TOUCH Module API Manual#
The touch module is based on RTT’s touch framework and supports single-point and multi-point capacitive touch screens as well as resistive touch screens.
API Introduction#
The TOUCH class is located under the machine module.
Example
from machine import TOUCH
# Instantiate TOUCH device 0
tp = TOUCH(0)
# Get TOUCH data
p = tp.read()
print(p)
# Print touch point coordinates
# print(p[0].x)
# print(p[0].y)
# print(p[0].event)
Constructor#
# when index is 0
touch = TOUCH(index, type = TOUCH.TYPE_CST328, rotation = -1)
# when index is 1
touch = TOUCH(index, type = TOUCH.TYPE_CST328, rotation = -1, range_x = -1, range_y = -1, i2c : I2C = None, rst : Pin = None, int : Pin = None)
  • index: TOUCH device number. When 0, it indicates the use of the system’s built-in touch. When 1, it indicates the use of the CanMV-specific touch driver.
  • type: The touch driver type, refer to Touch Types for specific definitions.
  • rotation: The rotation of the panel output coordinates relative to the screen coordinates, range [0-3]. Refer to Coordinate Rotation for specific definitions.
  • range_x: Valid when index=1. The maximum width of the touch output coordinates.
  • range_y: Valid when index=1. The maximum height of the touch output coordinates.
  • i2c: Valid when index=1. The I2C bus object used for touch.
  • rst: Valid when index=1. The reset pin object for the touch device.
  • int: Valid when index=1. The interrupt pin object for the touch device, currently not supported.
read Method#
TOUCH.read([count])
Get touch data.
  • count: Maximum number of touch points to read, range [0:10], default is 0, which means to read all touch points.
Returns touch point data, type is a tuple ([tp[, tp...]]), where each tp is an instance of the touch_info class.
deinit Method#
TOUCH.deinit()
Release TOUCH resources.
TOUCH_INFO Class#
The TOUCH_INFO class is used to store information about touch points, which users can access through related read-only properties.
  • event: Event code, see Touch Events for details.
  • track_id: Touch point ID, used for multi-point touch.
  • width: Touch point width.
  • x: x-coordinate of the touch point.
  • y: y-coordinate of the touch point.
  • timestamp: Touch point timestamp.
Constants#
Touch Events#
  • EVENT_NONE: No event.
  • EVENT_UP: Touch released after pressing.
  • EVENT_DOWN: Touch started when pressed.
  • EVENT_MOVE: Touch moved after pressing.
Coordinate Rotation#
  • ROTATE_0: No rotation.
  • ROTATE_90: Rotate coordinates 90 degrees.
  • ROTATE_180: Rotate coordinates 180 degrees.
  • ROTATE_270: Rotate coordinates 270 degrees.
Touch device Type#
  • TYPE_CST128: System Drive Touch
  • TYPE_CST328: CanMV Drive Touch
  • TYPE_FT5x16: System Drive Touch
