K230 OpenBLAS Development Guide#
Introduction to OpenBLAS#
OpenBLAS is an optimized BLAS computation library distributed under the BSD license (open-source). BLAS (Basic Linear Algebra Subprograms) is an API standard for releasing numerical libraries for basic linear algebra operations (such as vector or matrix multiplication). OpenBLAS is a specific implementation of the BLAS standard. In the SDK, a pre-cross-compiled OpenBLAS library is included (located at the path k230_sdk/src/big/utils/lib/openblas/). Users can directly use this static library to compile their own executable programs.
Test Case Compilation#
Note:
This section explains how to compile executable programs using the pre-set OpenBLAS static library in the SDK. The SDK includes multiple examples of executable program compilation based on OpenBLAS (located at k230_sdk/src/big/utils/examples/openblas/). This section explains based on these examples.
The directory structure under the path k230_sdk/src/big/utils/examples/openblas/ is as follows:
|-- 1_openblas_level1             # OpenBLAS Example 1
|   |-- CMakeLists.txt            # CMake configuration file for OpenBLAS Example 1
|   `-- openblas_level1.cpp
|-- 2_openblas_level2
|   |-- CMakeLists.txt
|   `-- openblas_level2.cpp
|-- 3_openblas_level3
|   |-- CMakeLists.txt
|   `-- openblas_level3.cpp
|-- 4_fortran_example
|   |-- CMakeLists.txt
|   `-- openblas_fortran.cpp
|-- CMakeLists.txt               # Overall CMake configuration file
|-- build_app.sh                 # Overall compilation script
|-- cmake                        # Default CMake configuration
|   |-- Riscv64.cmake
|   `-- link.lds
First, run the build_app.sh file under the path k230_sdk/src/big/utils/examples/openblas/:
./build_app.sh
If the following prompt appears in the terminal, it indicates that the executable program has been successfully compiled:
Install the project...
Finally, the k230_sdk/src/big/utils/examples/openblas/out/bin folder contains all the compiled elf files:
  • 1_openblas_level1.elf
  • 2_openblas_level2.elf
  • 3_openblas_level3.elf
  • 4_openblas_fortran.elf
Test Case Execution Demonstration#
level_1 Test Case#
Execution method and output example:
This is the result:
4 7 11 14
This is the reference:
4 7 11 14
{Test PASS}.
level_2 Test Case#
This is the result:
20 40 10 20 30 60
20 40 10 20 30 60
{Test PASS}.
level_3 Test Case#
This is the result:
7 10 15 22
7 10 15 22
{Test PASS}.
Fortran Interface Test Case#
This is matrix A
This is matrix B
This is the result:
{Test PASS}.
OpenBLAS Cross Compilation#
Note:
Although the SDK includes a pre-cross-compiled OpenBLAS library (located at the path k230_sdk/src/big/utils/lib/openblas/), interested users can also cross-compile OpenBLAS themselves to obtain the OpenBLAS static library adapted to K230.
Setting Up the OpenBLAS Compilation Environment#
Git Code Download#
First, use git to obtain the OpenBLAS repository. Since OpenBLAS comes from GitHub, slow cloning speed is normal, please be patient:
OpenBLAS has many versions. Since version 0.3.21 lacks some features compared to the latest branch, we use the current latest commit:
Applying Patch Package#
Note:
The patch package is located in the SDK at k230_sdk/src/big/rt-smart/userapps/openblas/.
First, create a patch directory in the root directory of OpenBLAS and copy the patch package to the patch directory. The directory structure after placing the folder is shown as follows:
├── appveyor.yml
├── azure-pipelines.yml
├── BACKERS.md
├── benchmark
├── cblas.h
├── common_lapack.h
├── common_level1.h
├── common_level2.h
├── common_level3.h
├── common_linux.h
├── common_loongarch64.h
├── common_macro.h
|-- patch # Patch package for OpenBLAS
| |-- 0001-****.patch
| |-- 0002-****.patch
| |-- 0003-****.patch
| |-- 0009-****.patch
| |-- 0010-****.patch
| |-- 0011-****.patch
├── utest
└── version.h
Execute the following command in the root directory of OpenBLAS to apply the patches:
git am ./patch/*.patch
OpenBLAS Compilation#
Enter the root directory of OpenBLAS and execute the following command to compile:
# Note: The toolchain path will vary depending on the developer's specific environment, and the path prefix is for reference only.
After the compilation is complete, install the compiled library to a specified folder. In this example, it is installed in the ./install folder:
# Note: You can modify the installation path according to your needs.
