2.16 TOUCH Module API Manual#
1. Overview#
The touch module is based on RTT’s touch framework and supports single-point and multi-point capacitive touch screens as well as resistive touch screens.
2. API Introduction#
The TOUCH class is located under the machine module.
Example
from machine import TOUCH
# Instantiate TOUCH device 0
tp = TOUCH(0)
# Get TOUCH data
p = tp.read()
print(p)
# Print touch point coordinates
# print(p[0].x)
# print(p[0].y)
# print(p[0].event)
Constructor#
# when index is 0
touch = TOUCH(index, type = TOUCH.TYPE_CST328, rotate = -1)
# when index is 1
touch = TOUCH(index, type = TOUCH.TYPE_CST328, rotate = -1, range_x = -1, range_y = -1, i2c : I2C = None, slave_addr = None, rst : Pin = None, int : Pin = None)
index: TOUCH device number. When0, it indicates the use of the system’s built-in touch. When1, it indicates the use of the CanMV-specific touch driver.type: The touch driver type, refer to Touch Types for specific definitions.rotate: The rotation of the panel output coordinates relative to the screen coordinates, range [0-3]. Refer to Coordinate Rotation for specific definitions.range_x: Valid whenindex=1. The maximum width of the touch output coordinates.range_y: Valid whenindex=1. The maximum height of the touch output coordinates.i2c: Valid whenindex=1. The I2C bus object used for touch.slave_addr: Valid whenindex=1. The touch device i2c slave address, if not set, use driver default.rst: Valid whenindex=1. The reset pin object for the touch device.int: Valid whenindex=1. The interrupt pin object for the touch device,currently not supported.
read Method#
TOUCH.read([count])
Get touch data.
count: Maximum number of touch points to read, range [0:10], default is 0, which means to read all touch points.
Returns touch point data, type is a tuple ([tp[, tp...]]), where each tp is an instance of the touch_info class.
deinit Method#
TOUCH.deinit()
Release TOUCH resources.
3. TOUCH_INFO Class#
The TOUCH_INFO class is used to store information about touch points, which users can access through related read-only properties.
event: Event code, see Touch Events for details.track_id: Touch point ID, used for multi-point touch.width: Touch point width.x: x-coordinate of the touch point.y: y-coordinate of the touch point.timestamp: Touch point timestamp.
4. Constants#
4.1 Touch Events#
EVENT_NONE: No event.EVENT_UP: Touch released after pressing.EVENT_DOWN: Touch started when pressed.EVENT_MOVE: Touch moved after pressing.
4.2 Coordinate Rotation#
ROTATE_0: No rotation.ROTATE_90: Rotate coordinates 90 degrees.ROTATE_180: Rotate coordinates 180 degrees.ROTATE_270: Rotate coordinates 270 degrees.
4.3 Touch device Type#
TYPE_CST328:CanMVDrive TouchTYPE_CST226SE:CanMVDrive TouchTYPE_GT911:CanMVDrive Touch
