1. nncase_runtime Module Usage Guide#
1. Overview#
This document introduces the CanMV nncase_runtime module, guiding developers on how to use MicroPython to call the KPU and AI2D modules.
2. Function Introduction#
2.1. Import Libraries#
Before using the nncase_runtime module, you need to import the relevant libraries:
import nncase_runtime as nn
import ulab.numpy as np
2.2. KPU Initialization#
Initialize the model inference module:
kpu = nn.kpu()
2.3. AI2D Initialization#
Initialize the image processing module:
ai2d = nn.ai2d()
2.4. Load Model#
There are two ways to load the model: by file path or binary data.
# By file path
# By binary data
data = f.read()
kpu.load_kmodel(data)
2.5. Using KPU for Inference Alone#
2.5.1. Set Model Input#
Before model inference, you need to set the corresponding model input data:
data = np.zeros((1, 3, 320, 320), dtype=np.uint8)
# If the model has multiple inputs
2.5.2. Execute Inference and Get Results#
Execute inference and get results:
kpu.run()
result = kpu.get_output_tensor(i) # Returns the i-th output tensor
data = result.to_numpy() # Converts the output tensor to a numpy object
2.6. Using AI2D+KPU for Inference#
Use AI2D to preprocess data collected from the camera, then use KPU for inference. For configuration of input devices such as cameras, refer to the AI Demo Documentation.
2.6.1. Configure AI2D Parameters#
AI2D functions include crop, shift, pad, resize, affine. Configure the corresponding parameters as needed; unused functions can be ignored.
# Basic configuration: input/output layout, input/output dtype
np.uint8, np.uint8)
# Function configuration, taking pad and resize as examples
ai2d.set_pad_param(True, [0, 0, 0, 0, 1, 1, 2, 2], 0, [127, 127, 127])
# Execute configuration, need to configure input/output shape
ai2d_builder = ai2d.build([1, 3, 224, 224], [1, 3, 256, 256])
2.6.2. AI2D+KPU Inference#
Execute AI2D and KPU combined inference:
data = np.zeros((1, 3, 224, 224), dtype=np.uint8)
# Get the input tensor for KPU
# Set the output of AI2D as the input of KPU
kpu.run()
# Get the output tensor of KPU
2.7. Release Memory#
Ensure that all global variable reference counts are zero before the program ends to avoid memory leaks. You can also call gc.collect() at the beginning of the program to release any unreleased memory.
import gc
del kpu
del ai2d
del ai2d_builder
# tensor = nn.from_numpy()
del tensor
del input_tensor
del output_tensor
gc.collect()
nn.shrink_memory_pool()
3. Summary#
This module provides a basic framework for using KPU and AI2D for deep learning inference. Developers can configure models and parameters according to specific needs, perform image processing and inference tasks, and manage memory to improve program stability and performance.
