K230D SDK Zero Board Demo Usage Guide#
Foreword#
This document mainly introduces the demo programs provided in the K230 SDK that are adapted to the Canmv-K230D-Zero development board.
Intended Audience#
  • Technical Support Engineers
Abbreviation Definitions#
Abbreviation
UVC
USB video class (USB camera)
VVI
Virtual video input, mainly used for pipeline debugging
Document Version
Author
Date
Initial version
System Software Department
2023-10-11
This document introduces the demo functions provided by the K230 SDK, usage methods, etc.
Demo Introduction#
Vicap_demo#
Vicap_demo Introduction#
The vicap demo implements camera data capture and preview functions by calling the mpi interface.
Feature Description#
Dependency Resources#
Camera module
Usage Instructions#
Compilation#
  1. Execute make mpp-clean && make rt-smart && make build-image in the k230_sdk directory to compile the changes into the SD card image. The image file sysimage-sdcard.img will be generated in the k230_sdk/output/k230_evb_defconfig/images/ directory.
Execution#
  1. On the main core, navigate to /sdcard/app using the command cd /sdcard/app.
  2. Execute the command ./sample_vicap in this directory to get command help information.
When the command sample_vicap is entered, the following prompt information is printed:
Options:
 -rotation:     display rotation[0: degree 0, 1: degree 90, 2: degree 270, 3: degree 180, 4: unsupported rotation]
Parameter Name
Optional Values
-dev
0: vicap device 0, 1: vicap device 1, 2: vicap device 2.
Specifies the current vicap device. The system supports up to three vicap devices. By specifying the device number, the sensor can be bound to different vicap devices. For example: -dev 1 -sensor 0 means binding the ov9732 1280x720 RGB image output to vicap device 1.
-mode
Specifies the vicap device work mode. Currently, there are online and offline modes. For multiple sensor inputs, it must be specified as offline mode.
-conn
0: screen hx8399; 1: HDMI; 3: st7701 480x800
Specifies the display method, either screen or HDMI. The default is 0.
-sensor
19: OV5647 (Canmv-K230D-Zero board)
Specifies the current sensor type
-chn
0: vicap device output channel 0; 1: vicap device output channel 1; 2: vicap device output channel 2.
Specifies the current vicap device output channel. A vicap device supports up to three outputs, with only channel 0 supporting RAW image format output.
-ow
Specifies the output image width, defaulting to the input image width. The width needs to be aligned to 16 bytes. If the default width exceeds the maximum width of the display output, the display output width is used as the final output width. If the output width is less than the input image width and the ox or oy parameters are not specified, it defaults to scaling output.
-oh
Specifies the output image height, defaulting to the input image height. If the default height exceeds the maximum height of the display output, the display output height is used as the final output height. If the output height is less than the input image height and the ox or oy parameters are not specified, it defaults to scaling output.
-ox
Specifies the horizontal start position of the image output. If this parameter is greater than 0, a cropping operation is performed.
-oy
Specifies the vertical start position of the image output. If this parameter is greater than 0, a cropping operation is performed.
-crop
0: disable cropping; 1: enable cropping
When the output image size is smaller than the input image size, it defaults to scaling output. If this flag is specified, it outputs as cropped.
-ofmt
0: yuv format output; 1: rgb format output; 2: raw format output
Specifies the output image format, defaulting to yuv output.
-preview
0: disable preview; 1: enable preview
Specifies the output image preview display function. The default is enabled. Currently, up to two output images can be previewed simultaneously.
-rotation
0: rotate 0 degrees; 1: rotate 90 degrees; 2: rotate 180 degrees; 3: rotate 270 degrees; 4: unsupported rotation
Specifies the rotation angle of the preview display window. By default, only the first output image window supports rotation.
Explanation: Bind ov5647@1920x1080 to vicap device 0, enable vicap device output channel 0, and display 800x480 through the screen.
DMA_demo#
DMA_demo Introduction#
Non-Binding Mode#
DMA channels 0-3 are GDMA, and 4-7 are SDMA.
  • Channel 0 continuously inputs an image with a resolution of 1920x1080, 8bit, YUV400, single-channel mode, rotates 90 degrees, and outputs, comparing with golden data.
  • Channel 1 continuously inputs an image with a resolution of 1280x720, 8bit, YUV420, dual-channel mode, rotates 180 degrees, and outputs, comparing with golden data.
  • Channel 2 continuously inputs an image with a resolution of 1280x720, 10bit, YUV420, triple-channel mode, x-mirror, y-mirror, and outputs, comparing with golden data.
  • Channel 4 is in 1D mode, cyclically transmitting a segment of data, and compares with golden data after transmission.
  • Channel 5 is in 2D mode, cyclically transmitting a segment of data, and compares with golden data after transmission.
Binding Mode#
Use VVI as DMA simulated input, bind channel 0 of VVI device 0 to DMA channel 0, and bind channel 1 of VVI device 0 to DMA channel 1. VVI inputs a 640x320, YUV400, 8bit image rotated 90° to channel 0 every second, and a 640x320, YUV400, 8bit image rotated 180° to channel 1.
Includes DMA device attribute configuration, channel attribute configuration, graphic input, output, release, pipeline binding, and other functions.
Usage Instructions#
Compilation#
Execution#
  1. Non-binding mode demo run
/sdcard/app/sample_dma.elf
Test information will be displayed on the screen, and input q to end the run.
  1. Binding mode demo run
USB_demo#
USB_demo Introduction#
The USB demo currently has four functions debugged:
As a device, it simulates a USB drive and simulates a mouse and keyboard.
As a host, it connects to a USB drive and connects to a mouse and keyboard.
The USB demo functions are originally integrated into the Linux system.
Usage Instructions#
Simulate USB Drive as Device#
# Allocate a memory space as the disk space for the simulated USB drive.
2+0 records in
2+0 records out
mkfs.fat 4.1 (2017-01-24)
## Use the FAT partition of SD/eMMC as the disk space for the simulated USB drive.
Connect the USB port of the development board, and the Type-C connects to the PC. The PC will display the USB drive connection.
Connect USB Drive as Host#
The USB port of the K230 development board connects to a USB drive through a Type-C to Type-A adapter.
Simulate Mouse and Keyboard as Device#
The USB port of the K230 development board connects to another computer device via Type-C for testing.
# Input the corresponding operations as prompted, such as -123 -123, and you can see the mouse pointer move on the PC.
# Input the corresponding operations as prompted, and you can see similar keyboard inputs on the PC. For example, a b c --return
Connect Mouse and Keyboard as Host#
The USB port of the K230 development board connects to a mouse or keyboard through a Type-C to Type-A adapter.
# Use the following command to determine the event corresponding to the input device. If the K230 development board is not connected to a screen, the event corresponding to the connected mouse and keyboard will change.
U: Uniq=
H: Handlers=event2
B: PROP=0
B: EV=17
B: KEY=ffff0000 0 0 0 0
B: REL=1943
B: MSC=10
# Click or move the mouse, and corresponding information will be displayed on the serial port.
# Press different keys on the keyboard, and corresponding information will be displayed on the serial port.
FFT Demo#
Demo Introduction#
This demo is used to verify the usage of the FFT API and test the FFT functionality. The code can be found in src/big/mpp/userapps/sample/sample_fft/.
First, perform FFT calculation, then perform IFFT calculation.
Usage Instructions#
Compilation#
Execution#
  1. After the system is up, execute the following commands on the main core command line:
    cd /sdcard/app; ./sample_fft.elf
    The main core serial port will output the following content:
        max diff 0003 0001
        max diff 0003 0002
        max diff 0003 0001
        max diff 0003 0003
        max diff 0005 0002
        max diff 0005 0003
        max diff 0005 0002
