K230 Video Encoding and Decoding API Reference
Contents
K230 Video Encoding and Decoding API Reference#
The products, services, or features you purchase are subject to the commercial contracts and terms of Canaan Creative Information Technology Co., Ltd. (“the Company”, hereinafter) and its affiliated companies. All or part of the products, services, or features described in this document may not be within the scope of your purchase or usage. Unless otherwise agreed in the contract, the Company does not provide any express or implied statements or warranties regarding the accuracy, reliability, completeness, merchantability, fitness for a particular purpose, and non-infringement of any statements, information, or content in this document. Unless otherwise agreed, this document is only for guidance and reference.
The content of this document may be updated or modified periodically without any notice due to product version upgrades or other reasons.
Trademark Statement#
logo “Canaan” and other Canaan trademarks are trademarks of Canaan Creative Information Technology Co., Ltd. and its affiliated companies. All other trademarks or registered trademarks mentioned in this document are owned by their respective owners.
Copyright © 2023 Canaan Creative Information Technology Co., Ltd. All rights reserved. Without the written permission of the Company, no unit or individual may excerpt, copy any part or all of the content of this document, or disseminate it in any form.
Table of Contents#
This document mainly introduces the functions and usage of the video encoding and decoding module.
Target Audience#
This document (guide) is mainly applicable to the following personnel:
  • Technical Support Engineers
Abbreviation Definitions#
Abbreviation
Document Version
Author
Date
Modification Description
System Software Department
2023.03.10
Initial version
V1.1
2023.03.31
1. Added 2D mode setting/getting interfaces kd_mpi_venc_set_2d_mode, kd_mpi_venc_get_2d_mode 2. Modified 2D parameter setting/getting interfaces kd_mpi_venc_set_2d_osd_param, kd_mpi_venc_get_2d_osd_param 3. Added interface for setting image format conversion coefficients in 2D computation kd_mpi_venc_set_2d_set_custom_coef 4. Removed pic_format attribute from encoder attribute structure k_venc_attr
V1.1.1
2023.04.11
1. Added encoding image rotation setting/getting interfaces kd_mpi_venc_set_rotaion, kd_mpi_venc_get_rotaion 2. Added 2D border attribute setting/getting interfaces kd_mpi_venc_set_2d_border_param, kd_mpi_venc_get_2d_border_param 3. Deleted 2D computation attribute structure k_venc_2d_attr 4. Added description of OSD background layer format 5. Added some MAPI function interfaces and data types, specifically in Chapter 4 MAPI
V1.2
2023.04.27
1. Modified line width parameter of 2D border structure k_venc_2d_border_attr 2. Modified 2D user-defined conversion coefficient API name kd_mpi_venc_set_2d_custom_coef 3. Modified conversion coefficient parameter type of kd_mpi_venc_set_2d_custom_coef 4. Added interface for getting conversion coefficients kd_mpi_venc_get_2d_custom_coef 5. Added color gamut setting/getting interfaces kd_mpi_venc_set_2d_color_gamut, kd_mpi_venc_get_2d_color_gamut 6. Modified rotation angle parameter of kd_mpi_venc_set_rotaion 7. Modified input format description of JPEG in video encoding function
V1.2.1
2023-04-28
1. Added GOP attribute in k_venc_chn_attr
V1.2.2
2023-05-24
1. Added image flip setting/getting interfaces kd_mpi_venc_set_mirror, kd_mpi_venc_get_mirror 2. Added IDR frame enable interface kd_mpi_venc_enable_idr
V1.3
2023-05-25
1. Added IDR frame enable interface in MAPI kd_mapi_venc_request_idr
V1.3.1
2023-06-14
1. Added mpi setting for decoding output downscaled image kd_mpi_vdec_set_downscale
V1.3.2
2023-06-19
1. Modified kd_mapi_venc_request_idr 2. Added kd_mpi_venc_request_idr, kd_mapi_venc_enable_idr 3. Added H.265 SAO setting/getting interfaces kd_mpi_venc_set_h265_sao, kd_mpi_venc_get_h265_sao 4. Added deblocking setting/getting interfaces kd_mpi_venc_set_dblk, kd_mpi_venc_get_dblk 5. Added ROI interfaces kd_mpi_venc_set_roi_attr, kd_mpi_venc_get_roi_attr
V1.3.3
2023-06-20
1. Added H.264/H.265 entropy coding mode setting/getting interfaces kd_mpi_venc_set_h264_entropy, kd_mpi_venc_get_h264_entropy, kd_mpi_venc_set_h265_entropy, kd_mpi_venc_get_h265_entropy 2. Renamed k_venc_rotation enumeration to k_rotation 3. Added decoding rotation setting interface kd_mpi_vdec_set_rotation
V1.3.4
2023-06-30
Modified data types supported by encoding, decoding, and 2D
1. Overview#
1.1 Overview#
The video encoding and decoding module supports H.264, H.265, and JPEG encoding and decoding. The VENC module implements 2D computation and encoding functions, which can be enabled simultaneously or used separately. The VDEC module implements decoding functions.
VENC, VENC+2D, and VDEC support system binding, while 2D computation alone does not support system binding.
1.2 Function Description#
1.2.1 Video Encoding#
encode flow
Figure 1-1 Encoding Data Flow Diagram
The typical encoding process includes receiving the input image, masking and overlaying the image content, encoding the image, and outputting the code stream.
The encoding module consists of the VENC receiving channel, encoding channel, 2D receiving channel, and 2D computation module. The encoding and 2D computation capabilities are shown in the table below.
The green arrows in the encoding data flow diagram indicate the process of 2D computation alone. The blue arrows indicate the process of encoding alone. The purple arrows indicate the process of 2D computation followed by encoding.
Table 1-1 Encoding Capabilities
H264
HEVC
JPEG
Input Format
YUV420 NV12 8bit, ARGB8888, BGRA8888
YUV420 NV12 8bit, YUV422 UYVY 8bit, ARGB8888, BGRA8888
Output Format
YUV420 H.264 Baseline Profile(BP); H.264 Main Profile(MP); H.264 High Profile(HP); H.264 High 10 Profile(HP)
YUV420 HEVC (H.265) Main; HEVC (H.265) Main 10 Profile
YUV420 and YUV422 JPEG baseline sequential
Maximum Resolution
3840x2160
3840x2160
8192x8192
Bitrate Control Mode
CBR/VBR/FIXQP
CBR/VBR/FIXQP
FIXQP
GOP
I/P frames
I/P frames
Encoding Channels
4 channels
4 channels
4 channels
Note: H264/HEVC/JPEG share 4 channels.
Table 1-2 2D Computation Capabilities
Video Input Format
Video Output Format
Overlay Data Format
Maximum Resolution
I420/NV12/ARGB8888/BGRA8888
Same as input format
ARGB8888/ARGB4444/ARGB1555
3840x2160
1.2.1.1 Encoding Channel#
The encoding channel serves as the basic container, storing various user settings and managing various internal resources of the encoding channel. The encoding channel completes the functions of image overlay and encoding. The 2D module performs image overlay computation, and the encoder module performs image encoding. Both can be used separately or in conjunction.
encode channel
Figure 1-2 Encoding Channel
1.2.1.2 Bitrate Control#
The bitrate controller manages the control of the encoding bitrate.
From an information theory perspective, the lower the compression ratio of an image, the higher the quality of the compressed image; the higher the compression ratio, the lower the quality of the compressed image. Under varying scene conditions, if stable image quality is pursued, the encoding bitrate will fluctuate significantly; if stable encoding bitrate is pursued, the image quality will fluctuate significantly.
H264/H265 encoding supports CBR, VBR, and FIXQP bitrate control modes.
MJPEG only supports FIXQP mode.
1.2.1.2.1 CBR#
(Constant Bit Rate) Fixed bitrate. Ensures stable encoding bitrate within the bitrate statistics time.
1.2.1.2.2 VBR#
(Variable Bit Rate) Allows bitrate fluctuations within the bitrate statistics time to ensure stable image quality.
1.2.1.2.3 FIXQP#
Fixed QP value. Within the bitrate statistics time, all macroblock QP values of the encoded image are the same, using the user-set image QP value.
1.2.1.3 GOP Structure#
This module only supports I-frames and P-frames.
1.2.1.4 2D Computation#
The 2D computation module can achieve OSD overlay on image data. The OSD mode can achieve overlay of 8 regions, with no overlap between regions. Supported OSD formats are: ARGB4444/ARGB1555/ARGB8888.
1.2.1.4.1 2D Conversion Coefficient Calculation#
During OSD overlay computation, if the input video format is YUV, the OSD layer needs to perform RGB to YUV conversion. The kernel has a set of default conversion coefficients. If the user needs to customize a set of 12-bit conversion coefficients, they can be obtained from the RGB to YUV conversion formula.
The known RGB to YUV conversion formula is as follows:
osd formula
The coefficients in the 3x3 matrix are obtained by multiplying by 256 and rounding to the nearest integer, and the values in the 3x1 matrix are the corresponding conversion coefficients.
For example, for BT709 LIMITED, the RGB to YUV conversion formula is:
The conversion coefficients are: { 47, 157, 16, 16, -26, -86, 112, 128, 112, -102, -10, 128 }
1.2.1.4.2 2D Conversion Coefficient Configuration#
2D conversion coefficients can be configured through the user-defined coefficient interface kd_mpi_venc_set_2d_custom_coef and the color gamut configuration interface kd_mpi_venc_set_2d_color_gamut. Either interface can be used for configuration. If neither interface is called before the computation starts, the default coefficients will be used for color gamut conversion.
1.2.1.5 Limitations#
Encoding operations have the following limitations:
  1. If the input data format is YUV420, the physical starting address of the image data for each component (Y, U, V) must be 4k aligned.
  2. If the input data format is NV12, the physical starting address of the image data for Y and UV must be 4k aligned.
2D operations have the following limitations:
  1. The physical starting address of the source and destination images in DDR must be 8-byte aligned.
  2. The dimensions of the image, OSD, and frame in the overlay and frame operations must be even numbers.
  3. The src and dst addresses of video data in overlay and frame operations must be the same.
Decoding operations have the following limitations:
  1. The physical starting address of the input data for each frame must be 4k aligned.
1.2.1.6 Typical Encoding Application Example#
venc sample flow
Figure 1-3 Typical Encoding Application Scenario Flow Diagram
1.2.2 Video Decoding#
Table 12 VPU Decoding Capabilities
H264
HEVC
JPEG
Input Format
H.264 Baseline; H.264 Main; H.264 High; H.264 High10; supports interlaced stream
HEVC (H.265) Main/Main10
JPEG, baseline sequential
Output Format
YUV420 NV12
YUV420 NV12
YUV422 UYVY, YUV420 NV12
Decoding Channels
4 channels
4 channels
4 channels
VDEC supports streaming mode:
  • Streaming Mode (K_VDEC_SEND_MODE_STREAM): Users can send any length of code stream to the decoder each time, and the decoder will internally complete the identification process of one frame of the code stream. Note that for H.264/H.265, the end of the current frame code stream can only be identified after receiving the next frame code stream, so in this sending mode, if you input one frame of H.264/H.265 code stream, you cannot expect the image decoding to start immediately.
1.2.2.1 Typical Decoding Application Example#
vdec sample flow
2. API Reference#
2.1 Video Encoding#
2.1.1 kd_mpi_venc_create_chn#
Description:
Create an encoding channel.
Syntax:
k_s32 kd_mpi_venc_create_chn(k_u32 chn_num, const [k_venc_chn_attr](#3115-k_venc_chn_attr) *attr);
Parameters:
Parameter Name
Input/Output
chn_num
Encoding channel information. Value range: [0, VENC_MAX_CHN_NUM).
Input
attr
Pointer to encoding channel attributes.
Input
Return Values:
Success.
Non-zero
Failure, see [Error Codes](#5. Error Codes).
Chip Differences:
None.
Requirements:
  • Header files: mpi_venc_api.h, k_type.h, k_module.h, k_sys_comm.h, k_venc_comm.h
  • Library files: libvenc.a
Notes:
  • The encoder supports channel width and height as shown in the table below:
H.264/H.265
JPEG
WIDTH
HEIGHT
WIDTH
HEIGHT
MAX
MIN
MAX
MIN
MAX
MIN
MAX
MIN
4096
128
4096
64
8192
128
8192
64
Examples:
None.
Related Topics:
None.
2.1.2 kd_mpi_venc_destory_chn#
Description:
Destroy an encoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Encoding channel number. Value range: [0, VENC_MAX_CHN_NUM).
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • Must stop receiving images before destroying, otherwise returns failure.
Examples:
None.
Related Topics:
kd_mpi_venc_stop_chn
2.1.3 kd_mpi_venc_start_chn#
Description:
Start the encoding channel to receive input images.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • If the channel is not created, it returns failure K_ERR_VENC_UNEXIST.
  • If the channel has already started receiving images and calls this interface again without stopping, it returns operation not allowed.
  • The encoder starts receiving images for encoding only after starting reception.
Examples:
None.
Related Topics:
kd_mpi_venc_create_chn kd_mpi_venc_stop_chn
2.1.4 kd_mpi_venc_stop_chn#
Description:
Stop the encoding channel from receiving input images.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • If the channel is not created, it returns failure.
  • This interface does not check if the reception is already stopped, allowing repeated stops without returning an error.
  • This interface is used to stop receiving images for encoding, and must be called before destroying or resetting the encoding channel.
  • Calling this interface only stops receiving raw data for encoding, the stream buffer will not be cleared.
Examples:
None.
Related Topics:
2.1.5 kd_mpi_venc_query_status#
Description:
Query the status of the encoding channel.
Syntax:
k_s32 kd_mpi_venc_query_status(k_u32 chn_num, [k_venc_chn_status](#3115-k_venc_chn_attr) *status);
Parameters:
Parameter Name
Input/Output
chn_num
Input
status
Pointer to the status of the encoding channel.
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Examples:
None.
Related Topics:
None. | Non-zero | Failure, see Error Codes. |
Chip Differences:
None.
Requirements:
Notes:
Examples:
None.
Related Topics:
2.1.6 kd_mpi_venc_get_stream#
Description:
Get the encoded stream.
Syntax:
k_s32 kd_mpi_venc_get_stream(k_u32 chn_num, [k_venc_stream](#3123-k_venc_stream) *stream, k_s32 milli_sec);
Parameters:
Parameter Name
Input/Output
chn_num
Input
stream
Pointer to the stream structure.
Output
milli_sec
Timeout for getting the stream. Value range: [-1, +∞) -1: Blocking. 0: Non-blocking. Greater than 0: Timeout
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • If stream is null, it returns K_ERR_VENC_NULL_PTR.
  • If milli_sec is less than -1, it returns K_ERR_VENC_ILLEGAL_PARAM.
Examples:
None.
Related Topics:
kd_mpi_venc_create_chn kd_mpi_venc_start_chn
2.1.7 kd_mpi_venc_release_stream#
Description:
Release the stream buffer.
Syntax:
k_s32 kd_mpi_venc_release_stream(k_u32 chn_num, [k_venc_stream](#3123-k_venc_stream) *stream);
Parameters:
Parameter Name
Input/Output
chn_num
Input
stream
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • If the channel is not created, it returns error code K_ERR_VENC_UNEXIST.
  • If stream is null, it returns error code K_ERR_VENC_NULL_PTR.
Examples:
None.
Related Topics:
2.1.8 kd_mpi_venc_send_frame#
Description:
Support users to send raw images for encoding.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
frame
Pointer to the raw image information structure, refer to “K230 System Control API Reference”.
Input
milli_sec
Timeout for sending the image. Value range: [-1, +∞) -1: Blocking. 0: Non-blocking. Greater than 0: Timeout.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • This interface supports users sending images to the encoding channel.
  • When calling this interface to send images, users need to ensure that the encoding channel is created and started to receive input images.
Examples:
None.
Related Topics:
2.1.9 kd_mpi_venc_set_rotation#
Description:
Set the rotation angle of the encoded image.
Syntax:
k_s32 kd_mpi_venc_set_rotation(k_u32 chn_num, const [k_rotation](#3112-k_rotation) rotation);
Parameters:
Parameter Name
Input/Output
chn_num
Channel number. Value range: [0, VENC_MAX_CHN_NUM).
Input
rotation
Rotation angle enumeration.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.10 kd_mpi_venc_get_rotation#
Description:
Get the rotation angle of the encoded image.
Syntax:
k_s32 kd_mpi_venc_get_rotation(k_u32 chn_num, [k_rotation](#3112-k_rotation) *rotation);
Parameters:
Parameter Name
Input/Output
chn_num
Input
rotation
Pointer to the rotation angle enumeration.
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.11 kd_mpi_venc_set_mirror#
Description:
Set the mirroring method of the encoded image.
Syntax:
k_s32 kd_mpi_venc_set_mirror(k_u32 chn_num, const [k_venc_mirror](#3113-k_venc_mirror) mirror);
Parameters:
Parameter Name
Input/Output
chn_num
Input
mirror
Mirroring method enumeration.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.12 kd_mpi_venc_get_mirror#
Description:
Get the mirroring method of the encoded image.
Syntax:
k_s32 kd_mpi_venc_get_mirror(k_u32 chn_num, [k_venc_mirror](#3113-k_venc_mirror) *mirror);
Parameters:
Parameter Name
Input/Output
chn_num
Input
mirror
Pointer to the mirroring method enumeration.
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.13 kd_mpi_venc_enable_idr#
Description:
Enable IDR frame.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number. Value range: [0, K_VENC_2D_MAX_CHN_NUM).
Input
idr_enable
Enable IDR frame. 0: Disable. 1: Enable.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • This interface needs to be called after creating the encoding channel and before starting the encoding channel.
None.
Related Topics:
None.
2.1.14 kd_mpi_venc_set_2d_mode#
Description:
Set the 2D computation mode.
Syntax:
k_s32 kd_mpi_venc_set_2d_mode(k_u32 chn_num, const [k_venc_2d_calc_mode](#318-k_venc_2d_calc_mode) mode);
Parameters:
Parameter Name
Input/Output
chn_num
Input
2D computation mode enumeration.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • Currently, the computation mode does not support K_VENC_2D_CALC_MODE_CSC mode.
None.
Related Topics:
None.
2.1.15 kd_mpi_venc_get_2d_mode#
Description:
Get the 2D computation mode.
Syntax:
k_s32 kd_mpi_venc_get_2d_mode(k_u32 chn_num, [k_venc_2d_calc_mode](#318-k_venc_2d_calc_mode) *mode);
Parameters:
Parameter Name
Input/Output
chn_num
Input
Pointer to the 2D computation mode enumeration.
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
2.1.16 kd_mpi_venc_set_2d_osd_param#
Description:
Set the region attributes of OSD in 2D computation.
Syntax:
k_s32 kd_mpi_venc_set_2d_osd_param(k_u32 chn_num, k_u8 index, const [k_venc_2d_osd_attr](#3125-k_venc_2d_osd_attr) *attr);
Parameters:
Parameter Name
Input/Output
chn_num
Input
index
OSD region index. Value range: [0, K_VENC_MAX_2D_OSD_REGION_NUM).
Input
attr
Pointer to OSD attributes.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • If there are n overlay regions, the index values should be set to 0~n-1 respectively.
None.
Related Topics:
None.
2.1.17 kd_mpi_venc_get_2d_osd_param#
Description:
Get the region attributes of the OSD with the specified index in 2D computation.
Syntax:
k_s32 kd_mpi_venc_get_2d_osd_param(k_u32 chn_num, k_u8 index, const [k_venc_2d_osd_attr](#3125-k_venc_2d_osd_attr) *attr);
Parameters:
Parameter Name
Input/Output
chn_num
Input
index
Input
attr
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.18 kd_mpi_venc_set_2d_border_param#
Description:
Set the border attributes in 2D computation.
Syntax:
k_s32 kd_mpi_venc_set_2d_border_param(k_u32 chn_num, k_u8 index, const [k_venc_2d_border_attr](#3126-k_venc_2d_border_attr) *attr);
Parameters:
Parameter Name
Input/Output
chn_num
Input
index
Border index. Value range: [0, K_VENC_MAX_2D_BORDER_NUM).
Input
attr
Pointer to border attributes.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • If there are n borders, the index values should be set to 0~n-1 respectively.
None.
Related Topics:
None.
2.1.19 kd_mpi_venc_get_2d_border_param#
Description:
Get the border attributes in 2D computation.
Syntax:
k_s32 kd_mpi_venc_get_2d_border_param(k_u32 chn_num, k_u8 index, [k_venc_2d_border_attr](#3126-k_venc_2d_border_attr) *attr);
Parameters:
Parameter Name
Input/Output
chn_num
Input
index
Input
attr
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.20 kd_mpi_venc_set_2d_custom_coef#
Description:
Set the image format conversion coefficients in 2D computation.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
coef
Pointer to conversion coefficients. Refer to [2D Conversion Coefficient Calculation](#12141-2D Conversion Coefficient Calculation).
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • The kernel has a set of default conversion coefficients. If custom conversion coefficients are needed, they can be configured through this interface.
  • This interface should be called after setting the computation mode.
  • For details on conversion coefficients, refer to [2D Conversion Coefficient Calculation](#12141-2D Conversion Coefficient Calculation).
  • When the computation mode is K_VENC_2D_CALC_MODE_BORDER, conversion coefficients are not applicable, and calling this interface will result in an error.
None.
Related Topics:
2.1.21 kd_mpi_venc_get_2d_custom_coef#
Description:
Get the image format conversion coefficients in 2D computation.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
coef
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
2.1.22 kd_mpi_venc_set_2d_color_gamut#
Description:
Set the color gamut in 2D computation.
Syntax:
k_s32 kd_mpi_venc_set_2d_color_gamut(k_u32 chn_num, const [k_venc_2d_color_gamut](#3114-k_venc_2d_color_gamut) color_gamut);
Parameters:
Parameter Name
Input/Output
chn_num
Input
color_gamut
Color gamut enumeration.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • When the computation mode is K_VENC_2D_CALC_MODE_BORDER, color gamut is not applicable, and calling this interface will result in an error.
None.
Related Topics:
None.
2.1.23 kd_mpi_venc_get_2d_color_gamut#
Description:
Get the color gamut in 2D computation.
Syntax:
k_s32 kd_mpi_venc_get_2d_color_gamut(k_u32 chn_num, [k_venc_2d_color_gamut](#3114-k_venc_2d_color_gamut) *color_gamut);
Parameters:
Parameter Name
Input/Output
chn_num
Input
color_gamut
Pointer to color gamut enumeration.
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
2.1.24 kd_mpi_venc_attach_2d#
Description:
Attach 2D computation to VENC.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • Currently, binding only supports the mode where the encoding channel number and the 2D computation channel number are the same. Only the first 3 encoding channels support the attach 2D operation.
None.
Related Topics:
None.
2.1.25 kd_mpi_venc_detach_2d#
Description:
Detach 2D computation from VENC.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
2D computation channel number. Value range: [0, K_VENC_2D_MAX_CHN_NUM).
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • When calling this interface, users need to ensure that the encoding channel has stopped.
None.
Related Topics:
2.1.26 kd_mpi_venc_send_2d_frame#
Description:
Send a frame of data to the 2D module.
Syntax:
k_s32 kd_mpi_venc_send_2d_frame(k_u32 chn_num, const k_video_frame_info *frame, k_s32 milli_sec);
Parameters:
Parameter Name
Input/Output
chn_num
Input
frame
Pointer to the original image information structure. Refer to the “K230 System Control API Reference”.
Input
milli_sec
Timeout for sending the image. Value range: [-1, +∞) -1: Blocking. 0: Non-blocking. > 0: Timeout duration.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • This interface is used only in scenarios involving single 2D computation. For scenarios involving 2D computation followed by encoding, use the VENC interface kd_mpi_venc_send_frame to send the image.
None.
Related Topics:
2.1.27 kd_mpi_venc_get_2d_frame#
Description:
Get the 2D computation result.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
frame
Pointer to the output image information structure. Refer to the “K230 System Control API Reference”.
Output
milli_sec
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • This interface is used only in scenarios involving single 2D computation. For scenarios involving 2D computation followed by encoding, use kd_mpi_venc_get_stream to get the encoded stream.
None.
Related Topics:
2.1.28 kd_mpi_venc_start_2d_chn#
Description:
Start the 2D channel to receive input images.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • This interface is used only in scenarios involving single 2D computation. For VENC+2D scenarios, use kd_mpi_venc_start_chn.
None.
Related Topics:
2.1.29 kd_mpi_venc_stop_2d_chn#
Description:
Stop the 2D channel from receiving input images.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.30 kd_mpi_venc_request_idr#
Description:
Request an IDR frame, generating one immediately after the call.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.31 kd_mpi_venc_set_h265_sao#
Description:
Set the Sao attributes for the H.265 channel.
Syntax:
k_s32 kd_mpi_venc_set_h265_sao(k_u32 chn_num, const [k_venc_h265_sao](#3127-k_venc_h265_sao) *h265_sao);
Parameters:
Parameter Name
Input/Output
chn_num
Input
h265_sao
Sao configuration for the H.265 encoding channel.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
  • This interface should be called after creating the encoding channel and before starting the encoding channel.
None.
Related Topics:
None.
2.1.32 kd_mpi_venc_get_h265_sao#
Description:
Get the Sao attributes for the H.265 channel.
Syntax:
k_s32 kd_mpi_venc_get_h265_sao(k_u32 chn_num, [k_venc_h265_sao](#3127-k_venc_h265_sao) *h265_sao);
Parameters:
Parameter Name
Input/Output
chn_num
Input
h265_sao
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.33 kd_mpi_venc_set_dblk#
Description:
Enable or disable deblocking for the H.264/H.265 encoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
dblk_en
Enable or disable deblocking. K_TRUE: Enable. K_FALSE: Disable. Default is enabled.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
2.1.34 kd_mpi_venc_get_dblk#
Description:
Get the deblocking status of the H.264/H.265 encoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
dblk_en
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.35 kd_mpi_venc_set_roi_attr#
Description:
Set the ROI attributes for the H.264/H.265 channel.
Syntax:
k_s32 kd_mpi_venc_set_roi_attr(k_u32 chn_num, const [k_venc_roi_attr](#3129-k_venc_roi_attr) *roi_attr);
Parameters:
Parameter Name
Input/Output
chn_num
Input
roi_attr
ROI attributes for the H.264/H.265 encoding channel.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
2.1.36 kd_mpi_venc_get_roi_attr#
Description:
Get the ROI attributes for the H.264/H.265 channel.
Syntax:
k_s32 kd_mpi_venc_get_roi_attr(k_u32 chn_num, [k_venc_roi_attr](#3129-k_venc_roi_attr) *roi_attr);
Parameters:
Parameter Name
Input/Output
chn_num
Input
roi_attr
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.37 kd_mpi_venc_set_h264_entropy#
Description:
Set the entropy encoding mode for the H.264 encoding channel.
Syntax:
k_s32 kd_mpi_venc_set_h264_entropy(k_u32 chn_num, const [k_venc_h264_entropy](#3130-k_venc_h264_entropy) *h264_entropy);
Parameters:
Parameter Name
Input/Output
chn_num
Input
h264_entropy
Entropy encoding mode for the H.264 encoding channel.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
2.1.38 kd_mpi_venc_get_h264_entropy#
Description:
Get the entropy encoding mode for the H.264 encoding channel.
Syntax:
k_s32 kd_mpi_venc_get_h264_entropy(k_u32 chn_num, [k_venc_h264_entropy](#3130-k_venc_h264_entropy) *h264_entropy);
Parameters:
Parameter Name
Input/Output
chn_num
Input
h264_entropy
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.1.39 kd_mpi_venc_set_h265_entropy#
Description:
Set the entropy encoding mode for the H.265 encoding channel.
Syntax:
k_s32 kd_mpi_venc_set_h265_entropy(k_u32 chn_num, const [k_venc_h265_entropy](#3131-k_venc_h265_entropy) *h265_entropy);
Parameters:
Parameter Name
Input/Output
chn_num
Input
h265_entropy
Entropy encoding mode for the H.265 encoding channel.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
2.1.40 kd_mpi_venc_get_h265_entropy#
Description:
Get the entropy encoding mode for the H.265 encoding channel.
Syntax:
k_s32 kd_mpi_venc_get_h265_entropy(k_u32 chn_num, [k_venc_h265_entropy](#3131-k_venc_h265_entropy) *h265_entropy);
Parameters:
Parameter Name
Input/Output
chn_num
Input
h265_entropy
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.2 Video Decoding#
This module provides the following APIs:
2.2.1 kd_mpi_vdec_create_chn#
Description:
Create a video decoding channel.
Syntax:
k_s32 kd_mpi_vdec_create_chn(k_u32 chn_num, const [k_vdec_chn_attr](#323-k_vdec_chn_attr) *attr);
Parameters:
Parameter Name
Input/Output
chn_num
Channel number. Value range: [0, K_VDEC_MAX_CHN_NUM).
Input
attr
Pointer to the decoding channel attributes.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
  • Header files: mpi_vdec_api.h, k_type.h, k_module.h, k_sys_comm.h, k_vdec_comm.h
  • Library files: libvdec.a
Notes:
None.
None.
Related Topics:
None.
2.2.2 kd_mpi_vdec_destroy_chn#
Description:
Destroy a video decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.2.3 kd_mpi_vdec_start_chn#
Description:
Start a video decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.2.4 kd_mpi_vdec_stop_chn#
Description:
Stop a video decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.2.5 kd_mpi_vdec_query_status#
Description:
Query the status of the decoding channel.
Syntax:
k_s32 kd_mpi_vdec_query_status(k_u32 chn_num, [k_vdec_chn_status](#324-k_vdec_chn_status) *status);
Parameters:
Parameter Name
Input/Output
chn_num
Input
status
Pointer to the video decoding channel status structure.
Output
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.2.6 kd_mpi_vdec_send_stream#
Description:
Send stream data to the video decoding channel.
Syntax:
k_s32 kd_mpi_vdec_send_stream(k_u32 chn_num, const [k_vdec_stream](#326-k_vdec_stream) *stream, k_s32 milli_sec);
Parameters:
Parameter Name
Input/Output
chn_num
Input
stream
Pointer to the decoding stream data.
Input
milli_sec
Timeout flag for sending stream. Value range: -1: Blocking. 0: Non-blocking. Positive value: Timeout duration in milliseconds, no upper limit.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.2.7 kd_mpi_vdec_get_frame#
Description:
Get the decoded image from the video decoding channel.
Syntax:
k_s32 kd_mpi_vdec_get_frame(k_u32 chn_num, k_video_frame_info *frame_info, [k_vdec_supplement_info](#327-k_vdec_supplement_info) *supplement, k_s32 milli_sec);
Parameters:
Parameter Name
Input/Output
chn
Input
frame_info
Pointer to the decoded image information. Refer to the “K230 System Control API Reference”.
Output
supplement
Pointer to the decoded image supplementary information.
Output
milli_sec
Timeout flag for sending stream. Value range: -1: Blocking. 0: Non-blocking. Positive value: Timeout duration in milliseconds.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None. Positive Value: Timeout duration, no upper limit, in milliseconds. Dynamic attribute. | Input |
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
2.2.8 kd_mpi_vdec_release_frame#
Description:
Release the decoded image from the video decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn
Input
frame_info
Pointer to the decoded image information obtained by the kd_mpi_vdec_get_frame interface. Refer to the “K230 System Control API Reference”.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.9 kd_mpi_vdec_set_downscale#
Description:
Set the downscaling of the output image (specify width and height or by ratio).
Syntax:
k_s32 kd_mpi_vdec_set_downscale(k_u32 chn_num, const [k_vdec_downscale](#3211-k_vdec_downscale) *downscale);
Parameters:
Parameter Name
Input/Output
chn_num
Input
downscale
Pointer to the downscaling parameter structure.
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
Set between kd_mpi_vdec_create_chn and kd_mpi_vdec_start_chn.
None.
Related Topics:
None.
2.2.10 kd_mpi_vdec_set_rotation#
Description:
Set the rotation angle of the decoded image.
Syntax:
k_s32 kd_mpi_vdec_set_rotation(k_u32 chn_num, const [k_rotation](#3112-k_rotation) rotation);
Parameters:
Parameter Name
Input/Output
chn_num
Input
rotation
Input
Return Values:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
Related Topics:
None.
3. Data Types#
3.1 Video Encoding#
The related data type definitions for this module are as follows:
3.1.1 VENC_MAX_CHN_NUM#
Description:
Defines the maximum number of channels.
Definition:
#define VENC_MAX_CHN_NUM 4
Notes:
None.
None.
3.1.2 K_VENC_MAX_2D_OSD_REGION_NUM#
Description:
Defines the maximum number of 2D OSD regions.
Definition:
Notes:
None.
None.
3.1.3 K_VENC_MAX_2D_BORDER_NUM#
Description:
Defines the maximum number of 2D borders.
Definition:
Notes:
None.
None.
3.1.4 K_VENC_2D_COFF_NUM#
Description:
Defines the number of 2D CSC conversion coefficients.
Definition:
#define K_VENC_2D_COFF_NUM 12
Notes:
None.
None.
3.1.5 K_VENC_2D_MAX_CHN_NUM#
Description:
Defines the number of 2D channels.
Definition:
Notes:
None.
None.
3.1.6 k_venc_rc_mode#
Description:
Defines the rate control mode for the encoding channel.
Definition:
    K_VENC_RC_MODE_CBR = 1,
    K_VENC_RC_MODE_VBR,
    K_VENC_RC_MODE_FIXQP,
    K_VENC_RC_MODE_MJPEG_FIXQP,
    K_VENC_RC_MODE_BUTT,
} k_venc_rc_mode;
Members:
Member Name
K_VENC_RC_MODE_CBR
H.264/H.265 CBR mode.
K_VENC_RC_MODE_VBR
H.264/H.265 VBR mode.
H.264/H.265 Fixqp mode.
MJPEG Fixqp mode.
Notes:
None.
None.
3.1.7 k_venc_pack_type#
Description:
Defines the JPEG stream pack type enumeration.
Definition:
    K_VENC_P_FRAME = 1,
    K_VENC_I_FRAME = 2,
    K_VENC_HEADER = 3,
    K_VENC_BUTT
} k_venc_pack_type;
Members:
Member Name
K_VENC_P_FRAME
I frame.
K_VENC_I_FRAME
P frame.
K_VENC_HEADER
Header.
Notes:
None.
None.
3.1.8 k_venc_2d_calc_mode#
Description:
Defines the calculation mode enumeration for 2D operations.
Definition:
    K_VENC_2D_CALC_MODE_CSC = 0,
    K_VENC_2D_CALC_MODE_OSD,
    K_VENC_2D_CALC_MODE_OSD_BORDER,
    K_VENC_2D_CALC_MODE_BUTT
} k_venc_2d_calc_mode;
Members:
Member Name
Image format conversion.
Image overlay.
Border drawing.
Image overlay followed by border drawing.
Notes:
  • Currently, K_VENC_2D_CALC_MODE_CSC mode is not supported.
None.
3.1.9 k_venc_2d_src_dst_fmt#
Description:
Defines the input/output data format enumeration for 2D operations.
Definition:
    K_VENC_2D_SRC_DST_FMT_YUV420_NV12 = 0,
    K_VENC_2D_SRC_DST_FMT_YUV420_NV21,
    K_VENC_2D_SRC_DST_FMT_YUV420_I420,
    K_VENC_2D_SRC_DST_FMT_ARGB8888 = 4,
    K_VENC_2D_SRC_DST_FMT_ARGB4444,
    K_VENC_2D_SRC_DST_FMT_ARGB1555,
    K_VENC_2D_SRC_DST_FMT_XRGB8888,
    K_VENC_2D_SRC_DST_FMT_XRGB4444,
    K_VENC_2D_SRC_DST_FMT_XRGB1555,
    K_VENC_2D_SRC_DST_FMT_BGRA8888,
    K_VENC_2D_SRC_DST_FMT_BGRA4444,
    K_VENC_2D_SRC_DST_FMT_BGRA5551,
    K_VENC_2D_SRC_DST_FMT_BGRX8888,
    K_VENC_2D_SRC_DST_FMT_BGRX4444,
    K_VENC_2D_SRC_DST_FMT_BGRX5551,
    K_VENC_2D_SRC_DST_FMT_RGB888,
    K_VENC_2D_SRC_DST_FMT_BGR888,
    K_VENC_2D_SRC_DST_FMT_RGB565,
    K_VENC_2D_SRC_DST_FMT_BGR565,
    K_VENC_2D_SRC_DST_FMT_SEPARATE_RGB,
    K_VENC_2D_SRC_DST_FMT_BUTT
} k_venc_2d_src_dst_fmt;
Notes:
None.
None.
3.1.10 k_venc_2d_osd_fmt#
Description:
Defines the enumeration of OSD layer data formats for 2D operations.
Definition:
    K_VENC_2D_OSD_FMT_ARGB8888 = 0,
    K_VENC_2D_OSD_FMT_ARGB4444,
    K_VENC_2D_OSD_FMT_ARGB1555,
    K_VENC_2D_OSD_FMT_XRGB8888,
    K_VENC_2D_OSD_FMT_XRGB4444,
    K_VENC_2D_OSD_FMT_XRGB1555,
    K_VENC_2D_OSD_FMT_BGRA8888,
    K_VENC_2D_OSD_FMT_BGRA4444,
    K_VENC_2D_OSD_FMT_BGRA5551,
    K_VENC_2D_OSD_FMT_BGRX8888,
    K_VENC_2D_OSD_FMT_BGRX4444,
    K_VENC_2D_OSD_FMT_BGRX5551,
    K_VENC_2D_OSD_FMT_RGB888,
    K_VENC_2D_OSD_FMT_BGR888,
    K_VENC_2D_OSD_FMT_RGB565,
    K_VENC_2D_OSD_FMT_BGR565,
    K_VENC_2D_OSD_FMT_SEPARATE_RGB,
    K_VENC_2D_OSD_FMT_BUTT
} k_venc_2d_osd_fmt;
Notes:
  • Currently, only ARGB8888, ARGB4444, and ARGB1555 formats are supported for image overlay.
None.
3.1.11 k_venc_2d_add_order#
Description:
Defines the enumeration of OSD overlay order (video, OSD, and background layers) for 2D operations.
Definition:
    /* bottom ------> top */
    K_VENC_2D_ADD_ORDER_VIDEO_OSD = 0,
    K_VENC_2D_ADD_ORDER_OSD_VIDEO,
    K_VENC_2D_ADD_ORDER_VIDEO_BG,
    K_VENC_2D_ADD_ORDER_BG_VIDEO,
    K_VENC_2D_ADD_ORDER_VIDEO_BG_OSD,
    K_VENC_2D_ADD_ORDER_VIDEO_OSD_BG,
    K_VENC_2D_ADD_ORDER_BG_VIDEO_OSD,
    K_VENC_2D_ADD_ORDER_BG_OSD_VIDEO,
    K_VENC_2D_ADD_ORDER_OSD_VIDEO_BG,
    K_VENC_2D_ADD_ORDER_OSD_BG_VIDEO,
    K_VENC_2D_ADD_ORDER_BUTT
} k_venc_2d_add_order;
Members:
Member Name
Video at the bottom, OSD at the top.
OSD at the bottom, video at the top.
Video at the bottom, background color on top.
Background color at the bottom, video on top.
Video at the bottom, background color in the middle, OSD at the top.
Video at the bottom, OSD in the middle, background color at the top.
Background color at the bottom, video in the middle, OSD at the top.
Background color at the bottom, OSD in the middle, video at the top.
OSD at the bottom, video in the middle, background color at the top.
OSD at the bottom, background color in the middle, video at the top.
Notes:
None.
None.
3.1.12 k_rotation#
Description:
Defines the enumeration of rotation angles for encoding.
Definition:
    K_VPU_ROTATION_0 = 0,
    K_VPU_ROTATION_90 = 1,
    K_VPU_ROTATION_180 = 2,
    K_VPU_ROTATION_270 = 3,
    K_VPU_ROTATION_BUTT
} k_rotation;
Members:
Member Name
K_VPU_ROTATION_0
No rotation, 0 degrees.
K_VPU_ROTATION_90
Rotate 90 degrees.
K_VPU_ROTATION_180
Rotate 180 degrees.
K_VPU_ROTATION_270
Rotate 270 degrees.
Notes:
None.
None.
3.1.13 k_venc_mirror#
Description:
Defines the enumeration of mirroring methods for encoding.
Definition:
    K_VENC_MIRROR_HORI = 0,
    K_VENC_MIRROR_VERT = 1,
    K_VENC_MIRROR_BUTT
} k_venc_mirror;
Members:
Member Name
K_VENC_MIRROR_HORI
Horizontal flip.
K_VENC_MIRROR_VERT
Vertical flip.
Notes:
None.
None.
3.1.14 k_venc_2d_color_gamut#
Description:
Defines the enumeration of color gamuts for 2D operations.
Definition:
    VENC_2D_COLOR_GAMUT_BT601 = 0,
    VENC_2D_COLOR_GAMUT_BT709,
    VENC_2D_COLOR_GAMUT_BT2020,
    VENC_2D_COLOR_GAMUT_BUTT
} k_venc_2d_color_gamut;
Members:
Member Name
BT.601 color gamut.
BT.709 color gamut.
BT.2020 color gamut.
Notes:
None.
None.
3.1.15 k_venc_chn_attr#
Description:
Defines the structure of encoding channel attributes.
Definition:
    k_venc_attr venc_attr;
    k_venc_rc_attr rc_attr;
} k_venc_chn_attr;
Members:
Member Name
venc_attr
Encoder attributes.
rc_attr
Rate controller attributes.
Notes:
None.
None.
3.1.16 k_venc_attr#
Description:
Defines the structure of encoder attributes.
Definition:
    k_payload_type type;
    k_u32 stream_buf_size;
    k_u32 stream_buf_cnt;
    k_u32 pic_width;
    k_u32 pic_height;
    k_venc_profile profile;
} k_venc_attr;
Members:
Member Name
Encoding protocol type.
stream_buf_size
Stream buffer size.
stream_buf_cnt
Number of stream buffers.
pic_width
Encoding image width. Range: [MIN_WIDTH, MAX_WIDTH], in pixels. Must be a multiple of MIN_ALIGN.
pic_height
Encoding image height. Range: [MIN_HEIGHT, MAX_HEIGHT], in pixels. Must be a multiple of MIN_ALIGN.
profile
Encoding profile enumeration.
Notes:
None.
None.
3.1.17 k_venc_rc_attr#
Description:
Defines the structure of rate controller attributes for encoding channels.
Definition:
    k_venc_rc_mode rc_mode;
    union {
        k_venc_cbr cbr;
        k_venc_vbr vbr;
        k_venc_fixqp fixqp;
        k_venc_mjpeg_fixqp mjpeg_fixqp;
} k_venc_rc_attr;
Members:
Member Name
rc_mode
RC mode.
cbr
CBR attributes for H.264/H.265 encoding channels.
vbr
VBR attributes for H.264/H.265 encoding channels.
fixqp
Fixqp attributes for H.264/H.265 encoding channels.
mjpeg_fixqp
Fixqp attributes for MJPEG encoding channels.
Notes:
None.
None.
3.1.18 k_venc_cbr#
Description:
Defines the structure of CBR attributes for H.264/H.265 encoding channels.
Definition:
    k_u32 gop;
    k_u32 stats_time;
    k_u32 src_frame_rate;
    k_u32 dst_frame_rate;
    k_u32 bit_rate;
} k_venc_cbr;
Members:
Member Name
gop
GOP value.
stats_time
CBR rate statistics time in seconds. Range: [1, 60].
src_frame_rate
Input frame rate in fps.
dst_frame_rate
Encoder output frame rate in fps.
bit_rate
Average bitrate in kbps.
Notes:
  • If the set bitrate exceeds the maximum real-time bitrate specified in the chip manual, real-time encoding cannot be guaranteed.
None.
3.1.19 k_venc_vbr#
Description:
Defines the structure of VBR attributes for H.264/H.265 encoding channels.
Definition:
    k_u32 gop;
    k_u32 stats_time;
    k_u32 max_bit_rate;
    k_u32 bit_rate;
} k_venc_vbr;
Members:
Member Name
gop
GOP value.
stats_time
VBR rate statistics time in seconds. Range: [1, 60].
src_frame_rate
dst_frame_rate
max_bit_rate
Maximum bitrate in kbps.
bit_rate
Notes:
Refer to k_venc_cbr for details on src_frame_rate and dst_frame_rate.
None.
3.1.20 k_venc_fixqp#
Description:
Defines the structure for H.264/H.265 encoding channel Fixqp attributes.
Definition:
    k_u32 gop;
    k_u32 i_qp;
    k_u32 p_qp;
} k_venc_fixqp;
Members:
Member Name
gop
GOP value.
src_frame_rate
Input frame rate, in fps.
dst_frame_rate
Encoder output frame rate, in fps.
i_qp
QP value for all macroblocks in I-frames. Range: [0, 51].
p_qp
QP value for all macroblocks in P-frames. Range: [0, 51].
Notes:
None.
3.1.21 k_venc_mjpeg_fixqp#
Description:
Defines the structure for MJPEG encoding channel Fixqp attributes.
Definition:
    k_u32 q_factor;
} k_venc_mjpeg_fixqp;
Members:
Member Name
src_frame_rate
dst_frame_rate
q_factor
Q factor for MJPEG encoding. Range: [1, 99].
Notes:
None.
3.1.22 k_venc_chn_status#
Description:
Defines the structure for the status of encoding channels.
Definition:
    k_u32 cur_packs;
    k_u64 release_pic_pts;
    k_bool end_of_stream;
} k_venc_chn_status;
Members:
Member Name
cur_packs
Number of stream packets in the current frame.
release_pic_pts
PTS of the released stream’s corresponding image.
end_of_stream
End of stream flag.
Notes:
None.
None.
3.1.23 k_venc_stream#
Description:
Defines the structure for frame stream type.
Definition:
    [k_venc_pack](#3124-k_venc_pack) *pack;
    k_u32 pack_cnt;
} k_venc_stream;
Members:
Member Name
pack
Frame stream packet structure.
pack_cnt
Number of packets in one frame stream.
Notes:
None.
None.
3.1.24 k_venc_pack#
Description:
Defines the structure for frame stream packets.
Definition:
    k_u64 phys_addr;
    k_u32 len;
    k_u64 pts;
    [k_venc_pack_type](#317-k_venc_pack_type) type;
} k_venc_pack;
Members:
Member Name
phys_addr
Physical address of the stream packet.
len
Length of the stream packet.
pts
Timestamp, in microseconds.
Data type of the packet.
Notes:
None.
None.
3.1.25 k_venc_2d_osd_attr#
Description:
Defines the structure for 2D overlay attributes.
Definition:
    k_u16 width;
    k_u16 height;
    k_u16 startx;
    k_u16 starty;
    k_u32 phys_addr[3];
    k_u8 bg_alpha;
    k_u8 osd_alpha;
    k_u8 video_alpha;
    [k_venc_2d_add_order](#3111-k_venc_2d_add_order) add_order;
    k_u32 bg_color;
    [k_venc_2d_osd_fmt](#3110-k_venc_2d_osd_fmt) fmt;
} k_venc_2d_osd_attr;
Members:
Member Name
Width of the OSD overlay area.
Height of the OSD overlay area.
startx
X offset of the top-left point of the OSD overlay area in the original image.
starty
Y offset of the top-left point of the OSD overlay area in the original image.
phys_addr
Physical address of the OSD image.
bg_alpha
Transparency of the background layer.
osd_alpha
Transparency of the OSD image.
video_alpha
Transparency of the video input image.
add_order
Enumeration of OSD overlay order.
bg_color
Background color of the OSD in YUV444 format. Y: bit0~bit7, U: bit8~bit15, V: bit16~bit23
fmt
Enumeration of the OSD image format.
Notes:
  • The starting address of the source image and the destination image in DDR must be 8-byte aligned.
  • Only even dimensions are supported for images and OSD.
  • The source and destination addresses for OSD must be the same.
None.
3.1.26 k_venc_2d_border_attr#
Description:
Defines the structure for 2D border drawing.
Definition:
    k_u16 width;
    k_u16 height;
    k_u16 line_width;
    k_u32 color;
    k_u16 startx;
    k_u16 starty;
} k_venc_2d_border_attr;
Members:
Member Name
Width of the border area, including the line width.
Height of the border area, including the line width.
line_width
Line width of the border.
color
Color of the border in YUV444 format. Y: bit0~bit7, U: bit8~bit15, V: bit16~bit23
startx
X offset of the top-left point of the border area in the original image.
starty
Y offset of the top-left point of the border area in the original image.
Notes:
  • Only even dimensions are supported for images and borders.
  • The source and destination addresses must be the same.
None.
3.1.27 k_venc_h265_sao#
Description:
Defines the structure for H.265 protocol encoding channel SAO.
Definition:
    k_u32 slice_sao_luma_flag;
    k_u32 slice_sao_chroma_flag;
} k_venc_h265_sao;
Members:
Member Name
slice_sao_luma_flag
Default is 1. Range: 0 or 1.
Notes:
None.
None.
3.1.28 k_venc_rect#
Description:
Defines the structure for rectangular area information.
Definition:
    k_s32 left;
    k_s32 right;
    k_u32 top;
    k_u32 bottom;
} k_venc_rect;
Members:
Member Name
left
Left offset.
right
Right offset.
top
Top offset.
bottom
Bottom offset.
Notes:
None.
None.
3.1.29 k_venc_roi_attr#
Description:
Defines the structure for encoding region of interest (ROI) information.
Definition:
    k_u32 idx;
    k_bool enable;
    k_bool is_abs_qp;
    k_s32 qp;
    [k_venc_rect](#3128-k_venc_rect) rect;
} k_venc_roi_attr;
Members:
Member Name
idx
Index of the ROI region. Supported index range: [0, 15]. Out of range indices are not supported.
enable
Whether to enable this ROI region.
is_abs_qp
QP mode of the ROI region. K_FALSE: relative QP. K_TRUE: absolute QP.
qp
QP value. Range: [0, 51].
rect
ROI region. left, right, top, and bottom must be 16-aligned.
Notes:
None.
None.
3.1.30 k_venc_h264_entropy#
Description:
Defines the structure for H.264 protocol encoding channel entropy coding.
Definition:
    k_u32 entropy_coding_mode;
    k_u32 cabac_init_idc;
} k_venc_h264_entropy;
Members:
Member Name
entropy_coding_mode
Entropy coding mode. 0: CAVLC. 1: CABAC. Values >= 2 are not meaningful. Baseline does not support CABAC. Default value is 1.
cabac_init_idc
Range: [0, 2], default value 0. For specific meanings, refer to the H.264 protocol.
Notes:
None.
None.
3.1.31 k_venc_h265_entropy#
Description:
Defines the structure for H.265 protocol encoding channel entropy coding.
Definition:
    k_u32 cabac_init_flag;
} k_venc_h265_entropy;
Members:
Member Name
cabac_init_flag
Range: [0, 1], default value 1. For specific meanings, refer to the H.265 protocol.
Notes:
None.
None.
3.2 Video Decoding#
The relevant data type definitions for this functional module are as follows:
3.2.1 K_VDEC_MAX_CHN_NUM#
Description:
Definition:
#define K_VDEC_MAX_CHN_NUM 4
Notes:
None.
None.
3.2.2 k_vdec_send_mode#
Description:
Defines the structure for decoding channel attributes.
Definition:
    K_VDEC_SEND_MODE_STREAM = 0,
    K_VDEC_SEND_MODE_FRAME,
    K_VDEC_SEND_MODE_BUTT
} k_vdec_send_mode;
Members:
Member Name
Send stream by stream mode.
Send stream by frame mode, in units of frames.
Notes:
Currently, only stream mode is supported.
None.
3.2.3 k_vdec_chn_attr#
Description:
Definition:
    [k_vdec_send_mode](#322-k_vdec_send_mode) mode;
    k_u32 pic_width;
    k_u32 pic_height;
    k_u32 frame_buf_size;
    k_u32 frame_buf_cnt;
    k_pixel_format pic_format;
} k_vdec_chn_attr;
Members:
Member Name
Enumeration value for decoding protocol type.
Stream sending mode.
pic_width
Maximum width of the decoded image supported by the channel (in pixels).
pic_height
Maximum height of the decoded image supported by the channel (in pixels).
stream_buf_size
Size of the stream buffer.
frame_buf_size
Size of the buffer for decoded image frames.
frame_buf_cnt
Number of frame buffers.
pic_format
Enumeration of input data format. Refer to “K230 System Control API Reference”.
Notes:
None.
None. |
【Notes】
  • Currently supported pic_format values are: PIXEL_FORMAT_YUV_SEMIPLANAR_420 and PIXEL_FORMAT_YVU_PLANAR_420.
【Related Data Types and Interfaces】
None.
3.2.4 k_vdec_chn_status#
【Description】
Defines the structure for channel status.
【Definition】
    k_bool is_started;
    k_u32 recv_stream_frames;
    k_u32 dec_stream_frames;
    [k_vdec_dec_err](#325-k_vdec_dec_err) dec_err;
    k_u32 width;
    k_u32 height;
    k_u64 latest_frame_pts;
} k_vdec_chn_status;
【Members】
Member Name
Decoding protocol.
is_started
Whether the decoder has started receiving streams.
recv_stream_frames
Number of stream frames received in the stream buffer. -1 indicates invalid. Not applicable in stream mode.
dec_stream_frames
Number of decoded frames in the stream buffer.
dec_err
Decoding error information.
Image width.
Image height.
latest_frame_pts
Timestamp of the latest decoded image.
end_of_stream
End of stream flag.
【Notes】
None.
None.
3.2.5 k_vdec_dec_err#
【Description】
Defines the structure for decoding error information.
【Definition】
    k_s32 set_pic_size_err;
    k_s32 format_err;
    k_s32 stream_unsupport;
} k_vdec_dec_err;
【Members】
Member Name
set_pic_size_err
Image width (or height) exceeds the channel’s width (or height).
format_err
Unsupported format.
stream_unsupport
Unsupported specification (stream specification does not match the claimed supported specification).
【Notes】
None.
None.
3.2.6 k_vdec_stream#
【Description】
Defines the structure for video decoding stream.
【Definition】
    k_u64 pts;
    k_u32 len;
    k_u8 *addr;
} k_vdec_stream;
【Members】
Member Name
end_of_stream
Whether all streams have been sent.
pts
Timestamp of the stream packet, in microseconds.
len
Length of the stream packet, in bytes.
addr
Address of the stream packet.
【Notes】
None.
None.
3.2.7 k_vdec_supplement_info#
【Description】
Defines the structure for output frame supplementary information.
【Definition】
    k_bool is_valid_frame;
} k_vdec_supplement_info;
【Members】
Member Name
Decoding protocol type enumeration.
is_valid_frame
Whether it is a valid frame.
end_of_stream
End of stream flag.
【Notes】
None.
None.
3.2.8 k_vdec_dsl_mode#
【Description】
Defines the enumeration for decoding downscale mode.
【Definition】
    K_VDEC_DSL_MODE_BY_SIZE,
    K_VDEC_DSL_MODE_BY_RATIO,
    K_VDEC_DSL_MODE_BUTT
} k_vdec_dsl_mode;
【Members】
Member Name
Downscale by size.
Downscale by ratio.
【Notes】
None.
None.
3.2.9 k_vdec_dsl_size#
【Description】
Defines the structure for downscaling size parameters.
【Definition】
    k_u32 dsl_frame_width;
    k_u32 dsl_frame_height;
} k_vdec_dsl_size;
【Members】
Member Name
dsl_frame_width
Width after downscaling.
dsl_frame_height
Height after downscaling.
【Notes】
None.
None.
3.2.10 k_vdec_dsl_ratio#
【Description】
Defines the structure for downscaling ratio parameters.
【Definition】
    k_u8 dsl_ratio_hor;
    k_u8 dsl_ratio_ver;
} k_vdec_dsl_ratio;
【Members】
Member Name
dsl_ratio_hor
Horizontal downscale ratio.
dsl_ratio_ver
Vertical downscale ratio.
【Notes】
None.
None.
3.2.11 k_vdec_downscale#
【Description】
Defines the structure for downscaling.
【Definition】
    [k_vdec_dsl_mode](#328-k_vdec_dsl_mode) dsl_mode;
    union
        [k_vdec_dsl_size](#329-k_vdec_dsl_size) dsl_size;
        [k_vdec_dsl_ratio](#3210-k_vdec_dsl_ratio) dsl_ratio;
} k_vdec_downscale;
【Members】
Member Name
dsl_mode
Downscale mode enumeration.
dsl_size
Structure for downscale by size.
dsl_ratio
Structure for downscale by ratio.
【Notes】
None.
None.
4. MAPI#
4.1 Video Encoding#
4.1.1 Overview#
MAPI is called on the small core to obtain VENC stream data.
4.1.2 Encoding Data Flow Diagram#
Figure 4-1
mapi encode channel
A typical encoding process includes receiving input images, encoding the images, cross-core data stream transmission, and stream output.
The encoding module (VENC) in the above figure consists of the VENC receiving channel, encoding channel, 2D receiving channel, and 2D operation module. For details, see [1.2.1 Video Encoding](#121-Video Encoding).
4.1.3 API#
The video encoding module mainly provides functions for creating and destroying video encoding channels, starting and stopping the reception of images on encoding channels, setting and getting encoding channel attributes, registering and deregistering callback functions for stream acquisition, etc.
This functional module provides the following MAPI:
kd_mapi_venc_init
kd_mapi_venc_deinit
kd_mapi_venc_registercallback
kd_mapi_venc_start
kd_mapi_venc_stop
kd_mapi_venc_bind_vi
kd_mapi_venc_unbind_vi
4.1.3.1 kd_mapi_venc_init#
【Description】
Initializes the encoding channel.
【Syntax】
k_s32 kd_mapi_venc_init(k_u32 chn_num, [k_venc_chn_attr](#3115-k_venc_chn_attr) *pst_venc_attr)
【Parameters】
Parameter Name
Input/Output
chn_num
VENC channel number. Range: [0, VENC_MAX_CHN_NUM)
Input
pst_venc_attr
Pointer to VENC channel attributes. Static attributes.
Input
【Return Value】
Success
Non-zero
Failure, the value is the error code
【Chip Differences】
None.
【Requirements】
Header files: mapi_venc_api.h, k_venc_comm.h Library files: libmapi.a, libipcmsg.a, libdatafifo.a
【Notes】
  • Before calling this interface, kd_mapi_sys_init() and kd_mapi_media_init() need to be successfully initialized. See the “SYS MAPI” section for details.
  • Reinitialization returns success.
【Example】
Please refer to the sample_venc code.
【Related Topics】
kd_mapi_venc_deinit k_venc_chn_attr
4.1.3.2 kd_mapi_venc_deinit#
【Description】
Deinitializes the encoding channel.
【Syntax】
【Parameters】
Parameter Name
Input/Output
chn_num
Input
【Return Value】
Success
Non-zero
Failure, the value is the [error code](#5. Error Codes)
【Chip Differences】
None.
【Requirements】
【Notes】
None.
【Example】
None.
【Related Topics】
kd_mapi_venc_init
4.1.3.3 kd_mapi_venc_registercallback#
【Description】
Registers a callback function for the encoding channel to acquire encoding data.
【Syntax】
k_s32 kd_mapi_venc_registercallback(k_u32 chn_num, [kd_venc_callback_s](#4141-kd_venc_callback_s) *pst_venc_cb);
【Parameters】
Parameter Name
Input/Output
chn_num
Input
pst_venc_cb
Pointer to the encoder callback function structure.
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
【Notes】
  • The callback function structure pointer cannot be null.
  • The structure contents must be exactly the same to indicate that the callback function structures are equal.
  • Each channel supports up to five callback functions.
【Example】
None.
【Related Topics】
4.1.3.4 kd_mapi_venc_unregistercallback#
【Description】
Unregisters a callback function for the encoding channel.
【Syntax】
k_s32 kd_mapi_venc_unregistercallback(k_u32 chn_num, [kd_venc_callback_s](#4141-kd_venc_callback_s) *pst_venc_cb);
【Parameters】
Parameter Name
Input/Output
chn_num
Input
pst_venc_cb
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
【Notes】
The contents of the pst_venc_cb callback function structure must be exactly the same as when it was registered to unregister the callback function.
【Example】
None.
【Related Topics】
4.1.3.5 kd_mapi_venc_start#
【Description】
Starts the encoding channel.
【Syntax】
【Parameters】
Parameter Name
Input/Output
chn_num
Input
s32_frame_cnt
Expected number of encoded frames.
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None. 【Requirements】
【Notes】
  • Scenario 1: In the video stream encoding scenario, s32_frame_cnt should be set to [KD_VENC_LIMITLESS_FRAME_COUNT](#4146-kd_venc_limitless_frame_count).
  • Scenario 2: In the scenario of single or multiple data encoding, you can only restart after the previous encoding is finished.
  • When switching from Scenario 1 to Scenario 2, you need to call the kd_mapi_venc_stop interface first.
  • When switching from Scenario 2 to Scenario 1, you can call the kd_mapi_venc_stop interface first or restart encoding after the current encoding is finished.
  • For the encoding completion flag, please refer to end_of_stream in kd_venc_data_s.
【Example】
None.
【Related Topics】
kd_mapi_venc_stop
4.1.3.6 kd_mapi_venc_stop#
【Description】
Stops the encoding channel.
【Syntax】
【Parameters】
Parameter Name
Input/Output
chn_num
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
【Notes】
None.
【Example】
None.
【Related Topics】
kd_mapi_venc_start
4.1.3.7 kd_mapi_venc_bind_vi#
【Description】
Binds the encoding channel to the input source VI.
【Syntax】
k_s32 kd_mapi_venc_bind_vi(k_s32 src_dev, k_s32 src_chn, k_s32 chn_num);
【Parameters】
Parameter Name
Input/Output
src_dev
Input source Device ID
Input
src_chn
Input source Channel ID
Input
chn_num
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
【Notes】
None.
【Example】
None.
【Related Topics】
4.1.3.8 kd_mapi_venc_unbind_vi#
【Description】
Unbinds the input source VI from the encoding channel.
【Syntax】
【Parameters】
Parameter Name
Input/Output
src_dev
Input
src_chn
Input
chn_num
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
【Notes】
None.
【Example】
None.
【Related Topics】
4.1.3.9 kd_mapi_venc_request_idr#
【Description】
Requests an IDR frame, which is generated immediately after the call.
【Syntax】
【Parameters】
Parameter Name
Input/Output
chn_num
VENC channel number. Range: [0, VENC_MAX_CHN_NUM]
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
【Notes】
None.
【Example】
None.
【Related Topics】
kd_mapi_venc_start
4.1.3.10 kd_mapi_venc_enable_idr#
【Description】
Enables IDR frames, generating them according to the GOP interval.
【Syntax】
【Parameters】
Parameter Name
Input/Output
chn_num
Input
idr_enable
Whether to enable IDR frames, 0: disable, 1: enable
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
【Notes】
【Example】
None.
【Related Topics】
kd_mapi_venc_start
4.1.4 Data Types#
The data types related to video encoding are defined as follows:
4.1.4.1 kd_venc_callback_s#
【Description】
Encoding callback function structure.
【Definition】
    [pfn_venc_dataproc](#4142-pfn_venc_dataproc);
    k_u8 *p_private_data;
} kd_venc_callback_s;
【Members】
Member Name
pfn_data_cb
Callback processing function for obtaining encoded data.
p_private_data
Private data pointer, used as a parameter in pfn_venc_dataproc.
【Notes】
  • After this structure is registered and encoding starts, pfn_data_cb will be called when there is encoded data. Users obtain encoded data through this function.
  • p_private_data is optional and can be used by the user.
4.1.4.2 pfn_venc_dataproc#
【Description】
Defines the encoding data callback function.
【Definition】
typedef k_s32 (*pfn_venc_dataproc)(k_u32 chn_num, [kd_venc_data_s](#4144-k_venc_data_pack_s) *p_vstream_data, k_u8 *p_private_data);
【Members】
Member Name
chn_num
Encoding channel handle
kd_venc_data_s
Data pointer
p_private_data
【Notes】
None.
4.1.4.3 kd_venc_data_s#
【Description】
Encoded data packet type.
【Definition】
    [k_venc_chn_status](#3122-k_venc_chn_status);
    k_u32 u32_pack_cnt;
    [k_venc_data_pack_s](#4144-k_venc_data_pack_s) astPack[KD_VENC_MAX_FRAME_PACKCOUNT];
} kd_venc_data_s;
【Members】
Member Name
status
Channel status
u32_pack_cnt
Number of packs
astPack
Data packs
【Notes】
None.
pfn_venc_dataproc kd_mapi_venc_start
4.1.4.4 k_venc_data_pack_s#
【Description】
【Definition】
    k_char *vir_addr;
    k_u64 phys_addr;
    k_u32 len;
    k_u64 pts;
    k_venc_pack_type type;
} k_venc_data_pack_s;
【Members】
Member Name
vir_addr
Virtual address of the data pack
phys_addr
Physical address of the data pack
len
Length of the data pack
pts
Timestamp
Stream pack type
【Notes】
Both vir_addr and phys_addr have one address.
kd_venc_data_s
4.1.4.5 KD_VENC_MAX_FRAME_PACKCOUNT#
【Description】
Defines the maximum number of packs per frame.
【Definition】
【Notes】
None.
None.
4.1.4.6 KD_VENC_LIMITLESS_FRAME_COUNT#
【Description】
Defines unlimited video encoding.
【Definition】
【Notes】
None.
kd_mapi_venc_start
4.2 Video Decoding#
4.2.1 API#
The video decoding module mainly provides functions for creating and destroying video decoding channels, starting and stopping the reception of images on decoding channels, setting and getting decoding channel attributes, and binding output decoded images to VO.
kd_mapi_vdec_init
kd_mapi_vdec_deinit
kd_mapi_vdec_start
kd_mapi_vdec_stop
kd_mapi_vdec_bind_vo
kd_mapi_vdec_unbind_vo
kd_mapi_vdec_send_stream
kd_mapi_vdec_query_status
4.2.1.1 kd_mapi_vdec_init#
【Description】
Initializes the decoding channel.
【Syntax】
k_s32 kd_mapi_vdec_init(k_u32 chn_num, const [k_vdec_chn_attr](#323-k_vdec_chn_attr) *attr);
【Parameters】
Parameter Name
Input/Output
chn_num
VDEC channel number. Range: [0, VDEC_MAX_CHN_NUM)
Input
attr
Pointer to VDEC channel attributes. Static attributes.
Input
【Return Value】
Success
Non-zero
【Chip Differences】
None.
【Requirements】
Header files: mapi_vdec_api.h, k_vdec_comm.h Library files: libmapi.a, libipcmsg.a, libdatafifo.a
【Notes】
【Example】
Please refer to the sample_vdec code.
【Related Topics】
kd_mapi_vdec_deinit
4.2.1.2 kd_mapi_vdec_deinit#
【Description】
Deinitializes the decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mapi_vdec_init
4.2.1.3 kd_mapi_vdec_start#
Description:
Starts the decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mapi_vdec_stop
4.2.1.4 kd_mapi_vdec_stop#
Description:
Stops the decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Input
Return Values:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mapi_vdec_start
4.2.1.5 kd_mapi_vdec_bind_vo#
Description:
Binds the decoding channel to the output source VO.
Syntax:
k_s32 kd_mapi_vdec_bind_vo(k_s32 chn_num, k_s32 vo_dev, k_s32 vo_chn);
Parameters:
Parameter Name
Input/Output
chn_num
Input
vo_dev
Output VO device ID
Input
vo_chn
Output VO device channel
Input
Return Values:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
4.2.1.6 kd_mapi_vdec_unbind_vo#
Description:
Unbinds the output source VO from the decoding channel.
Syntax:
k_s32 kd_mapi_vdec_unbind_vo(k_s32 chn_num, k_s32 vo_dev, k_s32 vo_chn);
Parameters:
Parameter Name
Input/Output
chn_num
Input
vo_dev
Output VO device ID
Input
vo_chn
Input
Return Values:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
4.2.1.7 kd_mapi_vdec_send_stream#
Description:
Sends stream data for decoding.
Syntax:
k_s32 kd_mapi_vdec_send_stream(k_u32 chn_num, [k_vdec_stream](#326-k_vdec_stream) *stream, k_s32 milli_sec);
Parameters:
Parameter Name
Input/Output
chn_num
Input
stream
Pointer to the stream data for decoding
Input
milli_sec
Flag for sending stream data. Range: -1: Blocking, 0: Non-blocking, Positive value: Timeout period in milliseconds
Input
Return Values:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
4.2.1.8 kd_mapi_vdec_query_status#
Description:
Queries the status of the decoding channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Encoding channel information. Range: [0, [K_VDEC_MAX_CHN_NUM](#321-k_vdec_max_chn_num))
Input
status
Output
Return Values:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
None.
5. Error Codes#
Table 41 Encoding API Error Codes
Error Code
Macro Definition
0xa0098001
K_ERR_VENC_INVALID_DEVID
Device ID out of valid range
0xa0098002
K_ERR_VENC_INVALID_CHNID
Channel ID out of valid range
0xa0098003
Parameters out of valid range
0xa0098004
K_ERR_VENC_EXIST
Attempt to create an existing device, channel, or resource
0xa0098005
K_ERR_VENC_UNEXIST
Attempt to use or destroy a non-existent device, channel, or resource
0xa0098006
K_ERR_VENC_NULL_PTR
Null pointer in function parameter
0xa0098007
K_ERR_VENC_NOT_CONFIG
Not configured before use
0xa0098008
K_ERR_VENC_NOT_SUPPORT
Unsupported parameter or function
0xa0098009
K_ERR_VENC_NOT_PERM
Operation not allowed, such as trying to modify static configuration parameters
0xa009800c
K_ERR_VENC_NOMEM
Memory allocation failure, such as insufficient system memory
0xa009800d
K_ERR_VENC_NOBUF
Buffer allocation failure, such as requested data buffer too large
0xa009800e
K_ERR_VENC_BUF_EMPTY
No data in the buffer
0xa009800f
K_ERR_VENC_BUF_FULL
Data in the buffer is full
0xa0098010
K_ERR_VENC_NOTREADY
System not initialized or corresponding module not loaded
0xa0098011
K_ERR_VENC_BADADDR
Address out of valid range
0xa0098012
K_ERR_VENC_BUSY
VENC system busy
Table 42 Decoding API Error Codes
Error Code
Macro Definition
0xa00a8001
K_ERR_VDEC_INVALID_DEVID
0xa00a8002
K_ERR_VDEC_INVALID_CHNID
0xa00a8003
K_ERR_VDEC_ILLEGAL_PARAM
0xa00a8004
K_ERR_VDEC_EXIST
0xa00a8005
K_ERR_VDEC_UNEXIST
0xa00a8006
K_ERR_VDEC_NULL_PTR
0xa00a8007
K_ERR_VDEC_NOT_CONFIG
0xa00a8008
K_ERR_VDEC_NOT_SUPPORT
0xa00a8009
K_ERR_VDEC_NOT_PERM
0xa00a800c
K_ERR_VDEC_NOMEM
0xa00a800d
K_ERR_VDEC_NOBUF
0xa00a800e
K_ERR_VDEC_BUF_EMPTY
0xa00a800f
K_ERR_VDEC_BUF_FULL
0xa00a8010
K_ERR_VDEC_NOTREADY
0xa00a8011
K_ERR_VDEC_BADADDR
0xa00a8012
K_ERR_VDEC_BUSY
VDEC system busy
6. Debug Information#
For multimedia memory management and system binding debug information, please refer to the “K230 System Control API Reference”.
