K230 FFT API Reference#
Introduction to K230 FFT#
The FFT module of K230 is mainly used for hardware acceleration of FFT and IFFT calculations. Its features are as follows:
  • Supports 64, 128, 256, 512, 1024, 2048, 4096-point FFT and IFFT calculations.
  • Supports int16 calculation precision, i.e., the real and imaginary parts of the input and output are in int16 format.
  • Supports standard AXI4 slave interface, with parameter configuration and data transfer using this interface.
  • The input supports RIRI…., RRRR…. (pure real part), RRRR…IIII… format arrangement, and the output supports RIRI…., RRRR…IIII… format arrangement.
  • Uses radix-2 time decimation calculation method, with only one butterfly operator inside.
  • Uses single clock domain design, with the bus clock also serving as the operation clock to save cross-clock domain overhead.
  • The calculation time for 4096-point FFT/IFFT is controlled within 1ms, including the total overhead of data transfer, calculation, and interrupt interaction.
  • Supports interrupt mask and raw interrupt query.
API Reference#
The K230 FFT module mainly provides the following APIs:
kd_mpi_fft_or_ifft#
Description:
Core function for FFT or IFFT calculation.
Syntax:
Parameters:
Parameter
Input/Output
fft_args
FFT parameters k_fft_args_st
Input/Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
  • Header file: mpi_fft_api.h
  • Library file: libfft.a
Notes:
int kd_mpi_fft(int point, k_fft_input_mode_e im, k_fft_out_mode_e om,
               k_u32 timeout, k_u16 shift,
    int ret = 0;
    k_fft_args_st fft_args;
    ret = kd_mpi_fft_args_init(point, FFT_MODE, im, om, timeout, shift, rx_in, iy_in, &fft_args); ERET(ret);
    ret = kd_mpi_fft_args_2_array(&fft_args, rx_out, iy_out); ERET(ret);
Related Topics:
kd_mpi_fft_args_init#
Description:
Initialization of fft_args (helper function)
Syntax:
int kd_mpi_fft_args_init(int point, k_fft_mode_e mode, k_fft_input_mode_e im,
                         k_fft_out_mode_e om, k_u32 timeout, k_u16 shift,
                         short *real, short *imag, k_fft_args_st *fft_args);
Parameters:
Parameter
Input/Output
point
Number of points, valid values are 64, 128, 256, 512, 1024, 2048, 4096
Input
Input
im
k_fft_input_mode_e Input mode
Input
om
k_fft_out_mode_e Output mode
Input
timeout
Timeout
Input
shift
Offset
Input
rx_input
Input real data
Input
iy_input
Input imaginary data
Input
fft_args
k_fft_args_st Variable to be filled
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
    int ret = 0;
Related Topics:
kd_mpi_fft_args_2_array#
Description:
Convert FFT output to array (helper function, convenient for printing).
Syntax:
Parameters:
Parameter
Input/Output
fft_args
k_fft_args_st Structure
Input
rx_out
Real data
Output
iy_out
Imaginary data
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
int kd_mpi_fft(int point, fft_input_mode_e im, fft_out_mode_e om,
               k_u32 timeout, k_u16 shift, k_u16 dma_ch,
    int ret = 0;
    ret = kd_mpi_fft_args_init(point, FFT_MODE, im, om, timeout, shift, dma_ch, rx_in, iy_in, &fft_args); ERET(ret);
Related Topics:
kd_mpi_fft#
Description:
FFT calculation.
The core functions kd_mpi_fft_args_init, kd_mpi_fft_or_ifft, and kd_mpi_fft_args_2_array are encapsulated together for convenience of use.
Syntax:
Parameters:
Parameter
Input/Output
point_num
Input
im
Input
om
Input
timeout
Timeout
Input
shift
Offset
Input
rx_input
Input real data
Input
iy_input
Input
rx_out
Computed result real data
Output
iy_out
Computed result imaginary data
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
    //soft_fft_ifft_calc(point);
    clock_gettime(CLOCK_MONOTONIC, &begin_time);
    kd_mpi_fft(point, RIRI, RR_II_OUT, 0, 0x555, i_real, i_imag, o_h_real, o_h_imag);
    kd_mpi_ifft(point, RIRI, RR_II_OUT, 0, 0xaaa, o_h_real, o_h_imag, o_h_ifft_real, o_h_ifft_imag);
    display_calc_result(point);
Related Topics:
kd_mpi_ifft#
Description:
IFFT calculation.
Syntax:
int kd_mpi_ifft(int point, k_fft_input_mode_e im, k_fft_out_mode_e om,
Parameters:
Parameter
Input/Output
point_num
Input
im
Input
om
Input
timeout
Timeout
Input
shift
Offset
Input
dma_ch
DMA channel, valid values are 0-3; other values are invalid
Input
rx_input
Input real data
Input
iy_input
Input
rx_out
Output
iy_out
Output
Return Value:
Success
Non-zero
Failure
Chip Differences:
Requirements:
Notes:
Related Topics:
Data Structures#
The data types related to this functional module are defined as follows:
k_fft_args_st#
Description: FFT ioctl parameters
Definition:
typedef union
    struct {
        volatile k_fft_input_mode_e im:2; //5:4 0:RIRI....;1:RRRR.... (pure real part);2:RRRR...IIII..
        volatile k_u16 shift:12; //19:8  [11] Enable right shift for the 12th stage.....[0] Enable right shift for the 1st stage
        volatile k_u32 fft_disable_cg : 1;//20 Clock gating disable signal, write 1 to disable FFT clock gating
        volatile k_u32 time_out:32;//63:32 Indicates the timeout threshold for FFT module calculation after FFT is enabled; writing 0 means that the FFT timeout interrupt function does not exist
    }__attribute__ ((packed));
    volatile k_u64 cfg_value;
    k_fft_cfg_reg_st reg;
    k_char rsv[4];
} k_fft_args_st;
Members:
Member Name
reg
Configuration register value for FFT
Input and output data for FFT
Notes:
k_fft_mode_e#
Definition:
typedef enum  {
    FFT_MODE = 0,
    IFFT_MODE,
} k_fft_mode_e;
Members:
Member Name
FFT_MODE
FFT
IFFT_MODE
IFFT
Notes:
k_fft_input_mode_e#
Definition:
    RIRI = 0,
    RRRR,
    RR_II,
} k_fft_input_mode_e;
Members:
Member Name
RIRI
RIRI format data
RRRR
Pure real part data
RR_II
RR_II format data
Notes:
k_fft_out_mode_e#
Definition:
    RIRI_OUT = 0,
    RR_II_OUT,
} k_fft_out_mode_e;
Members:
Member Name
RIRI_OUT
RIRI format data
RR_II_OUT
RR_II format data
Notes:
