K230_DRM_API_Reference#
Directory#
preface#
This document mainly introduces the DRM driver and its user-mode interface libdrm library
Reader object#
This document is intended primarily for:
  • Technical Support Engineer
Definition of acronyms#
abbreviation
illustrate
DRM
Direct Rendering Manager
KMS
Kernel Mode Setting
GEM
Graphics Execution Manager
Revision history#
Document version number
Modify the description
Author
date
Initial edition
Author
2023/06/29
Introduction to DRM#
DRM is the management architecture responsible for interacting with the graphics card in the Linux kernel, and user programs can easily use the API provided by DRM to achieve display control, 3D rendering, video encoding and decoding, GPU computing and other work
DRM architecture features#
DRM is the mainstream graphics display framework in the current Linux kernel, compared with the traditional FB architecture, it has the following characteristics:
  1. DRM architecture natively supports multi-layer synthesis, FB schema natively does not support multi-layer synthesis
  2. The DRM architecture natively supports VSYNC, DMA_BUF, and Fence mechanisms
  3. The DRM architecture manages rendering and display drivers in a unified manner, making software development and maintenance simpler
DRM architecture composition#
From the overall architecture, DRM is mainly divided into three parts:
  • libdrm
    libdrm encapsulates the underlying interface and provides a common API interface to user patterns
    libdrm also provides a modetest program internally for querying the details of DRM devices, as well as basic display testing
  • KMS
    KMS stands for Kernel Mode Settings, which mainly sets display resolution, color space, refresh rate, and display buffer switching and multilayer compositing
  • GEM
    Memory management, responsible for memory allocation and release
ModeTest instructions#
modetest is a test program provided by libdrm that can query the details of DRM devices while also performing basic display tests
Query K230 DRM details#
The specific instructions are as follows:
Encoders:
id      crtc    type    possible crtcs  possible clones
37      36      DSI     0x00000001      0x00000001
Connectors:
id      encoder status          name            size (mm)       modes   encoders
38      37      connected       DSI-1           68x120          1       37
  modes:
  #1080x1920 30.00 1080 1310 1330 1350 1920 1925 1931 1939 78529 flags: ; type: preferred, driver
  props:
        1 EDID:
                flags: immutable blob
                blobs:
                value:
        2 DPMS:
                flags: enum
                value: 0
        5 link-status:
                flags: enum
                enums: Good=0 Bad=1
                value: 0
        6 non-desktop:
                flags: immutable range
                values: 0 1
                value: 0
        4 TILE:
                blobs:
                value:
CRTCs:
id      fb      pos     size
36      0       (0,0)   (1080x1920)
  props:
        24 VRR_ENABLED:
                flags: range
                values: 0 1
                value: 0
        28 GAMMA_LUT:
                flags: blob
                blobs:
                value:
        29 GAMMA_LUT_SIZE:
                values: 0 4294967295
                value: 256
Planes:
id      crtc    fb      CRTC x,y        x,y     gamma size      possible crtcs
31      0       0       0,0             0,0     0               0x00000001
  formats: NV12 NV21 NV16 NV61
  props:
        8 type:
                flags: immutable enum
                value: 0
32      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 1
33      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 2
34      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 0
35      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 0
Frame buffers:
id      size    pitch
[root@canaan ~ ]#
The above information is the K230 DRM details, here is a brief description:
Module ID
Module name
Module description
37
Encoder
none
38
Connector
none
36
CRTC
Resolution support: 1080x1920
31
Video layer
Color space support: NV12, NV21, NV16, NV61
32
OSD layer
Color space support: AR24, AR12, AR15, RG24, RG16
33
OSD layer
34
OSD layer
35
OSD layer
AR24 Display ARGB8888
AR12 Display ARGB4444
AR15 Display ARGB1555
RG24 means RGB888
RG16 stands for RGB565
The 2.2 video layer outputs smpte color bars with NV12 color space#
The following figure shows the LCD display:
Display content
The OSD layer outputs tiles color bars, and the color space is AR24(ARGB8888)#
Display content
OSD layer outputs tiles color bars with a color space of RG16(RGB565)#
Display content
Introduction to DRM API#
Turn on the DRM device#
    if (fd < 0) {
        return -1;
Retrieving DRM resources#
typedef struct _drmModeRes {
        int count_fbs;
        uint32_t *fbs;
        int count_crtcs;
        uint32_t *crtcs;
        int count_connectors;
        uint32_t *connectors;
        int count_encoders;
        uint32_t *encoders;
} drmModeRes, *drmModeResPtr;
An example of a code call is as follows:
    if (res == NULL) {
        return -1;
    conn_id = res->connectors[0];
    crtc_id = res->crtcs[0];
Retrieving layer resources#
        uint32_t count_planes;
        uint32_t *planes;
    if (plane_res == NULL) {
        return -1;
In K230 DRM, the layer correspondence is as follows:
plane_res->plans[0] stand for Video layer
plane_res->plans[1] to plane_res->plans[4] stand for OSD layer
Obtaining Connectors#
        uint32_t connector_id;
        uint32_t connector_type;
        uint32_t connector_type_id;
        drmModeConnection connection;
        drmModeSubPixel subpixel;
        int count_modes;
        drmModeModeInfoPtr modes;
        int count_props;
        int count_encoders;
    if (conn == NULL) {
        return -1;
Apply for DRM DUMB buffer#
    creq.width = 1080;
    creq.height = 1920;
    creq.bpp = 32;
    if (ret < 0) {
            errno);
        return -errno;
Submit DRM Requests#
                   drmModeAtomicReqPtr req,
                   uint32_t flags,
                   void *user_data);
Precautions#
  1. K230 DRM development and testing rely on LCD screens
  2. K230 DRM internal module ID is not static, we should according to the actual ID of each module
