LED Module API Manual#
The development board includes an RGB LED, which users can control the brightness of each color through the API.
API Introduction#
The LED class is located under the machine module.
Example#
from machine import LED
# Instantiate LED objects
red_led = LED("LED_RED") # Or red_led = LED(1)
green_led = LED("LED_GREEN") # Or green_led = LED(2)
blue_led = LED("LED_BLUE") # Or blue_led = LED(3)
# Turn off all LEDs
blue_led.off()
green_led.off()
red_led.off()
# Set the brightness of the green LED
green_led.value(50) # Brightness range is 0-255
red_led.on() # Turn on the red LED
time.sleep_ms(250)
green_led.value(200) # Set the brightness of the green LED
red_led.off() # Turn off the red LED
time.sleep_ms(250)
Constructor#
led = LED(id)
id: Identifier of the LED, 1 or “LED_RED” for the red LED; 2 or “LED_GREEN” for the green LED; 3 or “LED_BLUE” for the blue LED.
value Method#
led.value(val)
Controls the brightness of the LED.
val: Brightness level, ranging from 0 to 255.
on Method#
led.on()
Turns on the LED at maximum brightness.
off Method#
led.off()
Turns off the LED.
