3.10 PM Module API Manual#
1. Overview#
The PM module, also known as the Power Management module, is specifically designed to optimize and manage the power consumption of devices. For a detailed description of the PM framework, please refer to the relevant documentation in the SDK (K230_PM Framework Usage Guide.md). In the MicroPython environment, the PM module encapsulates power management functions for both the CPU and KPU.
2. API Introduction#
The PM class is located under the mpp module, which contains two instantiated objects: cpu and kpu, used for managing the power consumption of the central processing unit and the neural network processor, respectively.
2.1 Example#
The following code demonstrates how to use the PM module to get the current CPU frequency, list the supported frequency profiles, and set the CPU frequency:
from mpp import pm
# Get the current CPU frequency
current_freq = pm.cpu.get_freq()
# Get the list of supported CPU frequency profiles
supported_freqs = pm.cpu.list_profiles()
# Set the CPU frequency to a specified profile
pm.cpu.set_profile(1)
2.2 get_freq#
pm.pm_domain.get_freq()
Description: Gets the current frequency of the specified power domain.
Parameters: None
Return Value: Returns the current frequency value of the specified domain.
2.3 list_profiles#
pm.pm_domain.list_profiles()
Description: Gets the list of supported frequency profiles for the specified power domain.
Parameters: None
Return Value: Returns a list containing all the supported frequency profiles of the domain.
2.4 set_profile#
pm.pm_domain.set_profile(index)
Description: Sets the frequency profile index for the specified power domain.
Parameters:
index: The frequency profile index to be set.
Return Value: None
This API manual aims to provide developers with a clear and detailed guide to using the PM module, ensuring effective implementation and optimization of power management.
