K230_DRM_API_Reference#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
**Copyright 2023 Canaan Inc.. © All Rights Reserved. Without the written permission of the company, no unit or individual may extract or copy part or all of the content of this document without authorization, and shall not disseminate it in any form.
Directory#
preface#
This document mainly introduces the DRM driver and its user-mode interface libdrm library
Reader object#
This document is intended primarily for:
Technical Support Engineer
Software Development Engineer
Definition of acronyms#
abbreviation |
illustrate |
DRM |
Direct Rendering Manager |
KMS |
Kernel Mode Setting |
GEM |
Graphics Execution Manager |
Revision history#
Document version number |
Modify the description |
Author |
date |
Initial edition |
Author |
2023/06/29 |
Introduction to DRM#
DRM is the management architecture responsible for interacting with the graphics card in the Linux kernel, and user programs can easily use the API provided by DRM to achieve display control, 3D rendering, video encoding and decoding, GPU computing and other work
DRM architecture features#
DRM is the mainstream graphics display framework in the current Linux kernel, compared with the traditional FB architecture, it has the following characteristics:
DRM architecture natively supports multi-layer synthesis, FB schema natively does not support multi-layer synthesis
The DRM architecture natively supports VSYNC, DMA_BUF, and Fence mechanisms
The DRM architecture manages rendering and display drivers in a unified manner, making software development and maintenance simpler
DRM architecture composition#
From the overall architecture, DRM is mainly divided into three parts:
libdrm
libdrm encapsulates the underlying interface and provides a common API interface to user patterns
libdrm also provides a modetest program internally for querying the details of DRM devices, as well as basic display testing
KMS
KMS stands for Kernel Mode Settings, which mainly sets display resolution, color space, refresh rate, and display buffer switching and multilayer compositing
GEM
Memory management, responsible for memory allocation and release
ModeTest instructions#
modetest is a test program provided by libdrm that can query the details of DRM devices while also performing basic display tests
Query K230 DRM details#
The specific instructions are as follows:
Encoders:
id crtc type possible crtcs possible clones
37 36 DSI 0x00000001 0x00000001
Connectors:
id encoder status name size (mm) modes encoders
38 37 connected DSI-1 68x120 1 37
modes:
#0 1080x1920 30.00 1080 1310 1330 1350 1920 1925 1931 1939 78529 flags: ; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
flags: immutable range
values: 0 1
value: 0
4 TILE:
blobs:
value:
CRTCs:
id fb pos size
36 0 (0,0) (1080x1920)
props:
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
28 GAMMA_LUT:
flags: blob
blobs:
value:
29 GAMMA_LUT_SIZE:
values: 0 4294967295
value: 256
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
31 0 0 0,0 0,0 0 0x00000001
formats: NV12 NV21 NV16 NV61
props:
8 type:
flags: immutable enum
value: 0
32 0 0 0,0 0,0 0 0x00000001
props:
8 type:
value: 1
33 0 0 0,0 0,0 0 0x00000001
props:
8 type:
value: 2
34 0 0 0,0 0,0 0 0x00000001
props:
8 type:
value: 0
35 0 0 0,0 0,0 0 0x00000001
props:
8 type:
value: 0
Frame buffers:
id size pitch
[root@canaan ~ ]#
The above information is the K230 DRM details, here is a brief description:
Module ID |
Module name |
Module description |
37 |
Encoder |
none |
38 |
Connector |
none |
36 |
CRTC |
Resolution support: 1080x1920 |
31 |
Video layer |
Color space support: NV12, NV21, NV16, NV61 |
32 |
OSD layer |
Color space support: AR24, AR12, AR15, RG24, RG16 |
33 |
OSD layer |
34 |
OSD layer |
35 |
OSD layer |
AR24 Display ARGB8888
AR12 Display ARGB4444
AR15 Display ARGB1555
RG24 means RGB888
RG16 stands for RGB565
The 2.2 video layer outputs smpte color bars with NV12 color space#
The following figure shows the LCD display:
The OSD layer outputs tiles color bars, and the color space is AR24(ARGB8888)#
OSD layer outputs tiles color bars with a color space of RG16(RGB565)#
Introduction to DRM API#
Turn on the DRM device#
if (fd < 0) {
return -1;
Retrieving DRM resources#
typedef struct _drmModeRes {
int count_fbs;
uint32_t *fbs;
int count_crtcs;
uint32_t *crtcs;
int count_connectors;
uint32_t *connectors;
int count_encoders;
uint32_t *encoders;
} drmModeRes, *drmModeResPtr;
An example of a code call is as follows:
if (res == NULL) {
return -1;
conn_id = res->connectors[0];
crtc_id = res->crtcs[0];
Retrieving layer resources#
uint32_t count_planes;
uint32_t *planes;
if (plane_res == NULL) {
return -1;
In K230 DRM, the layer correspondence is as follows:
plane_res->plans[0] stand for Video layer
plane_res->plans[1] to plane_res->plans[4] stand for OSD layer
Obtaining Connectors#
uint32_t connector_id;
uint32_t connector_type;
uint32_t connector_type_id;
drmModeConnection connection;
drmModeSubPixel subpixel;
int count_modes;
drmModeModeInfoPtr modes;
int count_props;
int count_encoders;
if (conn == NULL) {
return -1;
Apply for DRM DUMB buffer#
creq.width = 1080;
creq.height = 1920;
creq.bpp = 32;
if (ret < 0) {
errno);
return -errno;
Submit DRM Requests#
drmModeAtomicReqPtr req,
uint32_t flags,
void *user_data);
Precautions#
K230 DRM development and testing rely on LCD screens
K230 DRM internal module ID is not static, we should according to the actual ID of each module
