2.18 SPI_LCD Module API Manual#
1. Overview#
The SPI_LCD module provides interfaces to interact with an LCD display through the SPI bus, including screen initialization, drawing, and text display operations.
2. API Introduction#
2.1 Constructor#
SPI_LCD(spi: SPI, dc: Pin, cs: Pin = None, rst: Pin = None, bl: Pin = None, type: int = SPI_LCD.ST7789)
Initializes an SPI_LCD object, creating a connection with the specified SPI bus and pins.
Parameters:
spi: SPI object for communication with the LCD.dc: Data/command control pin.cs: (Optional) Chip select pin. It is highly recommended to use softwareCS.rst: (Optional) Reset pin.bl: (Optional) Backlight pin.type: LCD type (e.g.,SPI_LCD.ST7789).
Returns:
SPI_LCDobject.
2.2 configure Method#
lcd.configure(width, height, hmirror=False, vflip=False, bgr=False)
Configures basic parameters for the LCD display.
Parameters:
width: Screen width.height: Screen height.hmirror: (Optional) Whether to enable horizontal mirroring, defaultFalse.vflip: (Optional) Whether to enable vertical flipping, defaultFalse.bgr: (optional) whether to enable BGR color format. WhenTrue, the screen will be set toBGR565. WhenFalse, the screen will be set toRGB565. The default value isFalse.
Returns:
No return value.
The module parameters must be configured before calling init.
2.3 init Method#
lcd.init(custom_command=False)
Initializes the LCD screen.
Parameters:
custom_command: (Optional) Whether to use custom initialization commands, defaultFalse. If set toTrue, initialization commands are not automatically sent.
Returns:
img:Imageobject, which users can use for drawing operations on the buffer.
2.4 command Method#
lcd.command(cmd, data)
Sends a command to the LCD.
Parameters:
cmd: The command to send.data: The data to transfer.
Returns:
No return value.
2.5 deinit Method#
lcd.deinit()
Shuts down and releases the LCD display.
Returns:
No return value.
2.6 Display Size Retrieval Methods#
lcd.width()
Retrieves the LCD width.
Returns:
Width value.
lcd.height()
Retrieves the LCD height.
Returns:
Height value.
2.7 Display Orientation and Properties#
lcd.hmirror()
lcd.vflip()
lcd.bgr()
These methods return whether horizontal mirroring, vertical flipping, and BGR color format are enabled.
Passing True or False as parameters will set the properties, while not passing parameters will return the current configuration.
2.8 get_direction Method#
lcd.get_direction()
Retrieves the current configuration of the direction register, usually 0x36.
Returns:
The value of the direction register.
2.9 Backlight Control#
lcd.light(value)
Sets the LCD backlight brightness.
Parameters:
value: Brightness value (0-100).
Returns:
No return value.
2.10 Pixel Operations#
lcd.get(x, y)
Retrieves the pixel value at the specified position.
lcd.set(x, y, color)
lcd.pixel(x, y, color)
Draws a pixel at the specified position.
Both get, set, and pixel operate on the Image returned by init, and you need to call show to display it on the screen.
Parameters:
x,y: The coordinates of the pixel.color: The color of the pixel.
Returns:
No return value.
2.11 Screen Fill#
lcd.fill(color)
Fills the entire screen with the specified color.
fill operates on the Image returned by init, and you need to call show to display it on the screen.
Parameters:
color: The fill color.
Returns:
No return value.
2.12 Image Display#
lcd.show(img=None, x=0, y=0)
lcd.show_image(img=None, x=0, y=0)
Displays an image on the LCD.
If no img is provided, it displays the internal image buffer.
Parameters:
img: (Optional) The image object to display.x: (Optional) The starting x-coordinate of the image.y: (Optional) The starting y-coordinate of the image.
Returns:
No return value.
3. LCD Type#
SPI_LCD.ST7789: 1, SPI 4 Line ST7789
4. Example Code#
4.1 Displaying Text on the Screen#
import time, image
from machine import FPIOA, Pin, SPI, SPI_LCD
fpioa = FPIOA()
fpioa.set_function(19, FPIOA.GPIO19)
pin_cs = Pin(19, Pin.OUT, pull=Pin.PULL_NONE, drive=15)
pin_cs.value(1)
fpioa.set_function(20, FPIOA.GPIO20)
pin_dc = Pin(20, Pin.OUT, pull=Pin.PULL_NONE, drive=15)
pin_dc.value(1)
fpioa.set_function(44, FPIOA.GPIO44, pu=1)
pin_rst = Pin(44, Pin.OUT, pull=Pin.PULL_UP, drive=15)
# spi
fpioa.set_function(15, fpioa.QSPI0_CLK)
fpioa.set_function(16, fpioa.QSPI0_D0)
spi1 = SPI(1, baudrate=1000*1000*50, polarity=1, phase=1, bits=8)
lcd = SPI_LCD(spi1, pin_dc, pin_cs, pin_rst)
lcd.configure(320, 240, hmirror=False, vflip=True, bgr=False)
print(lcd)
img = lcd.init()
print(img)
img.clear()
img.draw_string_advanced(0, 0, 32, "RED, Hello World~", color=(255, 0, 0))
img.draw_string_advanced(0, 40, 32, "GREEN, Hello World~", color=(0, 255, 0))
img.draw_string_advanced(0, 80, 32, "BLUE, Hello World~", color=(0, 0, 255))
lcd.show()
This example will display “Hello World~” in red, green, and blue on the screen.
