K230 debian ubuntu Notes#
Directory#
preface#
This document mainly introduces the K230 canmv board debian and ubuntu image download and generation methods.
Reader object#
  • Technical Support Engineer
Definition of acronyms#
Abbreviation
Illustrate
gcc
GNU Compiler Collection
dhcp
Dynamic Host Configuration Protocol
Revision history#
Document version number
Modify the description
Author
date
Initial
System Software Department
2023-11-8
download note#
debian and ubuntu related files can be found on the canaan developer community website under k230/images
1.1). similar xxx_debian_sdcard_sdk_x.x.img.gz is k230 debian compressed image;
​ debian version is trixie/sid (debian13),You can see “Welcome to Debian GNU/Linux trixie/sid!” print at startup .
1.2) similar xxx_ubuntu_sdcard_x.x.img.gz is k230 ubuntu compressed mirror image;
​​ debian version is Ubuntu 23.10(mantic),You can see “Welcome to Ubuntu 23.10! “print at startup.
1.3) debian13.ext4.tar.gz is k230 debian rootfs;
1.4). ubuntu23_rootfs.ext4.gz is k230 ubuntu rootfs.
note1:The first string is the board name, such as canmv/k230_evb etc.
note2:image need uncompress.
note3: The network port is unstable. If the network port cannot be found, reset the board.
k230 debian Rootfs build and verification#
environment#
I build the debian rootfs file system in ubuntu21.04 (other systems should be able to do it too), and it need root permission.
 No LSB modules are available.
 Distributor ID: Ubuntu
 Description:    Ubuntu 21.04
 Release:        21.04
 Codename:       hirsute
debian rootfs build#
please referring to the following command to build the debian rootfs.
sudo rm -rf debian13
sudo apt-get update
sudo chroot debian13/
echo "root:root" | chpasswd
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
EOF
ntpdate ntp.ntsc.ac.cn
exit
2.3image build#
1).download and compile k230 sdk
Compile related issues please reference
#target file is "output/k230_canmv_only_linux_defconfig/images/sysimage-sdcard.img"
2). Decompress debian13.ext4.tar.gz to output/k230_canmv_only_linux_defconfig/images/
3).k230_sdk code modify:
#board/common/gen_image_cfg/genimage-sdcard.cfg add:
 partition debian {
        image = "debian13.ext4"
#board/common/env/default.env bootcmd modify to
4).build sdk image
make build-image
5).burn image and boot system
burn “output/k230_canmv_only_linux_defconfig/images/sysimage-sdcard.img” file to tf card,Insert the tf card into the device and restart the device。
note1:Burning method can reference.
note2: The network port is unstable. If the network port cannot be found, reset the board.
1.3gcc test#
dhclient
date -s 20231027
apt-get update
apt-get install gcc
apt-get install ssh
gcc a.c
./a.out
note: The network port is unstable. If the network port cannot be found, reset the board.
k230 ubuntu23 rootfs build#
environment#
build k230 ubuntu23 need ubuntu23 systerm, i use follow command to build ubuntu23 systerm:
3.1.1)save follow content to Dockerfile23:
#构建ubuntu23.04容器;
FROM ubuntu:23.04
# install software
RUN apt-get update
# set default timezone
ENV TZ=Asia/Shanghai
3.1.1)build ubuntu23 systerm
docker build -t ubuntu23:v1 . -f  Dockerfile23
k230 ubuntu rootfs build#
please referring to the following command to build the k230 ubuntu23 rootfs
rm -rf ubuntu23_rootfs
EOF
echo k230>/etc/hostname
exit
image build#
1).下载k230 sdk并进行编译:
2). Decompress ubuntu23_rootfs.ext4.gz to output/k230_canmv_only_linux_defconfig/images/
 partition debian {
#board/common/env/default.env bootcmd modify to:
4).build sdk image
make build-image
gcc test#
dhcpcd
apt-get update
apt-get install gcc
apt-get install ssh
gcc a.c
./a.out
4.add Qt and lxqt#
install Qt, lxqt#
reference debian rootfs build or ubuntu根文件系统制作
chroot /path/to/rootfs
apt-get install libdrm-dev
apt-get install lxqt
systemctl disable sddm
run Qt example#
Create a new QPA output configuration file and copy the following to kms_config.json
  "device": "/dev/dri/card0",
  "outputs": [
Create a new QPA environment variables file and copy the following toenv.sh
export QT_QPA_FB_DRM=1
run Qt example
source env.sh
run lxqt#
Currently lxqt can only be displayed on a pc or other platform via X11Forwarding, connected to the board via ssh-X, and then executed startlxqt
reference material#
carlosedp/riscv-bringup
