LED Module API Manual#
The development board includes an RGB LED, which users can control the brightness of each color through the API.
API Introduction#
The LED class is located under the machine module.
Example#
from machine import LED
# Instantiate LED objects
red_led = LED("LED_RED")          # Or red_led = LED(1)
green_led = LED("LED_GREEN")      # Or green_led = LED(2)
blue_led = LED("LED_BLUE")        # Or blue_led = LED(3)
# Turn off all LEDs
blue_led.off()
green_led.off()
red_led.off()
    # Set the brightness of the green LED
    green_led.value(50)    # Brightness range is 0-255
    red_led.on()           # Turn on the red LED
    time.sleep_ms(250)
    green_led.value(200)   # Set the brightness of the green LED
    red_led.off()          # Turn off the red LED
    time.sleep_ms(250)
Constructor#
led = LED(id)
  • id: Identifier of the LED, 1 or “LED_RED” for the red LED; 2 or “LED_GREEN” for the green LED; 3 or “LED_BLUE” for the blue LED.
value Method#
led.value(val)
Controls the brightness of the LED.
  • val: Brightness level, ranging from 0 to 255.
on Method#
led.on()
Turns on the LED at maximum brightness.
off Method#
led.off()
Turns off the LED.
