K230 System Control MAPI Reference#
The products, services, or features you purchase are subject to the commercial contracts and terms of Beijing Canaan Creative Information Technology Co., Ltd. (“the Company”, hereinafter) and its affiliates. All or part of the products, services, or features described in this document may not be within your purchase or usage scope. Unless otherwise stipulated in the contract, the Company does not make any express or implied statements or warranties regarding the accuracy, reliability, completeness, merchantability, fitness for a particular purpose, or non-infringement of any representations, information, or content in this document. Unless otherwise agreed, this document is for reference purposes only.
Trademark Statement#
logo “Canaan” and other Canaan trademarks are trademarks of Beijing Canaan Creative Information Technology Co., Ltd. and its affiliates. All other trademarks or registered trademarks mentioned in this document are owned by their respective owners.
Copyright © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. No part of this document may be excerpted, copied, or disseminated in any form without the written permission of the Company.
Table of Contents#
This document mainly introduces the functions and usage of the system control module in MAPI. The functions and usage of other modules will be discussed in their respective dedicated documents.
Intended Audience#
  • Technical Support Engineers
Abbreviations#
Abbreviation
mpp
Media Process Platform
vb
video buffer
Document Version
Author
Date
Initial Version
Haibo Hao
2023/5/4
1. Overview#
1.1 Overview#
System control, based on the characteristics of the K230 chip, completes the reset and basic initialization of various hardware components. It is also responsible for establishing inter-core communication for the MPP (Media Process Platform) system and initializing and deinitializing modules such as multimedia memory management.
1.2 Function Description#
MAPI features cross-OS calls, enabling the same API to be called on both the big and small cores of the K230 to achieve the required functionality.
For specific details on binding and memory management in MAPI, please refer to the document “K230 System Control API Reference V1.0”.
2. API Reference#
2.1 kd_mapi_sys_init#
Description:
Initialize system resources and establish message communication channels between the two cores. To establish a dual-core connection, services running on each operating system need to call this interface during initialization to establish the connection, after which inter-core communication can be performed.
Syntax:
k_s32 kd_mapi_sys_init(void);
Parameters:
Return Values:
Success
Non-zero
Failure, see Error Codes for values
Chip Differences:
Requirements:
  • Header file: mapi_sys_api.h
  • Library file: libmapi.a
Notes:
This function needs to be called before calling kd_mapi_media_init.
Related Topics:
2.2 kd_mapi_sys_deinit#
Description:
Deinitialize system resources and disconnect the message communication channels between the two cores.
Syntax:
k_s32 kd_mapi_sys_deinit(void);
Parameters:
Return Values:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
If kd_mapi_sys_init has not been called, calling this API will return success.
Related Topics:
2.3 kd_mapi_media_init#
Description:
Initialize multimedia-related resources, mainly configuring the number and size of the video buffers (vb).
Syntax:
Parameters:
Parameter Name
Input/Output
media_attr
Pointer to media attributes
Input
Return Values:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
2.4 kd_mapi_media_deinit#
Description:
Deinitialize multimedia-related resources.
Syntax:
Parameters:
Return Values:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
2.5 kd_mapi_alloc_buffer#
Description:
Allocate MMZ memory in user space (with cache).
Syntax:
Parameters:
Parameter Name
Input/Output
phys_addr
Physical address of the buffer
Output
virt_addr
Virtual address of the buffer
Output
len
Length of the buffer
Input
name
Name of the buffer
Input
Return Values:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • The virtual address and physical address of the buffer are already mapped.
  • After allocating memory, check whether the buffer is successfully allocated on the big core side via cat /proc/umap/media-mem.
Related Topics:
2.6 kd_mapi_free_buffer#
Description:
Free MMZ memory in user space.
Syntax:
Parameters:
Parameter Name
Input/Output
phys_addr
Input
virt_addr
Input
len
Input
Return Values:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
After freeing memory, check whether the buffer is successfully released on the big core side via cat /proc/umap/media-mem.
Related Topics:
2.7 kd_mapi_sys_get_vb_block#
Description:
Get a buffer block in user space.
Syntax:
Parameters:
Parameter Name
Input/Output
pool_id
ID of the buffer pool containing the block
Output
phys_addr
Physical address of the buffer block
Output
blk_size
Size of the buffer block
Input
mmz_name
Name of the DDR containing the buffer pool
Input
Return Values:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • If the user needs to get a buffer block of a specified size from any public buffer pool, set the second parameter blk_size to the required buffer block size and specify from which DDR to get the buffer block. If there is no public buffer pool on the specified DDR, the buffer block cannot be obtained. If mmz_name is NULL, it means getting the buffer block from the public buffer pool on an unnamed DDR.
  • During media initialization, if a buffer pool is created in an unnamed DDR, set mmz_name to NULL to get a buffer block of the specified size from any public buffer pool.
Related Topics:
2.8 kd_mapi_sys_release_vb_block#
Description:
Release a buffer block in user space.
Syntax:
Parameters:
Parameter Name
Input/Output
phys_addr
Output
blk_size
Input
Return Values:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
After using the buffer block, this interface should be called to release the buffer block.
Related Topics:
3. Data Types#
3.1 k_mapi_mod_id_e#
Description:
Defines MAPI module IDs.
Definition:
    K_MAPI_MOD_SYS = 0,
    K_MAPI_MOD_VI,
    K_MAPI_MOD_VPROC,
    K_MAPI_MOD_VENC,
    K_MAPI_MOD_VDEC,
    K_MAPI_MOD_VREC,
    K_MAPI_MOD_VO,
    K_MAPI_MOD_AI,
    K_MAPI_MOD_AENC,
    K_MAPI_MOD_ADEC,
    K_MAPI_MOD_AREC,
    K_MAPI_MOD_AO,
    K_MAPI_MOD_VVI,
    K_MAPI_MOD_VVO,
    K_MAPI_MOD_DPU,
    K_MAPI_MOD_VICAP,
    K_MAPI_MOD_SENSOR,
    K_MAPI_MOD_ISP,
    K_MAPI_MOD_BUTT,
} k_mapi_mod_id_e;
Members:
Notes:
3.2 k_mapi_media_config_t#
Description:
Defines the media configuration attribute structure.
Definition:
    k_vb_config vb_config;
} k_mapi_media_config_t;
Members:
Member Name
vb_supp
VB Supplement Information Structure, see “K230 System Control API Reference”
vb_config
Video Buffer Pool Attribute Structure, see “K230 System Control API Reference”
Notes:
3.3 k_mapi_media_attr_t#
Description:
Defines the media initialization attribute structure.
Definition:
} k_mapi_media_attr_t;
Members:
Member Name
media_config
Media configuration attribute structure
Notes:
4. Error Codes#
Table 41
Error Code
Macro Definition
0xb0008003
K_MAPI_ERR_SYS_ILLEGAL_PARAM
Parameter error
0xb0008006
K_MAPI_ERR_SYS_NULL_PTR
Null pointer error
0xb0008009
K_MAPI_ERR_SYS_NOT_PERM
Operation not permitted
0xb0008010
K_MAPI_ERR_SYS_NOTREADY
Device not ready
0xb0008012
K_MAPI_ERR_SYS_BUSY
System busy
0xb000800c
K_MAPI_ERR_SYS_NOMEM
Memory allocation failure, such as insufficient system memory
