2.10 SPI Module API Manual#
1. Overview#
The K230 integrates three SPI hardware modules internally, supporting chip select polarity configuration and adjustable clock rates. The I/O configuration for channel output can refer to the IOMUX module.
2. API Introduction#
The SPI class is located in the machine module.
2.1 Example Code#
from machine import SPI
# Initialize SPI with a clock rate of 5 MHz, polarity 0, phase 0, and data width of 8 bits
spi = SPI(id, baudrate=5000000, polarity=0, phase=0, bits=8)
# Send data to the slave device
spi.write(buf)
# Read data into a variable while sending data
spi.write_readinto(write_buf, read_buf)
# Close the SPI
spi.deinit()
2.2 Constructor#
spi = machine.SPI(id, baudrate=20, polarity=0, phase=0, bits=8)
id: SPI module ID, range [0~2] (corresponding tospi.SPI0tospi.SPI2).baudrate: SPI clock rate, calculated as ( F_{sclk_out} = \frac{F_{ssi_clk}}{BAUDR} ).polarity: Clock polarity.phase: Clock phase.bits: Data width.
2.3 read Method#
spi.read(nbytes)
Reads the specified number of bytes.
nbytes: Number of bytes to read.
Returns a bytes object.
2.4 readinto Method#
spi.readinto(buf)
Reads data into the specified buffer.
buf: A buffer of typebytearray.
2.5 write Method#
spi.write(buf)
Sends data.
buf: Data of typebytearray, defining the data to be sent and its length.
2.6 write_readinto Method#
Reads data into the specified variable while sending data.
write_buf: Data of typebytearray, defining the data to be sent and its length.read_buf: A buffer of typebytearrayto store the received data.
2.7 deinit Method#
spi.deinit()
Unregisters the SPI module.
