2.4 ADC Module API Manual#
1. Overview#
The K230 processor integrates an internal ADC (Analog-to-Digital Converter) hardware module, providing 6 independent channels. The module has a sampling resolution of 12 bits, meaning the output range is 0-4095, with a sampling rate of 1 MHz.
2. API Introduction#
The ADC class belongs to the machine module.
2.1 Example#
from machine import ADC
# Instantiate ADC channel 0
adc = ADC(0)
# Get the sampling value of ADC channel 0
print(adc.read_u16())
# Get the voltage value of ADC channel 0 (in microvolts)
print(adc.read_uv(), "uV")
2.2 Constructor#
adc = ADC(channel)
  • channel: Indicates the ADC channel number to use, ranging from [0, 5].
2.3 read_u16#
ADC.read_u16()
Function#
Gets the current sampling value of the specified channel.
Returns the sampling value of the ADC channel, ranging from [0, 4095].
2.4 read_uv#
ADC.read_uv()
Function#
Gets the current voltage value (in microvolts) of the specified channel.
Returns the voltage value of the ADC channel, in microvolts (uV), ranging from [0, 1800000] microvolts.
