K230 OpenBLAS Development Guide#
The products, services, or features you purchase are subject to the commercial contract and terms of Beijing Canaan Creative Information Technology Co., Ltd. (“the Company”) and its affiliates. All or part of the products, services, or features described in this document may not be within your purchase or usage scope. Unless otherwise agreed in the contract, the Company does not provide any express or implied statement or warranty regarding the correctness, reliability, completeness, merchantability, suitability for a particular purpose, or non-infringement of any statements, information, or content in this document. Unless otherwise agreed, this document is only for reference as a usage guide.
Trademark Statement#
Copyright © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. Without the written permission of the Company, no unit or individual is allowed to excerpt, copy, or disseminate part or all of the content of this document in any form.
Table of Contents#
This document mainly introduces K230 OpenBLAS.
Target Audience#
This document (guide) is primarily intended for the following personnel:
Technical Support Engineers
Abbreviation Definitions#
Abbreviation |
OpenBLAS |
Open Basic Linear Algebra Subprograms |
Document Version |
Modification Description |
Modifier |
Date |
Initial Version |
Algorithm Department |
2023-05-30 |
Introduction to OpenBLAS#
OpenBLAS is an optimized BLAS computation library distributed under the BSD license (open-source). BLAS (Basic Linear Algebra Subprograms) is an API standard for releasing numerical libraries for basic linear algebra operations (such as vector or matrix multiplication). OpenBLAS is a specific implementation of the BLAS standard.
In the SDK, a pre-cross-compiled OpenBLAS library is included (located at the path k230_sdk/src/big/utils/lib/openblas/). Users can directly use this static library to compile their own executable programs.
Test Case Compilation#
Note:
This section explains how to compile executable programs using the pre-set OpenBLAS static library in the SDK. The SDK includes multiple examples of executable program compilation based on OpenBLAS (located at
k230_sdk/src/big/utils/examples/openblas/). This section explains based on these examples.
The directory structure under the path k230_sdk/src/big/utils/examples/openblas/ is as follows:
|-- 1_openblas_level1 # OpenBLAS Example 1
| |-- CMakeLists.txt # CMake configuration file for OpenBLAS Example 1
| `-- openblas_level1.cpp
|-- 2_openblas_level2
| |-- CMakeLists.txt
| `-- openblas_level2.cpp
|-- 3_openblas_level3
| |-- CMakeLists.txt
| `-- openblas_level3.cpp
|-- 4_fortran_example
| |-- CMakeLists.txt
| `-- openblas_fortran.cpp
|-- CMakeLists.txt # Overall CMake configuration file
|-- build_app.sh # Overall compilation script
|-- cmake # Default CMake configuration
| |-- Riscv64.cmake
| `-- link.lds
First, run the build_app.sh file under the path k230_sdk/src/big/utils/examples/openblas/:
./build_app.sh
If the following prompt appears in the terminal, it indicates that the executable program has been successfully compiled:
Install the project...
Finally, the k230_sdk/src/big/utils/examples/openblas/out/bin folder contains all the compiled elf files:
1_openblas_level1.elf2_openblas_level2.elf3_openblas_level3.elf4_openblas_fortran.elf
Test Case Execution Demonstration#
level_1 Test Case#
Execution method and output example:
This is the result:
4 7 11 14
This is the reference:
4 7 11 14
{Test PASS}.
level_2 Test Case#
This is the result:
20 40 10 20 30 60
20 40 10 20 30 60
{Test PASS}.
level_3 Test Case#
This is the result:
7 10 15 22
7 10 15 22
{Test PASS}.
Fortran Interface Test Case#
This is matrix A
This is matrix B
This is the result:
{Test PASS}.
OpenBLAS Cross Compilation#
Note:
Although the SDK includes a pre-cross-compiled OpenBLAS library (located at the path
k230_sdk/src/big/utils/lib/openblas/), interested users can also cross-compile OpenBLAS themselves to obtain the OpenBLAS static library adapted to K230.
Setting Up the OpenBLAS Compilation Environment#
Git Code Download#
First, use git to obtain the OpenBLAS repository. Since OpenBLAS comes from GitHub, slow cloning speed is normal, please be patient:
OpenBLAS has many versions. Since version 0.3.21 lacks some features compared to the latest branch, we use the current latest commit:
Applying Patch Package#
Note:
The patch package is located in the SDK at
k230_sdk/src/big/rt-smart/userapps/openblas/.
First, create a patch directory in the root directory of OpenBLAS and copy the patch package to the patch directory. The directory structure after placing the folder is shown as follows:
├── appveyor.yml
├── azure-pipelines.yml
├── BACKERS.md
├── benchmark
├── cblas.h
├── common_lapack.h
├── common_level1.h
├── common_level2.h
├── common_level3.h
├── common_linux.h
├── common_loongarch64.h
├── common_macro.h
|-- patch # Patch package for OpenBLAS
| |-- 0001-****.patch
| |-- 0002-****.patch
| |-- 0003-****.patch
| |-- 0009-****.patch
| |-- 0010-****.patch
| |-- 0011-****.patch
├── utest
└── version.h
Execute the following command in the root directory of OpenBLAS to apply the patches:
git am ./patch/*.patch
OpenBLAS Compilation#
Enter the root directory of OpenBLAS and execute the following command to compile:
# Note: The toolchain path will vary depending on the developer's specific environment, and the path prefix is for reference only.
After the compilation is complete, install the compiled library to a specified folder. In this example, it is installed in the ./install folder:
# Note: You can modify the installation path according to your needs.
