K230 FFT API Reference#
The products, services, or features you purchase are subject to the commercial contracts and terms of Beijing Canaan Creative Information Technology Co., Ltd. (hereinafter referred to as “the Company”) and its affiliates. All or part of the products, services, or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any explicit or implicit statements or guarantees regarding the correctness, reliability, completeness, merchantability, fitness for a particular purpose, and non-infringement of any representations, information, or content in this document. Unless otherwise agreed, this document is only for use as a reference guide.
Due to product version upgrades or other reasons, the contents of this document may be updated or modified periodically without any notice.
Trademark Statement#
Copyright © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. Without the Company’s written permission, no unit or individual may excerpt, copy any part or all of the content of this document, and may not disseminate it in any form.
Table of Contents#
This document mainly introduces the API of K230 FFT, including the usage of the API and the introduction of test programs.
Target Audience#
This document (this guide) is mainly suitable for the following personnel:
  • Technical Support Engineers
Abbreviation Definitions#
Abbreviation
FFT
Fast Fourier Transform, a fast algorithm for discrete Fourier transform
IFFT
Inverse Fast Fourier Transform, the inverse of the fast Fourier transform
Revision Record#
Document Version
Modification Description
Modifier
Date
Initial Version
Wang Jianxin
2023-08-08
1. Introduction to K230 FFT#
The FFT module of K230 is mainly used for hardware acceleration of FFT and IFFT calculations. Its features are as follows:
  • Supports 64, 128, 256, 512, 1024, 2048, 4096-point FFT and IFFT calculations.
  • Supports int16 calculation precision, i.e., the real and imaginary parts of the input and output are in int16 format.
  • Supports standard AXI4 slave interface, with parameter configuration and data transfer using this interface.
  • The input supports RIRI…., RRRR…. (pure real part), RRRR…IIII… format arrangement, and the output supports RIRI…., RRRR…IIII… format arrangement.
  • Uses radix-2 time decimation calculation method, with only one butterfly operator inside.
  • Uses single clock domain design, with the bus clock also serving as the operation clock to save cross-clock domain overhead.
  • The calculation time for 4096-point FFT/IFFT is controlled within 1ms, including the total overhead of data transfer, calculation, and interrupt interaction.
  • Supports interrupt mask and raw interrupt query.
2. API Reference#
The K230 FFT module mainly provides the following APIs:
2.1 kd_mpi_fft_or_ifft#
Description:
Core function for FFT or IFFT calculation.
Syntax:
Parameters:
Parameter
Input/Output
fft_args
FFT parameters k_fft_args_st
Input/Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
  • Header file: mpi_fft_api.h
  • Library file: libfft.a
Notes:
int kd_mpi_fft(int point, k_fft_input_mode_e im, k_fft_out_mode_e om,
               k_u32 timeout, k_u16 shift,
    int ret = 0;
    k_fft_args_st fft_args;
    ret = kd_mpi_fft_args_init(point, FFT_MODE, im, om, timeout, shift, rx_in, iy_in, &fft_args); ERET(ret);
    ret = kd_mpi_fft_args_2_array(&fft_args, rx_out, iy_out); ERET(ret);
Related Topics:
2.2 kd_mpi_fft_args_init#
Description:
Initialization of fft_args (helper function)
Syntax:
int kd_mpi_fft_args_init(int point, k_fft_mode_e mode, k_fft_input_mode_e im,
                         k_fft_out_mode_e om, k_u32 timeout, k_u16 shift,
                         short *real, short *imag, k_fft_args_st *fft_args);
Parameters:
Parameter
Input/Output
point
Number of points, valid values are 64, 128, 256, 512, 1024, 2048, 4096
Input
Input
im
k_fft_input_mode_e Input mode
Input
om
k_fft_out_mode_e Output mode
Input
timeout
Timeout
Input
shift
Offset
Input
rx_input
Input real data
Input
iy_input
Input imaginary data
Input
fft_args
k_fft_args_st Variable to be filled
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
    int ret = 0;
Related Topics:
2.3 kd_mpi_fft_args_2_array#
Description:
Convert FFT output to array (helper function, convenient for printing).
Syntax:
Parameters:
Parameter
Input/Output
fft_args
k_fft_args_st Structure
Input
rx_out
Real data
Output
iy_out
Imaginary data
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
int kd_mpi_fft(int point, fft_input_mode_e im, fft_out_mode_e om,
               k_u32 timeout, k_u16 shift, k_u16 dma_ch,
    int ret = 0;
    ret = kd_mpi_fft_args_init(point, FFT_MODE, im, om, timeout, shift, dma_ch, rx_in, iy_in, &fft_args); ERET(ret);
Related Topics:
2.4 kd_mpi_fft#
Description:
FFT calculation.
The core functions kd_mpi_fft_args_init, kd_mpi_fft_or_ifft, and kd_mpi_fft_args_2_array are encapsulated together for convenience of use.
Syntax:
Parameters:
Parameter
Input/Output
point_num
Input
im
Input
om
Input
timeout
Timeout
Input
shift
Offset
Input
rx_input
Input real data
Input
iy_input
Input
rx_out
Computed result real data
Output
iy_out
Computed result imaginary data
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
    //soft_fft_ifft_calc(point);
    clock_gettime(CLOCK_MONOTONIC, &begin_time);
    kd_mpi_fft(point, RIRI, RR_II_OUT, 0, 0x555, i_real, i_imag, o_h_real, o_h_imag);
    kd_mpi_ifft(point, RIRI, RR_II_OUT, 0, 0xaaa, o_h_real, o_h_imag, o_h_ifft_real, o_h_ifft_imag);
    display_calc_result(point);
Related Topics:
2.5 kd_mpi_ifft#
Description:
IFFT calculation.
Syntax:
int kd_mpi_ifft(int point, k_fft_input_mode_e im, k_fft_out_mode_e om,
Parameters:
Parameter
Input/Output
point_num
Input
im
Input
om
Input
timeout
Timeout
Input
shift
Offset
Input
dma_ch
DMA channel, valid values are 0-3; other values are invalid
Input
rx_input
Input real data
Input
iy_input
Input
rx_out
Output
iy_out
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
Related Topics:
3. Data Structures#
The data types related to this functional module are defined as follows:
3.1 k_fft_args_st#
Description: FFT ioctl parameters
Definition:
typedef union
    struct {
        volatile k_fft_input_mode_e im:2; //5:4 0:RIRI....;1:RRRR.... (pure real part);2:RRRR...IIII..
        volatile k_u16 shift:12; //19:8  [11] Enable right shift for the 12th stage.....[0] Enable right shift for the 1st stage
        volatile k_u32 fft_disable_cg : 1;//20 Clock gating disable signal, write 1 to disable FFT clock gating
        volatile k_u32 time_out:32;//63:32 Indicates the timeout threshold for FFT module calculation after FFT is enabled; writing 0 means that the FFT timeout interrupt function does not exist
    }__attribute__ ((packed));
    volatile k_u64 cfg_value;
    k_fft_cfg_reg_st reg;
    k_char rsv[4];
} k_fft_args_st;
Members:
Member Name
reg
Configuration register value for FFT
Input and output data for FFT
Notes:
3.2 k_fft_mode_e#
Definition:
typedef enum  {
    FFT_MODE = 0,
    IFFT_MODE,
} k_fft_mode_e;
Members:
Member Name
FFT_MODE
FFT
IFFT_MODE
IFFT
Notes:
3.3 k_fft_input_mode_e#
Definition:
    RIRI = 0,
    RRRR,
    RR_II,
} k_fft_input_mode_e;
Members:
Member Name
RIRI
RIRI format data
RRRR
Pure real part data
RR_II
RR_II format data
Notes:
3.4 k_fft_out_mode_e#
Definition:
    RIRI_OUT = 0,
    RR_II_OUT,
} k_fft_out_mode_e;
Members:
Member Name
RIRI_OUT
RIRI format data
RR_II_OUT
RR_II format data
Notes:
