3.9 RTSP Module API Manual#
1. Overview#
This document aims to provide a detailed introduction to the usage and functions of the K230_CanMV RTSP module API. The RTSP module is specifically designed for creating and managing RTSP servers, supporting the transmission and reception of video and audio data.
2. API Introduction#
The multimedia module provides the following RTSP interfaces:
multimedia.rtspserver_create: Create an RTSP server.multimedia.rtspserver_destroy: Destroy an RTSP server.multimedia.rtspserver_init: Initialize an RTSP server.multimedia.rtspserver_deinit: Deinitialize an RTSP server.multimedia.rtspserver_createsession: Create an RTSP session.multimedia.rtspserver_destroysession: Destroy an RTSP session.multimedia.rtspserver_getrtspurl: Get the RTSP URL.multimedia.rtspserver_start: Start the RTSP server.multimedia.rtspserver_stop: Stop the RTSP server.multimedia.rtspserver_sendvideodata: Send video data to the RTSP server.multimedia.rtspserver_sendaudiodata: Send audio data to the RTSP server.
These interfaces can be used to create and manage RTSP servers, create and destroy RTSP sessions, send video and audio data to the server, and obtain the RTSP URL for streaming.
2.1 multimedia.rtspserver_create#
Description Used to create an RTSP server.
Syntax
rtspserver_create()
Return Value |
Creation successful |
Non-0 |
Creation failed |
2.2 multimedia.rtspserver_destroy#
Description Used to destroy an RTSP server.
Syntax
rtspserver_destroy()
Return Value |
Destruction successful |
Non-0 |
Destruction failed |
2.3 multimedia.rtspserver_init#
Description Initialize an RTSP server.
Syntax
rtspserver_init(port)
Parameter Name |
Input / Output |
port |
RTSP server listening port |
Input |
Return Value None
Example
rtspserver_init(8554)
2.4 multimedia.rtspserver_deinit#
Description Deinitialize an RTSP server.
Syntax
rtspserver_deinit()
Return Value None
Example
rtspserver_deinit()
2.5 multimedia.rtspserver_createsession#
Description Create an RTSP session.
Syntax
rtspserver_createsession(session_name, video_type, enable_audio)
Parameter Name |
Input / Output |
session_name |
Session name |
Input |
video_type |
Video encoding type |
Input |
enable_audio |
Whether to enable audio |
Input |
Return Value None
Example
rtspserver_createsession("session1", "h264", True)
2.6 multimedia.rtspserver_destroysession#
Description Destroy an RTSP session.
Syntax
rtspserver_destroysession(session_name)
session_name: Session name.
Return Value None
Example
rtspserver_destroysession("session1")
2.7 multimedia.rtspserver_getrtspurl#
Description Get the RTSP URL.
Syntax
rtspserver_getrtspurl()
Parameter Name |
Input / Output |
url |
RTSP URL |
Output |
Example
url = rtspserver_getrtspurl()
print(url)
2.8 multimedia.rtspserver_start#
Description Start the RTSP server.
Syntax
rtspserver_start()
Return Value None
Example
rtspserver_start()
2.9 multimedia.rtspserver_stop#
Description Stop the RTSP server.
Syntax
rtspserver_stop()
Return Value None
Example
rtspserver_stop()
2.10 multimedia.rtspserver_sendvideodata#
Description Send video data to the RTSP server.
Syntax
rtspserver_sendvideodata(session_name, data, size, timestamp)
Parameter Name |
Input / Output |
session_name |
Session name |
Input |
data |
Video data |
Input |
size |
Data size |
Input |
timestamp |
Timestamp |
Input |
Return Value None
Example
rtspserver_sendvideodata("session1", video_data, video_size, video_timestamp)
2.11 multimedia.rtspserver_sendaudiodata#
Description Send audio data to the RTSP server.
Syntax
rtspserver_sendaudiodata(session_name, data, size, timestamp)
Parameter Name |
Input / Output |
session_name |
Session name |
Input |
data |
Audio data |
Input |
size |
Data size |
Input |
timestamp |
Timestamp |
Input |
Return Value None
Example
rtspserver_sendaudiodata("session1", audio_data, audio_size, audio_timestamp)
3. Example Program#
# Example: Demonstrates how to send video and audio data to network streaming via RTSP server.
# Note: Running this example requires an SD card.
# You can start the RTSP server for video and audio streaming.
from media.vencoder import *
from media.sensor import *
import time, os
import _thread
import multimedia as mm
from time import *
class RtspServer:
def __init__(self, session_name="test", port=8554, video_type=mm.multi_media_type.media_h264, enable_audio=False):
self.session_name = session_name # Session name
self.video_type = video_type # Video encoding type (H264/H265)
self.enable_audio = enable_audio # Whether to enable audio
self.port = port # RTSP server port number
self.rtspserver = mm.rtsp_server() # Instantiate RTSP server
self.venc_chn = VENC_CHN_ID_0 # Video encoding channel
self.start_stream = False # Whether to start streaming thread
self.runthread_over = False # Whether streaming thread has ended
def start(self):
# Initialize streaming
self._init_stream()
self.rtspserver.rtspserver_init(self.port)
# Create session
self.rtspserver.rtspserver_createsession(self.session_name, self.video_type, self.enable_audio)
# Start RTSP server
self.rtspserver.rtspserver_start()
self._start_stream()
# Start streaming thread
self.start_stream = True
_thread.start_new_thread(self._do_rtsp_stream, ())
def stop(self):
if not self.start_stream:
return
# Wait for streaming thread to exit
while not self.runthread_over:
sleep(0.1)
# Stop streaming
self._stop_stream()
self.rtspserver.rtspserver_stop()
self.rtspserver.rtspserver_deinit()
def get_rtsp_url(self):
return self.rtspserver.rtspserver_getrtspurl(self.session_name)
def _init_stream(self):
width = 1280
height = 720
width = ALIGN_UP(width, 16)
# Initialize sensor
self.sensor = Sensor()
self.sensor.reset()
self.sensor.set_framesize(width=width, height=height, alignment=12)
self.sensor.set_pixformat(Sensor.YUV420SP)
# Instantiate video encoder
self.encoder = Encoder()
self.encoder.SetOutBufs(self.venc_chn, 8, width, height)
# Bind camera and venc
self.link = MediaManager.link(self.sensor.bind_info()['src'], (VIDEO_ENCODE_MOD_ID, VENC_DEV_ID, self.venc_chn))
# Initialize media manager
# Create encoder
chnAttr = ChnAttrStr(self.encoder.PAYLOAD_TYPE_H264, self.encoder.H264_PROFILE_MAIN, width, height)
self.encoder.Create(self.venc_chn, chnAttr)
def _start_stream(self):
# Start encoding
self.encoder.Start(self.venc_chn)
# Start camera
self.sensor.run()
def _stop_stream(self):
# Stop camera
self.sensor.stop()
# Unbind camera and venc
del self.link
# Stop encoding
self.encoder.Stop(self.venc_chn)
self.encoder.Destroy(self.venc_chn)
# Clean buffer
def _do_rtsp_stream(self):
streamData = StreamData()
while self.start_stream:
# Get a frame of stream
self.encoder.GetStream(self.venc_chn, streamData)
# Streaming
stream_data = bytes(uctypes.bytearray_at(streamData.data[pack_idx], streamData.data_size[pack_idx]))
self.rtspserver.rtspserver_sendvideodata(self.session_name, stream_data, streamData.data_size[pack_idx], 1000)
#print("stream size: ", streamData.data_size[pack_idx], "stream type: ", streamData.stream_type[pack_idx])
# Release a frame of stream
self.encoder.ReleaseStream(self.venc_chn, streamData)
print(f"Exception {e}")
finally:
self.runthread_over = True
# Stop rtsp server
self.stop()
# Create rtsp server object
rtspserver = RtspServer()
# Start rtsp server
rtspserver.start()
# Print rtsp url
print("rtsp server start:", rtspserver.get_rtsp_url())
# Stream for 60s
sleep(60)
# Stop rtsp server
rtspserver.stop()
print("done")
