K230 debian ubuntu Notes#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
preface#
This document mainly introduces the K230 canmv board debian and ubuntu image download and generation methods.
Reader object#
Technical Support Engineer
Software Development Engineer
Definition of acronyms#
Abbreviation |
Illustrate |
gcc |
GNU Compiler Collection |
dhcp |
Dynamic Host Configuration Protocol |
Revision history#
Document version number |
Modify the description |
Author |
date |
Initial |
System Software Department |
2023-11-8 |
1. download note#
debian and ubuntu related files can be found on the canaan developer community website under k230/images
1.1). similar canmv_debian_sdcard_sdk_x.x.img.gz is k230 debian compressed image;
debian version is trixie/sid (debian13),You can see “Welcome to Debian GNU/Linux trixie/sid!” print at startup .
1.2) similar canmv_ubuntu_sdcard_x.x.img.gz is k230 ubuntu compressed mirror image;
debian version is Ubuntu 23.10(mantic),You can see “Welcome to Ubuntu 23.10! “print at startup.
1.3) debian13.ext4.tar.gz is k230 debian rootfs;
1.4). ubuntu23_rootfs.ext4.gz is k230 ubuntu rootfs.
note1:mirror image only applies to the canmv board. note2:image need uncompress. note3: The network port is unstable. If the network port cannot be found, reset the board.
2.k230 debian Rootfs build and verification#
2.1environment#
I build the debian rootfs file system in ubuntu21.04 (other systems should be able to do it too), and it need root permission.
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 21.04
Release: 21.04
Codename: hirsute
2.2debian rootfs build#
please referring to the following command to build the debian rootfs.
sudo rm -rf debian13
sudo apt-get update
sudo chroot debian13/
echo "root:root" | chpasswd
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
EOF
ntpdate ntp.ntsc.ac.cn
exit
2.3image build#
1).download and compile k230 sdk
Compile related issues please reference
#target file is "output/k230_canmv_only_linux_defconfig/images/sysimage-sdcard.img"
2). Decompress debian13.ext4.tar.gz to output/k230_canmv_only_linux_defconfig/images/
3).k230_sdk code modify:
#board/common/gen_image_cfg/genimage-sdcard.cfg add:
partition debian {
image = "debian13.ext4"
#board/common/env/default.env bootcmd modify to
4).build sdk image
make build-image
5).burn image and boot system
burn “output/k230_canmv_only_linux_defconfig/images/sysimage-sdcard.img” file to tf card,Insert the tf card into the device and restart the device。
note1:Burning method can reference.
note2: The network port is unstable. If the network port cannot be found, reset the board.
1.3gcc test#
dhclient
date -s 20231027
apt-get update
apt-get install gcc
apt-get install ssh
gcc a.c
./a.out
note: The network port is unstable. If the network port cannot be found, reset the board.
3. k230 ubuntu23 rootfs build#
3.1 environment#
build k230 ubuntu23 need ubuntu23 systerm, i use follow command to build ubuntu23 systerm:
3.1.1)save follow content to Dockerfile23:
#构建ubuntu23.04容器;
#docker run --privileged -u root -it -v $(pwd):$(pwd) -w $(pwd) ubuntu23:v1 /bin/bash
FROM ubuntu:23.04
# install software
RUN apt-get update
# set default timezone
ENV TZ=Asia/Shanghai
3.1.1)build ubuntu23 systerm
docker build -t ubuntu23:v1 . -f Dockerfile23
3.2 k230 ubuntu rootfs build#
please referring to the following command to build the k230 ubuntu23 rootfs
rm -rf ubuntu23_rootfs
EOF
echo k230>/etc/hostname
exit
3.3 image build#
1).下载k230 sdk并进行编译:
2). Decompress ubuntu23_rootfs.ext4.gz to output/k230_canmv_only_linux_defconfig/images/
partition debian {
#board/common/env/default.env bootcmd modify to:
4).build sdk image
make build-image
2.4 gcc test#
dhcpcd
apt-get update
apt-get install gcc
apt-get install ssh
gcc a.c
./a.out
