2. Face Detection Example#
1. Overview#
K230 CanMV face detection is a simple application developed using the Python language. It includes features such as camera data acquisition, preview, and face detection with bounding boxes. This example program utilizes multiple hardware modules of the K230 CanMV platform: AI2D, KPU, Camera, Display, etc.
2. Hardware Environment#
The following hardware environment is required to run this example program:
K230 CanMV development board and the accompanying Sensor module
3. Example Code#
from media.sensor import * # Import camera module for camera-related interfaces
from media.display import * # Import display module for display-related interfaces
from media.media import * # Import media module for media-related interfaces
from time import *
import nncase_runtime as nn # Import nn module for nn-related interfaces
import ulab.numpy as np # Import np module for np-related interfaces
import image
import random
import gc
DISPLAY_HEIGHT = 1080
OUT_RGB888P_WIDTH = ALIGN_UP(1024, 16)
OUT_RGB888P_HEIGH = 624
confidence_threshold = 0.5
top_k = 5000
nms_threshold = 0.2
keep_top_k = 750
vis_thres = 0.5
variance = [0.1, 0.2]
anchors_path = '/sdcard/app/tests/nncase_runtime/face_detection/prior_data_320.bin'
prior_data = np.fromfile(anchors_path, dtype=np.float)
prior_data = prior_data.reshape((4200, 4))
scale = np.ones(4, dtype=np.uint8) * 1024
scale1 = np.ones(10, dtype=np.uint8) * 1024
def decode(loc, priors, variances):
boxes = np.concatenate(
(priors[:, :2] + loc[:, :2] * variances[0] * priors[:, 2:],
priors[:, 2:] * np.exp(loc[:, 2:] * variances[1])), axis=1)
boxes[:, :2] -= boxes[:, 2:] / 2
boxes[:, 2:] += boxes[:, :2]
return boxes
def decode_landm(pre, priors, variances):
landms = np.concatenate((priors[:, :2] + pre[:, :2] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 2:4] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 4:6] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 6:8] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 8:10] * variances[0] * priors[:, 2:])
, axis=1)
return landms
def py_cpu_nms(dets, thresh):
x1 = dets[:, 0]
y1 = dets[:, 1]
x2 = dets[:, 2]
y2 = dets[:, 3]
scores = dets[:, 4]
order = np.argsort(scores, axis=0)[::-1]
keep = []
while order.size > 0:
i = order[0]
keep.append(i)
new_x1 = []
new_x2 = []
new_y1 = []
new_y2 = []
new_areas = []
for order_i in order:
new_x1.append(x1[order_i])
new_x2.append(x2[order_i])
new_y1.append(y1[order_i])
new_y2.append(y2[order_i])
new_x1 = np.array(new_x1)
new_x2 = np.array(new_x2)
new_y1 = np.array(new_y1)
new_y2 = np.array(new_y2)
inter = w * h
new_order = []
for ovr_i, ind in enumerate(ovr):
if ind < thresh:
order = np.array(new_order, dtype=np.uint8)
return keep
def pad_img_to_square(image, rgb_mean):
height, width, _ = image.shape
long_side = max(width, height)
image_t = np.empty((long_side, long_side, 3), dtype=image.dtype)
image_t[:, :] = rgb_mean
image_t[0:0 + height, 0:0 + width] = image
return image_t
def softmax(x):
x = x[0]
x_row_max = np.max(x, axis=-1)
x_row_max = x_row_max.reshape(tuple(list(x.shape)[:-1] + [1]))
x = x - x_row_max
x_exp = np.exp(x)
x_exp_row_sum = np.sum(x_exp, axis=-1).reshape(tuple(list(x.shape)[:-1] + [1]))
softmax = x_exp / x_exp_row_sum
return softmax
def draw_image(img_raw, dets):
pass
def get_result(output_data):
loc = []
loc = np.zeros((1, 4200, 4), dtype=np.float)
start_i = 0
for _i in range(0, 3):
sum_shape = 1
for sh_i in output_data[_i].shape:
sum_shape *= sh_i
output_data[_i] = output_data[_i].reshape((1, -1, loc.shape[2]))
loc[:, start_i:start_i + int(sum_shape / loc.shape[2]), :] = output_data[_i]
start_i = start_i + int(sum_shape / loc.shape[2])
# conf = []
start_i = 0
conf = np.zeros((1, 4200, 2), dtype=np.float)
for _i in range(3, 6):
sum_shape = 1
sum_shape *= sh_i
output_data[_i] = output_data[_i].reshape((1, -1, conf.shape[2]))
conf[:, start_i:start_i + int(sum_shape / conf.shape[2]), :] = output_data[_i]
start_i = start_i + int(sum_shape / conf.shape[2])
conf = softmax(conf)
boxes = decode(loc[0], prior_data, variance)
boxes = boxes * scale
scores = conf[:, 1]
# ignore low scores
inds = []
boxes_ind = []
scores_ind = []
for i in range(len(scores)):
if scores[i] > confidence_threshold:
inds.append(i)
boxes_ind.append(boxes[i])
scores_ind.append(scores[i])
boxes_ind = np.array(boxes_ind)
scores_ind = np.array(scores_ind)
# landms = landms[inds]
# keep top-K before NMS
order = np.argsort(scores_ind, axis=0)[::-1][:top_k]
boxes_order = []
scores_order = []
boxes_order.append(boxes_ind[order_i])
scores_order.append(scores_ind[order_i])
if len(boxes_order) == 0:
return []
boxes_order = np.array(boxes_order)
scores_order = np.array(scores_order).reshape((-1, 1))
# do NMS
dets = np.concatenate((boxes_order, scores_order), axis=1)
keep = py_cpu_nms(dets, nms_threshold)
dets_out = []
for keep_i in keep:
dets_out.append(dets[keep_i])
dets_out = np.array(dets_out)
# keep top-K faster NMS
dets_out = dets_out[:keep_top_k, :]
return dets_out
def face_detect_test():
print("face_detect_test start")
# Initialize KPU
kpu = nn.kpu()
# Initialize AI2D
ai2d = nn.ai2d()
# Load model
kpu.load_kmodel("/sdcard/app/tests/nncase_runtime/face_detection/face_detection_320.kmodel")
ai2d.set_dtype(nn.ai2d_format.NCHW_FMT,
np.uint8, np.uint8)
ai2d.set_pad_param(True, [0, 0, 0, 0, 0, 125, 0, 0], 0, [104, 117, 123])
ai2d_builder = ai2d.build([1, 3, OUT_RGB888P_HEIGH, OUT_RGB888P_WIDTH], [1, 3, 320, 320])
# Initialize and configure sensor
sensor = Sensor()
sensor.reset()
sensor.set_hmirror(False)
sensor.set_vflip(False)
# Channel 0 directly to display VO, format is YUV420
sensor.set_framesize(width=DISPLAY_WIDTH, height=DISPLAY_HEIGHT)
# Channel 2 for AI processing, format is RGBP888
sensor.set_framesize(width=OUT_RGB888P_WIDTH, height=OUT_RGB888P_HEIGH, chn=CAM_CHN_ID_2)
# OSD image initialization
sensor_bind_info = sensor.bind_info(x=0, y=0, chn=CAM_CHN_ID_0)
Display.bind_layer(**sensor_bind_info, layer=Display.LAYER_VIDEO1)
# Set to LT9611 display, default 1920x1080
Display.init(Display.LT9611, to_ide=True)
# Media initialization
# Start sensor
sensor.run()
rgb888p_img = None
# Capture camera data
rgb888p_img = sensor.snapshot(chn=CAM_CHN_ID_2)
if rgb888p_img == -1:
print("face_detect_test, capture_image failed")
continue
# For rgb888planar
ai2d_input = rgb888p_img.to_numpy_ref()
ai2d_input_tensor = nn.from_numpy(ai2d_input)
data = np.ones((1, 3, 320, 320), dtype=np.uint8)
ai2d_out = nn.from_numpy(data)
ai2d_builder.run(ai2d_input_tensor, ai2d_out)
# Set kpu input
kpu.set_input_tensor(0, ai2d_out)
# Run kmodel
kpu.run()
del ai2d_input_tensor
del ai2d_out
# Get output
results = []
data = kpu.get_output_tensor(i)
result = data.to_numpy()
tmp = (result.shape[0], result.shape[1], result.shape[2], result.shape[3])
result = result.reshape((result.shape[0] * result.shape[1], result.shape[2] * result.shape[3]))
result = result.transpose()
tmp2 = result.copy()
tmp2 = tmp2.reshape((tmp[0], tmp[2], tmp[3], tmp[1]))
del result
results.append(tmp2)
gc.collect()
# Get face detection results
dets = get_result(results)
osd_img.clear()
if dets:
for det in dets:
w = (x2 - x1) * DISPLAY_WIDTH // OUT_RGB888P_WIDTH
h = (y2 - y1) * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH
# Draw face box
osd_img.draw_rectangle(x1 * DISPLAY_WIDTH // OUT_RGB888P_WIDTH, y1 * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH, w, h, color=(255, 255, 0, 255))
Display.show_image(osd_img, 0, 0, Display.LAYER_OSD3)
rgb888p_img = None
print(f"An error occurred during running: {e}")
finally:
# Stop camera output
sensor.stop()
# Deinitialize display device
# Release media buffer
del kpu # Release kpu resources
del ai2d # Release ai2d resources
gc.collect()
time.sleep(1)
print("face_detect_test end")
return 0
face_detect_test()
4. Running the Example Code#
Open the example program code through K230 CanMV IDE and click the run button to start running the face detection example program. For the usage of the IDE, please refer to the “K230_CanMV_IDE User Manual”. For image burning and development environment setup, please refer to the “K230_CanMV User Manual”.
Open the example program and run it through the IDE as shown in the figure below:
The running result is shown in the figure below:
