3.2 Display Module API Manual#
Attention
This module has significant changes starting from firmware version V0.7. If you are using firmware prior to V0.7, please refer to the old version of the documentation.
1. Overview#
This manual is intended to guide developers on using the Micro Python API to call the CanMV Display module for image display functionality.
2. API Introduction#
2.1 init#
Initializes the Display path, including the VO module, DSI module, and LCD/HDMI.
Must be called before MediaManager.init()
Syntax
init(type=None, width=None, height=None, osd_num=1, to_ide=False, fps=None, quality=90)
Parameter Name |
Input / Output |
Notes |
type |
Input |
Required |
Resolution width |
Input |
Default value depends on |
Resolution height |
Input |
osd_num |
Number of layers supported in show_image |
Input |
The larger the number, the more memory it occupies |
to_ide |
Whether to transfer screen display to IDE display |
Input |
Occupies more memory when enabled |
fps |
Display frame rate |
Input |
Only supports |
quality |
Sets |
Input |
Only effective when |
Return Value |
None |
2.2 show_image#
Displays an image on the screen.
Syntax
show_image(img, x=0, y=0, layer=None, alpha=255, flag=0)
Parameter Name |
Input / Output |
Notes |
img |
Image to display |
Input |
x |
X value of the starting coordinate |
Input |
y |
Y value of the starting coordinate |
Input |
layer |
Display on the specified layer |
Input |
Only supports |
alpha |
Layer blending alpha |
Input |
flag |
Display flag |
Input |
Return Value |
None |
2.3 deinit#
Performs deinitialization. The deinit method will shut down the entire Display path, including the VO module, DSI module, and LCD/HDMI.
Must be called before MediaManager.deinit()
Must be called after sensor.stop()
Syntax
deinit()
Return Value |
None |
2.4 bind_layer#
Binds the output of the sensor or vdec module to the screen display. This allows continuous image display without manual intervention.
Must be called before init
Syntax
Parameter Name |
Input / Output |
Notes |
src |
Output information of |
Input |
Obtainable via |
dstlayer |
Display layer to bind to display layer |
Input |
Can be bound to |
rect |
Display area |
Input |
Obtainable via |
pix_format |
Image pixel format |
Input |
Obtainable via |
alpha |
Input |
flag |
Display flag |
Input |
Return Value |
None |
3. Data Structure Description#
3.1 type#
Type |
Resolution |
Notes |
LT9611 |
1920x1080@30 |
Default value |
1280x720@30 |
640x480@60 |
HX8377 |
1080x1920@30 |
Default value |
ST7701 |
800x480@30 |
Default value |
854x480@30 |
Can be set to portrait mode 480x854 |
VIRT |
640x480@90 |
Default value |
3.2 layer#
K230 provides support for 2 video layers and 4 OSD layers. Listed as follows:
Display Layer |
Notes |
LAYER_VIDEO1 |
Only usable in bind_layer |
LAYER_VIDEO2 |
LAYER_OSD0 |
Supports use in show_image and bind_layer |
LAYER_OSD1 |
LAYER_OSD2 |
LAYER_OSD3 |
3.3 flag#
Flag |
Notes |
FLAG_ROTATION_0 |
Rotate |
FLAG_ROTATION_90 |
Rotate |
FLAG_ROTATION_180 |
Rotate |
FLAG_ROTATION_270 |
Rotate |
FLAG_MIRROR_NONE |
No mirroring |
FLAG_MIRROR_HOR |
Horizontal mirroring |
FLAG_MIRROR_VER |
Vertical mirroring |
FLAG_MIRROR_BOTH |
Horizontal and vertical mirroring |
4. Sample Program#
The following is a sample program:
from media.display import * # Import the display module to use display related interfaces
from media.media import * # Import the media module to use media related interfaces
import os, time, image # Import the image module to use image related interfaces
# Use LCD as display output
# Initialize media manager
# Create an image for drawing
img.clear()
img.draw_string_advanced(0, 0, 32, "Hello World!,你好世界 ! ! ! ", color=(255, 0, 0))
Display.show_image(img)
time.sleep(1)
print(" User stopped:", e)
print(f" Exception: {e}")
