K230 nncase Development Guide#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
preface#
This document is the K230 nncase user description document, providing users with how to install nncase, how to call compiler APIs to compile neural network models and runtime APIs to write AI inference programs.
Reader object#
Technical Support Engineer
Software Development Engineer
Definition of acronyms#
abbreviation |
description |
PTQ |
Post-training quantization |
MSE |
mean-square error |
Revision history#
Document version number |
Modify the description |
Author |
date |
First version of the document |
Yang Zhang/Chenghai Huo |
2023/4/7 |
V1.1 |
Uniformly change to word format, improve AI2D |
2023/5/5 |
V1.2 |
New architecture for nncase v2 |
Yang Zhang/Qihang Zheng/Chenghai Huo |
2023/6/2 |
V1.3 |
nncase_k230_v2.1.0, ai2d/runtime_tensor supports physical addresses |
Yang Zhang |
2023/7/3 |
1. Overview#
1.1 What is nncase#
nncase is a neural network compiler designed for AI accelerators, and currently supports targets such as CPU/K210/K510/K230.
Features provided by nncase
Support multiple-input multiple-output network, support multi-branch structure
Static memory allocation, no heap memory required
Operator merging and optimization
Supports float and uint8/int8 quantized inference
Supports post-training quantization, using floating-point models and quantization calibration sets
Flat model with zero-copy loading
Neural network model formats supported by nncase
tflite
onnx
1.2 nncase architecture#
The nncase software stack consists of two parts: compiler and runtime.
Compiler: Used to compile a neural network model on a PC and finally generate a kmodel file. It mainly includes importer, IR, Evaluator, Quantize, Transform optimization, Tiling, Partition, Schedule, Codegen and other modules.
Importer: Import models from other neural network frameworks into nncase
IR: Intermediate representation, divided into Neutral IR imported by importer (device-independent) and Target IR (device-dependent) generated by Neutral IR through lower conversion
Evaluator: Evaluator provides IR interpretation execution capabilities and is often used in scenarios such as Constant Folding/PTQ Calibration
Transform: Used for IR conversion and graph traversal optimization, etc
Quantize: Quantize after training, add quantization tags to the tensor to be quantized, call Evaluator to interpret and execute according to the input correction set, collect the data range of tensor, insert quantization/dequantization nodes, and finally optimize to eliminate unnecessary quantization/dequantization nodes
Tiling: Limited by the low memory capacity of NPU, large chunks of computation need to be split. In addition, selecting the Tiling parameter when there is a large amount of data multiplexing will affect the delay and bandwidth
Partition: Divide the graph according to ModuleType, each subgraph after splitting will correspond to the RuntimeModule, and different types of RuntimeModule will correspond to different Devices (cpu/K230)
Schedule: Generates a calculation order and allocates Buffers based on data dependencies in the optimized graph
Codegen: Call the codegen corresponding to ModuleType for each subgraph to generate a RuntimeModule
Runtime: Integrated in the user app, it provides functions such as loading kmodel/setting input data/KPU execution/obtaining output data.
1.3 Development Environment#
1.3.1 Operating System#
Supported operating systems include Ubuntu 18.04/Ubuntu 20.04
1.3.2 Software Environment#
serial number |
Software |
Version number |
1 |
python |
3.6/3.7/3.8/3.9/3.10 |
2 |
pip |
>=20.3 |
3 |
numpy |
1.19.5 |
4 |
onnx |
1.9.0 |
5 |
onnx-simplifier |
0.3.6 |
6 |
Onnxoptimizer |
0.2.6 |
7 |
Onnxruntime |
1.8.0 |
8 |
dotnet-runtime |
7.0 |
1.3.3 Hardware Environment#
K230 evb
2. Compiling Model APIs (Python)#
nncase provides Python APIs for compiling neural network models on a PC
2.1 Supported operators#
2.1.1 tflite arithmetic#
Operator |
Is Supported |
ABS |
Yes |
ADD |
Yes |
ARG_MAX |
Yes |
ARG_MIN |
Yes |
AVERAGE_POOL_2D |
Yes |
BATCH_MATMUL |
Yes |
CAST |
Yes |
CEIL |
Yes |
CONCATENATION |
Yes |
CONV_2D |
Yes |
COS |
Yes |
CUSTOM |
Yes |
DEPTHWISE_CONV_2D |
Yes |
DIV |
Yes |
EQUAL |
Yes |
EXP |
Yes |
EXPAND_DIMS |
Yes |
FLOOR |
Yes |
FLOOR_DIV |
Yes |
FLOOR_MOD |
Yes |
FULLY_CONNECTED |
Yes |
GREATER |
Yes |
GREATER_EQUAL |
Yes |
L2_NORMALIZATION |
Yes |
LEAKY_RELU |
Yes |
LESS |
Yes |
LESS_EQUAL |
Yes |
LOG |
Yes |
LOGISTIC |
Yes |
MAX_POOL_2D |
Yes |
MAXIMUM |
Yes |
MEAN |
Yes |
MINIMUM |
Yes |
MUL |
Yes |
NEG |
Yes |
NOT_EQUAL |
Yes |
PAD |
Yes |
PADV2 |
Yes |
MIRROR_PAD |
Yes |
PACK |
Yes |
POW |
Yes |
REDUCE_MAX |
Yes |
REDUCE_MIN |
Yes |
REDUCE_PROD |
Yes |
RELU |
Yes |
PRELU |
Yes |
RELU6 |
Yes |
RESHAPE |
Yes |
RESIZE_BILINEAR |
Yes |
RESIZE_NEAREST_NEIGHBOR |
Yes |
ROUND |
Yes |
RSQRT |
Yes |
SHAPE |
Yes |
SIN |
Yes |
SLICE |
Yes |
SOFTMAX |
Yes |
SPACE_TO_BATCH_ND |
Yes |
SQUEEZE |
Yes |
BATCH_TO_SPACE_ND |
Yes |
STRIDED_SLICE |
Yes |
SQRT |
Yes |
SQUARE |
Yes |
SUB |
Yes |
SUM |
Yes |
TANH |
Yes |
TILE |
Yes |
TRANSPOSE |
Yes |
TRANSPOSE_CONV |
Yes |
QUANTIZE |
Yes |
FAKE_QUANT |
Yes |
DEQUANTIZE |
Yes |
GATHER |
Yes |
GATHER_ND |
Yes |
ONE_HOT |
Yes |
SQUARED_DIFFERENCE |
Yes |
LOG_SOFTMAX |
Yes |
SPLIT |
Yes |
HARD_SWISH |
Yes |
2.1.2 ONNX arithmetic#
Operator |
Is Supported |
Abs |
Yes |
Acos |
Yes |
Acosh |
Yes |
And |
Yes |
ArgMax |
Yes |
ArgMin |
Yes |
Asin |
Yes |
Asinh |
Yes |
Add |
Yes |
AveragePool |
Yes |
BatchNormalization |
Yes |
Cast |
Yes |
Ceil |
Yes |
Celu |
Yes |
Clip |
Yes |
Compress |
Yes |
Concat |
Yes |
Constant |
Yes |
ConstantOfShape |
Yes |
Conv |
Yes |
ConvTranspose |
Yes |
Cos |
Yes |
Cosh |
Yes |
CumSum |
Yes |
DepthToSpace |
Yes |
DequantizeLinear |
Yes |
Div |
Yes |
Dropout |
Yes |
Elu |
Yes |
Exp |
Yes |
Expand |
Yes |
Equal |
Yes |
Erf |
Yes |
Flatten |
Yes |
Floor |
Yes |
Gather |
Yes |
GatherElements |
Yes |
GatherND |
Yes |
Gemm |
Yes |
GlobalAveragePool |
Yes |
GlobalMaxPool |
Yes |
Greater |
Yes |
GreaterOrEqual |
Yes |
GRU |
Yes |
Hardmax |
Yes |
HardSigmoid |
Yes |
HardSwish |
Yes |
Identity |
Yes |
InstanceNormalization |
Yes |
LayerNormalization |
Yes |
LpNormalization |
Yes |
LeakyRelu |
Yes |
Less |
Yes |
LessOrEqual |
Yes |
Log |
Yes |
LogSoftmax |
Yes |
LRN |
Yes |
LSTM |
Yes |
MatMul |
Yes |
MaxPool |
Yes |
Max |
Yes |
Min |
Yes |
Mul |
Yes |
Neg |
Yes |
Not |
Yes |
OneHot |
Yes |
Pad |
Yes |
Pow |
Yes |
PRelu |
Yes |
QuantizeLinear |
Yes |
RandomNormal |
Yes |
RandomNormalLike |
Yes |
RandomUniform |
Yes |
RandomUniformLike |
Yes |
ReduceL1 |
Yes |
ReduceL2 |
Yes |
ReduceLogSum |
Yes |
ReduceLogSumExp |
Yes |
ReduceMax |
Yes |
ReduceMean |
Yes |
ReduceMin |
Yes |
ReduceProd |
Yes |
ReduceSum |
Yes |
ReduceSumSquare |
Yes |
Relu |
Yes |
Reshape |
Yes |
Resize |
Yes |
ReverseSequence |
Yes |
RoiAlign |
Yes |
Round |
Yes |
Rsqrt |
Yes |
Selu |
Yes |
Shape |
Yes |
Sign |
Yes |
Sin |
Yes |
Sinh |
Yes |
Sigmoid |
Yes |
Size |
Yes |
Slice |
Yes |
Softmax |
Yes |
Softplus |
Yes |
Softsign |
Yes |
SpaceToDepth |
Yes |
Split |
Yes |
Sqrt |
Yes |
Squeeze |
Yes |
Sub |
Yes |
Sum |
Yes |
Tanh |
Yes |
Tile |
Yes |
TopK |
Yes |
Transpose |
Yes |
Trilu |
Yes |
ThresholdedRelu |
Yes |
Upsample |
Yes |
Unsqueeze |
Yes |
Where |
Yes |
2.2 APIs#
Currently, the compiled model APIs support deep learning models in TFLITE/ONNX/Caffe and other formats.
2.2.1 CompileOptions#
【Description】
The CompileOptions class, which configures nncase compilation options
【Definition】
class CompileOptions:
benchmark_only: bool
dump_asm: bool
dump_dir: str
dump_ir: bool
swapRB: bool
input_range: List[float]
input_shape: List[int]
input_type: str
is_fpga: bool
mean: List[float]
std: List[float]
output_type: str
preprocess: bool
quant_type: str
target: str
w_quant_type: str
use_mse_quant_w: bool
input_layout: str
output_layout: str
letterbox_value: float
tcu_num: int
def __init__(self) -> None:
self.benchmark_only = False
self.dump_asm = True
self.dump_dir = "tmp"
self.dump_ir = False
self.is_fpga = False
self.quant_type = "uint8"
self.target = "cpu"
self.w_quant_type = "uint8"
self.use_mse_quant_w = True
self.tcu_num = 0
self.preprocess = False
self.swapRB = False
self.input_range = []
self.input_shape = []
self.input_type = "float32"
self.mean = [0, 0, 0]
self.std = [1, 1, 1]
self.input_layout = ""
self.output_layout = ""
self.letterbox_value = 0
【Attributes】
name |
type |
description |
dump_asm |
bool |
Specifies whether to dump the asm assembly file, which defaults to True |
dump_dir |
bool |
After specifying the dump_ir and other switches earlier, specify the dump directory here, which defaults to “tmp” |
dump_ir |
bool |
Specifies whether to dump IR, which defaults to False |
swapRB |
bool |
Whether to exchange RGB input data red and blue channels (RGB–>BGR or BGR–>RGB), the default is False |
input_range |
list |
After the input data is dequantized, the range corresponding to the floating-point number is defaulted |
input_shape |
list |
Specify the shape of the input data, the layout of the input_shape needs to be consistent with the input layout, and the letterbox operation (resize/pad, etc.) will be performed when the input_shape of the input data is inconsistent with the input shape of the model. |
input_type |
string |
Specifies the type of input data, defaulting to ‘float32’ |
mean |
list |
Pre-processing normalized parameter mean, defaulted |
Std |
list |
Pre-process normalized parameter variance, defaulted to |
output_type |
string |
Specify the type of output data, e.g. ‘float32’, ‘uint8’ (only for specifying quantization) |
preprocess |
bool |
If pre-processing is enabled, the default value is False |
target |
string |
Specify the compilation target, such as ‘k210’, ‘k510’, ‘k230’ |
letterbox_value |
float |
Specifies the padding value of the pre-processing letterbox |
input_layout |
string |
Specify the layout of the input data, such as ‘NCHW’, ‘NHWC’. If the layout of the input data is different from the layout of the model itself, nncase will insert transpose for conversion |
output_layout |
string |
Specify the layout of the output data, such as ‘NCHW’, ‘NHWC’. If the layout of the output data is different from the layout of the model itself, nncase will insert transpose for conversion. |
【Note】
input range is the range of floating-point numbers, that is, if the input data type is uint8, input range is the range after dequantization to floating-point (can not be 0~1), which can be freely specified.
input_shape needs to be specified according to the input_layout. Take
[1,224,224,3]for example. If the input_layout is NCHW, the input_shape needs to be specified[1,3,224,224]. If input_layout is NHWC, the input_shape needs to be specified as[1,224,224,3]mean and std are parameters for normalize floating-point numbers, which users can freely specify.
When using the letterbox function, you need to limit the input size to 1.5MB, and the size of a single channel to 0.75MB.
For example:
The input data type is uint8, input_range set to
[0,255], then the function of dequantization is only to perform type conversion, convert the data of uint8 to float32, and the mean and std parameters can still be specified according to the data of 0~255If the input data type is uint8 and input_range is
[0,1], the[0,1]fixed-point number will be dequantized to a floating-point number of[0,1], mean and std need to be specified according to the new floating-point range.
The pre-processing process is as follows (all green nodes in the figure are optional):
【Example】
Instantiate CompileOptions to configure the values of each property
# compile_options
2.2.2 ImportOptions#
【Description】
The ImportOptions class, which configures nncase import options
【Definition】
class ImportOptions:
pass
【Example】
Instantiate ImportOptions to configure the values of each property
#import_options
2.2.3 PTQTensorOptions#
【Description】
The PTQTensorOptions class, which is used to configure nncase PTQ options
【Definition】
class PTQTensorOptions:
calibrate_method: str
input_mean: float
input_std: float
samples_count: int
quant_type: str
w_quant_type: str
finetune_weights_method: str
use_mix_quant: bool
quant_scheme: str
export_quant_scheme: bool
export_weight_range_by_channel: bool
cali_data: List[RuntimeTensor]
self.calibrate_method: str = "Kld"
self.input_mean: float = 0.5
self.input_std: float = 0.5
self.samples_count: int = 5
self.quant_type: str = "uint8"
self.w_quant_type: str = "uint8"
self.finetune_weights_method: str = "NoFineTuneWeights"
self.use_mix_quant: bool = False
self.quant_scheme: str = ""
self.export_quant_scheme: bool = False
self.export_weight_range_by_channel: bool = False
self.cali_data: List[RuntimeTensor] = []
【Attributes】
name |
type |
description |
calibrate_method |
string |
Calibration method , supports ‘NoClip’, ‘Kld’, default value is ‘Kld’ |
input_mean |
float |
The user specifies the mean of the input, default value of 0.5 |
input_std |
float |
The user specifies the variance of the input, default value of 0.5 |
samples_count |
Int |
Number of samples |
quant_type |
string |
Specify the data quantization type, such as ‘uint8’, ‘int8’, the default value is ‘uint8’ |
w_quant_type |
string |
Specify the weight quantization type, such as ‘uint8’, ‘int8’, the default value is ‘uint8’ |
finetune_weights_method |
string |
Adjust the weight methods, there are ‘NoFineTuneWeights’, ‘UseSquant’, the default value is ‘NoFineTuneWeights’ |
use_mix_quant |
bool |
Whether to use hybrid quantization, the default value is False |
【Example】
# ptq_options
ptq_options.samples_count = 6
compiler.use_ptq(ptq_options)
2.2.4 set_tensor_data#
【Description】
Set the tensor data
【Definition】
【Parameters】
name |
type |
description |
data |
List[List[np.ndarray] |
calibration data |
【Return value】
【Example】
# ptq_options
2.2.5 Compiler#
【Description】
Compiler class is used to compile neural network models
【Definition】
class Compiler:
_target: _nncase.Target
_compiler: _nncase.Compiler
_module: IRModule
2.2.6 import_tflite#
【Description】
Import the tflite model
【Definition】
【Parameters】
name |
type |
description |
model_content |
byte[] |
Read the model content |
import_options |
ImportOptions |
Import options |
【Return value】
【Example】
2.2.7 import_onnx#
【Description】
Import the ONNX model
【Definition】
【Parameters】
name |
type |
description |
model_content |
byte[] |
import_options |
ImportOptions |
Import options |
【Return value】
【Example】
2.2.8 use_ptq#
【Description】
Set PTQ configuration options.
The K230 must use quantization by default.
【Definition】
【Parameters】
name |
type |
description |
ptq_options |
PTQTensorOptions |
PTQ configuration options |
【Return value】 None
【Example】
2.2.9 compile#
【Description】
Compile the neural network model
【Definition】
compile()
【Parameters】
【Return value】
【Example】
compiler.compile()
2.2.10 gencode_tobytes#
【Description】
Generate a kmodel byte stream
【Definition】
gencode_tobytes()
【Parameters】
【Return value】
bytes[]
【Example】
f.write(kmodel)
2.3 Examples#
The model and python compilation script used in the following example
The original model files are located in the /path/to/k230_sdk/src/big/nncase/examples/models directory
Python compilation scripts are located in the /path/to/k230_sdk/src/big/nncase/examples/scripts directory
2.3.1 Compiling the tflite model#
mbv2_tflite.py is following
import argparse
import numpy as np
from PIL import Image
import nncase
model_content = f.read()
return model_content
data = []
for i in range(batch):
return data
def main():
args = parser.parse_args()
dump_dir = 'tmp/mbv2_tflite'
# compile_options
# compiler
# import
# ptq_options
# compile
compiler.compile()
# kmodel
f.write(kmodel)
if __name__ == '__main__':
main()
Run the following command to compile the tflite model of mobilenetv2, and the target is k230
2.3.2 Compiling the ONNX model#
For onnx models, it is recommended to use ONNX Simplifier for simplification before compiling with nncase
yolov5s_onnx.py is following
import argparse
import numpy as np
import onnxsim
import onnx
import nncase
input_tensors = [
# input
inputs = []
input_dict = {}
input_dict['name'] = e.name
inputs.append(input_dict)
return onnx_model, inputs
input_shapes = {}
for input in inputs:
return model_file
data = []
return data
data = []
return data
def main():
dump_dir = 'tmp/yolov5s_onnx'
os.makedirs(dump_dir)
# onnx simplify
# compile_options
# compiler
# import
# ptq_options
# compile
compiler.compile()
# kmodel
f.write(kmodel)
main()
Run the following command to compile the ONNX model with a target of K230
3. Simulator APIs (Python)#
In addition to compiling model APIs, nncase also provides APIs for inference models, kmodels generated by inference compilation models on PC, and is used to verify whether nncase inference results are consistent with the runtime results of the corresponding deep learning framework.
3.1 APIs#
3.1.1 MemoryRange#
【Description】
The MemoryRange class, which represents a range of memory
【Definition】
.def_property(
【Attributes】
name |
type |
description |
location |
Int |
Memory location, 0 means input, 1 means output, 2 means rdata, 3 represents data, and 4 represents shared_data |
dtype |
Python data types |
data type |
start |
Int |
Memory start address |
Size |
Int |
Memory size |
【Example】
mr = nncase.MemoryRange()
3.1.2 RuntimeTensor#
【Description】
The RuntimeTensor class, which is used to represent runtime tensor
【Definition】
datatype,
.unwrap_or_throw();
arr.inc_ref();
return tensor;
return py::array(
to_dtype(tensor.datatype()),
tensor.shape(),
src_buffer.data());
【Attributes】
name |
type |
description |
dtype |
Python data types |
The data type of Tensor |
shape |
list |
The shape of tensor |
3.1.3 from_numpy#
【Description】
Construct a RuntimeTensor object from numpy.ndarray
【Definition】
from_numpy(py::array arr)
【Parameters】
name |
type |
description |
Arr |
numpy.ndarray |
numpy.ndarray object |
【Return value】
RuntimeTensor
【Example】
3.1.4 copy_to#
【Description】
拷贝RuntimeTensor
【Definition】
copy_to(RuntimeTensor to)
【Parameters】
name |
type |
description |
to |
RuntimeTensor |
RuntimeTensor对象 |
【Return value】
【Example】
3.1.5 to_numpy#
【Description】
Convert the RuntimeTensor to a numpy.ndarray object
【Definition】
to_numpy()
【Parameters】
【Return value】
【Example】
3.1.6 Simulator#
【Description】
Simulator class is used to simulate kmodels on a PC
【Definition】
.def(py::init())
【Attributes】
name |
type |
description |
inputs_size |
Int |
Number of inputs |
outputs_size |
Int |
Number of outputs |
【Example】
sim = nncase.Simulator()
3.1.7 load_model#
【Description】
Load kmodel
【Definition】
load_model(model_content)
【Parameters】
name |
type |
description |
model_content |
byte[] |
kmodel byte stream |
【Return value】
【Example】
sim.load_model(kmodel)
3.1.8 get_input_desc#
【Description】
Gets the description of the input for the specified index
【Definition】
get_input_desc(index)
【Parameters】
name |
type |
description |
index |
Int |
The index of the input |
【Return value】
MemoryRange
【Example】
3.1.9 get_output_desc#
【Description】
Gets the description of the output of the specified index
【Definition】
get_output_desc(index)
【Parameters】
name |
type |
description |
index |
Int |
The index of the output |
【Return value】
MemoryRange
【Example】
3.1.10 get_input_tensor#
【Description】
Gets the RuntimeTensor of the input for the specified index
【Definition】
get_input_tensor(index)
【Parameters】
name |
type |
description |
index |
Int |
The index of input tensor |
【Return value】
RuntimeTensor
【Example】
3.1.11 set_input_tensor#
【Description】
Sets the RuntimeTensor for the input of the specified index
【Definition】
【Parameters】
name |
type |
description |
index |
Int |
Index of input tensor |
tensor |
RuntimeTensor |
Input tensor |
【Return value】
【Example】
3.1.12 get_output_tensor#
【Description】
Gets the RuntimeTensor of the output of the specified index
【Definition】
get_output_tensor(index)
【Parameters】
name |
type |
description |
index |
Int |
The index of the output tensor |
【Return value】
RuntimeTensor
【Example】
3.1.13 set_output_tensor#
【Description】
Sets the RuntimeTensor of the output of the specified index
【Definition】
【Parameters】
name |
type |
description |
index |
Int |
tensor |
RuntimeTensor |
Output tensor |
【Return value】
【Example】
3.1.14 run#
【Description】
Run kmodel inference
【Definition】
run()
【Parameters】
【Return value】
【Example】
sim.run()
3.2 Examples#
Preconditions: yolov5s_onnx.py script has compiled the yolov5s.onnx model
yolov5s_onnx_simu.py is located in the /path/to/k230_sdk/src/big/nncase/examples/scripts subdirectory, which is following.
import copy
import argparse
import numpy as np
import onnx
import onnxruntime as ort
import nncase
def cosine(gt, pred):
def main():
# cpu inference
output_names = []
model_input_type = np.float32
cpu_results = []
# create simulator
# read kmodel
# load kmodel
# read input.bin
# set input for simulator
# simulator inference
nncase_results = []
sim.run()
# compare
main()
Execute inference scripts
The comparison of NNcase Simulator and CPU inference results is following.
4. KPU runtime APIs (C++)#
4.1 Introduction#
KPU runtime APIs are used to load kmodels, set input data, perform kpu/cpu calculations, and obtain output data on AI devices.
Currently only C++ APIs are available, and the relevant header files and static libraries are located in the /path/to/k230_sdk/src/big/nncase/riscv64 directory.
$ tree -L 3 riscv64/
riscv64/
├── gsl
│ └── gsl-lite.hpp
├── nncase
│ ├── include
│ │ └── nncase
│ └── lib
│ ├── cmake
│ ├── libfunctional_k230.a
│ ├── libnncase.rt_modules.k230.a
│ └── libNncase.Runtime.Native.a
└── rvvlib
├── include
│ ├── k230_math.h
│ ├── nms.h
│ └── rvv_math.h
└── librvv.a
8 directories, 8 files
4.2 APIs#
4.2.1 hrt::create#
【Description】
Create a runtime_tensor
【Definition】
【Parameters】
name |
type |
description |
datatype |
typecode_t |
Data types, such as dt_float32, dt_uint8, etc |
shape |
dims_t |
data |
gsl::span<gsl::byte> |
User-mode data buffer |
copy |
bool |
Copy or not |
pool |
memory_pool_t |
Memory pool type, default value is pool_shared_first |
physical_address |
uintptr_t |
The user specifies the physical address of the buffer |
【Return value】
result<runtime_tensor>
【Example】
// create input tensor
4.2.2 hrt::sync#
【Description】
Synchronize the cache of tensor.
For the user’s input data, you need to call the sync_write_back of this interface to ensure that the data has been flashed to the DDR.
For the output data after gnne/ai2d calculation, the default gnne/ai2d runtime has been sync_invalidate processed.
【Definition】
【Parameters】
name |
type |
description |
tensor |
runtime_tensor |
The tensor to be manipulated |
on |
sync_op_t |
sync_invalidate (invalidate Tensor’s cache) or sync_write_back (write Tensor’s cache to DDR) |
force |
bool |
Whether it is enforced |
【Return value】
result<void>
【Example】
4.2.3 interpreter::load_model#
【Description】
Load the kmodel model
【Definition】
【Parameters】
name |
type |
description |
buffer |
gsl::span <const gsl::byte> |
kmodel buffer |
【Return value】
result<void>
【Example】
interpreter interp;
4.2.4 interpreter::inputs_size#
【Description】
Gets the number of model inputs
【Definition】
【Parameters】
【Return value】
size_t
【Example】
4.2.5 interpreter::outputs_size#
【Description】
Gets the number of model outputs
【Definition】
【Parameters】
【Return value】
size_t
【Example】
4.2.6 interpreter:: input_shape#
【Description】
Gets the shape of the specified input to the model
【Definition】
【Parameters】
name |
type |
description |
index |
size_t |
【Return value】
runtime_shape_t
【Example】
4.2.7 interpreter:: output_shape#
【Description】
Gets the shape of the specified output of the model
【Definition】
【Parameters】
name |
type |
description |
index |
size_t |
【Return value】
runtime_shape_t
【Example】
4.2.8 interpreter:: input_tensor#
【Description】
Gets/sets the input tensor for the specified index
【Definition】
【Parameters】
name |
type |
description |
index |
size_t |
tensor |
runtime_tensor |
The runtime tensor of the input |
【Return value】
(1) result<runtime_tensor>
(2) result<void>
```cpp
【示例】
```cpp
// set input
4.2.9 interpreter:: output_tensor#
【Description】
Gets/sets the output tensor of the specified index
【Definition】
【Parameters】
name |
type |
description |
index |
size_t |
tensor |
runtime_tensor |
The runtime tensor of the output |
【Return value】
(2) result<void>
【Example】
// get output
4.2.10 interpreter:: run#
【Description】
Perform kpu calculations
【Definition】
result<void> run() noexcept;
【Parameters】
【Return value】
返回result <void>
【Example】
// run
4.3 Examples#
#include <chrono>
#include <fstream>
#include <iostream>
#define USE_OPENCV 1
#define preprocess 1
#if USE_OPENCV
#endif
using namespace nncase;
#define INTPUT_HEIGHT 224
#define INTPUT_WIDTH 224
#define INTPUT_CHANNELS 3
template <class T>
ifs.seekg(0, ifs.end);
size_t len = ifs.tellg();
ifs.seekg(0, ifs.beg);
ifs.close();
return vec;
ifs.read(buffer, len);
ifs.close();
std::vector<std::string> vec;
vec.reserve(1024);
std::ifstream fp(file_name);
std::string label;
while (getline(fp, label))
vec.push_back(label);
return vec;
template<typename T>
T denominator{ 0 };
denominator += dst[i];
dst[i] /= denominator;
#if USE_OPENCV
std::vector<uint8_t> vec;
cv::split(img, rgbChannels);
return vec;
#endif
// load kmodel
interpreter interp;
interp.load_model({ (const gsl::byte *)kmodel.data(), kmodel.size() }).expect("cannot load model.");
// create output tensor
// set input data
#if USE_OPENCV
#else
#endif
// run
size_t counter = 1;
// get output data
size_t idx = it - buf;
// load label
if (argc != 4)
return -1;
if (ret)
return -2;
5. AI2D runtime APIs (C++)#
5.1 Introduction#
AI2D runtime APIs are used to configure AI2D parameters on AI devices, generate related register configurations, and perform AI2D calculations.
5.1.1 Supported format conversions#
Input format |
Output format |
remark |
YUV420_NV12 |
RGB_planar/YUV420_NV12 |
YUV420_NV21 |
RGB_planar/YUV420_NV21 |
YUV420_I420 |
RGB_planar/YUV420_I420 |
YUV400 |
YUV400 |
NCHW(RGB_planar) |
NCHW(RGB_planar) |
RGB_packed |
RGB_planar/RGB_packed |
RAW16 |
RAW16/8 |
Depth map, perform shift operation |
5.1.2 Function Description#
function |
description |
remark |
affine transformation |
Support input formats YUV420, YUV400, RGB (planar/packed) Support depth map RAW16 format Support output format YUV400, RGB, depth map |
Crop/Resize/Padding |
Support input YUV420, YUV400, RGB Support depth map RAW16 format Resize supports intermediate NCHW arrangement format Support output formats YUV420, YUV400, RGB |
Only the padding constant is supported |
Shift |
Support input format Raw16 Support output format Raw8 |
Symbol bits |
Both signed and unsigned input are supported |
5.2 APIs#
5.2.1 ai2d_format#
【Description】
ai2d_format is used to configure input and output data format, which is optional.
【Definition】
enum class ai2d_format
YUV420_NV12 = 0,
YUV420_NV21 = 1,
YUV420_I420 = 2,
NCHW_FMT = 3,
RGB_packed = 4,
RAW16 = 5,
5.2.2 ai2d_interp_method#
【Description】
ai2d_interp_method is used to configure optional interpolation.
【Definition】
enum class ai2d_interp_method
tf_nearest = 0,
tf_bilinear = 1,
cv2_nearest = 2,
cv2_bilinear = 3,
5.2.3 ai2d_interp_mode#
【Description】
ai2d_interp_mode is used to configure optional interpolation modes.
【Definition】
enum class ai2d_interp_mode
none = 0,
align_corner = 1,
half_pixel = 2,
5.2.4 ai2d_pad_mode#
【Description】
ai2d_pad_mode is used to configure padding modes, which is optional. Currently only constant padding is supported.
【Definition】
enum class ai2d_pad_mode
constant = 0,
copy = 1,
mirror = 2,
5.2.5 ai2d_datatype_t#
【Description】
ai2d_datatype_t is used to set the data type in the AI2D calculation process.
【Definition】
struct ai2d_datatype_t
ai2d_format src_format;
ai2d_format dst_format;
datatype_t src_type;
datatype_t dst_type;
【Parameters】
name |
type |
description |
src_format |
ai2d_format |
Input data format |
dst_format |
ai2d_format |
Output data format |
src_type |
datatype_t |
Input data type |
dst_type |
datatype_t |
Output data type |
src_loc |
ai2d_data_loc |
Enter the data location, default DDR |
dst_loc |
ai2d_data_loc |
Output data location, default DDR |
【Example】
5.2.6 ai2d_crop_param_t#
【Description】
ai2d_crop_param_t is used to configure crop-related parameters.
【Definition】
struct ai2d_crop_param_t
bool crop_flag = false;
int32_t start_x = 0;
int32_t start_y = 0;
int32_t width = 0;
int32_t height = 0;
【Parameters】
name |
type |
description |
crop_flag |
bool |
Whether to enable the crop function |
start_x |
Int |
The starting pixel in the width direction |
start_y |
Int |
The starting pixel in the height direction |
Int |
The length of the crop in the width direction |
Int |
The length of the crop in the height direction |
【Example】
5.2.7 ai2d_shift_param_t#
【Description】
ai2d_shift_param_t is used to configure shift-related parameters.
【Definition】
struct ai2d_shift_param_t
bool shift_flag = false;
int32_t shift_val = 0;
【Parameters】
name |
type |
description |
shift_flag |
bool |
Whether to enable the shift function |
shift_val |
Int |
The number of bits shifted right |
【Example】
5.2.8 ai2d_pad_param_t#
【Description】
ai2d_pad_param_t is used to configure pad-related parameters.
【Definition】
struct ai2d_pad_param_t
bool pad_flag = false;
runtime_paddings_t paddings;
【Parameters】
name |
type |
description |
pad_flag |
bool |
Whether to enable the pad function |
paddings |
runtime_paddings_t |
The padding, shape=, of each dimension, |
pad_mode |
ai2d_pad_mode |
padding模式,只支持constant padding |
pad_val |
std::vector<int32_t> |
The padding value of each channel |
【Example】
5.2.9 ai2d_resize_param_t#
【Description】
ai2d_resize_param_t is used to configure resize-related parameters.
【Definition】
struct ai2d_resize_param_t
bool resize_flag = false;
【Parameters】
name |
type |
description |
resize_flag |
bool |
Whether to enable the resize function |
interp_method |
ai2d_interp_method |
The resize interpolation method |
interp_mode |
ai2d_interp_mode |
Resize mode |
【Example】
5.2.10 ai2d_affine_param_t#
【Description】
ai2d_affine_param_t is used to configure affine-related parameters.
【Definition】
struct ai2d_affine_param_t
bool affine_flag = false;
uint32_t cord_round = 0;
uint32_t bound_ind = 0;
int32_t bound_val = 0;
uint32_t bound_smooth = 0;
std::vector<float> M;
【Parameters】
name |
type |
description |
affine_flag |
bool |
Whether to enable the affine function |
interp_method |
The interpolation method employed by Affine |
cord_round |
uint32_t |
Integer bounding 0 or 1 |
bound_ind |
uint32_t |
Boundary pixel mode 0 or 1 |
bound_val |
uint32_t |
Boundary-fill values |
bound_smooth |
uint32_t |
The boundary is smoothed by 0 or 1 |
M |
std::vector<float> |
The vector corresponding to the affine transformation matrix is $Y=[a_0, a_1; a_2, a_3] \cdot X + [b_0, b_1] $, then $ M={a_0,a_1,b_0,a_2,a_3,b_1} $ |
【Example】
5.2.11 ai2d_builder:: ai2d_builder#
【Description】
ai2d_builder constructor.
【Definition】
【Parameters】
name |
type |
description |
input_shape |
dims_t |
Enter a shape |
output_shape |
dims_t |
Output shapes |
ai2d_dtype |
ai2d_datatype_t |
AI2D data type |
crop_param |
ai2d_crop_param_t |
Crop-related parameters |
shift_param |
ai2d_shift_param_t |
shift-related parameters |
pad_param |
ai2d_pad_param_t |
Pad-related parameters |
resize_param |
ai2d_resize_param_t |
resize related parameters |
affine_param |
ai2d_affine_param_t |
Affine related parameters |
【Return value】
【Example】
5.2.12 ai2d_builder:: build_schedule#
【Description】
Generate the parameters required for AI2D calculation.
【Definition】
【Parameters】
【Return value】
result<void>
【Example】
5.2.13 ai2d_builder:: invoke#
【Description】
Configure the registers and start the calculation of AI2D.
【Definition】
【Parameters】
name |
type |
description |
input |
runtime_tensor |
Input tensor |
output |
runtime_tensor |
Output tensor |
【Return value】
result<void>
【Example】
// run ai2d
5.3 Examples#
// input tensor
// output tensor
// config ai2d
// run
// compare
if (!ret)
else
5.4 Precautions#
Affine and Resize are mutually exclusive and cannot be turned on at the same time
The input format of the Shift function can only be Raw16
Pad value is configured per channel, and the number of corresponding list elements should be equal to the number of channels
In the current version, when only one function of AI2D is required, other parameters also need to be configured, flag can be set to false, and other fields do not need to be configured.
When multiple functions are configured, the execution order is Crop->Shift->Resize/Affine->Pad, and be careful to match the parameters when configuring them.
6. FAQ#
6.1 xxx.whl is not a supported wheel on this platform. Error is reported when installing wheel package#
Q: ERROR: nncase-1.0.0.20210830-cp37-cp37m-manylinux_2_24_x86_64.whl is not a supported wheel on this platform.
A: Upgrade pip >= 20.3
sudo pip install --upgrade pip
6.2 python: symbol lookup error error is reported when compiling the model#
Q: python: symbol lookup error: /usr/local/lib/python3.8/dist-packages/libnncase.modules.k230.so: undefined symbol: \_ZN6nncase2ir5graph14split_subgraphESt4spanIKPNS0_4nodeELm18446744073709551615EEb error is reported when compiling a model
A: Check whether the nncase and nncase-k230 wheel package versions match
root@a829814d14b7:/mnt/examples# pip list
Package Version
gmssl 3.2.1
nncase 1.8.0.20220929
nncase-k230 1.9.0.20230403
numpy 1.24.2
Pillow 9.4.0
pip 23.0
pycryptodome 3.17
setuptools 45.2.0
wheel 0.34.2
6.3 std::bad_alloc error is reported when running the inference app on the board#
Q: Run the inference program on the board and throw std::bad_alloc exception
$ ./cpp.sh
case ./yolov3_bfloat16 build at Sep 16 2021 18:12:03
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
A: std::bad_alloc exception is usually caused by memory allocation failure, you can do the following troubleshooting.
Check if the generated kmodel exceeds the current system available memory
Check whether the app has memory leaks
6.4 data.size_bytes() == size = false (bool) error is reported when running the App inference program on the board#
Q: Run the inference program and throw[..t_runtime_tensor.cpp:310 (create)] data.size_bytes() == size = false (bool) an exception
A: Check the input tensor information of the settings, focusing on whether the input shape and the number of bytes occupied by each element (fp32/uint8) are consistent with the model
