3.3 Audio Module API Manual#
1. Overview#
This manual aims to provide a detailed introduction to the CanMV audio module, guiding developers on how to achieve audio capture and playback functions by calling the Python API interface.
2. API Introduction#
2.1 mpp.wave#
The wave module provides a convenient way to read and process WAV files. Using the wave.open function, you can open a WAV file and return the corresponding class object.
The
wave.Wave_readclass provides methods for obtaining metadata from a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and reading WAV audio data from the file.The
wave.Wave_writeclass provides methods for setting metadata for a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and saving PCM audio data to a WAV file.
This module, when used in conjunction with the pyaudio module, can easily achieve the playback and capture of WAV file audio and save WAV audio files.
2.1.1 open#
Open a WAVE file to read or write audio data.
Syntax
def open(f, mode=None)
Parameter Name |
Input/Output |
f |
File name |
Input |
mode |
Open mode (‘r’, ‘rb’, ‘w’, ‘wb’) |
Input |
Return Value |
Wave_read or Wave_write class object |
Success |
Others |
Failure, raises an exception |
2.1.2 wave.Wave_read#
The Wave_read class provides methods for obtaining metadata from a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and reading WAV audio data from the file.
2.1.2.1 get_channels#
Get the number of channels.
Syntax
def get_channels(self)
Return Value |
>0 |
Success |
Failure |
2.1.2.2 get_sampwidth#
Get the sample byte length.
Syntax
def get_sampwidth(self)
Return Value |
>0 (Valid range [1, 2, 3, 4] corresponding to sampling precision [8, 16, 24, 32]) |
Success |
Failure |
2.1.2.3 get_framerate#
Get the sample rate.
Syntax
def get_framerate(self)
Return Value |
>0 (Valid range (8000~192000)) |
Success |
Failure |
2.1.2.4 read_frames#
Read frame data.
Syntax
Parameter Name |
Input/Output |
nframes |
Length of frames to read (number of channels × sampling precision per sample point / 8) |
Input |
Return Value |
bytes sequence |
2.1.3 wave.Wave_write#
The Wave_write class provides methods for setting metadata for a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and saving PCM audio data to a WAV file.
2.1.3.1 set_channels#
Set the number of channels.
Syntax
Parameter Name |
Input/Output |
nchannels |
Number of channels |
Input |
2.1.3.2 set_sampwidth#
Set the sample byte length.
Syntax
Parameter Name |
Input/Output |
sampwidth |
Sample byte length, valid range [1, 2, 3, 4] corresponding to sampling precision [8, 16, 24, 32] |
Input |
2.1.3.3 set_framerate#
Set the sample rate.
Syntax
Parameter Name |
Input/Output |
framerate |
Sample rate [8000~192000] |
Input |
2.1.3.4 write_frames#
Write audio data.
Syntax
def write_frames(self, data)
Parameter Name |
Input/Output |
data |
Audio data (bytes sequence) |
Input |
2.2 mpp.pyaudio#
The pyaudio module is used for audio processing, responsible for capturing and playing binary PCM audio data. To play WAV format files or save captured data as WAV files, it needs to be used in conjunction with the mpp.wave library, as detailed in the Example Programs section.
2.2.1 pyaudio.PyAudio#
Responsible for managing multiple audio input and output channels, each channel is represented as a Stream class object.
2.2.1.1 open#
Open a stream.
Syntax
Variable parameters, refer to [Stream.__init__].
Return Value |
py:class: |
Success |
Others |
2.2.1.2 close#
Close a stream.
Syntax
def close(self, stream)
This function will call the close method in the Stream object and remove the Stream object from the PyAudio object. Therefore, this function can be omitted, and the Stream.close method can be called directly.
2.2.1.3 terminate#
Release audio resources. This function must be called to release audio resources when PyAudio is no longer in use. If a vb block is allocated in the default constructor, it should be released in this function.
Syntax
def terminate(self)
2.2.2 pyaudio.Stream#
The Stream class object is used to manage a single audio input or output channel.
2.2.2.1 __init__#
Constructor.
Syntax
def __init__(self,
PA_manager,
rate,
channels,
format,
input=False,
output=False,
input_device_index=None,
output_device_index=None,
enable_codec=True,
frames_per_buffer=1024,
start=True,
stream_callback=None)
Parameter Name |
Input/Output |
PA_manager |
PyAudio class object |
Input |
rate |
Sample rate |
Input |
channels |
Input |
format |
Sample point byte length |
Input |
input |
Is it audio input, default is False |
Input |
output |
Is it audio output, default is False |
Input |
input_device_index |
Input channel index [0,1], default is None (use default channel 0) |
Input |
output_device_index |
Output channel index [0,1], default is None (use default channel 0) |
Input |
enable_codec |
Enable codec, default is True |
Input |
frames_per_buffer |
Frames per buffer |
Input |
start |
Start immediately, default is True |
Input |
stream_callback |
Input/Output callback function |
Input |
2.2.2.2 start_stream#
Start the stream.
Syntax
def start_stream(self)
2.2.2.3 stop_stream#
Stop the stream.
Syntax
def stop_stream(self)
2.2.2.4 read#
Read audio data.
Syntax
def read(self, frames)
Parameter Name |
Input/Output |
frames |
Number of frames |
Input |
Return Value |
bytes |
Read audio data |
2.2.2.5 write#
Write audio data.
Syntax
def write(self, data)
Parameter Name |
Input/Output |
data |
Input |
2.2.2.6 volume#
Get or set the volume.
Syntax
def volume(self, vol=None, channel=LEFT_RIGHT)
Parameter Name |
Input/Output |
vol |
Set volume value |
Input |
channel |
Channel selection |
Input |
When setting the volume, return value: None When getting the volume, return value: tuple
2.2.2.7 enable_audio3a#
Enable audio 3A.
Syntax
def enable_audio3a(self, audio3a_value)
Parameter Name |
Input/Output |
audio3a_value |
Audio 3A enable options: AUDIO_3A_ENABLE_ANS (noise suppression), AUDIO_3A_ENABLE_AGC (automatic gain control), AUDIO_3A_ENABLE_AEC (echo cancellation) |
Input |
2.2.2.8 audio3a_send_far_echo_frame#
Send far-end reference audio (i.e., audio played by the near-end speaker), used only in the echo cancellation (AEC) scenario of audio 3A.
Syntax
def audio3a_send_far_echo_frame(self, frame_data, data_len)
Parameter Name |
Input/Output |
frame_data |
Far-end reference audio data (bytes sequence) |
Input |
data_len |
Data length |
Input |
3. Example Programs#
3.1 Example of Playing a WAV File#
import pyaudio
import wave
# Play a WAV file
def play_wav(file_path):
# Open the WAV file
wf = wave.open(file_path, 'rb')
# Create a PyAudio object
p = pyaudio.PyAudio()
# Open a stream
stream = p.open(format=p.get_format_from_width(wf.getsampwidth()),
channels=wf.getnchannels(),
rate=wf.getframerate(),
output=True)
# Read data and play
data = wf.readframes(1024)
while data:
stream.write(data)
# Close the stream
stream.stop_stream()
stream.close()
p.terminate()
3.2 Example of Capturing Audio and Saving as a WAV File#
import pyaudio
import wave
# Capture audio and save as a WAV file
def record_wav(file_path, duration):
# Open a stream
stream = p.open(format=pyaudio.paInt16,
channels=1,
rate=44100,
input=True,
frames_per_buffer=1024)
frames = []
# Capture audio data
for _ in range(0, int(44100 / 1024 * duration)):
data = stream.read(1024)
frames.append(data)
# Stop the stream
stream.close()
p.terminate()
# Save as a WAV file
wf = wave.open(file_path, 'wb')
wf.setnchannels(1)
wf.setsampwidth(2)
wf.setframerate(44100)
wf.writeframes(b''.join(frames))
wf.close()
4. Summary#
Through this manual, developers can easily use the CanMV audio module to achieve audio playback and capture functions. This module combines the advantages of the wave and pyaudio libraries, providing convenient interfaces and clear API documentation, making it easy to quickly develop and apply audio-related projects.
