K230 Debian Ubuntu Instructions#
This document mainly introduces the download and creation methods of Debian and Ubuntu images for the K230 canmv board.
Target Audience#
  • Technical Support Engineers
Abbreviation Definitions#
Abbreviation
gcc
GNU Compiler Collection
dhcp
Dynamic Host Configuration Protocol
Document Version
Modification Description
Modifier
Date
Initial version
SDK Dept
2023-12-28
Image Description#
Please download the images from the Kendryte Developer Community. You can find Debian and Ubuntu related files under k230/images on the Kendryte Developer Community website.
1.1) Files like xxxx_debian_sdcard_x.x.img.gz are compressed Debian images for the K230:
Using the trixie/sid (Debian 13) version, you will see “Welcome to Debian GNU/Linux trixie/sid!” printed during startup.
1.2) Files like xxxx_ubuntu_sdcard_x.x.img.gz are compressed Ubuntu images for the K230:
Using the Ubuntu 23.10 version, you will see “Welcome to Ubuntu 23.10!” printed during startup.
1.3) debian13.ext4.tar.gz is the K230 Debian root filesystem.
1.4) ubuntu23_rootfs.ext4.gz is the K230 Ubuntu root filesystem.
Note 1: The prefix indicates the board name, such as canmv/k230_evb, etc.
Note 2: You need to decompress the file before burning it.
Note 3: If the network port is unstable and cannot be found, restart the board.
Creating and Verifying the K230 Debian Root Filesystem#
Environment#
I created the Debian root filesystem under the Ubuntu 21.04 system (other systems should also work). Root privileges are required during creation.
 No LSB modules are available.
 Distributor ID: Ubuntu
 Description:    Ubuntu 21.04
 Release:        21.04
 Codename:       hirsute
Creating the Debian Root Filesystem#
Refer to the following commands to build the Debian root filesystem:
sudo rm -rf debian13
sudo apt-get update
sudo chroot debian13/
echo "root:root" | chpasswd
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
EOF
ntpdate ntp.ntsc.ac.cn
exit
# debian13.ext4.tar.gz is the compressed package of the Debian ext4 format root filesystem
Creating the Image#
  1. Download the K230 SDK and compile it. Note: For SDK compilation-related issues, please refer to this guide.
# The target file generated after compilation is output/k230_canmv_only_linux_defconfig/images/sysimage-sdcard.img
  1. Decompress debian13.ext4.tar.gz to the output/k230_canmv_only_linux_defconfig/images/ directory.
  1. Modify the K230 SDK code as follows:
# Add the following content to board/common/gen_image_cfg/genimage-sdcard.cfg:
partition debian {
        image = "debian13.ext4"
# Modify bootcmd in board/common/env/default.env to the following:
  1. After modification, execute the following command:
make build-image
  1. Burn it to the TF card and restart the device.
Burn the output/k230_canmv_only_linux_defconfig/images/sysimage-sdcard.img file to the TF card, insert the TF card into the device, and restart the device. For the burning method, please refer to this guide.
Note: If the network port is unstable and cannot be found, please restart the device and try again.
GCC Verification#
Note: If the network port is unstable and cannot be found, please restart and try again.
Main commands:
dhclient
date -s 20231027
apt-get update
apt-get install gcc
apt-get install ssh
apt-get install parted; parted /dev/mmcblk1 print; parted /dev/mmcblk1 resizepart 3 16G; resize2fs /dev/mmcblk1p3
gcc a.c
./a.out
Creating and Verifying the K230 Ubuntu 23 System#
Environment#
Creating the K230 Ubuntu 23 requires an Ubuntu 23 operating system. I used the following Dockerfile to build the Ubuntu system.
Build command: docker build -t ubuntu23:v1 . -f Dockerfile23
# Build the Ubuntu 23.04 container:
# docker build -t ubuntu23:v1 . -f ~/tools/docker/Dockerfile23
# docker run --privileged -u root -it -v $(pwd):$(pwd) -w $(pwd) ubuntu23:v1 /bin/bash
FROM ubuntu:23.04
# Config for default software install
# Install 32-bit lib for toolchain
# Config Ubuntu apt repo to Tsinghua
# Install software
RUN apt-get update
# Set default timezone
ENV TZ=Asia/Shanghai
Creating the K230 Ubuntu Root Filesystem#
Use the following script to create the K230 Ubuntu 23 root filesystem.
rm -rf ubuntu23_rootfs
EOF
echo k230>/etc/hostname
exit
Creating and Verifying the Image#
  1. Decompress ubuntu23_rootfs.ext4.tar.gz to the output/k230_evb_only_linux_defconfig/images/ directory.
partition debian {
  1. After modification, execute:
make build-image
GCC Verification#
Main commands:
dhcpcd
date -s "20240507 15:06"
apt-get update
apt-get install gcc
apt-get install ssh
gcc a.c
./a.out
Adding Qt and LXQt Support#
Installing Qt, LXQt#
Refer to [Creating the Debian Root Filesystem](#22 Creating the Debian Root Filesystem) or [Creating the K230 Ubuntu Root Filesystem](#32 Creating the K230 Ubuntu Root Filesystem) steps.
chroot /path/to/rootfs
apt-get install libdrm-dev
apt-get install lxqt
systemctl disable sddm
Running Qt Example#
Create a new QPA output configuration file and copy the following content to kms_config.json:
  "device": "/dev/dri/card0",
  "outputs": [
Create a new QPA environment variable file and copy the following content to env.sh:
export QT_QPA_FB_DRM=1
Run the Qt example with the following command:
source env.sh
4.3 Running LXQt
Currently, LXQt can only be displayed on a PC or other platforms via X11 Forwarding. Connect to the board using ssh -X, and then execute startlxqt.
References#
