3.8 Player Module API Manual#
1. Overview#
This document provides a detailed introduction to the K230_CanMV Player module API, which is designed to support the playback of MP4 format files. This module can simultaneously play audio and video, with audio formats supporting G.711A/U and video formats supporting H.264/H.265 encoding.
2. API Introduction#
The module provides the Player class, which includes the following methods:
2.1 Constructor#
Constructs a Player object based on the specified display_type. Users need to create a Player object first to perform subsequent operations.
Syntax
player = Player(Display.VIRT, [display_to_ide])
Parameter Name |
Input/Output |
Notes |
display_type |
Type of display device |
Input |
display_to_ide |
Whether to output to IDE virtual screen simultaneously |
Input |
Return Value |
Player object |
Created Player instance |
Example
player = Player(Display.VIRT)
player = Player(Display.ST7701)
player = Player(Display.LT9611)
2.2 Player.load#
Loads the specified file. The current version only supports MP4 format files.
Syntax
player = Player()
player.load("test.mp4")
Parameter Name |
Input/Output |
filename |
File name |
Input |
Return Value |
Success |
Non-zero |
Failure |
The current version only supports playing MP4 format files.
2.3 Player.start#
Starts playing audio and video content.
Syntax
player = Player()
player.start()
Return Value |
Success |
Non-zero |
Failure |
2.4 Player.pause#
Pauses the current playback.
Syntax
player = Player()
player.pause()
Return Value |
Success |
Non-zero |
Failure |
2.5 Player.resume#
Resumes playback.
Syntax
player = Player()
player.resume()
Return Value |
Success |
Non-zero |
Failure |
2.6 Player.stop#
Stops playback.
Syntax
player = Player()
player.stop()
Return Value |
Success |
Non-zero |
Failure |
2.7 Player.set_event_callback#
Sets the callback function for playback events.
Parameter Name |
Input/Output |
callback |
Callback function name |
Input |
Syntax
def player_event(event, data):
pass
player = Player()
player.set_event_callback(callback=player_event)
Return Value |
Success |
Non-zero |
Failure |
3. Data Structure Description#
3.1 play_event_type#
Defines the types of playback events.
Members
Member Name |
K_PLAYER_EVENT_EOF |
Playback End |
K_PLAYER_EVENT_PROGRESS |
Playback Progress |
4. Example Program#
4.1 Example 1#
from media.player import *
start_play = False
global start_play
if event == K_PLAYER_EVENT_EOF:
start_play = False
def play_mp4_test(filename):
global start_play
# Use IDE as output display, supports any resolution; suitable for BPI development board
# Use ST7701 LCD screen as output display, maximum resolution is 800x480
# player = Player(Display.ST7701)
# Use HDMI as output display
# player = Player(Display.LT9611)
player.load(filename)
player.set_event_callback(player_event)
player.start()
start_play = True
while start_play:
time.sleep(0.1)
player.stop()
print("Playback finished")
play_mp4_test("/sdcard/examples/test.mp4")
