K230 Hardware Design Guide#
Copyright 2023 Canaan Inc. ©
disclaimer#
Trademark Notice#
directory#
[toc]
preface#
overview#
This document mainly introduces the key points and precautions of K230 processor hardware design, aiming to help customers shorten the design cycle of products, improve product design stability and reduce failure rate. Customers are requested to refer to the requirements of this guide for hardware design, and try to use the relevant core templates released by K230. If it needs to be changed for special reasons, please strictly follow the high-speed digital circuit design requirements.
Reader object#
  • Hardware Development Engineer
  • Technical Support Engineer
  • Test Engineer
Glossary#
abbreviation
illustrate
DDR
Double Data Rate
SDRAM
Synchronous Dynamic Random Access Memory
LPDDR
low power double data rate
MIPI
Mobile Industry Processor Interface
OTG
On the Go
APB
Advanced Peripheral Bus
SPI
Serial Peripheral Interface
DMA
Direct Memory Access
AHB
Advanced High Performance Bus
PCM
Pulse Code Modulation
PDM
Pulse Density Modulation
PCLK
Peripheral High-speed Clock
CLK
Clock
DQS
Bi-directional Data Strobe
GPIO
General-purpose Input/Output
eMMC
Embedded Multi-media Card
SIP
System In a Package
PMU
Power Management Unit
Revision history#
Document version number
Modify the description
Modified by
date
first edition
Zhao Ruixin
2023-06-14
1. Chip overview#
1.1 Chip block diagram#
![Figure 1-1 K230 block diagram](../../zh/00_hardware/images/HDG/image002.jpg) Figure 1-1 K230 block diagram
1.2 Application Block Diagram#
Figure 1-2 is the K230 door lock application block diagram ![Figure 1-2 K230 door lock scheme application block diagram](../../zh/00_hardware/images/HDG/image003.jpg) Figure 1-2 K230 door lock scheme application block diagram Figure 1-3 is a block diagram of the dictionary pen scheme ![Figure 1-3 K230 dictionary pen scheme application block diagram](../../zh/00_hardware/images/HDG/image004.jpg) Figure 1-3 K230 dictionary pen scheme application block diagram
2. Package and pinout#
2.1 Encapsulation#
2.1.1 Information#
The package information of the K230 is shown in Table 2-1 below:
Devices
encapsulation
size
Pitch
K230
VFBGA390
13mm x 13mm
0.65
K230D
LFBGA256
11mm x 11mm
0.65
2.1.2 Package size#
K230 size#
![Figure 2-1](../../zh/00_hardware/images/HDG/image005.png) Figure 2-1 ![Figure 2-2](../../zh/00_hardware/images/HDG/image006.png) Figure 2-2 ![Figure 2-3](../../zh/00_hardware/images/HDG/image007.png) Figure 2-3
Spherical solder mask opening: 0.270mm
The main benchmark C and the bottom surface are solder balls
Size b is the measured maximum solder ball diameter, parallel to the main reference C
K230D size#
![Figure 2-4](../../zh/00_hardware/images/HDG/image008.png) Figure 2-4 ![Figure 2-5](../../zh/00_hardware/images/HDG/image009.png) Figure 2-5
2.1.3 Pin definition diagram#
The K230 pinout diagram is as follows: ![Figure 2-6 Pin distribution of K230 package](../../zh/00_hardware/images/HDG/image010.png) Figure 2-6 Pin distribution of K230 package ![Figure 2-7 Pin distribution of K230D package](../../zh/00_hardware/images/HDG/image011.png) Figure 2-7 Pin distribution of K230D package Pin details are shown in TableK230_PINOUT_V1.0_20230524.xlsx
3. Schematic design suggestions#
3.1. Minimal System Design#
3.1.1 Clock Requirements#
The K230’s main system requires a 24MHz high-speed clock, and the PMU subsystem’s RTC requires a low-speed clock of 32.768kHz.
Table 3-1 shows the allowed clock source parameters for K230.
Frequency
precision
Level
32.768KHz
20ppm
1.8V
24MHz
20ppm
1.8V
It is recommended to use a clock source of 20ppm or higher accuracy to provide the clock.
High-speed clock#
The recommended passive crystal connection method is shown in Figure 3-1. ![Figure 3-1 K230 crystal circuit](../../zh/00_hardware/images/HDG/image012.png) Figure 3-1 K230 crystal circuit Note:
  • The capacitor selected needs to match the load capacitance of the crystal oscillator, and the material is recommended to use NPO.
  • It is recommended to use a 4Pin oscillator, and the two GND pins are fully connected to the ground to enhance the system clock’s anti-ESD interference capability.
  • If you need to increase the starting speed, add a 1MΩ resistor between the IN pin and the OUT pin.
The recommended connection method of oscillator is shown in Figure 3-2. ![Figure 3-2 K230 oscillator circuit](../../zh/00_hardware/images/HDG/image013.png) Figure 3-2 K230 oscillator circuit When working, the oscillator output is connected to the CLK24M_XIN pin of the K230, and the CLK24M_XOUT foot is suspended in the air.
Low-speed clock#
The K230 chip has a built-in PMU module, and you should provide a clock circuit for the PMU module. The recommended circuit is shown in Figure 3-3. ![Figure 3-3 K230 RTC clock crystal circuit](../../zh/00_hardware/images/HDG/image014.png) Figure 3-3 K230 RTC clock crystal circuit The recommended connection method of active crystal oscillator is shown in Figure 3-4. ![Figure 3-4 K230 RTC clock oscillator circuit](../../zh/00_hardware/images/HDG/image015.png) Figure 3-4 K230 RTC clock oscillator circuit
When working, the oscillator output is connected to the CLK32K768_XIN feet of the K230, and the CLK32K768_XOUT feet are suspended in the air. Note:
  • When using oscillators, the NC needs to be connected with 0Ω resistors in the above oscillator circuit diagrams.
3.1.2 Reset circuit#
The hardware reset of the K230 is implemented by the function of RSTN, which is active low. If you use the button reset, it is recommended to add 100nF capacitor to the reset signal pin to eliminate the jitter of the reset signal, enhance the anti-interference ability, and prevent abnormal system reset caused by false triggering. A schematic diagram of the reset circuit is shown in Figure 3-5. ![Figure 3-5 K230 reset circuit](../../zh/00_hardware/images/HDG/image016.png) Figure 3-5 K230 reset circuit
3.1.3 System boot sequence#
The K230 chip provides four boot methods, which can be configured through the BOOT0 and BOOT1 pins. Table 3-2 shows the startup mode of K230 under different configurations.
BOOT0
BOOT1
K230
K230D
NOR FLASH
NOR FLASH
NAND FLASH
NAND FLASH
MMC0
MMC1
MMC1
MMC0
Table 3-2 Description of the start-up method
Note:
  • When all four boot methods fail, it will jump to USB/UART boot.
Figure 3-6 shows the recommended BOOT circuit ![Figure 3-6 K230 BOOT circuit](../../zh/00_hardware/images/HDG/image017.png) Figure 3-6 K230 BOOT circuit
3.1.4 JTAG Debug circuit#
The recommended JTAG interface circuit for the K230 chip is shown in Figure 3-7. ![Figure 3-7 K230 JTAG download circuit](../../zh/00_hardware/images/HDG/image018.png) [Figure 3-7 K230 JTAG download circuit.] Among them, JTAG_TCK, JTAG_TDI, JTAG_TMS and JTAG_RST are recommended to use 10kΩ pull-up JTAG_TDO dangling. The K230 must use the CKLink series debugger provided by Pingtouge Semiconductor Co., Ltd., otherwise the chip cannot be debugged.
3.1.5 DDR controller#
The K230 chip is available in K230 and K230D versions, and the K230 version requires a separate DDR circuit. The K230D version packages a DDR Die without the need for external DDR circuitry. The K230 DDR controller has the following features:
  • Support LPDDR3/LPDDR4
  • Support 2 rank
  • Supports 16-bit and 32-bit DDR data bus widths
  • Verified model: | type | Part number | Manufacturer | Capacity | | —— | —————- | ——– | —- | | LPDDR3 | NT6CL128M32DM-H0 | Nanya | 4Gb | | LPDDR4 | W66AP6NBUAF/G/HI | Winbond | 4Gb |
The schematics of the K230 DDR PHY and individual DRAM must match the reference schematic, including the power supply decoupling capacitors.
LPDDR3#
The circuit design of LPDDR3 is based on Figures 3-8, 3-9, 3-10, and 3-11. ![Figure 3-8 K230 LPDDR3 circuit](../../zh/00_hardware/images/HDG/image019.png) Figure 3-8 K230 LPDDR3 circuit ![Figure 3-9 K230 LPDDR3 power supply circuit](../../zh/00_hardware/images/HDG/image020.png) Figure 3-9 K230 LPDDR3 power supply circuit ![Figure 3-10 LPDDR3 particle power supply circuit](../../zh/00_hardware/images/HDG/image021.png) Figure 3-10 LPDDR3 particle power supply circuit ![Figure 3-11 LPDDR3 particle circuit](../../zh/00_hardware/images/HDG/image022.png) Figure 3-11 LPDDR3 particle circuit
When using LPDDR3:
  • The DDR PHY and each DRAM schematic need to be consistent with the reference design diagram, including the power supply decoupling capacitors
  • DDR_ZN pin needs to be connected to ground with a calibration resistor of 240Ω (1%)
  • DDR_RESET pin should be floating
  • The chip has built-in the VREF circuit of the DDR controller, so the DDR_VREF pin needs to be floating
  • The LP3 particles have a LP3_VREFDQ voltage of 0.8V, and it is recommended to divide the voltage using resistors of 100Ω and 200Ω (1%)
  • LP3_VREFCA voltage is 0.6V, it is recommended to use a 1kΩ (1%) resistor generated
  • The CA, CS, CKE, CLK, and ODT pins of LP3 all require 100Ω resistors to be pulled up and down to DDR_VDDQ_1V2 and ground
LPDDR4#
The circuit design of LPDDR4 refers to Figure 3-12, Figure 3-13, Figure 3-14, Figure 3-15, and Figure 3-16. ![Figure 3-12 K230 LPDDR4 circuit](../../zh/00_hardware/images/HDG/image023.png) Figure 3-12 K230 LPDDR4 circuit ![Figure 3-13 K230 LPDDR4 power supply circuit](../../zh/00_hardware/images/HDG/image024.png) K230 LPDDR4 power circuit ![Figure 3-14 K230 LPDDR4 reference voltage circuit](../../zh/00_hardware/images/HDG/image025.png) Figure 3-14 K230 LPDDR4 reference voltage circuit LPDDR4 particle circuit] (../../zh/00_hardware/images/HDG/image026.png) ![Figure 3-16 LPDDR4 particle power supply circuit](../../zh/00_hardware/images/HDG/image027.png) Figure 3-16 LPDDR4 particle power supply circuit
When using LPDDR4, note:
  • RESRT_N pin is connected directly to the corresponding pin of the Dram
  • When the K230 uses LPDDR4 particles, the VREF voltage is 0.6V, and it is recommended to use a 1kΩ (1%) resistor generated
K230D DDR module#
The K230D already has a built-in DDR die, so just connect the reference voltage and calibration resistor. The reference circuits are shown in Figure 3-17 and Figure 3-18
![Figure 3-17 K230D DDR peripheral circuit](../../zh/00_hardware/images/HDG/image028.png) Figure 3-17 K230D DDR peripheral circuit ![Figure 3-18 K230D DDR reference voltage](../../zh/00_hardware/images/HDG/image029.png) Figure 3-18 K230D DDR reference voltage
When using the K230D’s DDR module, note:
  • The VREF voltage is 0.55V, and a 100Ω (1%) resistor divider is recommended
  • 240Ω (1%) for calibration resistor
3.1.6 FLASH#
The K230 has an OSPI/QSPI controller that can be used to connect FLASH memory chips, which has the following features:
  • OSPI supports NOR FLASH in 4/8-BIT MODE
  • OSPI supports up to DDR200, SDR166 NOR FLASH
  • QSPI SUPPORTS NAND&NOR FLASH IN 1/2/4 BIT MODE
  • QSPI SUPPORTS NOR-FLASH UP TO SDR100
OSPI#
The OSPI reference schematics are shown in Figure 3-19 and Figure 3-20 ![Figure 3-19 K230 OSPI circuit](../../zh/00_hardware/images/HDG/image030.png) Figure 3-19 K230 OSPI circuit ![FIG. 3-20 OSPI FLASH CIRCUIT](../../zh/00_hardware/images/HDG/image031.png) FIG. 3-20 OSPI FLASH CIRCUIT
Please place the pull-up resistor according to the requirements of the FLASH chip.
QSPI NOR#
In the QSPI signal, the pins of the CS, CLK, D0, D1, D2 and D3 signals are multiplexed with the pins of the corresponding signals of OSPI, as shown in Table 3-3
QSPI pins
OSPI pins
QSPI_CS
OSPI_CS
QSPI_CLK
OSPI_CLK
QSPI_D0
OSPI_D0
QSPI_D1
OSPI_D1
QSPI_D2
OSPI_D2
QSPI_D3
OSPI_D3
Table 3-3 QSPI and OSPI correspond to the pins
The reference circuit is shown in Figure 3-21 ![FIG. 3-21 QSPI NOR FLASH CHIP CIRCUIT](../../zh/00_hardware/images/HDG/image032.png) FIG. 3-21 QSPI NOR FLASH CHIP CIRCUIT Please place the pull-up resistor according to the requirements of the FLASH chip.
QSPI NAND#
The reference circuit for QSPI NAND is shown in Figure 3-22. ![FIG. 3-22 QSPI NAND FLASH CHIP CIRCUIT](../../zh/00_hardware/images/HDG/image033.png) FIG. 3-22 QSPI NAND FLASH CHIP CIRCUIT Please place the pull-up resistor according to the requirements of the FLASH chip.
3.2. MMC circuit#
The K230 eMMC control circuit has two controllers, MMC0 and MMC1.
MMC0#
The MMC0 controller has the following features:
  • Support SDIO 3.0, operate in 4/1-bits mode, and support up to SDR104
  • Support eMMC5.0 works in 8/4/1-bits mode, supports HS200
  • Supports conversion of 3.3V and 1.8V voltages required by SD cards
MMC0 has more functions and is generally used to control eMMC circuits. The recommended reference circuits for eMMC are shown in Figure 3-23 and Figure 3-24.
![Figure 3-23 K230 eMMC circuit](../../zh/00_hardware/images/HDG/image034.png) Figure 3-23 K230 eMMC circuit ![Figure 3-24 eMMC particle circuit](../../zh/00_hardware/images/HDG/image035.png) Figure 3-24 eMMC particle circuit
Please connect the corresponding pins according to the vender’s requirements. If there are no special requirements, directly connect the corresponding pin.
MMC1#
The MMC1 controller has the following features:
the performance and function of MMC1 interface cannot meet the requirements of controlling eMMC circuits, and can only be used to control SD/TF card circuits. The reference schematics are shown in Figure 3-25, Figure 3-26 and Figure 3-27.
![Figure 3-25 K230 SD card interface circuit](../../zh/00_hardware/images/HDG/image036.png) Figure 3-25 K230 SD card interface circuit ![Figure 3-26 SD card pull-up circuit](../../zh/00_hardware/images/HDG/image037.png) Figure 3-26 SD card pull-up circuit ![Figure 3-27 SD card holder circuit](../../zh/00_hardware/images/HDG/image038.png) Figure 3-27 SD card holder circuit
SD card circuit design should pay attention to:
  • The voltage decoupling capacitor of the SD card pin must not be removed and should be placed close to the card holder
  • Each signal needs to be placed with an ESD device near the SD card holder
  • Each signal requires a pull-up resistor
  • It is recommended to design according to the reference circuit
3.3. USB circuits#
The K230 chip has two built-in USB2.0 OTG controllers, which have the following features:
  • Supports USB 2.0 protocol and backward compatibility with USB 1.1 protocol
  • Support Host mode or Device mode, optional support dynamic switching
  • Host mode supports 480Mbps, 12Mbps, 1.5Mbps transmission rates
  • Device mode supports 480Mbps, 12Mbps transmission mode
The USB circuit reference schematic is shown in Figure 3-28 and Figure 3-29.
![Figure 3-28 K230 USB circuit](../../zh/00_hardware/images/HDG/image039.png) Figure 3-28 K230 USB circuit ![Figure 3-29 USB interface circuit](../../zh/00_hardware/images/HDG/image040.png) Figure 3-29 USB interface circuit
Note:
  • Each signal needs to be placed with an ESD device near the USB base
  • The USB_VBUS power supply of the K230 must be connected in series with a 30kΩ (1%) resistor to a 5V power supply, and cannot be directly connected to the power supply
  • To ensure signal quality, the K230’s USB_TXRTUNE pin must be connected to ground with a 200Ω (1%) resistor
  • USB_ID can be used for the identification of OTG devices, K230 is used as the HOST end when it is grounded, and K230 is used as the SLAVE end when it floats or pulls high
3.4. Audio Circuits#
3.4.1 I2S#
The K230 chip has an I2S controller, which has the following features:
  • Has two inputs and outputs
  • Supports the PHILIP I2S standard
  • Supports left and right and PCM formats
  • Synchronous working mode
  • Master or slave mode is optional
  • Adjustable interface voltage
  • Sample rates 8k to 384kHz
The I2S interface has 3 pins: I2S_CLK, I2S_WS and I2S_SD. I2S_CK is a serial clock signal, I2S_WS is a data frame control signal, and I2S_SD is a serial data signal. I2S interfaces are typically used to connect audio peripherals such as decoders. Figure 3-30 and Figure 3-31 show the K230 I2S interface circuit and some peripheral circuits. ![Figure 3-30 K230 I2S interface circuit](../../zh/00_hardware/images/HDG/image041.png) Figure 3-30 K230 I2S interface circuit ![Figure 3-31 K230 I2S reference peripheral](../../zh/00_hardware/images/HDG/image042.png) Figure 3-31 K230 I2S reference peripheral
3.4.2 PDM#
The K230 supports 4 PDM signal inputs. Sample rates from 8k to 384kHz. PDM interfaces are typically used to access audio devices with PDM interfaces such as digital microphones. Figure 3-32 shows the PDM peripheral circuit of the K230. ![Figure 3-32 K230 PDM peripheral circuit](../../zh/00_hardware/images/HDG/image043.png) Figure 3-32 K230 PDM peripheral circuit
3.4.3 Analog Audio Interface#
The analog audio part of the K230 chip has the following features:
  • Supports 2 DACs and 2 ADCs
  • The DAC supports differential and single-ended outputs, and the ADC supports differential and single-ended inputs
  • Supports low-noise analog microphone bias outputs
The reference circuits for analog audio are shown in Figure 3-33 and Figure 3-34 ![Figure 3-33 K230 analog audio interface circuit](../../zh/00_hardware/images/HDG/image044.png) Figure 3-33 K230 analog audio interface circuit ![Figure 3-34 Audio interface circuit](../../zh/00_hardware/images/HDG/image045.png) Figure 3-34 Audio interface circuit
Note that for better sound quality, it is recommended to consider the following measures:
  • The power supply pins use both large and small capacity low ESR ceramic capacitors
  • The MICBIAS pin requires a large capacity low ESR capacitor
  • The DC-blocking capacitor of the audio input is placed close to the K230 chip
  • The output pin requires filter circuitry or DC-blocking capacitors
3.5. Video Circuits#
3.5.1 MIPI DSI#
The K230’s MIPI DSI controller has the following features:
  • Support 1 signal output
  • Supports 1/2/4 lane mode
  • The maximum speed can reach 1.5Gbps
Each MIPI DSI signal is directly connected. The reference hardware design is shown in Figure 3-35 and Figure 3-36
![Figure 3-35 K230 MIPI DSI interface circuit](../../zh/00_hardware/images/HDG/image046.png) ![Figure 3-35 K230 MIPI DSI interface circuit](../../zh/00_hardware/images/HDG/image047.png) Figure 3-35 K230 MIPI DSI interface circuit ![Figure 3-36 Screen interface circuit](../../zh/00_hardware/images/HDG/image048.png) Figure 3-36 Screen interface circuit Note:
  • MIPI_ATB pin must be floating
  • The MIPI_REXT pin must be connected to a 200Ω (1%) resistor to ground
  • Each pin of this connector circuit is only suitable for the screen of Jinchaohui, please design the circuit according to your own screen module
3.6. Camera circuitry#
3.6.1 MIPI CSI#
The K230’s MIPI CSI controller has the following features:
  • Support up to 3 channels MIPI input, support 1/2/4lane mode
  • It can be configured as up to 3 channel 2lane or 1 channel 4lane and 1 channel 2lane signal input
The MIPI CSI signal is recommended for direct connection. The reference hardware design is shown in Figure 3-37 and Figure 3-38 ![Figure 3-37 K230 MIPI CSI interface circuit](../../zh/00_hardware/images/HDG/image049.png) Figure 3-37 K230 MIPI CSI interface circuit ![Figure 3-38 Camera connector circuit](../../zh/00_hardware/images/HDG/image050.png) Figure 3-38 Camera connector circuit Note:
  • This connector circuit is for internal testing only, please design the circuit according to your needs
3.7. Low-speed subsystem circuits#
3.7.1 I2C circuit#
The K230 chip supports 5 I2C interfaces with the following functions:
  • Support I2C bus master mode
  • Supports 7/10 bit addresses
  • Supports I2C rates up to 3.4Mbit/s
When using I2C peripherals, it is necessary to pay attention to the corresponding power domain power supply, which must be consistent. The SCL and SDA of I2C signals require external pull-up resistors, and resistors with different values are selected according to the bus load and bus rate.
  • In a system of no more than 400kb/s, the recommended resistance is 4.7kΩ;
  • In systems greater than 400 kb/s and less than 3.4 Mb/s, a pull-up resistor of 2.2 kΩ is recommended.
3.7.2 UART circuits#
The K230 supports 5 UART signals, which have the following features:
  • Supports 2-wire UART and 4-wire UART
  • Support RS485 interface
  • Supports baud rates up to 3.125M
  • Support software and hardware flow control, in line with 16750 standard
  • Supports IrDA 1.0 SIR reception
When using UART peripherals, it is necessary to pay attention to the corresponding power domain, which must be consistent.
3.7.3 PWM circuit#
K230 supports 6 PWM signals, which have the following features:
  • Any duty cycle is supported
  • Support programmable output waveform
  • Supports the generation of periodic pulse signals and one-off pulse signals
  • Can be used as a cycle-accurate interrupt generator
  • Supports output glitch removal
3.7.4 MCLK circuit#
The K230 supports the output of 3 MCLK signals. This signal can be used as the camera’s drive clock. The supported output clock frequencies are shown in Table 3-4:
792
132
66.67
46.59
36
28.57
23.76
18.56
594
118.8
66
45.69
34.94
28.29
23.53
18.18
400
113.14
66
44.44
34.43
28.29
22.85
17.39
396
100
60.92
44
33.33
27.31
22.22
16.67
297
99
59.4
42.43
33
27
22
16
264
99
57.14
41.68
33
26.67
21.21
15.38
200
88
56.57
40
31.68
26.4
21.05
14.81
198
84.86
54
39.6
31.26
25.83
20.48
14.29
198
80
52.8
39.6
30.77
25.55
20
13.79
158.4
79.2
50
37.71
30.46
25
19.8
13.33
148.5
74.25
49.5
37.13
29.7
24.75
19.16
12.9
133.33
72
49.5
36.36
29.33
24.75
19.05
12.5
Table 3-4 MCLK output clock frequency (unit: MHz)
3.7.5 ADC circuit#
The K230 integrates a SARADC with a resolution of 11 bits (effective resolution) and a maximum sampling rate of not less than 1MHz. It has the following characteristics:
  • Signal input range: 0-1.8V
  • Supports 6 channel inputs
  • Supports single and continuous sampling
  • Integrated signal conditioning circuitry with a cutoff frequency of 1/2 bandwidth. The ADC can sample the signal directly or design peripheral circuitry as needed
3.7.6 PMU circuit#
The K230’s PMU module is used to control the internal and external power supplies of the management chip. It has a built-in RTC circuit and supports 6 inputs. Its functions are as follows:
Interruption source
Along trigger
Level triggering
Debounce
Edge quantity detection
Long and short press detection
INT_0
support
support
support
support
INT_1
support
support
support
support
INT_2
support
support
INT_3
support
support
INT_4
support
INT_5
support
Two outputs, OUT0 and OUT1, can be used to enable the power supply. In the cold crank state, the PMU only enables the long press interrupt of INT0 and the high input interrupt of INT4 as the trigger source for the PMU module startup. OUT0 and OUT1 default output low with an initial pull-down resistor of approximately 40Ω. When one of the above two interrupts is received, OUT0 pulls high, and OUT1 pulls up after about 50ms. OUT0 and OUT1 can be used to control the enable pins of external PMICs or for other purposes.
3.8. Power Supply Design#
3.8.1 K230 Power Requirements#
module
Power pins
description
CORE
VDD0P8_CORE
CPU0 and other unit power supplies
CPU
VDD0P8_CPU
CPU1 power supply
KPU
VDD0P8_KPU
KPU power supply
DDR controller
VDD0P8_DDR_CORE
DDR’s digital CORE power supply, which can be powered down
VDD1P1_DDR_IO
IO power supply for DDR
VAA_DDR
DDR phase-locked loop power supply
USB
AVDD3P3_USB
The 3.3V power supply used by the USB PHY does not power up when not in use
AVDD1P8_USB
The 1.8V power supply used by the USB PHY does not power up when not in use
PLL
AVDD0P8_PLL
PLL power supply
MIPI
AVDD0P8_MIPI
MIPI 0.8V power supply, not powered up when not in use
AVDD1P8_MIPI
MIPI 1.8V power supply, not powered up when not in use
VDD1P8
VDD1P8
1.8V module power supply
ADC
AVDD1P8_ADC
ADC power supply, which does not power up when not in use
CODEC
AVDD1P8_CODEC
CODEC power supply, can not be powered on when not in use
PMU
AVDD1P8_RTC
The PMU has a built-in RTC power supply and can not be powered on when not in use
AVDD1P8_LDO
The PMU has a built-in LDO power supply and can not be powered on when not in use
MMC
VDD3P3_SD
3.3V output buffer and pre-buffer I/O power supply, which can not be powered up when not in use
IO
VDDIO3P3_0
IO_2-IO_13 power supply, the voltage can be selected from 1.8V or 3.3V, and it can not be powered on when not in use
VDDIO3P3_1
IO_14-IO_25 power supply, the voltage can be selected from 1.8V or 3.3V, and it can not be powered on when not in use
VDDIO3P3_2
IO_26-IO_37 power supply, the voltage can be selected from 1.8V or 3.3V, and it can be unpowered when not in use
VDDIO3P3_3
IO_38-IO_49 power supply, the voltage can be selected 1.8V or 3.3V, and it can not be powered on when not in use
VDDIO3P3_4
IO_50-IO_61 power supply, the voltage can be selected from 1.8V or 3.3V, and it can not be powered on when not in use
VDDIO3P3_5
IO_62-IO_63 power supply, the voltage can be selected from 1.8V or 3.3V, and it can be powered up when not in use
K230D DDR section
VDD1P8_DDR_VDD1
In the K230D, the DDR particle power supply, the K230 does not have this pin
VDD1P1_DDR_VDD2
In the K230D DDR particle power supply, the K230 does not have this pin, and it cannot be powered down
VDD1P1_DDR_VDDQ
The DDR particle power supply in the K230D, the K230 does not have this pin, and it can be powered down
Table 3-6 K230 Power Requirements Table
3.8.2 Power-up timing#
VDD0P8_CORE power-on must be earlier than VDD1P8, the IO interface from VDDIO3P3_0 to VDDIO3P3_5 must be powered on, AVDD0P8_MIPI power-up must be earlier than AVDD1P8_MIPI, AVDD1P8_RTC no later than AVDD1P8_LDO, and the rest of the order is not required.
3.8.3 Power Supply Design Recommendations#
PMU#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
PMU
AVDD1P8_RTC
1.674
1.8
1.98
LDO power supply is recommended
AVDD1P8_LDO
1.674
1.8
1.98
Core modules#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
CORE
VDD0P8_CORE
0.72
0.8
0.88
2250
It is recommended to use DC/DC with a power supply capacity of not less than 3A and low ripple noise
CPU
VDD0P8_CPU
0.72
0.8
0.88
1000
It is recommended to use DC/DC with a power supply capacity of not less than 2A and low ripple noise
KPU
VDD0P8_KPU
0.72
0.8
0.88
3000
It is recommended to use DC/DC with a power supply capacity of not less than 4A and low ripple noise
DDR#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
DDR
VDD0P8_DDR_CORE
0.744
0.8
0.88
400
The power supply ripple is required to be within 4%, and low-noise LDOs that can output high currents are recommended
VDD1P1_DDR_IO(LPDDR4)
1.06
1.1
1.17
800
LP4 ripple requirements are within 5%, and low-noise LDOs that can output large currents are recommended
VDD1P1_DDR_IO(LPDDR3)
1.14
1.2
1.3
800
LP3 ripple requirements are within 10%, and low-noise LDOs that can output large currents are recommended
VAA_DDR
1.674
1.8
1.98
The ripple is required to be within 5% of the typical voltage
K230D DDR Die#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
K230D DDR die
VDD1P8_DDR_VDD1
1.7
1.8
1.95
75
The ripple requirement is within 5% of the typical voltage and is in the same power network as the DDR controller power supply
VDD1P1_DDR_VDD2
1.06
1.1
1.17
450
In the same power network as the VDD1P1_DDR_IO
VDD1P1_DDR_VDDQ
1.06
1.1
1.17
300
Low-noise LDOs that can output high currents are recommended
I/O#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
IO
VDDIO3P3_0
1.62/2.97
1.8/3.3
1.98/3.63
50
The IO unit has a total of 5 sets of voltages, all of which can be configured as 1.8V or 3.3V, each group of voltages controls the output voltage and input voltage of the I/O port of the group, and also controls the output voltage and input voltage of the I/O multiplexed function. The IO voltage should be consistent with the peripheral device to be connected, and if it is inconsistent, level shifting is required.
VDDIO3P3_1
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_2
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_3
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_4
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_5
1.62/2.97
1.8/3.3
1.98/3.63
50
USB#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
USB
AVDD3P3_USB
3.07
3.3
3.63
50
It is recommended to use an LDO for power supply
AVDD1P8_USB
1.674
1.8
1.98
60
PLL#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
PLL
AVDD0P8_PLL
0.72
0.8
0.88
120
It is recommended to use a high-precision LDO for power supply
MIPI#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
MIPI
AVDD0P8_MIPI
0.744
0.8
0.88
100
AVDD1P8_MIPI
1.674
1.8
1.98
30
ADC#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
ADC
AVDD1P8_ADC
1.62
1.8
1.98
CODEC#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
CODEC
AVDD1P8_CODEC
1.62
1.8
1.98
100
other#
Module name
Pins
Minimum voltage(V)
Typical voltage (V)
Maximum voltage(V)
Current (mA)
Notes
other
VDD3P3_SD
2.7
3.3
3.63
50
VDD1P8
1.62
1.8
1.98
500
Note:
  • For the DDR particles required by the K230, the power supply needs to be in the same power network as the main chip power supply.
  • When voltage accuracy requirements and current requirements are met, modules with the same voltage requirements can use the same voltage source. For applications where accuracy is not required, analog modules such as ADCs can also be isolated and connected to the power supply used by digital modules.
  • The K230 integrates DDR_Vref power to the chip DDR controller, and for external particles, the VREF power supply reference design of LPDDR3 is shown in Figure 3-39
![Figure 3-39 LPDDR3 particle Vref circuit](../../zh/00_hardware/images/HDG/image051.png) Figure 3-39 LPDDR3 particle Vref circuit
Resistors with an accuracy of ±1% are recommended for voltage divider resistors. The external particle VREF power supply reference design for LPDDR4 is shown in Figure 3-40.
![Figure 3-40 LPDDR4 particle Vref circuit](../../zh/00_hardware/images/HDG/image052.png) Figure 3-40 LPDDR4 particle Vref circuit
The reference design of the K230D’s DDR module VREF power supply is shown in Figure 3-41
![Figure 3-41 K230D version DDR Vref circuit](../../zh/00_hardware/images/HDG/image053.png) Figure 3-41 K230D version DDR Vref circuit
3.8.4 Dynamic voltage regulation#
The K230’s CPU and KPU power supplies support dynamic voltage regulation to ensure both high performance and low power consumption. The adjustable voltage nodes of the CPU are shown in Table 3-7
Voltage node
Voltage(V)
V_typical
0.8
V_high
0.9
V_ultrahigh
1.0
V_low
0.7
V_retention
0.48
Table 3-8 CPU adjustable voltage nodes
Among them, V_retention is the voltage node for the DDR retention function. The adjustable voltage nodes of the KPU are shown in Table 3-8
Voltage node
Voltage(V)
V_typical
0.8
V_high
0.9
V_ultrahigh
1.0
V_low
0.7
Table 3-9 KPU adjustable voltage nodes
4. PCB design recommendations#
4.1 High-speed PCB design recommendations#
4.1.1 DDR design#
Impedance control: DDR single wire 60Ω, differential (clock CLK, data DQS) 120Ω; Crosstalk requirements: Follow the 3W principle Constant length requirements: the number of vias of the same type of signal line is consistent; The length of the DDR trace in the substrate is shown in Table 4-1, which must be considered when routing the PCB to ensure that the sum of the inner and outer traces meets the equal length requirements. PCB design strongly recommends referring to the design of the K230 EVB, including the selection and placement of traces and capacitors.
Pin number
Pin name
Length(μm)
Length (mil)
N17
DDR_CKE0_CKEA0
3725.8
146.8
P18
DDR_CKE1_CKEA1
4338.56
170.94
T20
DDR_CS0_CSA0
5839.03
230.06
T19
DDR_CS1_CSA1
5528.07
217.81
R19
DDR_CKP_CKAP
6252.24
246.34
R20
DDR_CKN_CKAN
6050.13
238.38
N18
DDR_NC_NC
3937.42
155.13
M17
DDR_NC_NC
1925.8
75.88
P19
DDR_CA9_CAA5
5809.3
228.89
M18
DDR_CA8_CAA4
4033.87
158.93
N20
DDR_CA7_CAA3
4888.23
192.6
N19
DDR_CA6_CAA2
4415.08
173.95
L16
DDR_CA5_CAA1
2171.4
85.55
M19
DDR_CA4_CAA0
4599.65
181.23
L17
DDR_CA3_NC
2258.98
89
M20
DDR_CA2_NA
4190.42
165.1
L20
DDR_CA1_NC
5108.55
201.28
K20
DDR_CA0_NC
4832.33
190.39
L18
DDR_ODT_NC
3849.11
151.65
J18
DDR_NC_CKEB0
2599.43
102.42
J17
DDR_NC_CKEB1
2792.84
110.04
J19
DDR_NC_CSB1
4018.49
158.33
J20
DDR_NC_CSB0
4941.35
194.69
G20
DDR_NC_CKBP
5403.63
212.9
F20
DDR_NC_CKBN
5418.33
213.48
H18
DDR_NC_NC
4350.39
171.41
H19
DDR_NC_NC
4900.25
193.07
E20
DDR_NC_CAB0
5468.25
215.45
G19
DDR_NC_CAB1
4067.91
160.28
G18
DDR_NC_CAB2
3807.29
150.01
H17
DDR_NC_CAB3
3113.45
122.67
F17
DDR_NC_CAB4
2757.73
108.65
F19
DDR_NC_CAB5
4558.27
179.6
D20
DDR_NC_NC
6535.69
257.51
G17
DDR_NC_NC
3477.72
137.02
D19
DDR_NC_NC
5257.59
207.15
F18
DDR_NC_NC
4584.72
180.64
C20
DDR_NC_NC
6979.27
274.98
U17
DDR_DQ29_DQA7
4829.45
190.28
Y18
DDR_DQ28_DQA6
6467.43
254.82
V18
DDR_DQ25_DQA5
5047.5
198.87
W18
DDR_DQ24_DQA4
5267.44
207.54
Y16
DDR_DQ27_DQA3
5846.86
230.37
V16
DDR_DQ26_DQA2
4311.64
169.88
T16
DDR_DQ30_DQA1
3576.39
140.91
U16
DDR_DQ31_DQA0
3132.83
123.43
V17
DDR_DM3_DMIA0
4110.44
161.95
W17
DDR_DQS3P_DQSA0P
6342.48
249.89
Y17
DDR_DQS3N_DQSA0N
6135.17
241.73
R17
DDR_DQ10_DQA8
4018.24
158.32
T18
DDR_DQ12_DQA9
5760.1
226.95
R18
DDR_DQ8_DQA10
4540.62
178.9
U20
DDR_DQ13_DQA11
5625.11
221.63
W19
DDR_DQ11_DQA12
6897.92
271.78
U18
DDR_DQ14_DQA13
4908.14
193.38
P16
DDR_DQ9_DQA14
2036.92
80.25
T17
DDR_DQ15_DQA15
4492.07
176.99
P17
DDR_DM1_DMIA1
4129.14
162.69
V20
DDR_DQS1P_DQSA1P
7005.11
276
V19
DDR_DQS1N_DQSA1N
6768.98
266.7
C17
DDR_DQ0_DQB4
4038.16
159.1
D16
DDR_DQ1_DQB1
3663.33
144.34
D17
DDR_DQ2_DQB0
4242.29
167.15
C18
DDR_DQ3_DQB5
5598.19
220.57
E18
DDR_DQ4_DQB2
3830.51
150.92
E17
DDR_DQ5_DQB3
4273.06
168.36
B19
DDR_DQ6_DQB7
6879.01
271.03
C19
DDR_DQ7_DQB6
6640.84
261.65
D18
DDR_DM0_DMIB0
5275.38
207.85
B18
DDR_DQS0P_DQSB0P
6516.79
256.76
A18
DDR_DQS0N_DQSB0N
6628.66
261.17
C14
DDR_DQ16_DQB11
2966.98
116.9
D14
DDR_DQ20_DQB8
2708.03
106.7
B14
DDR_DQ17_DQB10
4486.79
176.78
A14
DDR_DQ21_DQB9
5608.52
220.98
A17
DDR_DQ19_DQB14
5037.71
198.49
B16
DDR_DQ23_DQB15
4419.48
174.13
C16
DDR_DQ18_DQB13
4381.95
172.65
B17
DDR_DQ22_DQB12
5515.88
217.33
C15
DDR_DM2_DMIB1
4509.87
177.69
B15
DDR_DQS2P_DQSB1P
4623.9
182.18
A15
DDR_DQS2N_DQSB1N
4942.59
194.74
Table 4-1 Chip internal DDR trace length
LPDDR3 part#
  • 数据线内部等长要求:(DQ to DQS domain)DQS_P/N and DQ [7:0] & DM for each byte lane, the length of DQ = DQS +/- 10ps
  • Address line internal isometric requirements: (CS, ODT, CKE, CMD, ADD TO CK/CK#)
  • When routing CK_P/N and CA signals for the memory interface, the length of the CA = CK +/- 10ps
  • DQS与CK之间的等长要求:(DQS to CK domain)When routing DQS for each byte lane, the length of each DQS pair must be (CK – 85ps) <= DQS <= CK
LPDDR4 part#
  • 数据线内部等长要求:DQS_P/N and DQ [7:0] & DM for each byte lane, the length of DQ = DQS +/- 10ps
  • 地址线内部等长要求:(CS, ODT, CKE, Cmd, Add to CK/CK#)When routing CK_P/N and CA signals for the memory interface, the length of the CA = CK +/- 10ps
  • DQS与CK之间的等长要求:When routing DQS for each byte lane, the length of each DQS pair must be (CK – 60ps) <= DQS <= CK
4.1.2 USB 2.0 design#
  • Impedance control: differential 90Ω.
  • The differential pair does not exceed 4ps within the skew, and the maximum allowable number of vias does not exceed 6.
4.1.3 MIPI design#
  • Impedance control: MIPI_DSI differential 100Ω, MIPI_CSI differential 100Ω
  • The equal length within the line pair is controlled at 0.3mm.
