K230 SDK Release Notes#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
preface#
This document mainly describes the content related to the release of K230 SDK V1.2.0, including the hardware, features, and usage restrictions supported by the current version.
Reader object#
  • Technical Support Engineer
Definition of acronyms#
Abbreviation
Illustrate
K230 USIP LP3 EVB
The K230 chip in the USIP package is equipped with an LPDDR3 development board
EXPIRES
Video Encoder, a video coding module
VDEC
Video Decoder, a video decoding module
VICAP
Video Input Capture, an image input acquisition module
IN
Video Output, a video output module
.AI
Audio Input, the audio input module
TO
Audio Output, the audio output module
AENC
Audio Encoder, an audio coding module
ADEC
Audio Decoder, an audio decoding module
NonAI-2D
2D graphics acceleration processing module, support OSD overlay, picture frame, CSC transformation and other functions.
MCM
Multi Camera Management
Revision history#
Document version number
Modify the description
Author
date
Initial
System Software Department
2023-11-8
1. Version Information#
Affiliated products
Version number
Release date
K230 SDK
V1.2.0
2023-11-8
2. Supported hardware#
The K230 platform supports K230 USIP LP3 EVB, CanMV-K230 and other motherboards, and the specific hardware information is referred to the document directory:00_hardware.
3. Description of Version Usage Restrictions#
The following figure shows the memory layout of the current SDK USIP LP3 EVB and CanMV-K230:
EVB
Figure 1 SDK memory layout
You can configure the memory interval of each module by entering selection in the k230_sdk directorymake menuconfig``Memory->Configuration, and configuration is not supported at this time Memory configuration of parameter areas and intercore communication areas
4. Version function statistics#
4.1 Multimedia#
ID
Supported versions
Functional overview
Feature description
remark
K230 SDK V0.5
EXPIRE
H264/H265/JPEG encoding
K230 SDK V0.5
vdec
H264/H265/JPEG decoding
3
K230 SDK V0.5
Vicap Bind Venc
The vicap input is bound to the venc output
4
K230 SDK V0.5
vdec bind vo
VDEC is bound to VO output images
5
K230 SDK V0.5
venc_2d
OSD encoding after superposition
6
K230 SDK V0.5
nonai_2d
OSD overlay
7
K230 SDK V0.5
I2S audio input
Sampling accuracy (16/24/32), sampling rate (8K-192K), timestamp (US), two-channel, sample point per frame can be configured.
8
K230 SDK V0.5
PDM audio input
Sampling accuracy (16/24), sampling rate (8K-192K), oversampling (32/64/128), single and double channels, timestamp (US), sampling points per frame can be configured.
9
K230 SDK V0.5
I2S audio output
Sampling accuracy (16/24/32), sampling rate (8K-192K), two-channel, sample point per frame can be configured.
K230 SDK V0.5
Internal Audio Codec
Support ADC, DAC, sampling accuracy (16/24), sampling rate (8K-192K)
11
K230 SDK V0.5
ai(i2s) bind ao(i2s)
AI binds AO, and I2S audio is collected to I2S audio output loopback
12
K230 SDK V0.5
ai(pdm) bind ao(i2s)
AI binds AO, PDM audio acquisition to I2S audio output loopback
13
K230 SDK V0.6
EXPIRE
Multicode, rotate and mirror
14
K230 SDK V0.6
venc_2d
Picture frame
15
K230 SDK V0.6
venc MAPI
VI->VENC-> little core storage file
16
K230 SDK V0.6
aenc
Audio coding, built-in G711A/U
17
K230 SDK V0.6
ADEC
Audio decoding, built-in G711A/U
18
K230 SDK V0.6
AI bind aenc
AI binds AENC to collect encoded data
19
K230 SDK V0.6
adec bind to the
ADEC binds to the AO and plays the output decoded audio
20
K230 SDK V0.6
audio 3a
AEC (Echo Cancellation), ANS (Noise Suppression), AGC (Automatic Gain)
21
K230 SDK V0.7
Venc GOP
Support setting encoding GOP
22
K230 SDK V0.7
venc mirror
Support setting encoding horizontal and vertical flipping
23
K230 SDK V0.7
Venc IDR
Support encoded IDR frames funciton:enable/disable
24
K230 SDK V0.7
venc multi channel
mapi_venc_2 H264 encoding
25
K230 SDK V0.7
audio i2s mapi
MAPI-audio_i2S captures audio encoding and passes it to the big core
26
K230 SDK V0.7
Audio enc mapi
Mapi-audio_ little core encoding files are passed to big core for decoding and playback
27
K230 SDK V0.7
audio volume
Added built-in audio codec digital and analog volume control interfaces.
28
K230 SDK V0.7
Mapi rtsp
MAPI-Network Transmission-RTSP audio and video streaming
29
K230 SDK V0.8
MAPI VDEC
The small-core video encoding file is transmitted to the large-core to be decoded and played
30
K230 SDK V0.8
venc mpi
31
K230 SDK V0.8
VDEC MPI
Support down scale
32
K230 SDK V0.8
DPU Demo
Screen depth map: vicap->dma->dpu->vo
32
K230 SDK V0.8
Voice intercom demo
Add a voice intercom demo
33
K230 SDK V0.9
Peephole POC
Remote peephole realizes video intercom, voice change, video, humanoid detection and capture functions.
34
K230 SDK V1.0
Peephole POC
1. Add UI control on the peephole device. 2. Add local peephole voice intercom function. 3. The mobile phone recording function is changed to the device side implementation, and it is always recording. 4. Add playback function on the peephole device.
35
K230 SDK V1.2
Peephole POC
nor flash boot up
4.2 Images#
ID
Supported versions
Functional overview
Feature description
remark
K230 SDK V0.5
Vicap
Support capture sensor image (OV9732, OV9286)
K230 SDK V0.5
AE
AE auto exposure is supported
3
K230 SDK V0.5
Vicap Bind VO
vicap is bound to the VO output image
4
K230 SDK V0.5
GPU drawing
Vector drawing fills (straight line, quadratic Bezier curve, cubic Bezier curve, elliptic curve) Linear gradient Color lookup table Image compositing/blending, BLIT
5
K230 SDK V0.5
Image tuning
tuning tool which Connect the development board through the network and serial port for image optimization. Black level correction lens shading correction color calibration AWB CAC gamma
6
K230 SDK V0.5
display bind
VO and VICAP, VO and VDEC bindings are supported
7
K230 SDK V0.5
display display
Support OSD and YUV display, support dump frame function, support DSI and VO timing, can be configured, support interpolation frame function
8
K230 SDK V0.6
Image tuning
The tuning tool configures the sensor register
9
K230 SDK V0.6
Timestamp, frame number
Supports timestamp and frame number
K230 SDK V0.6
ISP+KPU Demo
Face detection demo
11
K230 SDK V0.7
dewarp
Add the dewarp function to achieve distortion correction
12
K230 SDK V0.7
AE Side
Added FaceAE function and corresponding FaceAE demo
13
K230 SDK V0.7
Add Imx335
Add Imx335 sensor driver and demo
14
K230 SDK V0.8
Add DRM
Linux little core adds DRM driver and demo
15
K230 SDK V0.8
Add LVGL
Linux little core adds LVGL and demo
16
K230 SDK V0.8
Launch the APP quickly
Quick Start APP Sensor changed to Imx335 (with crystal oscillator)
17
K230 SDK V0.9
mcm
Supports up to three sensors
18
K230 SDK V0.9
display mapi
Add the video output class MAPI
19
K230 SDK V1.0
Debug-Dump sensor raw
Support for dump sensor RAW data
20
K230 SDK V1.0
Commissioning - frame count statistics
Support total input and output frame count function
21
K230 SDK V1.0
dewarp split-screen
Support 2, 4 split screen output
22
K230 SDK V1.0
HDR
Support HDR function, support Imx335 2dol HDR
23
K230 SDK V1.1
MAPI
Add vicap’s MAPI
24
K230 SDK V1.1
HDR frequency conversion
Supports HDR frequency conversion
25
K230 SDK V1.1
Parameter export
Support ISP Dewarp parameter export
26
K230 SDK V1.2
Add Dictionary Pen POC
4.3 Platform#
ID
Supported versions
Functional overview
Feature description
remark
K230 SDK V0.5
Start the peripheral
Support eMMC, 1/4-wire SD card
K230 SDK V0.5
big core DPU driver
Image input and output driver development, basic functions, EG reading parameters, support dynamic update of long-period parameters, output buffer, timestamp, algorithm, etc. Support pipeline binding
3
K230 SDK V0.5
little core UBOOT
DDR training, disk drive (emmc, sd, spi 1 line); Supports PUFS and gzip decompression
4
K230 SDK V0.5
little core SPI driver
1 line
5
K230 SDK V0.5
little core SDIO driver
SDIO0/1 is supported to mount SDCard
6
K230 SDK V0.5
Small-core USB (UVC) driver
Support UVC driver (K230 chip as slave)
7
K230 SDK V0.5
Small-core GPIO drivers
Supports separate allocation of each IO as a logical resource; Supports IO and interrupts
8
K230 SDK V0.5
little core disks and file systems
Support SDIO0/1 to mount SDCard, support SDIO0/1 to mount eMMC; Supports ext2/3/4, FAT32 file systems
9
K230 SDK V0.5
I2C driver
Large and little core I2C bus driver
K230 SDK V0.5
UART driven
Large and little core UART drivers
11
K230 SDK V0.5
UVC basic demo
UVC Camera, which uses the board as a camera
12
K230 SDK V0.5
GSDMA (Big Core Drive)
Support using gdma for image migration, configure channel properties to achieve image rotation and mirroring, transport multiple image formats (such as YUV400, YUV420, YUV444), move images with multiple pixel widths (such as 8bit, 10bit, 16bit); Support data migration using SDMA, support 1D mode and 2D mode handling. Support pipeline binding.
13
K230 SDK V0.6
Large-core GPIO drivers
Supports independent configuration and use of IO functions, independent configuration and triggering interrupts, and hardware mutexes are added to ensure the mutex of register access.
14
K230 SDK V0.6
Support SPI nor Flash image generation and startup
15
K230 SDK V0.6
uboot SPI norflash driver
Supports 8-wire DMA
16
K230 SDK V0.6
big core ADC drive
Allows the ADC to read voltage values
17
K230 SDK V0.7
Large and little core WDT drivers
Support for watchdog reset SoC
18
K230 SDK V0.7
big core SPI driver
Support SPI single-wire mode, support NANDFLASH
19
K230 SDK V0.7
Support SPI single-wire, eight-wire mode, support NordFlash
20
K230 SDK V0.7
Quick-up feature
The SDK defaults to fast starting, and non-fast versions can turn off CONFIG_QUICK_BOOT macros through make menuconfig. The fast version uboot will not enter the command line.
21
K230 SDK V0.7
Secure mirroring
The SDK does not generate a secure image by default, and you can configure the CONFIG_GEN_SECURITY_IMG to generate a secure image by making menuconfig
22
K230 SDK V0.7
UVC basic demo
Added support for H264 format, there is currently a bug, can only run for a while
23
K230 SDK V0.7
DPU、GSDMA
The number of buffers is configurable
24
K230 SDK V0.8
big core timer、rtc、pwm
The big core adds timer driver and demo; the big core adds the PWM driver and demo; and the big core adds the RTC driver and demo.
25
K230 SDK V0.8
SPI NAND support
The little core (uboot, Linux) supports 4-wire SPI NAND driver, and the SDK supports booting from Spiron;
26
K230 SDK V0.8
UVC basic demo
UVC supports IMX335 camera, UVC supports MJPEG format
27
K230 SDK V0.8
spinor adds parameter partitioning such as face characteristics
SPI NOR adds parameter partitions such as face features, AI models, calibration parameters, big core apps, speckles, and quick-start parameters; when booting from Spinor, uboot parses and loads the data of each partition.
28
K230 SDK V0.9
little core PWM driver
Supports little core PWM drivers
29
K230 SDK V0.9
little core ADC drive
Supports small-core ADC driving
30
K230 SDK V0.9
Support K230D development board
SDK support K230D development board (SD card boot)
31
K230 SDK V0.9
STING
Support OTA upgrade
32
K230 SDK V1.0
Large nuclear FFT
Support FFT driver
33
K230 SDK V1.0.1
Support CanMV-K230 development board
SDK support CanMV-K230 development board (SD card boot)
34
K230 SDK V1.1
little core Wifi driver
The little core supports AP6256 drivers
35
K230 SDK V1.1
little core three-color lamp driven
The little core supports the I2S interface WS2812 driver
35
K230 SDK V1.1
little core SPI LCD driver
The little core supports SPI interface ST7735S 0.96 inch LCD screen driver
36
K230 SDK V1.1
BurnTool Burning Tool V2
Delete the full image burning page and add loader_sip.bin support for SIP burning, see K230_SDK_Burntool User Guide.md for details
37
K230 SDK V1.1
USB port use
USB1 is fixed in host mode, which can be connected to peripherals such as USB-ETH or U disk, and EVB’s J5 pin pin 3 is connected to pin4 jumper cap to enable power supply to peripherals. USB0 is used for USB gadget testing and USB upgrades, and EVB’s J5 pin headers, pins 1 and pin2, are no longer connected using jumper caps.
38
K230 SDK V1.2
canmv wifi ap6212
canmv support ap6212
39
K230 SDK V1.2
canmv only linux
add k230_canmv_only_linux_defconfig config
40
K230 SDK V1.3
debian ubuntu image
add debian and ubuntu image
4.4 Architecture#
ID
Supported versions
Functional overview
Feature description
remark
K230 SDK V0.5
Multimedia memory management
Multimedia area memory management driver, MPI, MAPI; video buffer pool driver, MPI, MAPI
K230 SDK V0.5
Log management
Multimedia log management driver, MPI, MAPI
3
K230 SDK V0.5
System binding
Multimedia system binding driver, MPI
4
K230 SDK V0.5
Large-core multimedia debugging
The proc file system is provided for debugging
5
K230 SDK V0.5
Internuclear communication
Internuclear communication drive
6
K230 SDK V0.5
Internuclear control communication
IPCMSG library
7
K230 SDK V0.5
Internuclear data communication
DATAFIFO library
8
K230 SDK V0.5
Shared file system
hlutabréf
The little core is the server, and the big core is the client
9
K230 SDK V0.5
System control
Large and little core clock power supply and reset drive
K230 SDK V0.5
KPU
KPU driven
11
K230 SDK V0.5
big core system debugging
JTAG debugging, local serial port, CPU usage statistical analysis, etc
12
K230 SDK V0.5
Small-core system debugging
JTAG debugging, serial port debugging, network port debugging, CPU usage statistical analysis, performance debugging methods, debugging and log output ports (physical serial ports), kernel and exception information output, dump, debug version
Perf is not configured into the kernel and buildroot by default
13
K230 SDK V0.7
Software SHA256
The SHA256 software implementation is added under the large-core MPP
14
K230 SDK V0.7
OTP read and write function
The OTP read and write function is added to the large-core rt-smart, and the OTP read function is added to the small-core Linux
15
K230 SDK V0.7
Tsensor read function
Tsensor read function is added to the large-core rt-smart, and Tsensor read function is added to the small-core Linux to read the chip junction temperature
16
K230 SDK V0.7
TRNG read function
Added TRNG read function in small-core Linux
17
K230 SDK V0.7
quickly demo
Add a big core to quickly launch the face detection demo
18
K230 SDK V0.7
PMU function
Add PMU standby and wake-up functions for small-core Linux
19
K230 SDK V0.8
Door lock POC
The big core adds POC door lock function, and the little core adds UI function, and the face is registered and recognized through the UI interface or SD card
20
K230 SDK V0.9
Door lock POC
Support ov9286, face detection and recognition (including IR and speckle live, speckle including DPU deep extraction)
21
K230 SDK V0.9
Encryption and decryption
Adds AES-GCM encryption and decryption for small-core Linux
22
K230 SDK V0.9
Power control
uboot adds chip clock/power domain management, big core rt-smart adds power control for CPU1, DPU, VPU, KPU, display, and little core Linux adds power control for display
23
K230 SDK V1.0
Door lock POC
Add the function of scanning and decrypting facial feature values
24
K230 SDK V1.0
SH256 drive
Added SH256 driver for large and little core hardware
25
K230 SDK V1.1
big core encryption and decryption driver
Added big core hardware AES-GCM driver and SM4-ECB/CBC/CFB/OFB/CTR driver
26
K230 SDK V1.2
Door lock OTA
Add Door lock OTA
4.5 Miscellaneous#
ID
Supported versions
Functional overview
Feature description
remark
K230 SDK V0.5
to the demos
Provide three AI demos door_lock, object_detect, and image_classify;
K230 SDK V0.5
AiW4211LV10 WiFi driver
Support network data communication; support control command sending;
3
K230 SDK V0.6
AiW4211LV10 WiFi firmware
Firmware compatible with instructions and network configuration, support network connection reconnection, support K230 level monitoring and wake-up
4
K230 SDK V0.6
Touch screen support
5
K230 SDK V0.7
Software image
SDK compilation will generate demo executables, but will not be packaged into images by default, and security image files will not be generated by default, so you can configure them manually
6
K230 SDK V0.7
Toolchain
The big core toolchain version is updated to: riscv64-unknown-linux-musl-rv64imafdcv-lp64d-20230420.tar.bz2
7
K230 SDK V0.8
Software image
When the EMMC/SDCARD image is packaged, the demos of the big core will be packaged into the little core/sharefs
8
K230 SDK V0.8
Demo
In order to adapt to different camera modules and modify the relevant demo, such as encoding/UVC, the specific use of the demo can be found in the “K230 SDK Demo User Guide”
5. Legacy issues and limitations of the version#
ID
Function modules
Problem/limitation description
remark
VPU encoding
VPU repeats the code many times and is probabilistic stuck
usb
Transporting H264 encoding over USB for a long time is abnormal
3
Peephole
During the operation of the simulated mobile phone, the network cannot be automatically reconnected after it is disconnected
