2.5 FFT Module API Manual#
1. Overview#
The FFT (Fast Fourier Transform) module is used to perform a Fourier transform on input time-domain data, converting it into frequency-domain data and returning the corresponding frequency magnitudes. Through FFT operations, time-domain signals can be effectively transformed into frequency-domain signals, facilitating the analysis of the signal’s frequency components.
2. API Introduction#
The FFT module provides an FFT class, supporting three main functions: run(), freq(), and amplitude(), which are used for performing Fast Fourier Transform, frequency calculation, and amplitude calculation, respectively.
2.1 Class machine.FFT#
This class is used to create an FFT object and perform the Fourier transform on the input data.
Syntax
from machine import FFT
import array
# Define time-domain data
data = array.array('i', [1, 2, 3, 4, 5, 6, 7, 8])
# Create an FFT object, perform a 64-point FFT operation, with an offset of 0
fft1 = FFT(data, 64, 0)
Parameter Name
Type
Input/Output
Input time-domain data, of type bytearray.
Input
points
Number of points for the FFT operation, supports 64, 128, 256, 512, 1024, 2048, and 4096 points.
Input
shift
Data offset, default is 0.
Input
Return Values
Operation successful.
Non-zero
Operation failed.
2.1.1 run() Method#
This function is used to obtain the frequency-domain data after the Fourier transform.
Syntax
res = fft1.run()
Return Values
res
Returns a list containing the frequency-domain data, which includes points tuples, each containing 2 elements: the real part and the imaginary part.
2.1.2 freq() Method#
This function is used to obtain the calculated frequency values.
Syntax
res = FFT.freq(points, sample_rate)
Parameter Name
Input/Output
points
Number of points involved in the FFT operation.
Input
sample_rate
Data sampling rate.
Input
Return Values
res
Returns a list containing the frequency values for each frequency point.
2.1.3 amplitude() Method#
This function is used to calculate the amplitude of each frequency point. It is mainly used for testing purposes, and users can write more complex amplitude processing functions in Python.
Syntax
amp = FFT.amplitude(FFT_res)
Parameter Name
Input/Output
FFT_res
The FFT calculation result returned by the run() function.
Input
Return Values
amp
Returns a list containing the amplitude of each frequency point.
