K230 SDK Development Guide#
- K230 RVV Performance Optimization Description
- K230 Memory Optimization Guide
- K230 Memory Analysis Guide
- K230 Boot Optimization Guide
- Introduction to K230 Big-Little Core Communication with Sharefs
- K230 OpenBLAS Development Guide
- K230 OpenCV Development Guide
- K230 Camera Sensor Adaptation Guide
- Disclaimer
- Trademark Statement
- Table of Contents
- Preface
- 1. Overview
- 2. Camera Sensor Framework
- 3. Sensor Adaptation Preparations
- 4. Sensor Adaptation Example
- K230 Power Consumption Management Adaptation Guide
- Disclaimer
- Table of Contents
- Preface
- 1. Overview
- 2. Large Core Power Control
- 2.1 Control Framework Introduction
- 2.2 Usage
- 2.3 API Reference
- 2.3.1 kd_mpi_pm_set_reg
- 2.3.2 kd_mpi_pm_get_reg
- 2.3.3 kd_mpi_pm_get_profiles
- 2.3.4 kd_mpi_pm_get_stat
- 2.3.5 kd_mpi_pm_set_governor
- 2.3.6 kd_mpi_pm_get_governor
- 2.3.7 kd_mpi_pm_set_profile
- 2.3.8 kd_mpi_pm_get_profile
- 2.3.9 kd_mpi_pm_set_profile_lock
- 2.3.10 kd_mpi_pm_set_profile_unlock
- 2.3.11 kd_mpi_pm_set_thermal_protect
- 2.3.12 kd_mpi_pm_get_thermal_protect
- 2.3.13 kd_mpi_pm_set_thermal_shutdown
- 2.3.14 kd_mpi_pm_get_thermal_shutdown
- 2.3.15 kd_mpi_pm_set_clock
- 2.3.16 kd_mpi_pm_set_power
- 2.3.17 kd_mpi_pm_runtime_runstage
- 2.4 Data Structures
- 2.5 Error Codes
- 3. Low-Power Core Control
- K230 VICAP SENSOR Parameter Partition Reference
- K230 LCD Adaptation Guide
- K230 PMU User Guide
- K230 SDK IoT WiFi AiW4211LV10 User Guide
- Disclaimer
- Trademark Notice
- Directory
- Preface
- 1. Function Introduction
- 2. Module Dependencies
- 3. Module Configuration
- 4. Firmware Compilation
- 5. Module Starts
- 6. API Reference
- 7. WiFi Function Limitation
- K230 SDK IoT WiFi AiW4211LV10 Driver Development Guide
- K230 nncase Development Guide
- Disclaimer
- Table of Contents
- Preface
- 1. Overview
- 2. Model Compilation APIs (Python)
- 3. Simulator APIs (Python)
- 4. KPU Runtime APIs (C++)
- 5. AI2D Runtime APIs (C++)
- 5.1 Introduction
- 5.2 APIs
- 5.2.1 ai2d_format
- 5.2.2 ai2d_interp_method
- 5.2.3 ai2d_interp_mode
- 5.2.4 ai2d_pad_mode
- 5.2.5 ai2d_datatype_t
- 5.2.6 ai2d_crop_param_t
- 5.2.7 ai2d_shift_param_t
- 5.2.8 ai2d_pad_param_t
- 5.2.9 ai2d_resize_param_t
- 5.2.10 ai2d_affine_param_t
- 5.2.11 ai2d_builder::ai2d_builder
- 5.2.12 ai2d_builder::build_schedule
- 5.2.13 ai2d_builder::invoke
- 5.3 Example
- 5.4 Notes
- K230 SDK nncase Version Correspondence
- K230 Debian Ubuntu Instructions
- K230 SDK Burntool User Guide
- K230 SDK Dewarp User Guide
- K230 ISP Image Tuning Guide
- Disclaimer
- Table of Contents
- Preface
- 1. Overview of K230 ISP Image Tuning
- 2. Calibration
- 3. Module Introduction
- K230 ISP Initialization Configuration Guide
- Disclaimer
- Table of Contents
- Preface
- 1. Overview of K230 ISP Initialization Configuration
- 2. xml File
- 3. manual.json File
- 4. auto.json File
- K230 ISP Tuning Tool User Guide
- Disclaimer
- Table of Contents
- Preface
- 1. Module Software Architecture
- 2. Tuning Tool Connection and Activation
- 3. Tuning Tool Interface Introduction
- 3.1 Connect to Board-side Tuning Server
- 3.2 Create/Select Project
- 3.3 Online Debugging Interface and Function Description
- 3.3.1 Bypass Settings
- 3.3.2 Auto Focus Control (Focus Control)
- 3.3.3 Auto Exposure Control (Exposure Control)
- 3.3.4 Auto White Balance (White Balance)
- 3.3.5 Exposure Statistics
- 3.3.6 Auto Focus Measurement
- 3.3.7 High Dynamic Range
- 3.3.8 Compand
- 3.3.9 Black Level Subtraction
- 3.3.10 RGB Infrared Radiation
- 3.3.11 Lens Shading Correction
- 3.3.12 Digital Gain
- 3.3.13 Wide Dynamic Range
- 3.3.14 Green Equilibrate
- 3.3.15 Defect Pixel Cluster Correction
- 3.3.16 Denoising Prefilter
- 3.3.17 3D Noise Reduction
- 3.3.18 Demosaic
- 3.3.19 Color Correction Matrix
- 3.3.20 Gamma Correction
- 3.3.21 Edge Enhance
- 3.3.22 Color Processing
- 3.4 Capture Image
- 3.4.1 Set Image Format and Size
- 3.5 Import and Export Parameters
