K230 Power Management Usage Guide#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
preface#
This document describes the K230 platform power management framework and how to use power control.
Reader object#
Technical Support Engineer
Software Development Engineer
Definition of acronyms#
abbreviation |
illustrate |
Revision history#
Document version number |
Modify the description |
Author |
date |
Initial edition |
Zhang Tao |
2023/07/17 |
1. Overview#
The K230 platform power management framework is divided into big-core power management and little-core power management, and the two cores are independently controlled. The big core (rt-smart) mainly controls CPU1, AI module, display module, multimedia module, etc., and the little core (linux) mainly controls CPU0. All power domains and clocks are enabled by default after the chip is powered on, and in order to reduce power consumption, the following power domains and clocks are turned off during the uboot-SPL phase:
KPU Power、KPU clk、KPU aclk
VPU Power、VPU clk、VPU aclk、VPU cfgclk
DPU Power、DPU clk、DPU aclk、DPU pclk
DISP Power
mclk
At the same time, each device driver is responsible for the corresponding clock and power domain management, when the user turns on the device, the driver should open the power domain and clock, when the user turns off the device, the driver should turn off the clock and power domain. For devices that do not support power domain management, only the clock needs to be controlled.
2. Big core power consumption control#
2.1 Introduction to the control framework#
2.1.1 Power Management Domains#
The power control of big cores mainly revolves around several power management domains:
CPU1
KPU
DPU
VPU
DISP
Each power management domain can set the frequency separately, where CPU1 and KPU also support DVFS, and other power management domains only support setting frequency. The power management domain supports frequency as built-in drivers, and users can change it according to their actual scenarios.
2.1.2 Control Policies#
Each power management domain can set the power control policy separately, which is divided into four policies:
Manual mode, where the user can manually configure the frequency by invoking the interface in the program
Performance mode, which locks the highest frequency
Power saving mode to lock the lowest frequency
Auto mode, automatically switch frequency according to load (only CPU1 supported)
2.1.3 Thermal Protection#
Power control supports two levels of thermal protection, the first stage is to limit the frequency of the module after the specified temperature is exceeded, and the second stage is to force the module to shut down the power domain after the specified temperature is exceeded, both levels support user configuration.
2.1.4 Power Supply and Clock#
Power control supports manual power-up and down and clock control for each power management domain, users generally do not need to call manually, the device driver will turn on the power and clock when using the device, and the device driver will turn off the power and clock when the device is turned off.
2.1.5 CPU1#
The CPU supports 4 strategies: MANUAL_MODE, PERFORMANCE_MODE, ENERGYSAVING_MODE, AUTO_MODE
For the current CPU 1 power consumption optimization of door lock and dictionary pen POC, it mainly adopts manual mode, and the user sets the high frequency before the program segment with a large amount of calculation, and sets it to low frequency after running. For multi-process or multithreaded apps, each app can lock the minimum run frequency. You can tune your application to achieve optimal power consumption by looking at CPU statistics.
2.1.6 KPU#
KPU supports 3 strategies: MANUAL_MODE, PERFORMANCE_MODE, ENERGYSAVING_MODE
KPU power consumption control is mainly by adjusting the KPU frequency and switching power supply clock, through the nncase call interface to inform the current KPU operation stage, users can control each kd_mpi_pm_runtime_runstagemodule clock and power supply through each stage, such as when AI uses KPU, you can turn on the KPU clock, immediately after the use of the clock (AI2D clock control by default by hardware automatic control). Users can also manually set the KPU frequency according to the actual scenario, set the maximum frequency if the model is required to have a high frame rate, and set a lower frequency to reduce power consumption if the frame rate is not required or can meet the requirements.
2.1.7 DPU#
Refer to KPU
2.1.8 VPU#
Refer to KPU
2.1.9 DISPLAY#
Display the relevant part, built-in several frequency combinations, such as 60fps, 30fps, etc., set according to different scenarios at startup, do not support frequency adjustment at runtime, only support turning off the clock and turning off the power domain.
2.2 Usage#
The power management framework is enabled by default, all domains are initialized MANUAL_MODE and the frequency is the default initial value of the system, which does not affect the original system function.
2.2.1 Use manual mode#
Users can refer to the following process to use MANUAL_MODE:
Obtain the
kd_mpi_pm_get_profilesfrequency points supported by the power management domain through the interfaceSet the management
kd_mpi_pm_set_governorpolicy of the power management domain through the interface to manual modeSet the profile sequence number of the power management domain
kd_mpi_pm_set_profilethroughkd_mpi_pm_set_profile_lockthe OR interface
2.2.2 Use other modes#
Users can refer to the following process to use PERFORMANCE_MODE, ENERGYSAVING_MODE, AUTO_MODE
Set the management
kd_mpi_pm_set_governorpolicy of the power management domain through the interface to the appropriate mode
2.2.3 Use thermal protection#
Through the
kd_mpi_pm_set_thermal_protectinterface, set the thermal protection temperature and downclocking serial number, and reduce the frequency to the specified profile when the temperature exceeds the specified valueThe
kd_mpi_pm_set_thermal_shutdownthermal shutdown temperature is set through the interface, and each power management domain will force down power when the temperature exceeds the specified value
2.2.4 Use custom frequencies#
For example, if you need to modify the frequency supported by the CPU, you can modifyk230_sdk/src/big/mpp/kernel/pm/src/pm_domain_cpu.c the array in the fileprofiles:
{1.6e9, 0.8e6},
{1.188e9, 0.7e6},
{0.8e9, 0.68e6},
{0.594e9, 0.66e6},
{0.4e9, 0.64e6},
{0.2e9, 0.62e6},
After modifying the array, you also need to modify the function under the same file to generate the corresponding frequency, if the set_clockdomain supports DVFS, the user also needs to specify the voltage corresponding to each frequency, if not, it is unified to the default voltage.
The modifications of KPU, DPU, VPU are similar.
Note: If you need to use the CPU AUTO_MODE policy, modify the frequency and modify the load conversion table load_table.
2.3 API Reference#
The framework provides the following APIs:
2.3.1 kd_mpi_pm_set_reg#
【Description】
Write registers for expansion or debugging
【Syntax】
【Parameters】
Parameter name |
Input/output |
reg |
Register address |
input |
valley |
Register data |
input |
【Return value】
Return value |
succeed |
Non-0 |
Failed, the value of which is described in error code |
【Requirement】
Header file: mpi_pm_api.h
Library file: libpm.a
【Note】
Only CMU and PWR address blocks are supported
【Example】
2.3.2 kd_mpi_pm_get_reg#
【Description】
Read registers for expansion or debugging
【Syntax】
【Parameters】
Parameter name |
Input/output |
reg |
Register address |
input |
pval |
Register data |
output |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.3 kd_mpi_pm_get_profiles#
【Description】
Gets the profile property of the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
Power management domain |
input |
pcount |
The number of attributes |
Input/output |
pprofile |
attribute |
output |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
The maximum value of *pcount is 128
If *pcount is 0, the number of profiles in the power management domain is returned, and pprofile is not used
When *pcount is greater than 0 and less than a certain value, the profile property of the specified number is returned, and pprofile cannot be empty and must be greater than *pcount
When *pcount is greater than a certain value, the maximum number of profiles and the maximum number of profile properties are returned, and pprofile cannot be empty and must be greater than the maximum value of *pcount
Profile is in descending order, sequence number 0 is the highest frequency, the larger the sequence number, the lower the frequency
【Example】
2.3.4 kd_mpi_pm_get_stat#
【Description】
Gets statistics for the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
Currently, only CPU power management domains are supported
【Example】
2.3.5 kd_mpi_pm_set_governor#
【Description】
Set the management policy for the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
governor |
Manage policies |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.6 kd_mpi_pm_get_governor#
【Description】
Gets the management policy for the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
pgovernor |
Manage policies |
output |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.7 kd_mpi_pm_set_profile#
【Description】
Sets the current profile sequence number for the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
index |
profile index |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
Only manual mode settings are supported
Negative numbers are supported, such as -1 for the penultimate profile and -2 for the penultimate profile
Negative numbers that are out of range are limited to the first profile
Positive numbers that are out of range are limited to the last profile
【Example】
2.3.8 kd_mpi_pm_get_profile#
【Description】
Gets the current profile sequence number of the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
pindex |
profile index |
output |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.9 kd_mpi_pm_set_profile_lock#
【Description】
Sets the lowest profile sequence number for the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
index |
profile index |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
After the setting is completed, the current profile may be larger than the set value, such as other processes setting the minimum profile to 1, the current process setting the minimum profile to 2, and the actual profile is 1
Other referenceskd_mpi_pm_get_profile
【Example】
2.3.10 kd_mpi_pm_set_profile_unlock#
【Description】
Clear the lowest profile sequence number in the power management domain
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
index |
profile index |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.11 kd_mpi_pm_set_thermal_protect#
【Description】
Set up power management domain thermal protection throttling
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
temp |
Temperature in 0.01°C |
input |
index |
profile index |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
Thermal protection settings are only supported in CPU and KPU power management domains
【Example】
2.3.12 kd_mpi_pm_get_thermal_protect#
【Description】
Obtain a power management domain thermally protected throttling configuration
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
ptemp |
output |
pindex |
profile index |
output |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.13 kd_mpi_pm_set_thermal_shutdown#
【Description】
Set the thermal shutdown temperature
【Syntax】
【Parameters】
Parameter name |
Input/output |
temp |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.14 kd_mpi_pm_get_thermal_shutdown#
【Description】
Gets the thermal shutdown temperature
【Syntax】
【Parameters】
Parameter name |
Input/output |
ptemp |
output |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.15 kd_mpi_pm_set_clock#
【Description】
Set the power management domain clock
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
enable |
switch |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.16 kd_mpi_pm_set_power#
【Description】
Set the power management domain power
【Syntax】
【Parameters】
Parameter name |
Input/output |
domain |
input |
enable |
switch |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
【Example】
2.3.17 kd_mpi_pm_runtime_runstage#
【Description】
Set the nncase run stage, which is called by the nncase runtime
【Syntax】
【Parameters】
Parameter name |
Input/output |
stage |
Run stage ID |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Requirement】
【Note】
The PM module has a built-in control strategy to
RUNTIMESTAGE_ID_KPU_STARTturn on the KPU power and clock when it is turned on.RUNTIMESTAGE_ID_KPU_STOPWhen the KPU power and clock are turned off, the user can override this function according to actual needs.
【Example】
2.4 Data Structures#
2.4.1 k_pm_domain#
【Description】
Define the power management domain
【Definition】
PM_DOMAIN_CPU,
PM_DOMAIN_KPU,
PM_DOMAIN_DPU,
PM_DOMAIN_VPU,
PM_DOMAIN_DISPLAY,
PM_DOMAIN_MEDIA,
PM_DOMAIN_NR,
} k_pm_domain;
【Members】
Member Name |
PM_DOMAIN_CPU |
CPU power management domain |
PM_DOMAIN_KPU |
KPU power management domain |
PM_DOMAIN_DPU |
DPU power management domain |
PM_DOMAIN_VPU |
VPU power management domain |
PM_DOMAIN_DISPLAY |
Displays the power management domain |
PM_DOMAIN_MEDIA |
Video power management domain |
PM_DOMAIN_NR |
Total number of power management domains |
【Note】
2.4.2 k_pm_governor#
【Description】
Define power management policies
【Definition】
PM_GOVERNOR_MANUAL,
PM_GOVERNOR_PERFORMANCE,
PM_GOVERNOR_ENERGYSAVING,
PM_GOVERNOR_AUTO,
} k_pm_governor;
【Members】
Member Name |
PM_GOVERNOR_MANUAL |
Manual mode |
PM_GOVERNOR_PERFORMANCE |
Performance mode |
PM_GOVERNOR_ENERGYSAVING |
Energy saving mode |
PM_GOVERNOR_AUTO |
Automatic mode |
【Note】
2.4.3 k_pm_profile#
【Description】
Define frequency pairs, including frequency and voltage
【Definition】
int32_t freq;
int32_t volt;
} k_pm_profile;
【Members】
Member Name |
freq |
Frequency, unit: Hz |
volt |
Voltage, unit: uV |
【Note】
The frequency pairs are arranged in descending order, the sequence number 0 is the highest frequency, and the larger the serial number, the lower the frequency
2.4.4 k_runtimestage_id#
【Description】
Define the AI operation stage, which may use AI2D, KPU, and CPU during AI operation
【Definition】
RUNTIMESTAGE_ID_AI2D_START,
RUNTIMESTAGE_ID_AI2D_STOP,
RUNTIMESTAGE_ID_KPU_START,
RUNTIMESTAGE_ID_KPU_STOP,
RUNTIMESTAGE_ID_CPU_START,
RUNTIMESTAGE_ID_CPU_STOP,
} k_runtimestage_id;
【Members】
Member Name |
RUNTIMESTAGE_ID_AI2D_START |
The AI2D run begins |
RUNTIMESTAGE_ID_AI2D_STOP |
The AI2D run ends |
RUNTIMESTAGE_ID_KPU_START |
KPU operation begins |
RUNTIMESTAGE_ID_KPU_STOP |
KPU operation ends |
RUNTIMESTAGE_ID_CPU_START |
CPU operation starts |
RUNTIMESTAGE_ID_CPU_STOP |
The CPU is running at the end of operation |
【Note】
2.5 Error Codes#
Error code |
Macro definition |
0xa0178003 |
K_ERR_PM_ILLEGAL_PARAM |
The parameter setting is invalid |
0xa0178004 |
K_ERR_PM_EXIST |
Device already exists |
0xa0178005 |
K_ERR_PM_UNEXIST |
The device does not exist |
0xa0178006 |
K_ERR_PM_NULL_PTR |
Parameter null pointer |
0xa0178007 |
K_ERR_PM_NOT_CONFIG |
The device is not configured |
0xa0178008 |
K_ERR_PM_NOT_SUPPORT |
Operation is not supported |
0xa0178009 |
K_ERR_PM_NOT_PERM |
Operation is not allowed |
0xa017800c |
K_ERR_PM_NOMEM |
Memory allocation failed |
0xa0178010 |
K_ERR_PM_NOTREADY |
The device is not ready |
0xa0178011 |
K_ERR_PM_BADADDR |
Error address |
0xa0178012 |
K_ERR_PM_BUSY |
The device is busy |
3. Little core power consumption control#
3.1 Introduction to the control framework#
The little core control is mainly for CPU0, and supports Linux cpu_freq, temperature protection, and cooling control.
3.1.1 cpu_freq#
cpu_freq is a Linux standard, please refer to the kernel documentation
