K230 ISP Initialization Configuration Guide#
Overview of K230 ISP Initialization Configuration#
After image tuning, the formed ISP configuration parameters need to be written into the corresponding sensor’s initialization configuration file. During startup, the ISP will automatically call the settings in these configuration files to complete the initialization. When the module’s adaptive function is enabled, the ISP will operate according to the settings of the module’s adaptive function. The ISP initialization configuration includes three files: xml, manual.json, and auto.json. If the sensor supports different resolutions, these three configuration files are required for each resolution. These configuration files are stored in the \k230_sdk\src\big\mpp\userapps\src\sensor\config directory.
xml File#
The xml file can be generated using the K230 ISP Calibration Tool (K230ISPCalibrationTool.exe). All module calibrations in the tool need to be completed to obtain complete calibration data.
The data contained in the xml file comes from two sources:
  • Calibration results obtained using the Calibration Tool
  • Professional data files provided in the tool release package
The storage location of calibration data and calibration parameter files is shown in the table below:
Calibration Data
Generation Method or Parameter File
Calibration Parameter File Location
Auto White Balance
Calibration Tool
sensor/lens/sample/AWB/
Black Level Calibration
Calibration Tool
Chromatic Aberration
Calibration Tool
Color Calibration
Calibration Tool
Defect Pixel Color Correction
dpcc_para.txt
Auto Exposure Calibration
aec_para.m; k_para.txt
HDR
hdr_para.txt
Lens Shading Correction
Calibration Tool
Noise Calibration
Calibration Tool
Photo Response Linearity
degamma_para.txt
Creating Folders for Calibration Parameter Files#
Please follow the steps below to create folders for each resolution:
  1. Create a folder using the sensor name (e.g., /OV9732)
  2. Create a folder using the lens name (e.g., /2MP)
  3. Create a folder using the sample name (e.g., /01_30)
  4. Create subfolders for each calibration function (as shown in the figure below)
    Create folders
  5. Copy the calibration parameter files into the corresponding parameter folders
For each resolution, an example is as follows:
  • sensor
    • lens
      • sample
        • AWB
          • AWB parameters.txt
          • AWB parameters.mat
        • BlackLevel
          • BLS parameters.txt
Generating the xml File Using the K230 ISP Calibration Tool#
After copying all calibration parameter files into the corresponding folders, open the K230 ISP Calibration Tool and use it to generate the xml file.
As shown in the figure below, click the “7. XML Generator” button on the main interface:
Main Interface
The “XML Generator” dialog box will pop up as shown in the figure below:
Select XML File Generation
In the “Data Location” field, select the correct calibration directory address, select the created sensor folder in the “Sensor” field, select the created lens folder in the “Lens” field, and select the created sample folder in the “Data” field.
Enter the correct Width and Height of the image in the “Resolution” field, select “XML” in the “Format” field, enter the creator’s name in the “Creator” field, and then click “Manually Generate” to generate the “XML” subdirectory under the selected lens folder, where the .xml file will be generated.
XML Folder
Rename the generated xml file according to the xml name input in the K230 SDK code (e.g., ov9732-1280x720.xml), and place it in the config directory to be correctly called by the K230 SDK.
AWB Parameter K_Factor#
In the xml file, the awb segment contains a K_Factor parameter that needs to be calibrated and manually filled in. This parameter reflects the sensitivity of the camera module.
In the AWB algorithm, the environment is judged as outdoor if Exp*K_Factor <=0.12 (Exp is the exposure).
For example, using 2000 lux as the illumination point between outdoor and transition environments, obtain the exposure value corresponding to this illumination (ET gain), then calculate: K_Factor = 0.12 / (ETgain).
manual.json File#
The manual.json file needs to be created manually. Please refer to the imx335-2592x1944_manual.json file to create the manual.json file for the required sensor resolution.
CHdrv2#
Function Description#
This module sets the HDR mode parameters not included in other ISP modules.
Main Parameters#
Parameter
Type and Range
base_frame
int 0~1
0: S frame as reference frame;
1: L frame as reference frame.
Recommended setting is 0.
bls_out
int[4]
Black level out
Default configuration is [0,0,0,0], setting value based on ISP 12bits
bypass
bool
false: Pass through HDR module
true: Bypass HDR module
bypass_select
int 0~2
0: HDR module outputs L frame;
1: HDR module outputs S frame;
2: HDR module outputs VS frame
color_weight
int[3] 0~255
color_weight
Recommended setting is [255, 0, 1]
enable
bool
false: HDR not enabled
true: HDR enabled
extend_bit
int[2] -1~8
Extend bit position
[L/S frame fusion, LS/VS frame fusion]
Recommended setting is [-1,-1], auto-calculation; 0 ~ 8 is manual setting value.
ratio
float[3] 1.0~256.0
Exposure ratio
sensor_type
int 0~6
0,1,2: L_12+S_12+VS_12
3: LS_16+VS_12
4,6: L_12+S_12
5: L_12+VS_12
stitching_mode
int 0~1
0: Linear synthesis mode;
1: Non-linear synthesis mode
trans_range
float[6][2] 0.0~1.0
Synthesis range start and end values
Reference frame pixel lower than start value, synthesis frame pixel is longer frame;
Reference frame pixel higher than end value, synthesis frame pixel is shorter frame;
Reference frame pixel between the two, synthesis frame is fusion of longer and shorter frames.
In the above table:
Frame Number
L frame
Long exposure frame
S frame
Short exposure frame
VS frame
Very short exposure frame
LS frame
Frame fused from L and S frames
LSVS frame
Frame fused from LS and VS frames
Please note that in K230 HDR mode, the K230 CSI (Camera Serial Interface) module does not support sensor data mode where Hsync precedes Vsync, and each frame (L/S/VS) Vsync high (valid data output) cannot overlap.
CGreenEqu#
Please refer to section 3.7 of the “K230 ISP Image Tuning Guide.”
CRgbIR#
This module sets the input processing for RGBIR sensors.
Main Parameters#
Parameter
Type and Range
bit
int
12, fixed value
ccmatrix
float[12]
3x4 color conversion matrix, converts RGBIR values to RGB values
dpcc_mid_th
int
DPCC channel mid threshold value
dpcc_th
int
DPCC channel threshold value
enable
bool
false: RGBIR submodule not enabled
true: RGBIR submodule enabled
gain
int[3]
R/G/B channel gain
Default setting is [1,1,1]
ir_threshold
int
IR high value threshold
If IR value is higher than this value, IR color influence factor is 0.
irbayer_pattern
int
RGBIR arrangement type
0: BGGIR
2: RGGIR
K230 only supports RGGIR and BGGIR arrangement types, please set the RGBIR sensor data output to one of these two types.
l_threshold
int
IR low value threshold
If IR value is lower than this value, IR color influence factor is 1.
out_rgb_pattern
int
Output RGB data arrangement type
3: BGGR
No need to change.
CManualWb#
Please refer to section 3.12 of the “K230 ISP Image Tuning Guide.”
CCcm#
Please refer to section 3.13 of the “K230 ISP Image Tuning Guide.”
CDgain#
Please refer to section 3.3 of the “K230 ISP Image Tuning Guide.”
CCpdv1#
Please refer to section 3.19 of the “K230 ISP Image Tuning Guide.”
Bls#
This module sets the black level. The default bls function is turned on.
Main Parameters#
Parameter
Type and Range
bls
int[4]
Black level
[bls_r,bls_gr,bls_gb,bls_b].
Currently, the driver only supports the same black level configuration for each channel, setting value based on ISP 12bits
CGamma64#
Please refer to section 3.14 of the “K230 ISP Image Tuning Guide.”
CDpcc#
Please refer to section 3.8 of the “K230 ISP Image Tuning Guide.”
CDpf#
Please refer to section 3.9 of the “K230 ISP Image Tuning Guide.”
CLscv2#
Please refer to section 3.2 of the “K230 ISP Image Tuning Guide.”
CWdrv4#
Please refer to section 3.6 of the “K230 ISP Image Tuning Guide.”
C3dnrv3_1#
Please refer to section 3.10 of the “K230 ISP Image Tuning Guide.”
CCproc#
Please refer to section 3.18 of the “K230 ISP Image Tuning Guide.”
CEEv1#
This module includes three sub-blocks: CA, DCI, and EE.
Main Parameters#
Please refer to sections 3.15 (EE), 3.16 (CA), and 3.17 (DCI) of the “K230 ISP Image Tuning Guide.”
CDmscv2#
This module includes two sub-blocks: CAC and DMSC.
Main Parameters#
For CAC parameter settings, please refer to section 3.20 of the “K230 ISP Image Tuning Guide.” For DMSC parameter settings, please refer to section 3.11 of the “K230 ISP Image Tuning Guide.”
auto.json File#
The auto.json file needs to be created manually. Please refer to the imx335-2592x1944_auto.json file to create the auto.json file for the required sensor resolution.
AdaptiveAe#
This module sets the parameters for AE control and AE adaptive functionality.
Main Parameters#
Parameter
Type and Range
enable
bool
Auto-exposure enable switch.
false: Disable auto-exposure
true: Enable auto-exposure
semMode
int 0~2
Scene mode
0: Scene evaluation off mode
1: Scene evaluation fixed mode
2: Scene evaluation dynamic mode
antiFlickerMode
int 0~3
Anti-flicker mode
0: Off
1: 50Hz
2: 60Hz
3: User defined
setPoint
float 0~255.0
Set AE brightness target value
tolerance
float 0~100.0
Set AE brightness target value percentage lock range
dampOver
float 0~1.0
Damping factor for smoothing AE convergence during overexposure
dampOverGain
float 0~128.0
Convergence acceleration gain factor outside the clip range during AE overexposure, the larger the value, the faster the convergence
dampOverRatio
float 1.0~4.0
Proportional factor outside the clip range during AE overexposure, the smaller the value, the faster the convergence
dampUnder
float 0~1.0
Damping factor for smoothing AE convergence during underexposure
dampUnderGain
float 0~16.0
Convergence acceleration gain factor outside the clip range during AE underexposure, the larger the value, the faster the convergence
dampUnderRatio
float 0~1.0
Proportional factor outside the clip range during AE underexposure, the larger the value, the faster the convergence
motionFilter
float 0~1.0
Motion change smoothing parameter for calculating the motion factor in AE scene evaluation adaptive mode
motionThreshold
float 0~1.0
Motion discrimination threshold
targetFilter
float 0~1.0
AE brightness target value change smoothing coefficient, the larger the value, the faster the change
lowLightLinearRepress
float[20] 0~1.0
In linear mode, the target brightness suppression ratio corresponding to the current gain step
lowLightLinearGain
float[20] 0~255.0
In linear mode, the gain value corresponding to the current gain step
lowLightLinearLevel
int 0~19
Total gain steps in linear mode
lowLightHdrRepress
float[20] 0~1.0
In HDR mode, the target brightness suppression ratio corresponding to the current gain step
lowLightHdrGain
float[20] 0~255.0
In HDR mode, the gain value corresponding to the current gain step
lowLightHdrLevel
int 0~16
Total gain steps in HDR mode
wdrContrastMax
float 0~255.0
Maximum contrast value for calculating AE setpoint in AE scene evaluation adaptive mode
wdrContrastMin
float 0~255.0
Minimum contrast value for calculating AE setpoint in AE scene evaluation adaptive mode
frameCalEnable
bool
Exposure setting frame interval enable switch.
true: Enable exposure setting frame interval function
false: Disable exposure setting frame interval function
autoHdrEnable
bool
true: In HDR mode, automatically calculate the current frame HDR ratio
false: In HDR mode, use a fixed HDR ratio
roiNumber
int
Current ROI window index
roiWindow
float (fx,fy,fw,fh,weight)
Start coordinates (x,y), width, height, and brightness calculation weight of the current ROI window
expV2WindowWeight
float[32x32] 0~255
Exposure weight of each sub-block
Awbv2#
This module sets the parameters for the AWB adaptive functionality.
Main Parameters#
Parameter
Type and Range
enable
bool
true: Enable AWB
false: Disable AWB
int 0,1
0: AWB
1: AWB METADATA
useCcMatrix
bool
true: Enable CCM adaptive
false: Disable CCM adaptive
useCcOffset
bool
true: Enable CCM offset adaptive
false: Disable CCM offset adaptive
useDamping
bool
true: Enable AWB damping changes
false: Disable AWB damping changes
roiNumber
int
roiWindow
Start coordinates (x,y), width, height, and AWB calculation weight of the current ROI window
Af#
This module sets the parameters for the AF functionality. This module is not yet effective.
Main Parameters#
Parameter
Type and Range
enable
bool
false: Disable AF
true: Enable AF
int
0: Normal AF mode
(Other AF modes planned for development)
weightWindow
float[3] 0~255.0
Set the weight values for the three statistical windows used for sharpness calculation
cMotionThreshold
float 0~1.0
Not yet used, will be used for motion detection
cPointsOfCurve
int 1~20
Number of equal divisions for the AF ramp algorithm. The larger the value, the slower the focus speed; the smaller the value, the faster the focus speed, but a large step size may cause inaccurate focusing.
cStableTolerance
float 0~1.0
Threshold for AF to enter the defocus state from the locked state. The smaller the value, the easier it is to enter the refocus state.
focalFilter
float[5] 0~1023
Not yet used
shapFilter
float[5] 0~1023
Not yet used
focalStableThreshold
float 0~1.0
Threshold for focus to enter the locked state. The smaller the value, the harder it is to enter the locked state
maxFocal
int 0~1023
Maximum motor position calibrated for AF
minFocal
int 0~1023
Minimum motor position calibrated for AF
cMseTolerance
float 0~1.0
Not yet used
cPdConfThreshold
float 0~1023.0
Not used
PdFocal
int -254~254
Not used
PdDistance
int 1~254
Not used
PdShiftThrehold
float 0~1.0
Not used
PdStablecountMax
uint8 1~10
Not used
PdROIIndex
uint8 0~48
Not used
ALscv2#
This module sets the parameters for the LSC adaptive functionality.
Main Parameters#
Parameter
Type and Range
enable
bool
false: Disable ALSC
true: Enable ALSC
damping
float
Damping factor for smoothing LSC curve changes during ALSC
interMode
int 0~2
0: Adaptive adjustment based on gain value
1: Adaptive adjustment based on color temperature
2: Adaptive adjustment based on gain value and color temperature
hdr
bool
false: Indicates settings for linear mode
true: Indicates settings for HDR mode
gain
float[20]
Gain values for each step
strength
float[20] 0~1.0
LSC retention strength corresponding to each gain value
Others#
This section provides a unified introduction to other adaptive functionality modules.
The setting parameters of these adaptive functionality modules are usually divided into two parts, guided by the “tables” marker and enclosed in square brackets “[]”. Parameters outside these brackets are boolean type enable parameters, while those inside are parameters involved in adaptive functionality adjustment.
Description of Parameters Outside the Tables#
In these functionality modules, there are usually three parameters outside the tables:
Parameter
Type
disable
bool
Can be fixed to false
enable
bool
false: Disable; true: Enable
Set according to the required adaptive module functionality
forcecreate
bool
Can be fixed to true
In the A3dnrv3 module, there are also two parameters outside the tables:
Parameter
Type
nlm_en
bool
Non-local means denoising enable switch, recommended to be set to true
tnr_en
bool
Temporal denoising enable switch. Since K230 ISP tnr is actually controlled by external command parameters, it can be fixed to false
Description of Parameters Inside the Tables#
In the functionality modules, there are two parameters:
Parameter
Type and Range
hdr
bool
gain
float[20]
For other adaptive functionality parameters, please refer to the corresponding functionality sections in the “K230 ISP Image Tuning Guide.”
The “gain” parameter can be divided into a maximum of 20 steps from the minimum value (usually 1x) to the maximum value. Each step should set the corresponding gain value in the gain parameter array.
It is important to note that each adaptive module can define different step counts based on its adaptive needs, with a maximum of 20 steps.
All parameters involved in adaptive functionality within the same adaptive functionality module should determine their array size according to the number of gain steps, and each step should set an appropriate value based on the corresponding gain value for that step.
