VDEC Module API Manual#
This document provides a detailed introduction to the K230_CanMV VDEC module’s API. This module supports H.264 and H.265 decoding and can be bound to the VO module to output decoded data to VO display devices.
API Introduction#
This module provides the Decoder class, which includes the following methods:
Decoder.__init__#
Constructor to initialize the decoder instance.
Syntax
decoder = Decoder(K_PT_H264)
Parameter Name |
Input/Output |
type |
Encoding type |
Input |
Return Values
Return Value |
Success |
Non-0 |
Failure |
Notes
The VDEC module supports up to four concurrent decodings.
Decoder.Create#
Creates a decoder instance.
Syntax
decoder.create()
Return Values
Return Value |
Success |
Non-0 |
Failure |
Decoder.destroy#
Destroys the decoder instance.
Syntax
decoder.destroy()
Return Values
Return Value |
Success |
Non-0 |
Failure |
Decoder.Start#
Starts the decoder and begins the decoding process.
Syntax
decoder.Start()
Return Values
Return Value |
Success |
Non-0 |
Failure |
Decoder.decode#
Decodes a frame of data.
Syntax
decoder.decode(stream_data)
Parameter Name |
Input/Output |
stream_data |
Encoded data |
Input |
Return Values
Return Value |
Success |
Non-0 |
Failure |
Decoder.stop#
Releases the current decoded frame’s stream buffer.
Syntax
decoder.stop()
Return Values
Return Value |
Success |
Non-0 |
Failure |
Decoder.bind_info#
Used to get binding information when calling Display.bind_layer.
Syntax
vdec.bind_info(width=vdec_width, height=vdec_height, chn=0)
Parameter Name |
Input/Output |
Width of the decoded frame |
Input |
Height of the decoded frame |
Input |
chn |
Encoding output channel number |
Input |
Return Values
Return Value |
None |
Data Structure Description#
StreamData#
Stream structure containing decoded data and its timestamp information.
Definition
class StreamData:
def __init__(self):
self.data
self.pts
Members
Member Name |
data |
Stream data |
pts |
Timestamp info |
Example Program#
Example 1#
from media.display import *
STREAM_SIZE = 40960
def vdec_test(file_name, width=1280, height=720):
print("vdec_test start")
vdec_chn = VENC_CHN_ID_0
vdec_width = ALIGN_UP(width, 16)
vdec_height = height
vdec = None
vdec_payload_type = K_PT_H264
# display_type = Display.VIRT
display_type = Display.ST7701 # Use ST7701 LCD screen for output, max resolution 800*480
# display_type = Display.LT9611 # Use HDMI for output
# Determine file type
if suffix == '264':
elif suffix == '265':
vdec_payload_type = K_PT_H265
return
# Instantiate video decoder
vdec = vdecoder.Decoder(vdec_payload_type)
# Initialize display device
if display_type == Display.VIRT:
Display.init(display_type, width=vdec_width, height=vdec_height, fps=30)
Display.init(display_type, to_ide=True)
# Initialize buffer
# Create video decoder
vdec.create()
# Bind display
bind_info = vdec.bind_info(width=vdec_width, height=vdec_height, chn=vdec.get_vdec_channel())
Display.bind_layer(**bind_info, layer=Display.LAYER_VIDEO1)
vdec.start()
# Open file
with open(file_name, "rb") as fi:
# Read video data stream
data = fi.read(STREAM_SIZE)
if not data:
# Decode data stream
vdec.decode(data)
# Stop video decoder
vdec.stop()
# Destroy video decoder
vdec.destroy()
time.sleep(1)
# Close display
# Release buffer
print("vdec_test stop")
vdec_test("/sdcard/examples/test.264", 800, 480) # Decode H.264/H.265 video file
