K230 OpenBLAS Development Guide#
disclaimer#
directory#
preface#
overview#
This document focuses on the K230 OpenBLAS.
Reader object#
  • Technical Support Engineer
Definition of acronyms#
abbreviation
illustrate
OpenBLAS
Open Basic Linear Algebra Subprograms
Revision history#
Document version number
Modify the description
Modified by
date
first edition
Algorithm Department
2023-05-30
1.Introduction to OpenBLAS#
OpenBLAS is an optimized BLAS computing library based on the BSD license (open source). BLAS (Basic Linear Algebra Subprograms) is an application program interface (API) standard that specifies the publication of numerical libraries for basic linear algebra operations (such as vector or matrix multiplication), OpenBLAS is a concrete implementation of the BLAS standard. In the SDK, the pre-cross-compiled OpenBLAS library (located under the path) is included,k230_sdk/src/big/utils/lib/openblas/ and users can directly use this static library to compile their own executable programs.
Test case compilation#
Note:
This section explains how to compile executable programs using the default OpenBLAS static libraries in the SDK. The SDK already contains several examples of compiled executable programs based on OpenBLAS implementations (locatedk230_sdk/src/big/utils/examples/openblas/ in the path), and this section builds on these examples.
k230_sdk/src/big/utils/examples/openblas/The directory structure under the path is described as follows:
|-- 1_openblas_level1             # OpenBLAS Example 1
|   |-- CMakeLists.txt            # CMake Configuration File for OpenBLAS Example 1
|   `-- openblas_level1.cpp
|-- 2_openblas_level2
|   |-- CMakeLists.txt
|   `-- openblas_level2.cpp
|-- 3_openblas_level3
|   |-- CMakeLists.txt
|   `-- openblas_level3.cpp
|-- 4_fortran_example
|   |-- CMakeLists.txt
|   `-- openblas_fortran.cpp
|-- CMakeLists.txt               # Overall CMake Configuration File
|-- build_app.sh                 # Overall Compilation Script
|-- cmake                        # Default CMaek configuration
|   |-- Riscv64.cmake
|   `-- link.lds
First, k230_sdk/src/big/utils/examples/openblas/under the path, runbuild_app.sh the file:
./build_app.sh
The following prompt appears in the terminal to indicate that the executable program is compiled successfully:
Install the project...
Finally, all k230_sdk/src/big/utils/examples/openblas/out/binthe compiled ELF files are included in the folder:
  • 1_openblas_level1.elf
  • 2_openblas_level2.elf
  • 3_openblas_level3.elf
  • 4_openblas_fortran.elf
Test case run demo#
level_1 Test Cases#
The following is an example of the operation mode and output result:
This is the result:
4 7 11 14
This is the reference:
4 7 11 14
{Test PASS}.
level_2 Test Cases#
This is the result:
20 40 10 20 30 60
20 40 10 20 30 60
{Test PASS}.
level_3 Test Cases#
This is the result:
7 10 15 22
7 10 15 22
{Test PASS}.
Fortran Interface Test Cases#
This is matrix A
This is matrix B
This is the result:
{Test PASS}.
4.OpenBLAS cross-compilation#
Note:
Although the SDK already contains pre-cross-compiled OpenBLAS libraries (located k230_sdk/src/big/utils/lib/openblas/in the path), interested users can also cross-compile OpenBLAS themselves to get OpenBLAS static libraries adapted to K230.
OpenBLAS compilation environment is set up#
Git code download#
First use git to get the OpenBLAS repository, since OpenBLAS comes from Github, the cloning speed is normal, please be patient:
There are many versions in OpenBLAS, and since version 0.3.21 lacks some features compared to the latest branch, we choose the current one Submit:
Patch Service Pack Application#
Note:
The path of the patch service pack in the SDK isk230_sdk/src/big/rt-smart/userapps/openblas/.
First, in the root directory of OpenBLAS, create a newpatch directory, copy the patch service package to patchthe directory, and the folder directory structure is shown below:
├── appveyor.yml
├── azure-pipelines.yml
├── BACKERS.md
├── benchmark
├── cblas.h
├── common_lapack.h
├── common_level1.h
├── common_level2.h
├── common_level3.h
├── common_linux.h
├── common_loongarch64.h
├── common_macro.h
|-- patch # Patch Pack for OpenBLAS
| |-- 0001-****.patch
| |-- 0002-****.patch
| |-- 0003-****.patch
| |-- 0009-****.patch
| |-- 0010-****.patch
| |-- 0011-****.patch
├── utest
└── version.h
Run the following command in the OpenBLAS root directory to apply the patch:
git am ./patch/*.patch
OpenBLAS compilation#
Go to the root directory of OpenBLAS and execute the following command to compile:
# Note: The tool chain path may vary depending on the developer's specific environment, and the path prefix may vary for reference only.
After the compilation is complete, the compiled library is installed in the specified folder, and this example is installed in the folder./install:
# Note: You can modify the corresponding installation path according to your own needs.
