3.7 MP4 Module API Manual#
1. Overview#
This document provides a detailed introduction to the functions and usage of the K230_CanMV MP4 module API. The MP4 module is mainly used for generating MP4 files. Developers do not need to focus on the underlying implementation details; they only need to call the provided APIs to generate MP4 files in different encoding formats and video resolutions.
2. API Introduction#
This module provides the MP4Container class, which includes the following methods:
2.1 MP4Container.Create#
Used to create an instance of MP4Container.
Syntax
MP4Container.Create(mp4Cfg)
Parameter Name |
Input/Output |
mp4cfg |
MP4Container configuration |
Input |
Return Values
Return Value |
Success |
Non-zero |
Failure |
2.2 MP4Container.Start#
Starts the MP4Container to begin processing data.
Syntax
MP4Container.Start()
Return Values
Return Value |
Success |
Non-zero |
Failure |
2.3 MP4Container.Process#
Writes a frame of audio/video data into the MP4 file.
Syntax
MP4Container.Process()
Return Values
Return Value |
Success |
Non-zero |
Failure |
2.4 MP4Container.Stop#
Stops the MP4Container from processing data.
Syntax
MP4Container.Stop()
Return Values
Return Value |
Success |
Non-zero |
Failure |
2.5 MP4Container.Destroy#
Destroys the created instance of MP4Container.
Syntax
MP4Container.Destroy()
Return Values
Return Value |
Success |
Non-zero |
Failure |
3. Data Structure Description#
3.1 Mp4CfgStr#
Configuration properties for MP4Container.
Definition
class Mp4CfgStr:
def __init__(self, type):
self.type = type
self.muxerCfg = MuxerCfgStr()
def SetMuxerCfg(self, fileName, videoPayloadType, picWidth, picHeight, audioPayloadType, fmp4Flag=0):
self.muxerCfg.file_name = fileName
self.muxerCfg.video_payload_type = videoPayloadType
self.muxerCfg.pic_width = picWidth
self.muxerCfg.pic_height = picHeight
self.muxerCfg.audio_payload_type = audioPayloadType
self.muxerCfg.fmp4_flag = fmp4Flag
Members
Member Name |
type |
MP4Container type: muxer/demuxer, currently only supports muxer |
muxerCfg |
Muxer configuration |
3.2 MuxerCfgStr#
Configuration properties for MP4Container of muxer type.
Definition
class MuxerCfgStr:
def __init__(self):
self.file_name = 0
self.video_payload_type = 0
self.pic_width = 0
self.pic_height = 0
self.audio_payload_type = 0
Members
Member Name |
file_name |
Generated MP4 file name |
video_payload_type |
Video encoding format |
pic_width |
Video frame width |
pic_height |
Video frame height |
audio_payload_type |
Audio encoding format |
Related Data Types and Interfaces#
MP4Container.Create
3.3 MP4Container Types#
Enumeration of MP4Container types.
Members
Member Name |
MP4_CONFIG_TYPE_MUXER |
Muxer type |
MP4_CONFIG_TYPE_DEMUXER |
Demuxer type, currently unsupported |
3.4 video_payload_type#
Video encoding types.
Members
Member Name |
MP4_CODEC_ID_H264 |
H.264 video encoding type |
MP4_CODEC_ID_H265 |
H.265 video encoding type |
3.5 audio_payload_type#
Audio encoding types.
Members
Member Name |
MP4_CODEC_ID_G711U |
G.711U audio encoding type |
MP4_CODEC_ID_G711A |
G.711A audio encoding type |
4. Example Program#
4.1 Example 1#
from media.mp4format import *
def canmv_mp4_muxer_test():
print("mp4_muxer_test starts")
width = 1280
height = 720
# For BPI development boards, set the width and height to 640*360
# width=640
# height=360
# Instantiate MP4 Container
mp4_muxer = Mp4Container()
mp4_cfg = Mp4CfgStr(mp4_muxer.MP4_CONFIG_TYPE_MUXER)
if mp4_cfg.type == mp4_muxer.MP4_CONFIG_TYPE_MUXER:
file_name = "/sdcard/examples/test.mp4"
mp4_cfg.SetMuxerCfg(file_name, mp4_muxer.MP4_CODEC_ID_H265, width, height, mp4_muxer.MP4_CODEC_ID_G711U)
# Create MP4 muxer
mp4_muxer.Create(mp4_cfg)
# Start MP4 muxer
mp4_muxer.Start()
frame_count = 0
# Process audio-video data and write to file in MP4 format
mp4_muxer.Process()
frame_count += 1
print("frame_count = ", frame_count)
if frame_count >= 200:
print(e)
# Stop MP4 muxer
mp4_muxer.Stop()
# Destroy MP4 muxer
mp4_muxer.Destroy()
print("mp4_muxer_test stops")
