K230 Camera Sensor Adaptation Guide#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
preface#
This document describes the K230 platform Camera Sensor framework and how to add support for a new Camera Sensor.
Reader object#
Technical Support Engineer
Software Development Engineer
Definition of acronyms#
abbreviation |
illustrate |
Revision history#
Document version number |
Modify the description |
Author |
date |
Initial |
Wang Chenggen |
2023-05-30 |
1. Overview#
This document mainly describes the basic framework of the K230 platform Camera Sensor and how to add support for a new Camera Sensor.
The K230 platform supports a variety of interface types of sensors, and we take the most commonly used MIPI CSI interface Sensor as an example. The schematic diagram of the hardware connection between the sensor and the main control platform is as follows:
The master sends configuration registers through the I2C interface to control the working method of the sensor, and the sensor sends image data to the master SOC through the MIPI CSI interface.
2. Camera Sensor Framework#
2.1 Introduction to the framework#
The Camera Sensor framework is shown in Figure 2-1, and the lowest layer is the sensor driver layer
Figure 2-1 Camera sensor framework
From top to bottom: media interface layer, driver layer, and hardware layer
Media interface layer: This layer provides kd_mpi_sensor_xxx interfaces for external modules to operate and access sensor devices on the upper side, and operates specific sensor devices through IOCTL below
Driver layer: This layer includes the sensor’s common operating interface and the specific sensor device driver. The public operation interface is mainly IOCTL operation command and sensor I2C read and write interface, and the sensor driver mainly provides the implementation of device nodes and operation interface. This part is also the main work of sensor adaptation.
Hardware layer: corresponds to each specific sensor hardware
3. Sensor adaptation preparation#
Before adapting to a new sensor, users need to do the following preparations:
Get the Sensor datasheet from a formal channel, initialize the sequence.
View the Sensor datasheet and related application notes, with a particular focus on Sensor exposure, gain control methods, exposure and gain limitations in different modes, long exposure implementation methods, black level values, bayer data output sequences, and more.
Ask the Sensor manufacturer for the required mode initialization sequence, understand the data number rate of each sequence, the total width and height of the Sensor output, what is the exact frame rate, etc.
Confirm whether the Sensor control interface is I2C, SPI, or another interface, and the device address of the Sensor can be set through hardware. For scenarios with multiple cameras, the sensor tries not to multiplex the I2C bus. The Sensor IO level in different scenarios may be 1.8V or 3.3V, and the design needs to ensure that the IO level of the sensor is consistent with the GPIO supply voltage corresponding to the SOC. If the sensor level is 1.8V, GPIOs used for sensor control, such as Reset, I2C, PRDN, need to be powered by 1.8V.
Confirm that the Sensor outputs the data interface and protocol type. Currently, only the MIPI CSI interface is supported.
Confirm that wdr mode is VC, DT, or DOL.
Confirm whether image cropping is required for different timing.
4. Sensor adaptation example#
This section describes in detail how to add support for a new camera sensor.
The ov9732 driver is used as an example to illustrate, and the corresponding driver file source code path is as follows:
src/big/mpp/kernel/sensor/src/ov9732_drv.c
4.1 Define supported sensor types#
The sensor types supported by the system are defined by the following enumeration variables:
} k_vicap_sensor_type;
When the user needs to add a new sensor support type, he first needs to add the definition of the corresponding type here,which is the only sign for the application to obtain the sensor configuration
4.2 Sensor driver adaptation#
The sensor driver adaptation is the most important part of the whole process, and the user can modify it by copying the existing sensor driver file, in which the AE-related register configuration and calculation method of the sensor need to consult the corresponding manual or seek professional personnel assistance.
4.2.1 Define the list of sensor register configurations#
The sensor register configuration is defined by the data type k_sensor_reg_list:
k_u16 reg_addr;
k_u8 reg_val;
} k_sensor_reg_list;
The following is a list of register configurations for the OV9732
static k_sensor_reg_list ov9732_mipi2lane_720p_30fps_linear[] = {
{0x0103, 0x01},
{0x0100, 0x00},
{0x400b, 0xc0},
{REG_NULL, 0x00},
4.2.2 Define the modes supported by the sensor#
The mode parameter of the sensor is defined by the data type k_sensor_mode
k_u32 index;
k_sensor_size size;
k_u32 fps;
k_u32 hdr_mode;
k_u32 stitching_mode;
k_u32 bit_width;
k_u32 bayer_pattern;
k_sensor_mipi_info mipi_info;
k_sensor_ae_info ae_info;
k_sensor_reg_list *reg_list;
} k_sensor_mode;
The following are the supported modes for the OV9732
static k_sensor_mode ov9732_mode_info[] = {
.index = 2,
.sensor_type = OV_OV9732_MIPI_1280X720_30FPS_10BIT_LINEAR,
.size = {
.bounds_width = 1280,
.bounds_height = 720,
.top = 0,
.left = 0,
.width = 1280,
.height = 720,
.fps = 30000,
.bit_width = 10,
.bayer_pattern = BAYER_BGGR,
.mipi_info = {
.csi_id = 0,
.mipi_lanes = 1,
.data_type = 0x2B, //RAW10
.reg_list = ov9732_mipi2lane_720p_30fps_linear,
4.2.3 Implement the sensor operation interface#
The operation interface of the sensor is defined by the data type k_sensor_function, and the user implements the relevant operation interface according to the actual situation, and not all interfaces must be implemented.
} k_sensor_function;
.sensor_func = {
.sensor_power = ov9732_sensor_power_on,
.sensor_init = ov9732_sensor_init,
.sensor_get_chip_id = ov9732_sensor_get_chip_id,
.sensor_get_mode = ov9732_sensor_get_mode,
.sensor_set_mode = ov9732_sensor_set_mode,
.sensor_enum_mode = ov9732_sensor_enum_mode,
.sensor_get_caps = ov9732_sensor_get_caps,
.sensor_conn_check = ov9732_sensor_conn_check,
.sensor_set_stream = ov9732_sensor_set_stream,
.sensor_get_again = ov9732_sensor_get_again,
.sensor_set_again = ov9732_sensor_set_again,
.sensor_get_dgain = ov9732_sensor_get_dgain,
.sensor_set_dgain = ov9732_sensor_set_dgain,
.sensor_get_intg_time = ov9732_sensor_get_intg_time,
.sensor_set_intg_time = ov9732_sensor_set_intg_time,
.sensor_get_exp_parm = ov9732_sensor_get_exp_parm,
.sensor_set_exp_parm = ov9732_sensor_set_exp_parm,
.sensor_get_fps = ov9732_sensor_get_fps,
.sensor_set_fps = ov9732_sensor_set_fps,
.sensor_get_isp_status = ov9732_sensor_get_isp_status,
.sensor_set_blc = ov9732_sensor_set_blc,
.sensor_set_wb = ov9732_sensor_set_wb,
.sensor_get_tpg = ov9732_sensor_get_tpg,
.sensor_set_tpg = ov9732_sensor_set_tpg,
.sensor_get_expand_curve = ov9732_sensor_get_expand_curve,
.sensor_get_otp_data = ov9732_sensor_get_otp_data,
4.2.4 Define the sensor-driven structure#
The sensor driver structure is defined by struct sensor_driver_dev and mainly includes sensor I2C configuration information, sensor driver name, and sensor operation collection
struct sensor_driver_dev {
k_sensor_i2c_info i2c_info;
k_u8 *sensor_name;
k_sensor_mode *sensor_mode;
k_s32 pwd_gpio;
k_s32 reset_gpio;
The definition and initialization of the OV9732 driver structure are as follows:
struct sensor_driver_dev ov9732_sensor_drv = {
.i2c_info = {
.i2c_bus = NULL,
.i2c_name = "i2c1",
.slave_addr = 0x36,
.sensor_name = "ov9732",
.sensor_func = {
4.2.5 Update the sensor driver list#
Add the sensor-driven struct defined in the previous section to the sensor_drv_list array. The list of sensors supported by the current system is as follows:
struct sensor_driver_dev *sensor_drv_list[] = {
&ov9732_sensor_drv,
&ov9286_sensor_drv,
&imx335_sensor_drv,
4.3 Update the list of sensor configuration information#
The sensor configuration information is defined k_vicap_sensor_info structure:
const char *sensor_name; /*sensor name*/
const char *calib_file; /*sensor calibration file*/
k_u16 width; /*sensor width*/
k_u16 height; /*sensor height*/
k_vicap_csi_num csi_num; /*the csi num for sensor connected*/
k_vicap_mipi_lanes mipi_lanes; /*the mipi lanes for sensor connected*/
k_vicap_data_source source_id; /*source id*/
k_bool is_3d_sensor; /*3D sensor flag*/
k_vicap_mipi_phy_freq phy_freq; /*mipi phy freq*/
k_vicap_csi_data_type data_type; /*CSI data type*/
k_vicap_hdr_mode hdr_mode; /*HDR mode*/
k_vicap_vi_flash_mode flash_mode; /*flash mode*/
k_u16 glitch_filter;
k_vicap_sensor_type sensor_type; /*sensor type*/
} k_vicap_sensor_info;
The following is the corresponding configuration information of the OV9732:
"ov9732",
"ov9732",
1920,
1080,
VICAP_CSI0,
VICAP_MIPI_1LANE,
VICAP_SOURCE_CSI0,
K_FALSE,
VICAP_MIPI_PHY_800M,
VICAP_CSI_DATA_TYPE_RAW10,
VICAP_LINERA_MODE,
VICAP_FLASH_DISABLE,
VICAP_VI_FIRST_FRAME_FS_TR0,
0,
OV_OV9732_MIPI_1920X1080_30FPS_10BIT_LINEAR
Each time the user adds a sensor configuration mode, he needs to add a corresponding mode configuration to the sensor_info_list structure.
4.4 Add sensor configuration file#
The current SDK version sensor configuration file includes XML files and JSON files, and the file storage path is as follows:
The following is the corresponding configuration file for ov9732:
ov9732.xml ov9732_auto.json ov9732_manual.json
For newly added sensors, support can be achieved by copying and modifying existing files, and the calibration and tuning parameters can be modified and exported through related tools.
