FFT Module API Manual#
The FFT (Fast Fourier Transform) module is used to perform a Fourier transform on input time-domain data, converting it into frequency-domain data and returning the corresponding frequency magnitudes. Through FFT operations, time-domain signals can be effectively transformed into frequency-domain signals, facilitating the analysis of the signal’s frequency components.
API Introduction#
The FFT module provides an FFT class, supporting three main functions: run(), freq(), and amplitude(), which are used for performing Fast Fourier Transform, frequency calculation, and amplitude calculation, respectively.
Class machine.FFT#
This class is used to create an FFT object and perform the Fourier transform on the input data.
Syntax
from machine import FFT
import array
# Define time-domain data
data = array.array('i', [1, 2, 3, 4, 5, 6, 7, 8])
# Create an FFT object, perform a 64-point FFT operation, with an offset of 0
fft1 = FFT(data, 64, 0)
Parameter Name |
Type |
Input/Output |
Input time-domain data, of type |
Input |
Number of points for the FFT operation, supports 64, 128, 256, 512, 1024, 2048, and 4096 points. |
Input |
Data offset, default is 0. |
Input |
Return Values
Return Value |
Operation successful. |
Non-zero |
Operation failed. |
run() Method#
This function is used to obtain the frequency-domain data after the Fourier transform.
Syntax
res = fft1.run()
Return Values
Return Value |
Returns a |
freq() Method#
This function is used to obtain the calculated frequency values.
Syntax
res = FFT.freq(points, sample_rate)
Parameter Name |
Input/Output |
Number of points involved in the FFT operation. |
Input |
Data sampling rate. |
Input |
Return Values
Return Value |
Returns a list containing the frequency values for each frequency point. |
amplitude() Method#
This function is used to calculate the amplitude of each frequency point. It is mainly used for testing purposes, and users can write more complex amplitude processing functions in Python.
Syntax
amp = FFT.amplitude(FFT_res)
Parameter Name |
Input/Output |
The FFT calculation result returned by the |
Input |
Return Values
Return Value |
Returns a list containing the amplitude of each frequency point. |
