K230 SHA256 API Reference#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
This document mainly introduces the use of K230 SHA256 software, including the use of SHA256 API and test procedures.
Reader Object#
Technical Support Engineer
Software Development Engineer
Definition of Acronyms#
abbreviation |
illustrate |
SHA256 |
Secure Hash Algorithm |
Document version number |
Modify the description |
Author |
date |
Initial edition |
Yang Fan |
2023-05-30 |
1. Function Introduction#
SHA256 is mainly used to calculate the hash value of data, and the SHA256 algorithm is implemented in the big core rt-smart to calculate the hash value of data, and the code logic is shown in the following figure:
2. API Reference#
The SHA256 module mainly provides the following APIs:
2.1 kd_mpi_cipher_sha256#
【Description】
Calculates the hash value of the message based on the incoming message.
【Syntax】
【Parameters】
Parameter name |
description |
Input/output |
data |
Incoming messages |
input |
only |
The length of the incoming message |
input |
hash |
The calculated hash value |
output |
【Return value】
Return value |
description |
Succeed. |
Non-0 |
Failed, refer to Error Code Definition |
【Differences】
【Requirement】
Header file: mpi_cipher_api.h
Library file: libcipher.a
【Note】
【Example】
【See Also】
3. Debugging and Printing Information#
Write a user-mode application sample_cipher.c to test SHA256 functionality.
The test code has been written, located in the mpp/userapps/sample/sample_cipher directory, the specific debugging method is as follows:
After the big core starts, go to the bin directory;
Run the sample_cipher.elf program;
Print the information.
The specific printing information is as follows:
msh />cd bin/
msh /bin>./sample_cipher.elf
input = ''
result: PASS
input = 'abc'
result: PASS
result: PASS
result: PASS
result: PASS
result: PASS
