 -ow 640 -oh 480 -preview 1 -rotation 1      // Canmv-K230-V1.0/1.1 board
usage: ./sample_vicap -mode 0 -dev 0 -sensor 33 -chn 0 -chn 1 -ow 640 -oh 480 -preview 1 -rotation 1      // Canmv-K230-V2.0 board
Options:
Parameter Name
Optional Values
Parameter Description
-dev
0: vicap device 0, 1: vicap device 1, 2: vicap device 2
Specify the current vicap device in use. The system supports up to three vicap devices. By specifying the device number, the sensor can be bound to different vicap devices. For example: -dev 1 -sensor 0 indicates binding the OV9732 1280x720 RGB image output to vicap device 1.
-mode
Specify the vicap device working mode. Currently, both online and offline modes are supported. For multiple sensor inputs, offline mode must be specified.
-conn
0: Screen hx8399; 1: HDMI lt9611-1920x1080p60; 2: HDMI lt9611-1920x1080p30
Specify the display method, you can choose between screen or HDMI. The default is 0.
-sensor
23: OV5647 (Canmv-K230-V1.0/1.1 board), 33: OV5647 (Canmv-K230-V2.0 board)
Specify the current sensor type in use.
-chn
0: vicap device output channel 0, 1: vicap device output channel 1, 2: vicap device output channel 2
Specify the current output channel of the vicap device. A vicap device supports up to three outputs, with only channel 0 supporting RAW image format output.
-ow
Specify the output image width, default is the input image width. The width needs to be 16-byte aligned. If the default width exceeds the maximum output width of the display screen, the display output width will be used as the final output width. If the output width is less than the input image width and the -ox or -oy parameters are not specified, it defaults to scaled output.
-oh
Specify the output image height, default is the input image height. If the default height exceeds the maximum output height of the display screen, the display output height will be used as the final output height. If the output height is less than the input image height and the -ox or -oy parameters are not specified, it defaults to scaled output.
-ox
Specify the horizontal starting position of the image output. If this parameter is greater than 0, output cropping will be performed.
-oy
Specify the vertical starting position of the image output. If this parameter is greater than 0, output cropping will be performed.
-crop
0: disable cropping function, 1: enable cropping function
-ofmt
Specify the output image format, default is yuv output.
-preview
0: disable preview display, 1: enable preview display
Specify the output image preview display function. Default is enabled. Currently, up to 2 output images can be previewed simultaneously.
-rotation
0: rotate 0 degrees, 1: rotate 90 degrees, 2: rotate 180 degrees, 3: rotate 270 degrees, 4: unsupported rotation, 17 use gdma rotate 90 degrees, 18 use gdma rotate 180 degrees, 19 use gdma rotate 270 degrees
Specify the rotation angle of the preview display window. only the first output image window supports the vo rotation function, all output image window supports gdma rotation function.
Example 1:
./sample_vicap -conn 1 -dev 0 -sensor 23 -chn 0 -chn 1 -ow 640 -oh 480 -preview 0  // Canmv-K230-V1.0/1.1 board
./sample_vicap -conn 1 -dev 0 -sensor 33 -chn 0 -chn 1 -ow 640 -oh 480 -preview 0  // Canmv-K230-V2.0 board
Description: Bind the OV5647@1920x1080 RGB output to vicap device 0, and enable vicap device output channels 0 and 1. Channel 0 output size defaults to the input image size (1920x1080), and channel 1 output image size is 640x480.
Example 2: OV5647 Triple Camera
Triple Camera OV5647
Note: The two OV5647s on the back can use the Raspberry Pi OV5647 camera. The Canmv-K230 V1.0 V1.1 version of the board needs to replace the LDO to 1.8V, such as RT9013-18. As shown below:
Change LDO
If it is inconvenient to replace the LDO, you can wait for the subsequent V1.2 version of the board.
./sample_vicap.elf -conn 1 -mode 1 -dev 0 -sensor 23 -chn 0 -ow 320 -oh 240 -dev 1 -sensor 26 -chn 0 -ow 320 -oh 240 -dev 2 -sensor 27 -chn 0 -ow 320 -oh 240 -ofmt 1  // Canmv-K230-V1.0/1.1 board
./sample_vicap.elf -conn 1 -mode 1 -dev 0 -sensor 31 -chn 0 -ow 320 -oh 240 -dev 1 -sensor 32 -chn 0 -ow 320 -oh 240 -dev 2 -sensor 33 -chn 0 -ow 320 -oh 240 -ofmt 1  // Canmv-K230-V2.0 board
Triple Camera Result
DMA_demo#
DMA_demo Introduction#
Non-binding Mode#
DMA channels 0-3 are GDMA, and channels 4-7 are SDMA.
  • Channel 0 continuously inputs images with a resolution of 1920x1080, 8-bit, YUV400, single-channel mode, rotates 90 degrees, and outputs, comparing with golden data.
  • Channel 1 continuously inputs images with a resolution of 1280x720, 8-bit, YUV420, dual-channel mode, rotates 180 degrees, and outputs, comparing with golden data.
  • Channel 2 continuously inputs images with a resolution of 1280x720, 10-bit, YUV420, triple-channel mode, x-mirror, y-mirror, and outputs, comparing with golden data.
  • Channel 4 performs a 1D mode loop transfer of a segment of data, and after the transfer is complete, compares with golden data.
  • Channel 5 performs a 2D mode loop transfer of a segment of data, and after the transfer is complete, compares with golden data.
Binding Mode#
Use VVI as the DMA simulation input. Bind VVI device 0’s channel 0 to DMA channel 0, and VVI device 0’s channel 1 to DMA channel 1. VVI inputs a 640x320, YUV400, 8-bit, 90° rotated image to channel 0 every second, and a 640x320, YUV400, 8-bit, 180° rotated image to channel 1.
Includes DMA device property configuration, channel property configuration, graphical input, output, release, pipeline binding, and other functions.
Usage Instructions#
Compilation#
Execution#
  1. Non-binding mode demo execution
/sharefs/app/sample_dma.elf
Test information will be displayed on the screen, and press ‘q’ to end the execution.
  1. Binding mode demo execution
USB_demo#
USB_demo Introduction#
The USB demo currently includes four functionalities:
As a device, it simulates a USB drive and a mouse/keyboard.
As a host, it connects to a USB drive and a mouse/keyboard.
The USB demo’s functionalities are natively integrated into the Linux system.
Usage Instructions#
Simulating USB Drive as a Device#
# Allocate a memory space to simulate the USB drive's disk space.
2+0 records in
2+0 records out
mkfs.fat 4.1 (2017-01-24)
# Use the FAT partition of the SD/eMMC as the simulated USB drive's disk space.
Connect the USB port of the development board to a PC via a Type-C cable. The PC will display a connected USB drive.
Connecting USB Drive as a Host#
Connect the USB port of the K230 development board to a USB drive using a Type-C to Type-A adapter.
Simulating Mouse/Keyboard as a Device#
Connect the USB port of the K230 development board to another computer using a Type-C cable for testing.
# Enter the corresponding operations based on the prompts, such as -123 -123, and you will see the mouse pointer move on the PC.
# Enter the corresponding operations based on the prompts, and you will see keyboard-like input on the PC, such as a b c --return.
Connecting Mouse/Keyboard as a Host#
Connect the USB port of the K230 development board to a mouse or keyboard using a Type-C to Type-A adapter.
# Use the following command to determine the event corresponding to the input device. If the K230 development board is not connected to a screen, the event corresponding to the connected mouse/keyboard will change.
U: Uniq=
H: Handlers=event2
B: PROP=0
B: EV=17
B: KEY=ffff0000 0 0 0 0
B: REL=1943
B: MSC=10
# Click or move the mouse, and the corresponding display will appear in the terminal.
# Press different keys on the keyboard, and the corresponding display will appear in the terminal.
GPU_demo#
GPU_demo Introduction#
  • tiger: Draws a vector tiger illustration.
The GPU demo mainly covers three functions: vector drawing, linear gradient (implemented through pattern), and color lookup table.
Writable file system.
Usage Instructions#
Enter a writable directory and execute the program.
tiger#
Run the tiger command, and after execution, a tiger.png file will be generated in the current directory, as shown below:
Tiger Image
linearGrad#
Run the linearGrad command, and after execution, a linearGrad.png file will be generated in the current directory, as shown below:
Linear Gradient
imgIndex#
Run the imgIndex command, and after execution, four image files will be generated in the current directory, as shown below:
index1
index2
index4
index8
vglite_drm#
Run the vglite_drm command, and a pattern drawn by the GPU will be displayed on the LCD screen. Press the Enter key again to display the next pattern, as shown below:
First Pattern
vglite_cube#
Run the vglite_cube command, and a rotating cube drawn by the GPU will be displayed on the LCD screen, as shown below:
Cube
This demo will generate a lot of kernel messages. If you do not want to see these messages, you can lower the kernel log level:
sysctl -w kernel.printk=6
DRM Display Demo#
Demo Introduction#
This demo runs on the Linux system of the K230 small core, specifically displaying images on the screen.
  1. DRM supports operations on 5 layers, including: 1 video layer and 4 OSD layers.
HDMI display
Usage Instructions#
Compilation#
Execution#
After executing the above command, color bars will be displayed on the HDMI display, as shown below:
Image Description
LVGL Demo#
Demo Introduction#
This demo runs on the Linux system of the K230 small core and displays a configuration interface on the HDMI display.
HDMI display
Usage Instructions#
Compilation#
Execution#
lvgl_demo_widgets
After executing the above command, a configuration interface will be displayed on the HDMI display, as shown below:
Image Description
RTSP Streaming Demo#
Demo Introduction#
This demo supports simultaneous streaming of audio and video streams to an RTSP server, using the mapi venc&aenc interface for audio and video encoding. After streaming, you can pull the stream using a URL. Currently, this demo supports streaming and pulling three URLs.
A USB to Ethernet adapter is required to connect the development board to a network cable.
Usage Instructions#
Compilation#
Refer to the README.md in the release SDK package for instructions on compiling in the Docker environment. After compilation, the executable program rtsp_demo will be generated in the k230_sdk/src/common/cdk/user/out/little directory.
Execution#
The default sensor type used by rtsp_demo is IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_LINEAR. You can modify the sensor type and other parameters via command line arguments as follows:
  1. Use lsmod to check if the k_ipcm module is loaded on the smaller core. If not, load it with insmod k_ipcm.ko.
  2. Start the inter-core communication process on the larger core by executing ./sample_sys_inif.elf.
  3. On the smaller core, navigate to the /mnt directory and execute ./rtsp_demo. By default, it streams one H.265 video with a resolution of 1280x720. For other parameters, refer to the options below. When streaming MJPEG, the maximum supported resolution is 2032x1944, and the minimum is 640x480.
Usage: ./rtsp_demo -s 24 -n 2 -t h265 -w 1280 -h 720 -a 0  // Canmv-K230-V1.0/1.1 board
Usage: ./rtsp_demo -s 39 -n 2 -t h265 -w 1280 -h 720 -a 0  // Canmv-K230-V2.0 board
                    -s: the sensor type:
                        see vicap doc
                    -w: the video encoder width
                    -h: the video encoder height
                    -a: audio input type (0: mic input, 1: headphone input): default 0.
Refer to the k230_docs/zh/01_software/board/mpp/K230_Camera_Sensor适配指南.md document for the sensor type values under k_vicap_sensor_type.
The audio input type can be either the onboard mic or headphone input.
Once rtsp_demo is running on the smaller core, it will print a URL like rtsp://ip:8554/session0, where 0 represents the first session. You can use VLC to pull and play the stream from this URL. To stop the stream, first stop VLC and then press ctrl+c to terminate rtsp_demo.
FaceAeDemo#
Demo Introduction#
This demo runs on the larger core and demonstrates the integration of VICAP, KPU, VO (video output), and AERoi. It can adjust the facial exposure brightness through face detection.
Compilation#
  1. Refer to the README.md in the release SDK for instructions on using Docker to compile the image.
  2. After compilation, the sample (sample_face_ae.elf) will be located at k230_sdk/src/big/mpp/userapps/sample/elf.
  3. Since the KPU linkage requires the detection model test.kmodel, it will be stored at k230_sdk/src/big/mpp/userapps/sample/elf after compilation.
Execution#
cd /sharefs/app
./sample_face_ae.elf test.kmodel 1 # arg1: model name, arg2: enable face AE
Wait for initialization to complete and prompt for any letter + enter.
Type 'a' and press enter to run the face AE demo.
Upon successful execution, the physical address of each frame image will be printed.
FFT Demo#
Demo Introduction#
This demo verifies the usage of FFT APIs and tests the FFT functionality. The code is located at src/big/mpp/userapps/sample/sample_fft/.
First, an FFT calculation is performed, followed by an IFFT calculation.
Usage Instructions#
Compilation#
Refer to the README.md in the release SDK package.
Execution#
  1. Once both the large and small core systems are up, execute the following command on the larger core:
    The larger core serial output will display:
    msh /sharefs/app> ./sample_fft.elf 1 0
        max diff 0003 0001
        max diff 0003 0002
        max diff 0003 0001
        max diff 0003 0003
        max diff 0005 0002
        max diff 0005 0003
        max diff 0005 0002
SDIO WIFI#
Demo Introduction#
The CANMV development board uses an SDIO WIFI module that supports 2.4G, specifically the AP6212. It supports both STA and softAP modes.
Compilation#
The default configuration for building CANMV in k230_sdk supports AP6212 WIFI.
Run make menuconfig:
K230 SDK Configuration
    wifi configurations  --->
        [*] enable ap6212a
Once ap6212a is enabled, k230_sdk will copy the necessary firmware or nvram configuration to the file system.
Run make linux-menuconfig:
    Device Drivers  --->
            [*]   Wireless LAN  --->
Configure the LINUX build for the WIFI driver. The default mode for CANMV WIFI is STA and softAP coexistence. The source code path is:
Run make buildroot-menuconfig:
    Target packages  --->
        Networking applications  --->
            [*] hostapd
            [*]   Enable hostap driver
            [*]   Enable nl80211 driver
            [ ]   Enable wired driver
            [*]   Enable ACS
            [*]   Enable EAP
            [*]   Enable WPS
            [*]   Enable WPA3 support
            [*]   Enable VLAN support
            [*] wireless tools
                [*]   Install shared library
            [*] wpa_supplicant
                [*]   Enable nl80211 support
                [*]   Enable AP mode
                [*]     Enable Wi-Fi Display
                [*]   Enable autoscan
                [*]   Enable EAP
                [*]   Enable HS20
                [*]   Enable syslog support
                [*]   Enable WPS
                [*]   Install wpa_clibinary
Compile buildroot to add wireless tools.
The WIFI module is reset during system startup in uboot. Source code:
The WIFI module is powered on/off via if wlan down/up after system startup. Source code:
&gpio1 {
    status = "okay";
&mmc_sd0 {
    status = "okay";
    io_fixed_1v8;
    rx_delay_line = <0x00>;
    tx_delay_line = <0x00>;
    bcmdhd_wlan {
Execution#
STA (Station) mode is where the device acts as a client and connects to an AP (Access Point) for network access. Our mobile phones typically operate in STA mode when connecting to a router.
AP mode is where the device acts as a server, providing wireless access to other devices. Wireless routers, gateways, and hotspots typically operate in AP mode, allowing other devices to connect and communicate through it.
STA Testing#
ifconfig -a
ifconfig wlan0 up
wpa_cli -i wlan0 scan
wpa_cli -i wlan0 scan_result
wpa_cli -i wlan0 add_network
udhcpc -i wlan0 -q
AP Testing#
driver=nl80211
ieee80211n=1
interface=wlan1
hw_mode=g
channel=6
beacon_int=100
dtim_period=1
ssid=k230_ap
auth_algs=1
ap_isolate=0
ignore_broadcast_ssid=0
ifconfig wlan1 192.168.1.1
udhcpd /etc/udhcpd.conf &
hostapd /etc/hostapd.conf &
A STA device can connect directly to the k230_ap hotspot without a password.
UVC_demo#
uvc_demo Introduction#
The UVC demo turns the K230 development board into a USB camera. When connected to a PC via a USB cable, the PC’s player can display the real camera image.
The current version supports both bulk and ISO transfer.
It supports 640x480 NV12 format images and 1280x720 H264/MJPEG format images.
PID, VID, and device name can be configured by modifying the shell script.
A camera application on the PC or PotPlayer software.
Usage Instructions#
Compilation#
  1. The user program source code for the smaller core is located at cdk/user/mapi/sample/camera.
  2. The driver program for the smaller core is located at linux/drivers/usb/dwc2.
  3. The driver program for the smaller core is located at linux/drivers/usb/gadget.
  4. The larger core program involves the mpp repository and cdk.
The larger core’s RTT implements the camera driver functionality.
The smaller core’s Linux implements the USB driver functionality and obtains camera images from the larger core via mapi.
Refer to K230_USB_Application_Practice_UVC_Transmission_YUV_and_Encoding_Stream.
Execution#
After entering the large core RT-Smart system, navigate to the /bin directory and execute:
msh /sharefs/app> ./sample_sys_init.elf
./canaan-camera.sh start otg0
./camera -t 24
Connect the Type-C USB cable to USB0 and the PC, and use PotPlayer to play the camera.
By default, it uses BULK transfer. You can change to ISO transfer with the following command.
./canaan-camera.sh stop
./camera -i -t 24  // Canmv-K230-V1.0/1.1 board
./camera -i -t 39  // Canmv-K230-V2.0 board
The -t option is used to specify the vicap sensor type. Please refer to the k230_docs/zh/01_software/board/mpp/K230_Camera_Sensor适配指南.md document for the description of k_vicap_sensor_type. For CanMV, it should be set to 24.
Go to PotPlayer -> Options -> Device -> Camera interface, Video Recording Device -> Device, select UVC Camera Video Recording Device -> Format, select H264 1280*720 30(P 16:9) or MJPG 1280*720 30(P 16:9) or NV12 640*360p 30(P 16:9)
YUV Sensor Demo#
Demo Introduction#
Three-way YUV sensor input, outputting YUV444 packed format to DDR through VICAP’s MCM hardware, and converting to NV12 format using the CSC function of nonai_2d hardware.
VICAP binds to nonai_2d, nonai_2d outputs to both VENC and VO, performing RTSP streaming and screen display.
Depends on special adapter board hardware, as shown below:
Image Description
Usage Instructions#
After entering the large core RT-Smart system, execute:
After entering the small core Linux system, execute:
/mnt/yuv_sensor_demo -n 3
When rtsp_demo runs normally on the small core, it will print a URL like: rtsp://10.100.228.150:8554/BackChannelTest0, where 0 represents the first channel. You can use VLC to pull and play the stream from this URL, or connect to HDMI output to watch on the screen.
