CanMV-K230D Development Board
CanMV-K230D Development Board#
1. Overview#
The CanMV-K230D Zero development board is a collaborative design by Canaan Technology and the Banana Pi open-source hardware community. It features with the Kendryte K230D chip, equipped with a dual-core XuanTie C908 RISC-V CPU and an independently developed third-generation KPU (Neural Network Processing Unit). The board includes 128MB of LPDDR4 memory, providing robust support for high-performance local AI inference computing. With its comprehensive development resources and compact design, the CanMV-K230D Zero is well-suited for a wide range of DIY projects, AIoT (Artificial Intelligence of Things) devices, and embedded system applications. It is an ideal choice for programming education, AI-based audio and video innovation, and system performance evaluation, empowering users to embark on a journey of technological exploration.
Board Interface
2. Technical Specifications#
Parameter
CPU
Dual-core XuanTie C908 RISC-V CPU
- Core 1: 1.6GHz, supports RVV1.0
- Core 2: 800MHz
KPU
Third-generation Neural Network Processing Unit, supports multiple data types (e.g., INT8/INT16)
Typical performance: ResNet50 ≥ 85 fps@INT8, MobileNet_v2 ≥ 670 fps@INT8, YOLOv5s ≥ 38 fps@INT8
DPU
Integrated 3D structured light depth engine, supporting up to 1920×1080 resolution
VPU
Built-in H.264/H.265 hardware encoder and decoder
Video Input
Dual MIPI-CSI interfaces: 2-lane and 4-lane configurations
Display Output
MIPI DSI interface, supporting up to 1080P resolution
RAM
128MB LPDDR4 @ 2666Mbps
Storage
Onboard TF card slot, supporting up to 1TB
USB
One USB 2.0 port, supporting OTG functionality
Network
2.4GHz Wi-Fi module
Audio
Onboard audio input/output interface
GPIO Expansion
40-pin expandable GPIO, supports I2C, UART, I2S, SPI, PWM, ADC, JTAG, etc.
Buttons
One function button and one reset button
Power Supply
USB Type-C, 5V/2A input
Dimensions
65mm (Length) × 30mm (Width) × 7mm (Height)
3. Connection Diagram#
When using the BPI-CanMV-K230D Zero development board, connect two USB cables: one for power supply and the other for serial communication.
Connection Diagram
