K230 SHA256 API Reference#
Function Introduction#
SHA256 is mainly used to calculate the hash value of data. The SHA256 algorithm is implemented in the rt-smart of the main core to calculate the hash value of data. The code logic is shown in the following figure:
sha256
API Reference#
The SHA256 module mainly provides the following API:
kd_mpi_cipher_sha256#
Description:
Calculates the hash value of the message based on the input message.
Syntax:
Parameters:
Parameter Name
Input/Output
Input message
Input
len
Length of the input message
Input
hash
Calculated hash value
Output
Return Value:
Success
Non-zero
Failure, refer to error code definitions
Chip Differences:
Requirements:
  • Header file: mpi_cipher_api.h
  • Library file: libcipher.a
Notes:
Related Topics:
Debugging and Print Information#
Write a user-mode application sample_cipher.c to test the SHA256 functionality.
The test code is already written and located in the mpp/userapps/sample/sample_cipher directory. The specific debugging method is as follows:
  1. After the main core starts, enter the bin directory;
  2. Run the sample_cipher.elf program;
  3. Print information.
The specific print information is as follows:
msh />cd bin/
msh /bin>./sample_cipher.elf
input = ''
result: PASS
input = 'abc'
result: PASS
result: PASS
result: PASS
result: PASS
result: PASS
