Sensor Module API Manual#
Attention
This module has undergone significant changes since firmware version V0.7. If you are using firmware prior to V0.7, please refer to the old version of the documentation.
The sensor module on the CanMV K230 platform is responsible for image acquisition and data processing. This module provides a set of advanced APIs, allowing developers to easily obtain images in different formats and sizes without needing to understand the specifics of the underlying hardware implementation. The architecture is shown in the diagram below:
camera-block-diagram
In the diagram, sensor 0, sensor 1, and sensor 2 represent three image input sensor devices; Camera Device 0, Camera Device 1, and Camera Device 2 correspond to the respective image processing units; output channel 0, output channel 1, and output channel 2 indicate that each image processing unit supports up to three output channels. Through software configuration, different sensor devices can be flexibly mapped to the corresponding image processing units.
The sensor module of the CanMV K230 supports simultaneous access of up to three image sensors, each of which can independently complete image data acquisition, capture, and processing. Additionally, each video channel can output three image data streams in parallel for further processing by backend modules. In practical applications, the number of supported sensors, input resolution, and the number of output channels are limited by the hardware configuration and memory size of the development board, so a comprehensive evaluation based on project requirements is necessary.
API Introduction#
Constructor#
Construct a Sensor object using csi id and image sensor type.
In image processing applications, users typically need to first create a Sensor object. The CanMV K230 software can automatically detect built-in image sensors without users needing to specify the exact model; they only need to set the sensor’s maximum output resolution and frame rate. For information on supported image sensors, please refer to the Image Sensor Support List. If the set resolution or frame rate does not match the current sensor’s default configuration, the system will automatically adjust to the optimal configuration, and the final configuration can be viewed in the log, e.g., use sensor 23, output 640x480@90.
Syntax
Parameter Name
Input/Output
Notes
id
csi port, supports 0-2, refer to hardware schematic for specific ports
Input
Optional, default values vary for different development boards
Maximum output image width of the sensor
Input
Optional, default 1920
Maximum output image height of the sensor
Input
Optional, default 1080
fps
Maximum output frame rate of the sensor
Input
Optional, default 30
Sensor Object
Sensor object
Examples
sensor = Sensor(id=0)
sensor.reset#
Reset the sensor object. After constructing the Sensor object, this function must be called to continue with other operations.
Syntax
sensor.reset()
Parameter Name
Input/Output
Examples
# Initialize sensor device 0 and sensor OV5647
sensor.reset()
sensor.set_framesize#
Set the output image size for the specified channel. Users can configure the output image size through the framesize parameter or by directly specifying width and height. Width will automatically align to 16 pixels wide.
Syntax
sensor.set_framesize(framesize=FRAME_SIZE_INVALID, chn=CAM_CHN_ID_0, alignment=0, **kwargs)
Parameter Name
Input/Output
framesize
Output image size of the sensor
Input
chn
Sensor output channel number
Input
Output image width, kw_arg
Input
Output image height, kw_arg
Input
Notes
  • The output image size must not exceed the actual output capability of the image sensor.
  • The maximum output image size of each channel is limited by hardware.
Examples
# Configure sensor device 0, output channel 0, output image size 640x480
# Configure sensor device 0, output channel 1, output image size 320x240
sensor.set_pixformat#
Configure the image format output by the image sensor for the specified channel.
Syntax
Parameter Name
Input/Output
pix_format
Output image format
Input
chn
Input
Examples
# Configure sensor device 0, output channel 0, output format NV12
# Configure sensor device 0, output channel 1, output format RGB888
sensor.set_hmirror#
Configure whether the image sensor performs horizontal mirroring.
Syntax
sensor.set_hmirror(enable)
Parameter Name
Input/Output
enable
True to enable horizontal mirroring
False to disable horizontal mirroring
Input
Examples
sensor.set_hmirror(True)
sensor.set_vflip#
Configure whether the image sensor performs vertical flipping.
Syntax
sensor.set_vflip(enable)
Parameter Name
Input/Output
enable
True to enable vertical flipping
False to disable vertical flipping
Input
Examples
sensor.set_vflip(True)
sensor.run#
Start the output of the image sensor. This must be done before calling MediaManager.init().
Syntax
sensor.run()
Notes
  • When using multiple sensors simultaneously (up to 3), only one of them needs to execute run.
Examples
# Start the sensor device output data stream
sensor.run()
sensor.stop#
Stop the output of the image sensor. This must be done before calling MediaManager.deinit().
Syntax
sensor.stop()
Notes
  • If multiple image sensors are used simultaneously (up to 3), each sensor must call stop individually.
Examples
# Stop the data stream output of sensor device 0
sensor.stop()
sensor.snapshot#
Capture a frame of image data from the specified output channel.
Syntax
sensor.snapshot(chn=CAM_CHN_ID_0)
Parameter Name
Input/Output
chn
Input
image object
Captured image data
other
Capture failed
Examples
# Capture a frame of image data from channel 0 of sensor device 0
sensor.snapshot()
Data Structure Description#
frame_size#
Image Frame Size
Resolution
QQCIF
88x72
QCIF
176x144
CIF
352x288
QSIF
176x120
SIF
352x240
QQVGA
160x120
QVGA
320x240
VGA
640x480
HQQVGA
120x80
HQVGA
240x160
HVGA
480x320
B64X64
64x64
B128X64
128x64
B128X128
128x128
B160X160
160x160
B320X320
320x320
QQVGA2
128x160
WVGA
720x480
WVGA2
752x480
SVGA
800x600
XGA
1024x768
WXGA
1280x768
SXGA
1280x1024
SXGAM
1280x960
UXGA
1600x1200
HD
1280x720
FHD
1920x1080
QHD
2560x1440
QXGA
2048x1536
WQXGA
2560x1600
WQXGA2
2592x1944
pixel_format#
Pixel Format
RGB565
16-bit RGB format
RGB888
24-bit RGB format
RGBP888
Separated 24-bit RGB
YUV420SP
Semi-planar YUV
GRAYSCALE
Grayscale image
channel#
Channel Number
CAM_CHN_ID_0
Channel 0
CAM_CHN_ID_1
Channel 1
CAM_CHN_ID_2
Channel 2
CAM_CHN_ID_MAX
Invalid channel
Image Sensor Support List#
Image Sensor Model
Resolution
Width x Height
Frame Rate
OV5647
2592x1944
10 FPS
1920x1080
30 FPS
1280x960
45 FPS
1280x720
60 FPS
640x480
90 FPS
GC2093
1920x1080
30 FPS
1920x1080
60 FPS
1280x960
60 FPS
1280x720
90 FPS
IMX335
1920x1080
30 FPS
2592x1944
30 FPS
