K230 Graphics Practice - Boot Video and Boot Logo#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
overview#
This article explains how to implement the boot video and boot logo on the K230 EVB development board through video decoding. The video decoding module supports H.264/H.265/MJPEG decoding, and the maximum resolution of the screen display is 1920x1080, which can be rotated.
1. Environmental preparation#
1.1 Hardware Environment#
Typec USB cable for power supply.
SD card
Screen and cable
Camera board (IMX335)
1.2 Software Environment#
The toolchains are provided in the k230_sdk and are available in the following paths.
Big core RT-SAMRT toolchain
Small-core Linux toolchain
The toolchain can also be downloaded via the link below
2. Source code location#
The SDK contains a user-mode decoding demo at .k230_sdk/src/big/mpp/userapps/sample/sample_vdec The compiled executable file is k230_sdk/src/big/mpp/userapps/sample/elf/sample_vdec.elfnot loaded into the big core image by default, and you need to modify the Makefile according to the execution mode section to generate the executable file in the directory /mnt after the big core is started.
Source code analysis#
sample_vb_init: Configure VB Pool CNT and initialize VB.vb_create_pool: Configure the block size and number of each pool in VB.kd_mpi_vdec_create_chn: Create a decoding channel.kd_mpi_vdec_start_chn: Turn on the decoding channel.sample_vdec_bind_vo: Bind the decoding to VO.input_thread: Reads data from a file and callskd_mpi_vdec_send_streamto send data to the VPU.output_thread: Get the decoded data from the VPU.
3. Program Execution#
Modify the
mpp-appscompilation script ink230_sdk/Makefile. Modifycp userapps/sample/fastboot_elf/* $(RTSMART_SRC_DIR)/userapps/root/bin/; \
as
Copy the H.264/H.265/MJPEG/JPEG files that need to be displayed to the
k230_sdk/src/big/rt-smart/userapps/root/bindirectoryModify
k230_sdk/src/big/rt-smart/init.shto the following command:/bin/sample_vdec -i <filename> [-t <sec>]
<filename>is the video file copied in the previous step-tis the time the picture is displayed, Used only when a picture is displayed.
Execute the command
makeunder the directoryk230_sdk.The compiled and generated
k230_sdk/output/k230_evb_defconfig/images/sysimage-sdcard.imgprogramming is flashed to the SD card, and the EVB board DIP switch is all dialed to OFF (boot from the SD card) to realize the boot display video.
