K230 RVV optimization performance description#
Directory#
[toc]
preface#
This document describes the impact of RVV on model inference performance.
Reader object#
  • Technical Support Engineer
Revision history#
Document version number
Modify the description
Author
date
Initial edition
Yang Haoqi
2023/08/04
In recent years, the rapid development of the field of AI has derived a variety of neural network models, and new operators are constantly emerging. However, the iteration cycle of the AI chip is much longer than that of the AI model, and most of these newly emerged operators cannot directly use the AI chip for inference acceleration, and some of the old operators are not suitable for inference acceleration using the AI chip.Therefore, the CPU becomes the execution carrier of this part of operators, which also means that the performance of the CPU will become a factor affecting the final performance when the model is deployed, and the RVV expansion is an important means for RISC-V CPU to improve performance. The C908 dual-core processor used in K230 has the characteristics of RVV1.0 expansion, which can greatly improve the performance of CPU operator inference.
K230 needs to use the model in .kmodel format for model inference. .kmodel is compiled by nncase for ONNX and TFLite models. It is suitable for the development board produced by our company and related cooperative enterprises. nncase supports common neural network operators, but some operators cannot be accelerated by K230, and these operators can only be inferred using CPU.
RVV application scenarios#
At present, the most widely studied and applied neural network Transformer is quite different with CNN, and many AI chips designed based on CNN cannot fully accelerate Transformer. The following is the operator execution of the Decoder model with RVV optimization enabled and without RVV optimization, which is a sub-model in Transformer.
RVV optimization is not enabled#
stackvm tensor op
count
time consumption(ms)
percentage(%)
softmax
5
1749.61
88.6574
where
4
199.432
10.1058
EXTCALL
65
16.099
0.815779
layer_norm
7
5.81
0.294408
gather
0.393
0.0199144
STLOCAL
212
0.391
0.019813
LDC_I4
241
0.388
0.019661
reduce_arg
0.017026
reshape
26
0.281
0.014239
LDLOCAL
149
0.26
0.0131749
LDNULL
106
0.166
0.00841166
LDTENSOR
29
0.103
0.00521929
LEA_GP
58
0.097
0.00491525
LDDATATYPE
29
0.07
0.00354709
LDARG
5
0.008
0.000405381
RIGHT
0.000202691
LDTUPLE
0.000152018
total
941
1973.45
100
Enable RVV optimization#
stackvm tensor op
count
percentage(%)
softmax
5
25.722
55.6175
EXTCALL
65
16.179
34.9831
layer_norm
7
0.967
2.0909
where
4
0.912
1.97198
gather
0.39
0.84328
LDC_I4
241
0.386
0.834631
STLOCAL
212
0.379
0.819495
reduce_arg
0.735167
LDLOCAL
149
0.259
0.560024
reshape
26
0.243
0.525428
LDNULL
106
0.17
0.367583
LEA_GP
58
0.103
0.222712
LDTENSOR
29
0.103
0.222712
LDDATATYPE
29
0.076
0.164331
LDARG
5
0.011
0.0237848
RIGHT
0.0108113
LDTUPLE
0.00648677
total
941
46.248
100
Performance Analysis and Description#
From the above model inference situation, the KPU unit of K230 does not support hardware acceleration for softmax, layer_norm, where, gather, reduce_arg, and reshape, so we need to use CPU (C908) to implement inference. At present, the RVV optimization of softmax, layer_norm and where has been completed, and the performance has been improved significantly.
The following is a graph of the proportion of each operator in the model inference time before and after RVV optimization.
pie
    title without RVV optimization
    "softmax" : 88.6574
    "where" : 10.1058
    "EXTCALL" : 0.815779
    "layer_norm" : 0.294408
    "gather" : 0.0199144
    "STLOCAL" : 0.019813
    "LDC_I4" : 0.019661
    "reduce_arg" : 0.017026
    "reshape" : 0.014239
    "LDLOCAL" : 0.0131749
    "LDNULL" : 0.00841166
    "LDTENSOR" : 0.00521929
    "LEA_GP" : 0.00491525
    "LDDATATYPE" : 0.00354709
    "LDARG" : 0.000405381
    "RET" : 0.000202691
    "LDTUPLE" : 0.000152018
pie
    title Enable RVV optimization
    "softmax" : 55.6175
    "EXTCALL" : 34.9831
    "layer_norm" : 2.0909
    "where" : 1.97198
    "gather" : 0.84328
    "LDC_I4" : 0.834631
    "STLOCAL" : 0.819495
    "reduce_arg" : 0.735167
    "LDLOCAL" : 0.560024
    "reshape" : 0.525428
    "LDNULL" : 0.367583
    "LEA_GP" : 0.222712
    "LDTENSOR" : 0.222712
    "LDDATATYPE" : 0.164331
    "LDARG" : 0.0237848
    "RET" : 0.0108113
    "LDTUPLE" : 0.00648677
The following is a comparison of the performance of related operators before and after RVV optimization.
RVV
From the above comparison results, it can be seen that the RVV optimization can greatly improve the inference performance of the CPU operator and shorten the inference time of the whole model (1973–>46) ms. The time of softmax operator is reduced to 25 ms, the time of layer_norm operator is reduced to 0.97 ms, and the time of where operator is reduced to 0.91 ms. The inference time of the whole model is shortened by 97.6%, which has high application value in the actual model deployment.
RVV optimization example#
RVV code#
Please refer to layer_norm in nncase, requires some knowledge of RV instructions and V extension instructions.
The calculation formula of layer_norm is:
The overall calculation process is detailed in Functions layernorm_impl, in order to have higher readability of the code, the RVV optimization code is split into three parts:
  1. Calculation E[x], please refer to Function get_mean for details .
  2. Calculation Var[x], please refer to Function get_var for details .
  3. For the calculation of the layer_norm according to the above formula, please refer to layer_norm_update1 Function.
Since multiplication takes less time than division, the formula transformation is performed in step 3 of the calculation. Using rsqrt instead of sqrt and then using multiplication instead of division.
Core Code Description#
The following is the description of the function get_mean, which implements the loop loading summation of the array at a1, the sum result is stored in v0, and the final average is saved in ret. It utilizes the vector loading of RVV, vector accumulation instructions to achieve summation, thereby improving computing performance.
"vle32.v v8, (a1);"   // Load the 32 bit vector at the a1 address to the v8 register.
"sub a0,a0, t0;"      // a0 − = t0, for cycle control counting.
"slli t1, t0, 2;"     // t1 = t0 < < 2, because each float32 is 4 bytes, so the address is increased by 4 * t0.
"vfredsum.vs v0,v8,v0;"  // v0 + = v8, vector sum to v0.
"add a1, a1, t1;"      // a1 + = t1, update the loading address.
"bnez a0, XXXXXX%=;"   // If a0 ! = 0, jump to the loop start address.
"vfmv.f.s f0, v0;"     // Move the v0 vector accumulation result to f0.
"fcvt.s.w f1, %[avl];"  // Convert avl to float and save to f1.
"fdiv.s %[ret], f0, f1;" // ret = f0 / f1, get the average value.
Add RVV operator process#
In the following process, the path uses nncase as the root
  1. function declaration: src/Native/src/kernels/stackvm/optimized/opt_ops.h
  2. Operator implementation:
    • general optimization src/Native/src/kernels/stackvm/optimized
    • x86 optimization src/Native/src/kernels/stackvm/optimized/x86_64
    • RVV optimization src/Native/src/kernels/stackvm/optimized/riscv64
  3. Logic call: src/Native/src/kernels/stackvm/tensor_ops.cpp
  4. Modify CMakeLists:src/Native/src/kernels/stackvm/optimized/CMakeLists.txt
    • General optimization: 15 lines increase the source file name
    • Platform-specific optimization: 44 lines increase the source file name
tips#
If you encounter an operator that does not support RVV optimization and need to support it, you are welcome to submit an issue and PR.
