K230 Video Output API Reference
Contents
K230 Video Output API Reference#
The VO (Video Output) module actively reads video and graphic data from the corresponding location in the memory and outputs the video and graphics through the corresponding display device. The chip supports display/write-back devices, video layers, and graphic layers.
Layer support:
LAYER0
LAYER1
LAYER2
Input Format
YUV420 NV12
YUV420 NV12
YUV420 NV12 YUV422 NV16 ?
Max Resolution
1920x1080
1920x1080
1920x1080
Overlay Display
Supports configurable overlay order
Rotation
Scaler
Mirror
Gray
Independent Switch
OSD Layer support:
OSD0
OSD1
OSD2
OSD3
Input Format
RGB888 RGB565 ARGB8888 Monochrome-8-bit RGB4444 RGB1555
Max Resolution
1920x1080
1920x1080
1920x1080
1920x1080
Overlay Display
ARGB 265 Level ALPHA
Independent Switch
Hardware Description#
This hardware description is based on the evblp3.
Mipi Interface#
The hardware pins on the evblp3 are as follows:
Image containing diagram
  • Screen touch IIC uses iic4 (scl: gpio7, sda gpio8)
  • Screen touch rst: gpio29, int: gpio30
  • Screen rst: gpio9, backlight: gpio31
  • Mipi pins correspond one-to-one with the screen pins
Physical Diagram#
Image containing game console, electronics, circuit
  • In the figure, 1 is the mipi interface, using a soft ribbon cable
  • In the figure, 2 is the mipi signal test point, containing four data lines and one clk line
Software Description#
The video output software configuration is divided into three parts: phy configuration, dsi configuration, and VO configuration.
PHY Configuration Process#
The phy frequency requires three parameters to be configured: calculate PLL, configure voc, and configure freq. Based on these three parameters, the txphy frequency can be determined. Each parameter calculation is as follows.
Calculate the PHY PLL#
The data rate is given by twice the PLL output clock phase frequency: Data rate (Gbps) = PLL Fout (GHz) * 2. The output frequency is a function of the input reference frequency and the multiplication/division ratio. The calculation of the phy PLL is divided into 4 ranges, each corresponding to a different frequency. It can be determined as follows:
M
m+2
N
n+1
Fclkin
24M
For:
Text, letter
However, the following restrictions must be followed:
Image containing text
For:
Text, letter
For:
Text, letter
Text
For:
Text
Each of the above corresponds to a pll level, with different levels corresponding to different calculation formulas and restrictions. An example calculation is as follows:
The mipi rate is 445.5M, so the pll rate is 222.75M. The second formula should be chosen, and the calculation is as follows:
222750000 = 1M / 2N = (m+2) / 2(n+1) * 24000000. The formula is rearranged as follows:
222.75n + 198.75 = 12m. The calculation using Excel is as follows:
Table
The resulting m = 295, n = 15.
The configuration of m and n in the pll must be integer values. If none of the values are integers, m and n need to be adjusted by adding or subtracting 1, then recalculating to find the closest frequency, and verifying if it’s usable. If not, repeat the above steps.
Configure the PHY VOC#
The configuration of the phy voc can be determined by referring to the table:
Table
Table
The mipi rate is 445.5M, so the pll rate is 222.75M, voc = 010111 = 0x17.
Configure the Frequency#
The configuration of the phy frequency can be determined by referring to the table:
Table
Table
Table
The mipi rate is 445.5M, so the pll rate is 222.75M. The frequency is chosen as 0100101. When configuring this, the highest bit bit[7] = 1, so freq = 10100101= 0xa5.
DSI Configuration#
DSI (Display Serial Interface) is part of a set of communication protocols defined by the MIPI alliance, mainly implementing all the protocol functions defined in the MIPI DSI specification, including a bidirectional PHY with two and four channels.
DSI mainly configures the timing used for screen display and the functionality for sending commands.
Configuring Display Timing#
Each manufacturer’s screen has a set of timings used for screen control, mainly including frame control timing and line control timing, as shown in the following figure:
Diagram
Diagram
The timing used in DSI is consistent with the screen’s timing configuration.
Sending DSI Commands#
DSI needs to enter lp mode first, and then commands can be sent. The required APIs are as follows:
The sent data is in 8-bit format, and it will automatically choose to send long or short packets based on the quantity.
DSI Self-Test Mode#
The DSI self-test mode generates color bar data according to the configured DSI timing and sends it out, thus not relying on the VO to read data from DDR. The test mode display is as follows:
Pattern
The DSI and VO use a 24-bit interface, so the configured color bar appears as shown above. The usage method is to enable the color bar after configuring the DSI. The API is as follows:
VO Configuration#
The VO (video output) module actively reads video and graphic data from the corresponding location in the memory and outputs the video and graphics through the corresponding display device. The VO part includes two configurations: timing configuration and video layer configuration.
VO Timing Configuration#
The VO timing configuration uses the same parameters as the DSI timing configuration, as described in the DSI timing introduction.
VO Layer Configuration#
The VO layer currently supports 3 layers and 4 OSD layers. The layer can only display YUV image formats (the functions supported by layer0 and layer1 are listed in the Overview table).
VO Write-Back Function Configuration#
The VO also supports a write-back function, which can verify whether the VO configuration is correct. After the VO configuration is completed, the data will be written back to the DDR, making it easy to verify whether there is any anomaly in the VO configuration.
VO Module Debugging Methods#
Screen Testing Methods#
  • Configure the screen to enter self-test mode through LP commands and check if the generated image is normal.
  • Read the screen registers through LP commands to see if there is a response.
DSI Testing Methods#
  • After configuring the DSI, let the screen enter self-test mode, measure the signals to see if they are normal, and check if the screen generates a color bar image.
  • Check the phy error status register to see if there is an error status, which can be viewed through proc.
VO Testing Methods#
  • After the VO configuration is completed, enable the write-back function and check if it meets the configuration requirements.
  • Read the DSI error status register to check if there is any underflow or overflow in the data transmission between VO and DSI. If so, adjust the timing appropriately and try again.
API Reference#
TXPHY#
kd_mpi_set_mipi_phy_attr#
Description:
Sets the frequency of the PHY.
Syntax:
Parameters:
Parameter
Input/Output
attr
Description of the PHY frequency structure
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
  • Header files: mpi_vo_api.h, k_vo_comm.h
  • Library file: libvo.a
Notes:
Related Topics:
DSI#
kd_mpi_dsi_set_attr#
Description:
Configures DSI attribute parameters.
Syntax:
k_s32 kd_mpi_dsi_set_attr(k_display_mode *attr)
Parameters:
Parameter
Input/Output
attr
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dsi_enable#
Description:
Enables DSI.
Syntax:
k_s32 kd_mpi_dsi_enable(void)
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dsi_send_cmd#
Description:
Sends a command via DSI.
Syntax:
Parameters:
Parameter
Input/Output
Data to be sent
Input
cmd_len
Length of the data
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dsi_read_pkg#
Description:
Reads a package via DSI.
Syntax:
Parameters:
Parameter
Input/Output
rx_buf
Buffer to receive data
Input
cmd_len
Length of the data
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dsi_set_test_pattern#
Description:
Configures DSI to enter test mode.
Syntax:
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_dsi_set_lp_mode_send_cmd#
Description:
Configures DSI to enter LP mode and send commands.
Syntax:
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
VO#
kd_mpi_vo_init#
Description:
Initializes VO with default parameters.
Syntax:
k_s32 kd_mpi_vo_init(void)
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_set_dev_param#
Description:
Sets device parameters for VO.
Syntax:
Parameters:
Parameter
Input/Output
attr
Pointer to the public attribute structure of the video output device.
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_enable_video_layer#
Description:
Configures layer attribute parameters.
Syntax:
Parameters:
Parameter
Input/Output
layer
Video output layer number, range [0 – K_MAX_VO_LAYER_NUM]
Input
attr
Pointer to the video layer attribute structure
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_disable_video_layer#
Description:
Disables the video layer.
Syntax:
Parameters:
Parameter
Input/Output
layer
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
  • Header files:
  • Library file:
Notes:
Related Topics:
kd_mpi_vo_enable#
Description:
Enables VO.
Syntax:
k_u8 kd_mpi_vo_enable(void)
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
  • Header files:
  • Library file:
Notes:
Related Topics:
kd_mpi_vo_chn_insert_frame#
Description:
Inserts a frame into the VO channel.
Syntax:
Parameters:
Parameter
Input/Output
chn_num
Channel number
Input
vf_info
Pointer to the video frame structure
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
  • Header files: mpi_vo_api.h, k_video_comm.h
Notes:
Related Topics:
kd_mpi_vo_chn_dump_frame#
Description:
Captures a frame from the VO channel.
Syntax:
k_s32 kd_mpi_vo_chn_dump_frame(k_u32 chn_num, k_video_frame_info *vf_info, k_u32 timeout_ms)
Parameters:
Parameter
Input/Output
chn_num
Channel ID
Input
vf_info
Input
timeout_ms
Timeout duration
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_chn_dump_release#
Description:
Releases the captured frame.
Syntax:
k_s32 kd_mpi_vo_chn_dump_release(k_u32 chn_num, const k_video_frame_info *vf_info)
Parameters:
Parameter
Input/Output
chn_num
Channel ID
Input
vf_info
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_osd_enable#
Description:
Enables the OSD layer.
Syntax:
Parameters:
Parameter
Input/Output
layer
Video output layer number, range [0 – K_MAX_VO_OSD_NUM]
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_osd_disable#
Description:
Disables the OSD layer.
Syntax:
Parameters:
Parameter
Input/Output
layer
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_set_video_osd_attr#
Description:
Sets the attributes of the OSD layer.
Syntax:
Parameters:
Parameter
Input/Output
layer
Input
attr
OSD layer attribute parameters
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_set_wbc_attr#
Description:
Sets the writeback attributes.
Syntax:
Parameters:
Parameter
Input/Output
attr
Writeback attribute parameters
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_enable_wbc#
Description:
Enables writeback.
Syntax:
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_disable_wbc#
Description:
Disables writeback.
Syntax:
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_display_reset#
Description:
Resets the video output subsystem.
Syntax:
k_s32 kd_display_reset(void)
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_display_set_backlight#
Description:
Resets the screen and turns on the backlight.
Syntax:
Parameters:
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_set_user_sync_info#
Description:
Sets user interface timing information for configuring clock source, clock size, and clock division ratio.
Syntax:
Parameters:
Parameter
Input/Output
sync_info
User sync information
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vo_draw_frame#
Description:
Draws a frame.
Syntax:
Parameters:
Parameter
Input/Output
frame
Frame attribute parameters
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_get_connector_info#
Description:
Retrieves the connector data structure based on the connection type.
Syntax:
Parameters:
Parameter
Input/Output
connector_type
Type of the connector
Input
connector_info
Connector data structure
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
  • Header files: mpi_vo_api.h, k_vo_comm.h, k_connector_comm.h
  • Library file: libvo.a, libconnector.a
Notes:
Related Topics:
kd_mpi_connector_open#
Description:
Opens the connector device node based on the connector name.
Syntax:
Parameters:
Parameter
Input/Output
connector_name
Device node of the connector
Input
Return Values:
fd
Success, returns the file descriptor ID
< 0
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_connector_power_set#
Description:
Turns the power of the connector on or off.
Syntax:
Parameters:
Parameter
Input/Output
fd
File descriptor of the connector
Input
on
Power state of the connector
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_connector_init#
Description:
Initializes the VO connector.
Syntax:
Parameters:
Parameter
Input/Output
fd
Input
info
Initialization parameters of the connector
Input
Return Values:
Success.
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_connector_get_negotiated_data#
Description:
Automatically negotiates the resolution between the display driver and the monitor. The negotiated data is saved in the negotiated_data variable.
Syntax:
k_s32 kd_mpi_connector_get_negotiated_data(k_s32 fd, k_connector_negotiated_data *negotiated_data)
Parameters:
Parameter
Input/Output
fd
File descriptor
Input
negotiated_data
Data negotiated between the display driver and HDMI monitor
Input
Return Values:
>= 1
Success, number of resolutions supported by the display driver after negotiation
-1
Chip Differences:
Requirements:
Notes:
kd_mpi_connector_get_negotiated_data() only negotiates with the monitor. It does not set the best resolution to the VO, DSI, or HDMI modules.
Related Topics:
kd_mpi_connector_adapt_resolution#
Description:
Automatically negotiates the resolution between the display driver and the monitor. The negotiated data is saved in the negotiated_data variable, and the best resolution is set to the VO, DSI, and HDMI modules.
Syntax:
Parameters:
Parameter
Input/Output
Device node of the connector, HDMI interface is usually set to LT9611_MIPI_ADAPT_RESOLUTION
Input
negotiated_data
Input
Return Values:
Success.
-1
Chip Differences:
Requirements:
Notes:
  1. kd_mpi_connector_adapt_resolution() internally calls kd_mpi_connector_get_negotiated_data() to negotiate with the monitor.
  2. After the application calls kd_mpi_connector_adapt_resolution() to complete the adaptive setting, it can still call kd_mpi_get_connector_info(), kd_mpi_connector_open(), kd_mpi_connector_power_set(), and kd_mpi_connector_init() to reset the output resolution.
Related Topics:
kd_mpi_connector_set_mirror#
Description:
Sets the screen mirror function.
Syntax:
Parameters:
Parameter
Input/Output
fd
File descriptor
Input
mirror
Screen mirror function
Input
Return Values:
Success.
-1
Chip Differences:
Requirements:
Notes:
Related Topics:
k_vo_intf_sync#
Description:
Defines the resolution and frame rate in video.
Definition:
    K_VO_OUT_1080P30,
    K_VO_OUT_1080P60,
} k_vo_intf_sync;
Members:
Member Name
K_VO_OUT_1080P30
1080 indicates 1920x1080 pixels. 30 indicates 30fps
K_VO_OUT_1080P60
1080 indicates 1920x1080 pixels. 60 indicates 60fps
K_VO_OUT_1080x1920P30
1080x1920 indicates 1080x1920 pixels. 30 indicates 30fps
K_VO_OUT_1080x1920P60
1080x1920 indicates 1080x1920 pixels. 60 indicates 60fps
Notes:
k_vo_intf_type#
Description:
Definition:
    K_VO_INTF_MIPI = 0,
} k_vo_intf_type;
Members:
Member Name
K_VO_INTF_MIPI
MIPI interface
Notes:
k_pixel_format#
Description:
Data formats supported by the display layer. The following structure lists only the data formats supported by the display, not all data formats.
Definition:
    PIXEL_FORMAT_YVU_PLANAR_420,
    PIXEL_FORMAT_YVU_PLANAR_422,
    PIXEL_FORMAT_RGB_565,
    PIXEL_FORMAT_RGB_888,
    PIXEL_FORMAT_ARGB_8888,
    PIXEL_FORMAT_ARGB_4444,
    PIXEL_FORMAT_ARGB_1555,
} k_pixel_format;
Members:
Member Name
YUV420 NV12
YUV422 NV16
RGB565
RGB888
PIXEL_FORMAT_RGB_MONOCHROME_8BPP
8-bit RGB
ARGB8888
ARGB4444
ARGB1555
Notes:
k_vo_osd#
Description:
Number of OSDs and the ID of each OSD.
Definition:
    K_VO_OSD0,
    K_VO_OSD1,
    K_VO_OSD2,
    K_VO_OSD3,
    K_MAX_VO_OSD_NUM,
} k_vo_osd;
Members:
Member Name
K_VO_OSD0
OSD layer 0
K_VO_OSD1
OSD layer 1
K_VO_OSD2
OSD layer 2
K_VO_OSD3
OSD layer 3
K_MAX_VO_OSD_NUM
Maximum number of OSD layers
Notes:
k_vo_layer#
Description:
Number of layers and the ID of each layer.
Definition:
    K_VO_LAYER0 = 0,
    K_VO_LAYER1,
    K_VO_LAYER2,
    K_MAX_VO_LAYER_NUM,
} k_vo_layer;
Members:
Member Name
K_VO_LAYER0
Layer 0
K_VO_LAYER1
Layer 1
K_VO_LAYER2
Layer 2
K_MAX_VO_LAYER_NUM
Maximum number of layers
Notes:
k_vo_rotation#
Description:
Supported layer rotation functions.
Definition:
    K_ROTATION_0 = (0x01L << 0),
    K_ROTATION_90 = (0x01L << 1),
} k_vo_rotation;
Notes:
k_vo_mirror_mode#
Description:
Supported layer mirror functions.
Definition:
} k_vo_mirror_mode;
Members:
Member Name
K_VO_MIRROR_NONE
No mirror for the layer
K_VO_MIRROR_HOR
Horizontal mirror
K_VO_MIRROR_VER
Vertical mirror
K_VO_MIRROR_BOTH
Both horizontal and vertical mirror
Notes:
k_vo_user_sync_info#
Description:
User-defined clock division.
Definition:
    k_u32 ext_div;
    k_u32 dev_div;
    k_u32 clk_en;
} k_vo_user_sync_info;
Members:
Member Name
ext_div
External clock division
dev_div
Clock division
clk_en
Display clock enable
Notes:
k_vo_point#
Description:
Defines a coordinate information structure.
Definition:
    k_u32 x;
    k_u32 y;
} k_vo_point;
Members:
Member Name
x
X coordinate
y
Y coordinate
Notes:
k_vo_size#
Description:
Defines a size information structure.
Definition:
    k_u32 width;
    k_u32 height;
} k_vo_size;
Members:
Member Name
Width
Height
Notes:
k_vo_video_layer_attr#
Description:
Defines the attributes of the display layer.
Definition:
    k_vo_point display_rect;
    k_vo_size img_size;
    k_pixel_format pixel_format;
    k_u32 stride;
    k_u32 uv_swap_en;
    k_u32 alpha_type;
} k_vo_video_layer_attr;
Members:
Member Name
display_rect
Starting position of the OSD layer
img_size
Image resolution structure, i.e., the size of the composite image
pixel_format
Data format supported by the video layer
stride
Image stride
uv_swap_en
UV swap
alpha_type
Type of alpha, only used by OSD layers. Divided into fixed alpha (256 levels), using R from RGB as alpha, using G from RGB as alpha, using B from RGB as alpha, or using the alpha channel as alpha
Notes:
alpha_type is only used by OSD layers.
k_vo_wbc_attr#
Description:
Defines writeback attributes.
Definition:
    k_vo_size target_size;
    k_u32 stride;
    k_u32 y_phy_addr;
} k_vo_wbc_attr;
Members:
Member Name
target_size
Target size for writeback
pixel_format
Data format for writeback
stride
Writeback stride
y_phy_addr
Physical address for image writeback
Notes:
y_phy_addr needs allocated space.
k_vo_pub_attr#
Description:
Configures the public attributes of the video output device.
Definition:
    k_u32 bg_color;
    k_vo_intf_type intf_type;
    k_vo_intf_sync intf_sync;
} k_vo_pub_attr;
Members:
Member Name
bg_color
Background color
intf_type
Interface type, currently only supports MIPI
intf_sync
Resolution and frame rate in video
sync_info
Timing information for image output
Notes:
k_vo_scaler_attr#
Description:
Defines the scaler attributes.
Definition:
    k_vo_size in_size;
    k_vo_size out_size;
    k_u32 stride;
} k_vo_scaler_attr;
Members:
Member Name
in_size
Input size
out_size
Output size
stride
Input stride
y_phy_addr
Notes:
k_vo_draw_frame#
Description:
Defines the attributes for drawing a frame.
Definition:
    k_u32 draw_en;
    k_u32 line_x_start;
    k_u32 line_y_start;
    k_u32 line_x_end;
    k_u32 line_y_end;
    k_u32 frame_num;
} k_vo_draw_frame;
Members:
Member Name
draw_en
Enable drawing frame
line_x_start
X-axis start position
line_y_start
Y-axis start position
line_x_end
X-axis end position
line_y_end
Y-axis end position
frame_num
Frame number (0 - 16)
Notes:
k_vo_display_resolution#
Description:
Display timing attributes.
Definition:
    k_u32 pclk;
    k_u32 phyclk;
    k_u32 htotal;
    k_u32 hdisplay;
    k_u32 hsync_len;
    k_u32 hback_porch;
    k_u32 hfront_porch;
    k_u32 vtotal;
    k_u32 vdisplay;
    k_u32 vsync_len;
    k_u32 vback_porch;
    k_u32 vfront_porch;
} k_vo_display_resolution;
Members:
Member Name
pclk
Pixel clock frequency
phyclk
D-PHY frequency
htotal
Total pixels per line
hdisplay
Active pixels per line
hsync_len
Horizontal sync length
hback_porch
Horizontal back porch
hfront_porch
Horizontal front porch
vtotal
Total lines per frame
vdisplay
Active lines per frame
vsync_len
Vertical sync length
vback_porch
Vertical back porch
vfront_porch
Vertical front porch
Notes:
k_vo_mipi_phy_attr#
Description:
Defines the structure for MIPI PHY frequency.
Definition:
    k_u32 n;
    k_u32 m;
    k_u32 voc;
    k_u32 phy_lan_num;
    k_u32 hs_freq;
} k_vo_mipi_phy_attr;
Members:
Member Name
n
PLL coefficient
m
PLL coefficient
voc
PLL coefficient
hs_freq
PHY frequency range
phy_lan_num
Number of PHY lanes
Notes:
k_vo_video_osd_attr#
Description:
Configures the public attributes of the OSD layer.
Definition:
    k_vo_size img_size;
    k_u32 stride;
    k_u8 global_alpha;
} k_vo_video_osd_attr;
Members:
Member Name
display_rect
Position info
img_size
Effective size
pixel_format
Data format
stride
Stride
global_alpha
Transparency
Notes:
k_video_frame_info#
Description:
Information of a frame.
Definition:
    k_video_frame v_frame;
    k_u32 pool_id;
    k_mod_id mod_id;
} k_video_frame_info;
Members:
Member Name
v_frame
Frame information
pool_id
VB pool ID
mod_id
Video frame ID
Notes:
k_connector_type#
Description:
Type of screen connection.
Definition:
    LT9611_MIPI_4LAN_1920X1080_30FPS,
} k_connector_type;
Members:
Member Name
HX8377_V2_MIPI_4LAN_1080X1920_30FPS
HX8377 screen initialization
LT9611_MIPI_4LAN_1920X1080_60FPS
HDMI 1080p60 initialization
HDMI 1080p30 initialization
Notes:
k_dsi_lan_num#
Description:
Number of DSI lanes.
Definition:
    K_DSI_1LAN = 0,
    K_DSI_2LAN = 1,
    K_DSI_4LAN = 3,
} k_dsi_lan_num;
Members:
Member Name
K_DSI_1LAN
1-lane mode
K_DSI_2LAN
2-lane mode
K_DSI_4LAN
4-lane mode
Notes:
k_dsi_work_mode#
Description:
DSI work mode.
Definition:
    K_BURST_MODE = 0,
} k_dsi_work_mode;
Members:
Member Name
K_BURST_MODE
DSI works in burst mode
K_NON_BURST_MODE_WITH_SYNC_EVENT
DSI works in non-burst sync event mode
K_NON_BURST_MODE_WITH_PULSES
DSI works in non-burst pulses mode
Notes:
k_vo_dsi_cmd_mode#
Description:
DSI command transmission mode.
Definition:
    K_VO_LP_MODE,
    K_VO_HS_MODE,
} k_vo_dsi_cmd_mode;
Members:
Member Name
K_VO_LP_MODE
Send command in LP mode
K_VO_HS_MODE
Send command in HS mode
Notes:
k_connectori_phy_attr#
Description:
Configuration information for the PHY of the connector.
Definition:
    k_u32 n;
    k_u32 m;
    k_u32 voc;
    k_u32 hs_freq;
} k_connectori_phy_attr;
Members:
Member Name
n
PLL coefficient
m
PLL coefficient
voc
PLL coefficient
hs_freq
PHY frequency range
Notes:
k_connector_info#
Description:
Information of the connector.
Definition:
    const char *connector_name;
    k_u32 screen_test_mode;
    k_u32 dsi_test_mode;
    k_u32 bg_color;
    k_u32 intr_line;
    k_dsi_lan_num lan_num;
    k_dsi_work_mode work_mode;
    k_vo_dsi_cmd_mode cmd_mode;
    k_connector_type type;
} k_connector_info;
Members:
Member Name
connector_name
Name of the connector
screen_test_mode
Screen test mode
dsi_test_mode
DSI test mode
bg_color
Background color
intr_line
Interrupt line
lan_num
Number of DSI lanes
work_mode
DSI work mode
cmd_mode
DSI command mode
phy_attr
PHY attributes
resolution
Display resolution
Connector type
Notes:
k_connector_negotiated_data#
Description:
Data negotiated between the display driver and the HDMI display.
Definition:
    k_u32 connection_status;
    k_u32 negotiated_count;
Members:
Member Name
connection_status
HDMI interface connection status
negotiated_count
Number of resolutions supported by the display driver after negotiation with HDMI display
negotiated_types[256]
List of resolutions supported by the display driver after negotiation with HDMI display, negotiated_types[0] indicates the best resolution
Notes:
k_connector_mirror#
Description:
Mirror function of the display driver.
Definition:
    K_CONNECTOR_MIRROR_HOR = 1,
    K_CONNECTOR_MIRROR_VER,
    K_CONNECTOR_MIRROR_BOTH,
} k_connector_mirror;
Members:
Member Name
Horizontal mirror
Vertical mirror
Notes:
Error Codes#
Table 41 VO API Error Codes
Error Code
Macro Definition
0xa00b8006
K_ERR_VO_NULL_PTR
Null pointer error
0xa00b8001
K_ERR_VO_INVALID_DEVID
Invalid device ID
0xa00b8002
K_ERR_VO_INVALID_CHNID
Invalid channel ID
0xa00b8005
K_ERR_VO_UNEXIST
Video buffer does not exist
0xa00b8004
K_ERR_VO_EXIST
Video buffer exists
0xa00b8003
K_ERR_VO_ILLEGAL_PARAM
Invalid parameter settings
0xa00b8010
K_ERR_VO_NOTREADY
VO not ready
0xa00b8012
K_ERR_VO_BUSY
System busy
0xa00b8007
K_ERR_VO_NOT_CONFIG
Configuration not allowed
0xa00b8008
K_ERR_VO_NOT_SUPPORT
Unsupported operation
0xa00b8009
K_ERR_VO_NOT_PERM
Operation not permitted
0xa00b800c
K_ERR_VO_NOMEM
Memory allocation failure
0xa00b800d
K_ERR_VO_NOBUF
No buffer available
0xa00b800e
K_ERR_VO_BUF_EMPTY
Buffer is empty
0xa00b800f
K_ERR_VO_BUF_FULL
Buffer is full
0xa00b8011
K_ERR_VO_BADADDR
Invalid address
0xa00b8012
K_ERR_VO_BUSY
System busy
