K230 Product Brief#
Document version: V1.0 Release date: 2023-6-10
The products, services or features you purchase shall be subject to the commercial contracts and terms of Canaan Creative CO., LTD. (the “Company”) and its affiliates, and all or part of the products, services or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any express or implied representations or warranties as to the correctness, reliability, completeness, merchantability, fitness for a particular purpose and non-aggression of any statements, information, or content in this document.Unless otherwise agreed, this document is intended as a guide for use only.
Trademark Notice#
logo “Canaan” and other Canaan trademarks are trademarks of Canaan Creative CO., LTD. and its affiliates. All other trademarks or registered trademarks that may be mentioned in this document are owned by their respective owners.
Copyright©2023 Canaan Creative CO., LTD. This document is only suitable for the development and design of K230 platform, without the written permission of the company, any unit or individual shall not disseminate part or all of the content of this document in any form.
Canaan Creative CO., LTD. Website:canaan-creative.com Business Email:salesAI@canaan-creative.com
Purpose#
This document is intended to provide a general overview of the K230 platform and its features.
Intended Audience#
The main people to whom this document (this guide) applies:
  • Design and maintenance personnel for electronic products
  • Sales personnel for electronic products
  • Technical support personnel
Terms#
Revision history#
Version Number
Author
Revision Date
Revision Notes
Zhenming Huang
2023-6-10
Re-format to markdown document based on K230 Brief Datasheet_Complete_Apr_2023_v1
General Specifications#
CPU#
  • CPU 1: 64bit, RISC-V processor, 1.6GHz, supports RISC-V Vector Extension 1.0 specification, with floating-point units (FPUs), 128bits vector-process-unit, runs RTOS system
  • CPU 0: 64bit, RISC-V processor, 800MHz, supports RISC-V 64GCB instruction set, runs LINUX system
KPU#
  • Support INT8 and INT16
    • Resnet 50 ≥ 85fps @INT8
    • Mobilenet_v2 ≥ 670fps @INT8
    • YoloV5S ≥ 38fps @INT8
  • Support TVM / TensorFlow / Pytorch / ONNX
  • Support quantitative tool chain and profiling tools
2D Engine#
  • 2D(GDMA) Engine:
    • OSD/CSC/X-Mirror/Y-Mirror/Rotation(90/180/270)
  • Independent AI 2D Engine:
DPU (Depth Computing Unit)#
  • Support multiple operators, including Img_check / LCN / SAD / Post_proc / Align / Disptodepth
Memory#
  • DRAM: DDR3L / LPDDR4 with 16/32bit, LPDDR3 with 32bit
  • DRAM frequency:
    • DDR3L@1600Mbps / LPDDR3@2133Mbps
    • LPDDR4@2667Mbps
  • Maximum capacity: 2GB
  • SIP mode: 128MB 16bit LPDDR4@3200Mbps
  • SRAM:2MB+2MB (default for KPU)
Video Input#
  • 3 x MIPI CSI
  • (1 x 4lane+1 x 2lane) or 3 x 2lane
ISP#
  • Total throughput:8MP@30fps
  • Image 3A / 2DNR / 3DNR / WDR / HDR
  • Local Tone Mapping
  • Sharpen / BLS / LSC / De-warping
  • RGB-IR 4x4 pattern
Video Output#
  • Resolution: 2MP@60fps
Video Codec#
  • Video encoding
    • H.264 Baseline / Main Profile / High Profile
    • H.265 Main Profile
    • JPEG / MJPEG
    • Maximum encoding performance:
      • 8MP@20fps
  • Video decoding
    • H.264 Baseline, Main Profile, High Profile
    • JPEG / MJPEG
    • Maximum decoding performance:
      • 8MP@40fps
2.5D GPU#
  • Highly optimized Tessellation Engine, cooperates with the VGlite driver to provide vector graphics drawing functions
  • Support rotation, scaling, translation, and format conversion of the input image
  • The drawn picture can perform operations such as blending, compression, etc., with the picture in video memory
Audio#
  • 2 x DAC: 8-192Khz
  • 2 x ADC: 8-192Khz
  • Support ALC
  • Maximum 8 x PDM DMIC inputs
Peripherals#
  • Low-speed interface
    • 5 x UART / 5 x I2C / 6 x PWM
      • 64 x GPIO + 8 x PMU GPIO
  • High-speed interface
    • 2 x USB 2.0 OTG
    • 2 x SDxC: SD3.01, eMMC 5.0
    • 3 x SPI: 1 x OSPI + 2 x QSPI
  • WDT / RTC / Timer
Security#
  • PUF / OTP / TRNG
  • Support AES, SHA, RSA, SM2/3/4, ECC
PMU#
  • Ultra-low power consumption: in deep sleep mode, standby power consumption ≤ 20uW
  • Support RTC function in 32KHz
  • Support long and short press detection as system shutdown or wakeup signal
  • Support IO edge and level detection to generate interrupts
  • Support two output IOs to control PMIC and system reset
  • Support 512 bits system log when shutdown
Other Features#
  • Decompression module:
    • decompression bandwidth ≥ 400MB/s, GZIP format
  • 4096-point FFT / IFFT unit
  • Package:BGA, 0.65mm pitch
    • 13 x 13mm
    • 11 x 11mm (SIP 128MB 16bit LPDDR4)
Block Diagram#
Typical Applications#
  • 3D Face Lock Integrated Application Solution
  • Smart Dictionary Pen Application Solution
