K230 RVV optimization performance description#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
[toc]
preface#
This document describes the impact of RVV on model inference performance.
Reader object#
Technical Support Engineer
Software Development Engineer
Revision history#
Document version number |
Modify the description |
Author |
date |
Initial edition |
Yang Haoqi |
2023/08/04 |
1. Overview#
In recent years, the rapid development of the field of AI has derived a variety of neural network models, and new operators are constantly emerging. However, the iteration cycle of the AI chip is much longer than that of the AI model, and most of these newly emerged operators cannot directly use the AI chip for inference acceleration, and some of the old operators are not suitable for inference acceleration using the AI chip.Therefore, the CPU becomes the execution carrier of this part of operators, which also means that the performance of the CPU will become a factor affecting the final performance when the model is deployed, and the RVV expansion is an important means for RISC-V CPU to improve performance. The C908 dual-core processor used in K230 has the characteristics of RVV1.0 expansion, which can greatly improve the performance of CPU operator inference.
K230 needs to use the model in .kmodel format for model inference. .kmodel is compiled by nncase for ONNX and TFLite models. It is suitable for the development board produced by our company and related cooperative enterprises. nncase supports common neural network operators, but some operators cannot be accelerated by K230, and these operators can only be inferred using CPU.
2. RVV application scenarios#
At present, the most widely studied and applied neural network Transformer is quite different with CNN, and many AI chips designed based on CNN cannot fully accelerate Transformer. The following is the operator execution of the Decoder model with RVV optimization enabled and without RVV optimization, which is a sub-model in Transformer.
2.1 RVV optimization is not enabled#
stackvm tensor op |
count |
time consumption(ms) |
percentage(%) |
softmax |
5 |
1749.61 |
88.6574 |
where |
4 |
199.432 |
10.1058 |
EXTCALL |
65 |
16.099 |
0.815779 |
layer_norm |
7 |
5.81 |
0.294408 |
gather |
2 |
0.393 |
0.0199144 |
STLOCAL |
212 |
0.391 |
0.019813 |
LDC_I4 |
241 |
0.388 |
0.019661 |
reduce_arg |
1 |
0.336 |
0.017026 |
reshape |
26 |
0.281 |
0.014239 |
LDLOCAL |
149 |
0.26 |
0.0131749 |
LDNULL |
106 |
0.166 |
0.00841166 |
LDTENSOR |
29 |
0.103 |
0.00521929 |
LEA_GP |
58 |
0.097 |
0.00491525 |
LDDATATYPE |
29 |
0.07 |
0.00354709 |
LDARG |
5 |
0.008 |
0.000405381 |
RIGHT |
1 |
0.004 |
0.000202691 |
LDTUPLE |
1 |
0.003 |
0.000152018 |
total |
941 |
1973.45 |
100 |
2.2 Enable RVV optimization#
stackvm tensor op |
count |
percentage(%) |
softmax |
5 |
25.722 |
55.6175 |
EXTCALL |
65 |
16.179 |
34.9831 |
layer_norm |
7 |
0.967 |
2.0909 |
where |
4 |
0.912 |
1.97198 |
gather |
2 |
0.39 |
0.84328 |
LDC_I4 |
241 |
0.386 |
0.834631 |
STLOCAL |
212 |
0.379 |
0.819495 |
reduce_arg |
1 |
0.34 |
0.735167 |
LDLOCAL |
149 |
0.259 |
0.560024 |
reshape |
26 |
0.243 |
0.525428 |
LDNULL |
106 |
0.17 |
0.367583 |
LEA_GP |
58 |
0.103 |
0.222712 |
LDTENSOR |
29 |
0.103 |
0.222712 |
LDDATATYPE |
29 |
0.076 |
0.164331 |
LDARG |
5 |
0.011 |
0.0237848 |
RIGHT |
1 |
0.005 |
0.0108113 |
LDTUPLE |
1 |
0.003 |
0.00648677 |
total |
941 |
46.248 |
100 |
2.3 Performance Analysis and Description#
From the above model inference situation, the KPU unit of K230 does not support hardware acceleration for softmax, layer_norm, where, gather, reduce_arg, and reshape, so we need to use CPU (C908) to implement inference. At present, the RVV optimization of softmax, layer_norm and where has been completed, and the performance has been improved significantly.
The following is a graph of the proportion of each operator in the model inference time before and after RVV optimization.
pie
title without RVV optimization
"softmax" : 88.6574
"where" : 10.1058
"EXTCALL" : 0.815779
"layer_norm" : 0.294408
"gather" : 0.0199144
"STLOCAL" : 0.019813
"LDC_I4" : 0.019661
"reduce_arg" : 0.017026
"reshape" : 0.014239
"LDLOCAL" : 0.0131749
"LDNULL" : 0.00841166
"LDTENSOR" : 0.00521929
"LEA_GP" : 0.00491525
"LDDATATYPE" : 0.00354709
"LDARG" : 0.000405381
"RET" : 0.000202691
"LDTUPLE" : 0.000152018
pie
title Enable RVV optimization
"softmax" : 55.6175
"EXTCALL" : 34.9831
"layer_norm" : 2.0909
"where" : 1.97198
"gather" : 0.84328
"LDC_I4" : 0.834631
"STLOCAL" : 0.819495
"reduce_arg" : 0.735167
"LDLOCAL" : 0.560024
"reshape" : 0.525428
"LDNULL" : 0.367583
"LEA_GP" : 0.222712
"LDTENSOR" : 0.222712
"LDDATATYPE" : 0.164331
"LDARG" : 0.0237848
"RET" : 0.0108113
"LDTUPLE" : 0.00648677
The following is a comparison of the performance of related operators before and after RVV optimization.
From the above comparison results, it can be seen that the RVV optimization can greatly improve the inference performance of the CPU operator and shorten the inference time of the whole model (1973–>46) ms. The time of softmax operator is reduced to 25 ms, the time of layer_norm operator is reduced to 0.97 ms, and the time of where operator is reduced to 0.91 ms. The inference time of the whole model is shortened by 97.6%, which has high application value in the actual model deployment.
2.4 RVV optimization example#
2.4.1 RVV code#
Please refer to layer_norm in nncase, requires some knowledge of RV instructions and V extension instructions.
The calculation formula of layer_norm is:
The overall calculation process is detailed in Functions layernorm_impl, in order to have higher readability of the code, the RVV optimization code is split into three parts:
Calculation
E[x], please refer to Functionget_meanfor details .Calculation
Var[x], please refer to Functionget_varfor details .For the calculation of the layer_norm according to the above formula, please refer to
layer_norm_update1Function.
Since multiplication takes less time than division, the formula transformation is performed in step 3 of the calculation. Using rsqrt instead of sqrt and then using multiplication instead of division.
2.4.2 Core Code Description#
The following is the description of the function get_mean, which implements the loop loading summation of the array at a1, the sum result is stored in v0, and the final average is saved in ret. It utilizes the vector loading of RVV, vector accumulation instructions to achieve summation, thereby improving computing performance.
"vle32.v v8, (a1);" // Load the 32 bit vector at the a1 address to the v8 register.
"sub a0,a0, t0;" // a0 − = t0, for cycle control counting.
"slli t1, t0, 2;" // t1 = t0 < < 2, because each float32 is 4 bytes, so the address is increased by 4 * t0.
"vfredsum.vs v0,v8,v0;" // v0 + = v8, vector sum to v0.
"add a1, a1, t1;" // a1 + = t1, update the loading address.
"bnez a0, XXXXXX%=;" // If a0 ! = 0, jump to the loop start address.
"vfmv.f.s f0, v0;" // Move the v0 vector accumulation result to f0.
"fcvt.s.w f1, %[avl];" // Convert avl to float and save to f1.
"fdiv.s %[ret], f0, f1;" // ret = f0 / f1, get the average value.
2.4.3 Add RVV operator process#
In the following process, the path uses nncase as the root
function declaration: src/Native/src/kernels/stackvm/optimized/opt_ops.h
Operator implementation:
general optimization src/Native/src/kernels/stackvm/optimized
x86 optimization src/Native/src/kernels/stackvm/optimized/x86_64
RVV optimization src/Native/src/kernels/stackvm/optimized/riscv64
Logic call: src/Native/src/kernels/stackvm/tensor_ops.cpp
Modify CMakeLists:src/Native/src/kernels/stackvm/optimized/CMakeLists.txt
General optimization: 15 lines increase the source file name
Platform-specific optimization: 44 lines increase the source file name
2.5 tips#
If you encounter an operator that does not support RVV optimization and need to support it, you are welcome to submit an issue and PR.
