K230 Hardware Design Guide#
Chip Overview#
Chip Block Diagram#
Figure 1-1 K230 Block Diagram Figure 1-1 K230 Block Diagram
Application Block Diagram#
Figure 1-2 is the K230 door lock application block diagram Figure 1-2 K230 Door Lock Solution Application Block Diagram Figure 1-2 K230 Door Lock Solution Application Block Diagram Figure 1-3 is the dictionary pen solution application block diagram Figure 1-3 K230 Dictionary Pen Solution Application Block Diagram Figure 1-3 K230 Dictionary Pen Solution Application Block Diagram
Packaging and Pins#
Packaging#
Information#
The packaging information of K230 is shown in Table 2-1:
Device
Package
Size
Pitch
K230
VFBGA390
13mm x 13mm
0.65
K230D
LFBGA256
11mm x 11mm
0.65
Package Dimensions#
K230 Dimensions#
Figure 2-1 Figure 2-1 Figure 2-2 Figure 2-2 Figure 2-3 Figure 2-3
Ball Solder Mask Opening: 0.270mm
Primary datum C and bottom are solder balls
Dimension b is the maximum solder ball diameter, parallel to primary datum C
K230D Dimensions#
Figure 2-4 Figure 2-4 Figure 2-5 Figure 2-5
Pin Definition Diagram#
The pin distribution diagram of K230 is as follows: Figure 2-6 K230 Package Pin Distribution Figure 2-6 K230 Package Pin Distribution Figure 2-7 K230D Package Pin Distribution Figure 2-7 K230D Package Pin Distribution For pin details, see table K230_PINOUT_V1.2_20240822.xlsx.
Schematic Design Recommendations#
Minimum System Design#
Clock Requirements#
The main system of K230 requires a 24MHz high-speed clock, and the RTC of the PMU subsystem requires a 32.768kHz low-speed clock.
Table 3-1 shows the parameters of the allowable clock sources for K230.
Frequency
Accuracy
Level
32.768KHz
20ppm
1.8V
24MHz
20ppm
1.8V
It is recommended to use clock sources with an accuracy of 20ppm or higher.
High-Speed Clock#
The recommended passive crystal connection method is shown in Figure 3-1. Figure 3-1 K230 Crystal Circuit Figure 3-1 K230 Crystal Circuit Note:
  • The selected capacitors need to match the load capacitance of the crystal, and it is recommended to use NPO material.
  • It is recommended to use a 4-pin SMD crystal, with 2 GND pins fully connected to the ground to enhance the system clock’s ESD interference resistance.
  • To improve the startup speed, a 1MΩ resistor can be added between the IN pin and the OUT pin.
The recommended active crystal connection method is shown in Figure 3-2. Figure 3-2 K230 Active Crystal Circuit Figure 3-2 K230 Active Crystal Circuit During operation, the crystal output is connected to the CLK24M_XIN pin of K230, and the CLK24M_XOUT pin is left floating.
Low-Speed Clock#
The K230 chip has a built-in PMU circuit, and the single board needs to provide a clock for the PMU circuit. The recommended circuit is shown in Figure 3-3. Figure 3-3 K230 RTC Clock Passive Crystal Circuit Figure 3-3 K230 RTC Clock Passive Crystal Circuit The recommended active crystal connection method is shown in Figure 3-4. Figure 3-4 K230 RTC Clock Active Crystal Circuit Figure 3-4 K230 RTC Clock Active Crystal Circuit
During operation, the crystal output is connected to the CLK32K768_XIN pin of K230, and the CLK32K768_XOUT pin is left floating. Note:
  • When using an active crystal, the NC places in the above active crystal circuits need to be connected with a 0Ω resistor.
Reset Circuit#
The hardware reset of K230 is achieved through the RSTN pin, which is active low. If using a button reset, it is recommended to add a 100nF capacitor to the reset signal pin to eliminate reset signal jitter, enhance anti-interference ability, and prevent system abnormal reset caused by mis-triggering. The reset circuit schematic is shown in Figure 3-5. Figure 3-5 K230 Reset Circuit Figure 3-5 K230 Reset Circuit
System Boot Sequence#
The K230 chip provides four boot modes, which can be configured through the BOOT0 and BOOT1 pins. Table 3-2 shows the boot modes of K230 under different configurations.
BOOT0
BOOT1
K230
K230D
NOR FLASH
NOR FLASH
NAND FLASH
NAND FLASH
MMC0
MMC1
MMC1
MMC0
Table 3-2 Boot Mode Description
Note:
  • When all four boot modes fail, it will jump to USB/UART boot.
Figure 3-6 shows the recommended BOOT circuit Figure 3-6 K230 BOOT Circuit Figure 3-6 K230 BOOT Circuit
JTAG Debug Circuit#
The recommended JTAG interface circuit for the K230 chip is shown in Figure 3-7. Figure 3-7 K230 JTAG Download Circuit Figure 3-7 K230 JTAG Download Circuit Among them, JTAG_TCK, JTAG_TDI, JTAG_TMS, and JTAG_RST are recommended to be pulled up with 10kΩ, and JTAG_TDO is left floating. K230 must use the CKLink series debugger provided by Pingtouge Semiconductor Co., Ltd., otherwise, the chip cannot be debugged.
DDR Controller#
The K230 chip has two versions, K230 and K230D. The K230 version requires a separate DDR circuit design. The K230D version has the DDR Die packaged together and does not require an external DDR circuit design. The K230 DDR controller has the following features:
  • Supports LPDDR3/LPDDR4
  • Supports 2 ranks
  • Supports 16-bit, 32-bit DDR data bus width
  • Verified models:
    Type
    Model
    Manufacturer
    Capacity
    LPDDR3
    NT6CL128M32DM-H0
    Nanya
    4Gb
    LPDDR3
    RS128M32LD3D1LMZ-125BT
    Rayson
    4Gb
    LPDDR4
    W66AP6NBUAF/G/HI
    Winbond
    4Gb
    LPDDR4
    K4F8E304HB-MGCJ
    Samsung
    8Gb
The schematic of the K230 DDR PHY and each DRAM chip must be consistent with the reference schematic, including power decoupling capacitors.
LPDDR3#
The circuit design of LPDDR3 refers to Figures 3-8, 3-9, 3-10, and 3-11. Figure 3-8 K230 LPDDR3 Circuit Figure 3-8 K230 LPDDR3 Circuit Figure 3-9 K230 LPDDR3 Power Circuit Figure 3-9 K230 LPDDR3 Power Circuit Figure 3-10 LPDDR3 Chip Power Circuit Figure 3-10 LPDDR3 Chip Power Circuit Figure 3-11 LPDDR3 Chip Circuit Figure 3-11 LPDDR3 Chip Circuit
When using LPDDR3:
  • The schematic of the DDR PHY and each DRAM chip needs to be consistent with the reference design, including power decoupling capacitors.
  • The DDR_ZN pin needs to be connected to a 240Ω (1%) calibration resistor to ground.
  • The DDR_RESET pin is left floating.
  • The chip has a built-in VREF circuit for the DDR controller, so the DDR_VREF pin needs to be left floating.
  • The LP3_VREFDQ voltage of the LP3 chip is 0.8V, and it is recommended to use 100Ω and 200Ω (1%) resistors for voltage division.
  • The LP3_VREFCA voltage is 0.6V, and it is recommended to use 1kΩ (1%) resistors for voltage division.
  • The CA, CS, CKE, CLK, and ODT pins of the LP3 need to use 100Ω resistors to pull up to DDR_VDDQ_1V2 and ground.
LPDDR4#
The circuit design of LPDDR4 refers to Figures 3-12, 3-13, 3-14, 3-15, and 3-16. Figure 3-12 K230 LPDDR4 Circuit Figure 3-12 K230 LPDDR4 Circuit Figure 3-13 K230 LPDDR4 Power Circuit Figure 3-13 K230 LPDDR4 Power Circuit Figure 3-14 K230 LPDDR4 Reference Voltage Circuit Figure 3-14 K230 LPDDR4 Reference Voltage Circuit Figure 3-15 LPDDR4 Chip Circuit Figure 3-16 LPDDR4 Chip Power Circuit Figure 3-16 LPDDR4 Chip Power Circuit
When using LPDDR4, note:
  • The RESRT_N pin is directly connected to the corresponding pin of the chip.
  • When using LPDDR4 chips with K230, the VREF voltage is 0.6V, and it is recommended to use 1kΩ (1%) resistors for voltage division.
K230D DDR Module#
K230D has a built-in DDR Die, so only the reference voltage and calibration resistor need to be connected. Reference circuits are shown in Figures 3-17 and 3-18.
Figure 3-17 K230D DDR Peripheral Circuit Figure 3-17 K230D DDR Peripheral Circuit Figure 3-18 K230D DDR Reference Voltage Figure 3-18 K230D DDR Reference Voltage
When using the K230D DDR module, note:
  • The VREF voltage is 0.55V, it is recommended to use 100Ω (1%) resistors for voltage division.
  • The calibration resistor should be 240Ω (1%).
FLASH#
The K230 has an OSPI/QSPI controller that can be used to connect FLASH memory chips, with the following features:
  • OSPI supports 4/8-bit mode NOR FLASH.
  • OSPI supports NOR FLASH up to DDR200, SDR166.
  • QSPI supports 1/2/4-bit mode NAND & NOR FLASH.
  • QSPI supports NOR FLASH up to SDR100.
OSPI#
The OSPI reference schematic is shown in Figures 3-19 and 3-20. Figure 3-19 K230 OSPI Circuit Figure 3-19 K230 OSPI Circuit Figure 3-20 OSPI FLASH Circuit Figure 3-20 OSPI FLASH Circuit
Please place pull-up resistors according to the requirements of the FLASH chip.
QSPI NOR#
In the QSPI signals, the CS, CLK, D0, D1, D2, and D3 pins are multiplexed with the corresponding OSPI signal pins, as shown in Table 3-3.
QSPI Pin
OSPI Pin
QSPI_CS
OSPI_CS
QSPI_CLK
OSPI_CLK
QSPI_D0
OSPI_D0
QSPI_D1
OSPI_D1
QSPI_D2
OSPI_D2
QSPI_D3
OSPI_D3
Table 3-3 QSPI and OSPI Corresponding Pins
The reference circuit is shown in Figure 3-21. Figure 3-21 QSPI NOR FLASH Chip Circuit Figure 3-21 QSPI NOR FLASH Chip Circuit Please place pull-up resistors according to the requirements of the FLASH chip.
QSPI NAND#
The reference circuit for QSPI NAND is shown in Figure 3-22. Figure 3-22 QSPI NAND FLASH Chip Circuit Figure 3-22 QSPI NAND FLASH Chip Circuit Please place pull-up resistors according to the requirements of the FLASH chip.
MMC Circuit#
The K230 eMMC control circuit has two controllers, MMC0 and MMC1.
MMC0#
The MMC0 controller has the following features:
  • Supports SDIO3.0, operating in 4/1-bit mode, up to SDR104.
  • Supports eMMC5.0, operating in 8/4/1-bit mode, supports HS200.
  • Supports voltage switching required by SD cards, 3.3V and 1.8V.
MMC0 is generally used to control eMMC circuits. The recommended eMMC reference circuit is shown in Figures 3-23 and 3-24.
Figure 3-23 K230 eMMC Circuit Figure 3-23 K230 eMMC Circuit Figure 3-24 eMMC Chip Circuit Figure 3-24 eMMC Chip Circuit
Please connect the corresponding pins according to the eMMC manufacturer’s requirements. If there are no special requirements, connect the corresponding pins directly.
MMC1#
The MMC1 controller has the following features:
The MMC1 interface’s performance and pin count cannot meet the requirements for controlling eMMC circuits, so it can only be used to control SD/TF card circuits. The reference schematics are shown in Figures 3-25, 3-26, and 3-27.
Figure 3-25 K230 SD Card Interface Circuit Figure 3-25 K230 SD Card Interface Circuit Figure 3-26 SD Card Pull-up Circuit Figure 3-26 SD Card Pull-up Circuit Figure 3-27 SD Card Slot Circuit Figure 3-27 SD Card Slot Circuit
When designing the SD card circuit, note:
  • The decoupling capacitors for SD card pins should not be omitted and should be placed close to the card slot.
  • ESD devices should be placed near the SD card slot for each signal.
  • Pull-up resistors are required for each signal.
  • It is recommended to design according to the reference circuit.
USB Circuit#
The K230 chip has two built-in USB2.0 OTG controllers with the following features:
  • Supports USB2.0 protocol, backward compatible with USB 1.1 protocol.
  • Supports Host mode or Device mode, can be dynamically switched.
  • Host mode supports 480Mbps, 12Mbps, 1.5Mbps transfer rates.
  • Device mode supports 480Mbps, 12Mbps transfer modes.
The USB reference schematics are shown in Figures 3-28 and 3-29.
Figure 3-28 K230 USB Circuit Figure 3-28 K230 USB Circuit Figure 3-29 USB Interface Circuit Figure 3-29 USB Interface Circuit
Note:
  • ESD devices should be placed near the USB port for each signal.
  • The USB_VBUS power of K230 must be connected to a 5V power supply through a 30kΩ (1%) resistor and cannot be directly connected to the power supply.
  • To ensure signal quality, the USB_TXRTUNE pin of K230 must be connected to a 200Ω (1%) resistor to ground.
  • The USB_ID can be used for OTG device identification. When grounded, K230 acts as a HOST; when floating or pulled high, K230 acts as a SLAVE.
Audio Circuit#
I2S#
The K230 chip has an I2S controller with the following features:
  • Two input and output channels.
  • Supports PHILIP I2S standard.
  • Supports left/right, PCM formats.
  • Synchronous operation mode.
  • Selectable master or slave mode.
  • Adjustable interface voltage.
  • Sampling rates from 8kHz to 384kHz.
The I2S interface has three pins: I2S_CLK, I2S_WS, and I2S_SD. I2S_CLK is the serial clock signal, I2S_WS is the data frame control signal, and I2S_SD is the serial data signal. The I2S interface is typically used to connect to decoders and other audio peripherals. Figures 3-30 and 3-31 show the K230 I2S interface circuit and some peripheral circuits. Figure 3-30 K230 I2S Interface Circuit Figure 3-30 K230 I2S Interface Circuit Figure 3-31 K230 I2S Reference Peripheral Figure 3-31 K230 I2S Reference Peripheral
PDM#
The K230 supports 4 channels of PDM signal input. Sampling rates range from 8kHz to 384kHz. The PDM interface is typically used to connect to digital microphones and other audio devices with PDM interfaces. Figure 3-32 shows the K230 PDM peripheral circuit. Figure 3-32 K230 PDM Peripheral Circuit Figure 3-32 K230 PDM Peripheral Circuit
Analog Audio Interface#
The analog audio section of the K230 chip has the following features:
  • Supports 2 DAC channels and 2 ADC channels.
  • DAC supports differential and single-ended output, ADC supports differential and single-ended input.
  • Supports low-noise analog microphone bias output.
The reference circuit for analog audio is shown in Figures 3-33 and 3-34. Figure 3-33 K230 Analog Audio Interface Circuit Figure 3-33 K230 Analog Audio Interface Circuit Figure 3-34 Audio Interface Circuit Figure 3-34 Audio Interface Circuit
Note, to achieve better audio quality, consider the following measures:
  • Use both large and small capacitance low-ESR ceramic capacitors for power pins.
  • Place a large capacitance low-ESR capacitor on the MICBIAS pin.
  • Place the DC blocking capacitors for audio input close to the K230 chip.
  • Place filter circuits or DC blocking capacitors on the output pins.
Video Circuit#
MIPI DSI#
The MIPI DSI controller of the K230 has the following features:
  • Supports 1 signal output.
  • Supports 1/2/4-lane mode.
  • Maximum rate up to 1.5Gbps.
All MIPI DSI signals are directly connected. The reference hardware design is shown in Figures 3-35 and 3-36.
Figure 3-35 K230 MIPI DSI Interface Circuit Figure 3-35 K230 MIPI DSI Interface Circuit Figure 3-35 K230 MIPI DSI Interface Circuit Figure 3-36 Screen Interface Circuit Figure 3-36 Screen Interface Circuit
Note:
  • The MIPI_ATB pin must be left floating.
  • The MIPI_REXT pin must be connected to a 200Ω (1%) resistor to ground.
  • The connector circuit pins are only suitable for the JinZhaoHui screen; please design the circuit according to your own screen module.
Camera Circuit#
MIPI CSI#
The MIPI CSI controller of the K230 has the following features:
  • Supports up to 3 MIPI signal inputs, supports 1/2/4-lane mode.
  • Can be configured as 3 channels of 2-lane signal input or 1 channel of 4-lane and 1 channel of 2-lane signal input.
It is recommended to directly connect MIPI CSI signals. The reference hardware design is shown in Figures 3-37 and 3-38. Figure 3-37 K230 MIPI CSI Interface Circuit Figure 3-37 K230 MIPI CSI Interface Circuit Figure 3-38 Camera Connector Circuit Figure 3-38 Camera Connector Circuit
Note:
  • This connector circuit is for internal testing only; please design the circuit according to your needs for actual use.
Low-Speed Subsystem Circuit#
I2C Circuit#
The K230 chip supports 5 I2C interfaces with the following features:
  • Supports I2C bus master mode.
  • Supports 7/10-bit addresses.
  • Supports I2C rates up to 3.4Mbit/s.
When using I2C peripherals, pay attention to the corresponding power domain supply, which must be consistent. The SCL and SDA signals of the I2C need external pull-up resistors. Choose different resistor values based on bus load and bus rate.
  • For systems not exceeding 400kb/s, the recommended resistor value is 4.7kΩ.
  • For systems exceeding 400kb/s but less than 3.4Mb/s, the recommended pull-up resistor is 2.2kΩ.
UART Circuit#
The K230 supports 5 UART signals with the following features:
  • Supports 2-wire UART and 4-wire UART.
  • Supports RS485 interface.
  • Supports baud rates up to 3.125M.
  • Supports software and hardware flow control, compliant with the 16750 standard.
  • Supports IrDA 1.0 SIR reception.
When using UART peripherals, pay attention to the corresponding power domain supply, which must be consistent.
PWM Circuit#
The K230 supports 6 PWM signals with the following features:
  • Supports arbitrary duty cycle.
  • Supports programmable output waveform.
  • Supports generating periodic pulse signals and one-time pulse signals.
  • Can be used as a periodic accurate interrupt generator.
  • Supports output glitch elimination.
MCLK Circuit#
The K230 supports outputting 3 MCLK signals. This signal can be used as the driving clock for cameras.
MCLK Circuit#
Supports output clock frequencies as shown in Table 3-4:
792
132
66.67
46.59
36
28.57
23.76
18.56
594
118.8
66
45.69
34.94
28.29
23.53
18.18
400
113.14
66
44.44
34.43
28.29
22.85
17.39
396
100
60.92
44
33.33
27.31
22.22
16.67
297
99
59.4
42.43
33
27
22
16
264
99
57.14
41.68
33
26.67
21.21
15.38
200
88
56.57
40
31.68
26.4
21.05
14.81
198
84.86
54
39.6
31.26
25.83
20.48
14.29
198
80
52.8
39.6
30.77
25.55
20
13.79
158.4
79.2
50
37.71
30.46
25
19.8
13.33
148.5
74.25
49.5
37.13
29.7
24.75
19.16
12.9
133.33
72
49.5
36.36
29.33
24.75
19.05
12.5
Table 3-4 MCLK Output Clock Frequencies (in MHz)
ADC Circuit#
The K230 integrates an 11-bit (effective resolution) SAR ADC with a maximum sampling rate of no less than 1MHz. It has the following features:
  • Signal input range: 0-1.8V
  • Supports 6-channel input
  • Supports single sampling and continuous sampling
  • Internally integrated signal conditioning circuit with a cutoff frequency at half the bandwidth. The ADC can directly sample signals or design peripheral circuits as needed.
PMU Circuit#
The PMU module of the K230 is used to control and manage internal and external power supplies of the chip. It has a built-in RTC circuit and supports 6 input channels. Its functions are shown in the table below:
Interrupt Source
Edge Trigger
Level Trigger
Debounce
Edge Count Detection
Long/Short Press Detection
INT_0
Yes
Yes
Yes
Yes
INT_1
Yes
Yes
Yes
Yes
INT_2
Yes
Yes
INT_3
Yes
Yes
INT_4
Yes
INT_5
Yes
Supports two output channels OUT0 and OUT1, which can be used to enable power supplies. In a cold start state, the PMU only enables the long press interrupt of INT0 and the high-level input interrupt of INT4 as triggers for PMU module startup. OUT0 and OUT1 default to low level with an initial pull-down resistance of about 40Ω. Upon receiving either of these two interrupts, OUT0 is pulled high, and OUT1 is pulled high after approximately 50ms. OUT0 and OUT1 can be used to control the enable pins of external PMICs or for other purposes.
Power Design#
K230 Power Requirements#
Module
Power Pin
CORE
VDD0P8_CORE
Power for CPU0 and other units
CPU
VDD0P8_CPU
Power for CPU1
KPU
VDD0P8_KPU
Power for KPU
DDR Controller
VDD0P8_DDR_CORE
Digital CORE power for DDR, can be powered off
VDD1P1_DDR_IO
IO power for DDR
VAA_DDR
PLL power for DDR
USB
AVDD3P3_USB
3.3V power for USB PHY, can be left unpowered if not in use
AVDD1P8_USB
1.8V power for USB PHY, can be left unpowered if not in use
PLL
AVDD0P8_PLL
Power for PLL
MIPI
AVDD0P8_MIPI
0.8V power for MIPI, can be left unpowered if not in use
AVDD1P8_MIPI
1.8V power for MIPI, can be left unpowered if not in use
VDD1P8
VDD1P8
1.8V module power
ADC
AVDD1P8_ADC
Power for ADC, can be left unpowered if not in use
CODEC
AVDD1P8_CODEC
Power for CODEC, can be left unpowered if not in use
PMU
AVDD1P8_RTC
RTC power for PMU, can be left unpowered if not in use
AVDD1P8_LDO
LDO power for PMU, can be left unpowered if not in use
MMC
VDD3P3_SD
3.3V output buffer and pre-buffer IO power, can be left unpowered if not in use
IO
VDDIO3P3_0
IO power for IO_2-IO_13, voltage selectable between 1.8V or 3.3V, can be left unpowered if not in use
VDDIO3P3_1
IO power for IO_14-IO_25, voltage selectable between 1.8V or 3.3V, can be left unpowered if not in use
VDDIO3P3_2
IO power for IO_26-IO_37, voltage selectable between 1.8V or 3.3V, can be left unpowered if not in use
VDDIO3P3_3
IO power for IO_38-IO_49, voltage selectable between 1.8V or 3.3V, can be left unpowered if not in use
VDDIO3P3_4
IO power for IO_50-IO_61, voltage selectable between 1.8V or 3.3V, can be left unpowered if not in use
VDDIO3P3_5
IO power for IO_62-IO_63, voltage selectable between 1.8V or 3.3V, can be left unpowered if not in use
K230D DDR Part
VDD1P8_DDR_VDD1
DDR power in K230D, not present in K230
VDD1P1_DDR_VDD2
DDR power in K230D, not present in K230, cannot be powered off
VDD1P1_DDR_VDDQ
DDR power in K230D, not present in K230, can be powered off
Table 3-6 K230 Power Requirements
Power-Up Sequence#
VDD0P8_CORE must be powered up earlier than VDD1P8 and VDDIO3P3_0 to VDDIO3P3_5 IO interfaces. AVDD0P8_MIPI must be powered up earlier than AVDD1P8_MIPI, and AVDD1P8_RTC must not be powered up later than AVDD1P8_LDO. There are no other specific power-up sequence requirements.
Power Design Recommendations#
PMU#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
PMU
AVDD1P8_RTC
1.674
1.8
1.98
Recommended to use LDO
AVDD1P8_LDO
1.674
1.8
1.98
Core Modules#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
CORE
VDD0P8_CORE
0.72
0.8
0.88
2250
Recommended to use a DC/DC with at least 3A capacity and low ripple noise
CPU
VDD0P8_CPU
0.72
0.8
0.88
1000
Recommended to use a DC/DC with at least 2A capacity and low ripple noise
KPU
VDD0P8_KPU
0.72
0.8
0.88
3000
Recommended to use a DC/DC with at least 4A capacity and low ripple noise
DDR#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
DDR
VDD0P8_DDR_CORE
0.744
0.8
0.88
400
Power ripple requirement within 4%, recommended to use a low noise LDO capable of high current output
VDD1P1_DDR_IO (LPDDR4)
1.06
1.1
1.17
800
LP4 ripple requirement within 5%, recommended to use a low noise LDO capable of high current output
VDD1P1_DDR_IO (LPDDR3)
1.14
1.2
1.3
800
LP3 ripple requirement within 10%, recommended to use a low noise LDO capable of high current output
VAA_DDR
1.674
1.8
1.98
Ripple requirement within 5% of typical voltage
K230D DDR Die#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
K230D DDR die
VDD1P8_DDR_VDD1
1.7
1.8
1.95
75
Ripple requirement within 5% of typical voltage, same power network as DDR controller
VDD1P1_DDR_VDD2
1.06
1.1
1.17
450
Same power network as VDD1P1_DDR_IO
VDD1P1_DDR_VDDQ
1.06
1.1
1.17
300
Recommended to use a low noise LDO capable of high current output
I/O#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
IO
VDDIO3P3_0
1.62/2.97
1.8/3.3
1.98/3.63
50
IO units have 5 voltage groups, each configurable to 1.8V or 3.3V. Each group controls the output and input voltage of the corresponding I/O ports and their multiplexed functions. The IO voltage should match the connected peripherals; if not, level shifting is required.
VDDIO3P3_1
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_2
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_3
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_4
1.62/2.97
1.8/3.3
1.98/3.63
50
VDDIO3P3_5
1.62/2.97
1.8/3.3
1.98/3.63
50
USB#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
USB
AVDD3P3_USB
3.07
3.3
3.63
50
AVDD1P8_USB
1.674
1.8
1.98
60
PLL#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
PLL
AVDD0P8_PLL
0.72
0.8
0.88
120
Recommended to use high-precision LDO
MIPI#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
MIPI
AVDD0P8_MIPI
0.744
0.8
0.88
100
AVDD1P8_MIPI
1.674
1.8
1.98
30
ADC#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
ADC
AVDD1P8_ADC
1.62
1.8
1.98
CODEC#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
CODEC
AVDD1P8_CODEC
1.62
1.8
1.98
100
Others#
Module Name
Pin
Min Voltage (V)
Typical Voltage (V)
Max Voltage (V)
Current (mA)
Notes
Others
VDD3P3_SD
2.7
3.3
3.63
50
VDD1P8
1.62
1.8
1.98
500
Note:
  • For the DDR chips used by the K230, the power supply must be on the same power network as the main chip.
  • Modules with the same voltage requirements can use the same power source if the voltage accuracy and current requirements are met. For applications with low precision requirements, analog modules like ADCs can also be connected to the power source used by digital modules after isolation.
  • The K230 integrates a DDR_Vref power supply for the chip’s DDR controller. For external chips, the reference design for the LPDDR3 VREF power supply is shown in Figure 3-39.
Figure 3-39 LPDDR3 Chip Vref Circuit Figure 3-39 LPDDR3 Chip Vref Circuit
It is recommended to use resistors with an accuracy of ±1%. The reference design for the external LPDDR4 VREF power supply is shown in Figure 3-40.
Figure 3-40 LPDDR4 Chip Vref Circuit Figure 3-40 LPDDR4 Chip Vref Circuit
The reference design for the K230D DDR module VREF power supply is shown in Figure 3-41.
Figure 3-41 K230D Version DDR Vref Circuit Figure 3-41 K230D Version DDR Vref Circuit
Dynamic Voltage Scaling#
The power supplies for the CPU and KPU in the K230 support dynamic voltage scaling to ensure high performance and low power consumption. The adjustable voltage nodes for the CPU are shown in Table 3-7.
Voltage Node
Voltage (V)
V_typical
0.8
V_high
0.9
V_ultrahigh
1.0
V_low
0.7
V_retention
0.48
Table 3-7 CPU Adjustable Voltage Nodes
Among them, V_retention is the voltage node for the DDR retention function. The adjustable voltage nodes for the KPU are shown in Table 3-8.
Voltage Node
Voltage (V)
V_typical
0.8
V_high
0.9
V_ultrahigh
1.0
V_low
0.7
Table 3-8 KPU Adjustable Voltage Nodes
PCB Design Recommendations#
High-Speed PCB Design Recommendations#
DDR Design#
Impedance Control: Single-ended DDR 50Ω, Differential (clock clk, data dqs) 100Ω; Crosstalk Requirements: Follow the 3W rule; Length Matching Requirements: Ensure the same number of vias for the same type of signal lines, and avoid more than 2 layer changes for vias; The internal DDR routing length of the chip is shown in Table 4-1. When routing on the PCB, ensure that the total length of internal and external routing meets the length matching requirements. It is strongly recommended to refer to the design of the K230 EVB, including routing and capacitor selection and placement.
Pin Length Table:
Pin Number
Pin Name
Length (μm)
Length (mil)
N17
DDR_CKE0_CKEA0
3725.8
146.8
P18
DDR_CKE1_CKEA1
4338.56
170.94
T20
DDR_CS0_CSA0
5839.03
230.06
T19
DDR_CS1_CSA1
5528.07
217.81
R19
DDR_CKP_CKAP
6252.24
246.34
R20
DDR_CKN_CKAN
6050.13
238.38
P19
DDR_CA9_CAA5
5809.3
228.89
M18
DDR_CA8_CAA4
4033.87
158.93
N20
DDR_CA7_CAA3
4888.23
192.6
N19
DDR_CA6_CAA2
4415.08
173.95
L16
DDR_CA5_CAA1
2171.4
85.55
M19
DDR_CA4_CAA0
4599.65
181.23
L17
DDR_CA3_NC
2258.98
89
M20
DDR_CA2_NC
4190.42
165.1
L20
DDR_CA1_NC
5108.55
201.28
K20
DDR_CA0_NC
4832.33
190.39
L18
DDR_ODT_NC
3849.11
151.65
J18
DDR_NC_CKEB0
2599.43
102.42
J17
DDR_NC_CKEB1
2792.84
110.04
J19
DDR_NC_CSB1
4018.49
158.33
J20
DDR_NC_CSB0
4941.35
194.69
G20
DDR_NC_CLKBP
5403.63
212.9
F20
DDR_NC_CLKBN
5418.33
213.48
E20
DDR_NC_CAB0
5468.25
215.45
G19
DDR_NC_CAB1
4067.91
160.28
G18
DDR_NC_CAB2
3807.29
150.01
H17
DDR_NC_CAB3
3113.45
122.67
F17
DDR_NC_CAB4
2757.73
108.65
F19
DDR_NC_CAB5
4558.27
179.6
U17
DDR_DQ24_DQA7
4829.45
190.28
Y18
DDR_DQ25_DQA6
6467.43
254.82
V18
DDR_DQ26_DQA5
5047.5
198.87
W18
DDR_DQ27_DQA4
5267.44
207.54
Y16
DDR_DQ28_DQA3
5846.86
230.37
V16
DDR_DQ29_DQA2
4311.64
169.88
T16
DDR_DQ30_DQA1
3576.39
140.91
U16
DDR_DQ31_DQA0
3132.83
123.43
V17
DDR_DM3_DMIA0
4110.44
161.95
W17
DDR_DQS3P_DQSA0P
6342.48
249.89
Y17
DDR_DQS3N_DQSA0N
6135.17
241.73
R17
DDR_DQ8_DQA8
4018.24
158.32
T18
DDR_DQ9_DQA9
5760.1
226.95
R18
DDR_DQ10_DQA10
4540.62
178.9
U20
DDR_DQ11_DQA11
5625.11
221.63
W19
DDR_DQ12_DQA12
6897.92
271.78
U18
DDR_DQ13_DQA13
4908.14
193.38
P16
DDR_DQ14_DQA14
2036.92
80.25
T17
DDR_DQ15_DQA15
4492.07
176.99
P17
DDR_DM1_DMIA1
4129.14
162.69
V20
DDR_DQS1P_DQSA1P
7005.11
276
V19
DDR_DQS1N_DQSA1N
6768.98
266.7
C17
DDR_DQ0_DQB15
4038.16
159.1
D16
DDR_DQ1_DQB14
3663.33
144.34
D17
DDR_DQ2_DQB13
4242.29
167.15
C18
DDR_DQ3_DQB12
5598.19
220.57
E18
DDR_DQ4_DQB11
3830.51
150.92
E17
DDR_DQ5_DQB10
4273.06
168.36
B19
DDR_DQ6_DQB9
6879.01
271.03
C19
DDR_DQ7_DQB8
6640.84
261.65
D18
DDR_DM0_DMIB0
5275.38
207.85
B18
DDR_DQS0P_DQSB1P
6516.79
256.76
A18
DDR_DQS0N_DQSB1N
6628.66
261.17
C14
DDR_DQ16_DQB0
2966.98
116.9
D14
DDR_DQ17_DQB1
2708.03
106.7
B14
DDR_DQ18_DQB2
4486.79
176.78
A14
DDR_DQ19_DQB3
5608.52
220.98
A17
DDR_DQ20_DQB4
5037.71
198.49
B16
DDR_DQ21_DQB5
4419.48
174.13
C16
DDR_DQ22_DQB6
4381.95
172.65
B17
DDR_DQ23_DQB7
5515.88
217.33
C15
DDR_DM2_DMIB1
4509.87
177.69
B15
DDR_DQS2P_DQSB1P
4623.9
182.18
A15
DDR_DQS2N_DQSB1N
4942.59
194.74
Table 4-1 Internal DDR Trace Lengths
Within LPDDR3 byte groups, DQ can be swapped, but DQ swapping is not supported between bytes or between byte groups. For LPDDR4, DQ can be swapped within byte groups, DQ swapping is not supported between bytes, but byte swapping within channel groups is supported.
It is recommended to follow the EVB swap order for routing. If you modify the swap during your own design, you need to adjust the DDR training code. Please contact FAE in advance.
Figure 4-1 DDR Trace Spacing Design Rules Figure 4-1 DDR Trace Spacing Design Rules
Figures 4-2 and 4-3 show the length matching design requirements for LPDDR3 and LPDDR4 respectively. To ensure stable operation at higher speeds, it is recommended to design according to the requirements listed under “Recommended Routed Skew Limits”.
LPDDR3 Section:
Figure 4-2 LPDDR3 Length Matching Design Rules Figure 4-2 LPDDR3 Length Matching Design Rules
LPDDR4 Section:
Figure 4-3 LPDDR4 Length Matching Design Rules Figure 4-3 LPDDR4 Length Matching Design Rules
USB 2.0 Design#
  • Impedance Control: Differential 90Ω.
  • Skew within the differential pair should not exceed 4ps, with a maximum of 6 vias allowed.
MIPI Design#
  • Impedance Control: MIPI_DSI differential 100Ω, MIPI_CSI differential 100Ω.
  • Length matching within the pair should be controlled within 0.3mm.
